How to configure etherchannel load-balance policy for one Po1 interface?
Igor Tiunov
Hello, Experts!
How can I set a policy of load-balancing etherchannel for only one interface Po1? This policy be applied to this interface only, and NOT applied to other interfaces.
Device:
C2960G
IOS:
c2960-lanbasek9-mz.122-58.SE2.bin
I don't think you can as load balancing is configured globally not per Portchannel interface.
Regards.
Alain.
Somasundaram Jayaraman
++ Load balance algorithm can be applied only to the port-channel. By default the load-balance algorithm will be source mac & Destination Mac.
++ Whenever a packet is arrived on the port-channel interfaces, the packet will be forwarded on any one of the interfaces based on the source mac & destination mac.
++ You can set the load-distribution method based on the source MAC address by using the
port-channel load-balance src-mac in global configuration mode.
Command
Purpose
Step 1
configure terminal
Enter global configuration mode.
Step 2
port-channel load-balance {dst-ip | dst-mac | src-dst-ip | src-dst-mac | src-ip | src-mac}
Configure an EtherChannel load-balancing method.
The default is src-mac.
Select one of these load-distribution methods:
dst-ip—Load distribution is based on the destination-host IP address.
dst-mac—Load distribution is based on the destination-host MAC address of the incoming packet.
src-dst-ip—Load distribution is based on the source-and-destination host-IP address.
src-dst-mac—Load distribution is based on the source-and-destination host-MAC address.
src-ip—Load distribution is based on the source-host IP address.
src-mac—Load distribution is based on the source-MAC address of the incoming packet.
Step 3
end
Return to privileged EXEC mode.
Step 4
show etherchannel load-balance
Verify your entries.
Step 5
copy running-config startup-config
(Optional) Save your entries in the configuration file.
To return EtherChannel load balancing to the default configuration, use the no port-channel load-balance global configuration command.
useful links:
-http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_53_se/configuration/guide/swethchl.html#wp1276203
-http://www.cisco.com/en/US/tech/tk389/tk213/technologies_tech_note09186a0080094646.shtml
-http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_58_se/release/notes/OL24337.html
Hope this helps.
Cheers
Somu
Rate helpful posts
Thank you for your reply!
This is not what I need.
I have several Po interfaces on the switch. I need to for different Po interfaces worked different policy etherchannel. For Example,
Po1 - dst-mac;
Po2 - src-mac;
Po3 - dst-ip.
Can I set up this configuration?
Regards.
Alain.
Thank you. I understood everything.
