remote ipphone
Answered Question
Sep 16th, 2011
I would like to configure a single IPPhone on Site NORFOLK to use TWICKENHAM SIP no
both sites connected via VPN and can do intersite extension calling without any problem.
please see the diagram (TWICKENHAM router SIP has a spare number, so i would like to use it on NORFOLK phone for outgoing and incoming)
I entered following related commands on NORFOLK router
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
dial-peer cor custom
name sip2800
dial-peer cor list usesip2800
member sip2800
dial-peer voice 2800 voip
corlist outgoing usesip2800
destination-pattern .T
session protocol sipv2
session target ipv4:83.245.6.81  **this the sip provider ip/sip registrar server ip. This ip is used in other side of the router to route the cals via sip)
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2801 voip
corlist incoming usesip2800
answer-address 222 **extension on the phone***
ephone-dn  44  dual-line
number 222 secondary 0208123456
label sipcall
description sipcall
name sipcall
ephone 24
button 1:44
mac-address xxx.xxx.xxx
AM i missing anything. is it possible. is there any better ways to accomplish this task
Basically when ephone 24 attached to NORFOLK router placed a outbound call the call should route through the TWICKENHAM router by using its sip no.
shameer
Correct Answer by David Trad about 5 years 5 months ago
Hi Shameer,
This is a typo on my part, the session target should be different on both sides, for instance Site "A" should be pointing to site "B" and site "B" should be pointing to site "A" this is the only way it will work.
Site "A" should have said pointing to "ISR" and site "B" should have said pointing to "UC" my excuse is that I was tired and my brain was mashed up from a bad day at work managing too many problems... Well that is my excuse and I'm sticking to it
Cheers,
David.
Hi Shameer,
You will need to do the following to get this to work, based also on the diagram you sent to me and the information supplied.
Site "B":
dial-peer voice 2031 voip
description ***ISR2800-CALLING-UC500***
preference 1
destination-pattern XXX
dtmf-relay h245-alphanumeric
dial-peer voice 2010 voip
description Incoming Call
incoming called-number .
Site "A":
incoming called-number .%
dial-peer voice 2015 voip
description ***UC500-CALLING-ISR2800***
preference 1
codec g711ulaw
Now this is working on the assumption you have CME installed on the ISR-2800, if not then the only other way is to do it via Manual programming of the phone at site "B"
To do it VIA manual programming you would ensure that there is a VPN tunnel between the two sites, you would need to make sure that each site can route to all the subnets (Vlans I.E VLAN-1 Data, VLAN-100 Voice and VLAN-90 if the UC has a CUE VLAN).
On Site "B" phone, you would program in the TFTP address manually in the phones configuration options, this way it can shoot down the VPN tunnel and speak to the TFTP-SOURCE address of the UC-500.
Once it is done this way, you only need the DN to be created on the UC-500 side and any voice translation rules/profiles setup to have that SIP trunk DID routed to this DN (Extension).
These are the only two options I know of and have done in the past that work, there might be others but I have not done them or am not aware of them.
Cheers,
David.
Overall Rating: 5 (2 ratings)
Correct Answer
David Trad Tue, 09/20/2011 - 14:30
Hi Shameer,
Site "B":
preference 1
Site "A":
preference 1
codec g711ulaw
Cheers,
David.
Mohamed Shameer... Fri, 09/23/2011 - 04:39
Hi David
Thank you very much for the solution.
I  did implement the solution today and able to dial the extension and see its ringing.
But unfortunately there is no one at the other site to answer the call, also to do outbound calls.
so waiting for response from the customer. I'll update you as soon as i get some reply.
Hope it work
thanks
shameer
Mohamed Shameer... Mon, 09/26/2011 - 05:00
Hi David
just a small question
why we assign same ip address for session target on both SiteA and SiteB dial-peers
THANKS FOR YOUR HELP
SHAMEER
Correct Answer
David Trad Mon, 09/26/2011 - 15:03
Hi Shameer,
Cheers,
David.
