Can't connect to WLAN - trying to setup WLC2100
huwyhuwy123
hi there,
I'm trying to setup a WLC2100 to work with a cisco 3750 and an aironet 1130ag (LW).
The problem I'm having is that I see the wireless network but I can't connect to it. Even if I set a static IP it won't ping anything on that network.
I have attached the config of the 3750 as I think its a vlan issue.
The access point is connected to g1/0/29
The WLC is connected to g1/0/42 (ticketing interface)
Can anyone help with this as I can't figure it out?
Cheers,
Huw
Surendra BG
Let the topology bre like this..
WLC --------- Switch ------------ AP
Connect a single port between the switch and the WLC.. the nthen restrict VLANs if needed on the switch!! here is the 2100 best practise guide..
https://supportforums.cisco.com/docs/DOC-11760
Lemme know how this helps!!
Surendra
Surendra BG
thanks for the response. I managed to get this working following the info here....
http://www.it-book.co.uk/1753/setup-cisco-wireless-controller-and-cisco-aironets
