cisco ASA5505 with dual ISP + IPSEC
martin.elias
Hello guys,
I have problem with dual ISP + IPSEC on my cisco ASA5505 sec plus licence.
Routing is working correct (connect to Internet from siteA is working trought
1st also second ISP) but IPSEC is working just trought the first
ISP! It seemt that phase 1 and 2 of IPSEC is correct but packets
are just encrypting but not decrypting. Do you have any idea what is wrong?
I'm trying ping from siteA (PC - 10.4.1.66) to siteB (PC - 10.3.128.50)
config site A:
ASA5505 Version 8.2(1)
interface Vlan1
nameif inside
security-level 100
ip address 10.4.1.65 255.255.255.248
interface Vlan2
nameif outside
security-level 0
ip address 192.168.1.2 255.255.255.0
interface Vlan3
nameif internet
security-level 0
ip address 212.89.235.yy 255.255.255.248
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
switchport access vlan 3
access-list outside_cryptomap extended permit icmp 10.4.1.64 255.255.255.248 10.3.128.0 255.255.255.0
access-list nonat extended permit ip 10.4.1.64 255.255.255.248 10.3.0.0 255.255.0.0
access-list nonat extended permit ip 10.4.1.64 255.255.255.248 10.16.0.0 255.255.0.0
access-list inside extended permit ip any any
access-list inside extended permit icmp any any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu internet 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-621.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
global (internet) 1 interface
nat (inside) 0 access-list nonat
nat (inside) 1 10.4.1.64 255.255.255.248
access-group internet_in in interface outside
access-group internet_in in interface internet
route outside 0.0.0.0 0.0.0.0 192.168.1.1 1 track 1
route internet 0.0.0.0 0.0.0.0 212.89.235.yy 254
snmp-server enable traps snmp authentication linkup linkdown coldstart
sla monitor 123
type echo protocol ipIcmpEcho 212.89.229.xx interface outside
num-packets 3
frequency 10
sla monitor schedule 123 life forever start-time now
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 3600
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map0 1 match address outside_cryptomap
crypto map outside_map0 1 set peer 212.89.229.xx
crypto map outside_map0 1 set transform-set ESP-AES-256-SHA
crypto map outside_map0 1 set security-association lifetime seconds 28800
crypto map outside_map0 1 set security-association lifetime kilobytes 4608000
crypto map outside_map0 2 match address outside_cryptomap_1
crypto map outside_map0 interface outside
crypto map outside_map0 interface internet
crypto isakmp identity hostname
crypto isakmp enable outside
crypto isakmp enable internet
crypto isakmp policy 3
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 300
track 1 rtr 123 reachability
telnet 10.4.1.64 255.255.255.248 inside
telnet timeout 1440
ssh 10.4.1.64 255.255.255.248 inside
ssh 212.89.229.xx 255.255.255.255 outside
ssh timeout 60
ssh version 2
console timeout 0
management-access inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 194.160.23.2 source outside
webvpn
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol IPSec l2tp-ipsec
username xx
tunnel-group 212.89.229.xx type ipsec-l2l
tunnel-group 212.89.229.xx ipsec-attributes
pre-shared-key *
siteA# sh crypto isakmp sa d
   Active SA: 1
    Rekey SA: 0 (A tunnel will report 1 Active and 1 Rekey SA during rekey)
Total IKE SA: 1
1   IKE Peer: 212.89.229.xx
    Type    : L2L             Role    : initiator
    Rekey   : no              State   : MM_ACTIVE
    Encrypt : aes-256         Hash    : SHA
    Auth    : preshared       Lifetime: 300
    Lifetime Remaining: 91
siteA# sh crypto ipsec sa
interface: internet
    Crypto map tag: outside_map0, seq num: 1, local addr: 212.89.235.yy
      access-list outside_cryptomap permit icmp 10.4.1.64 255.255.255.248 10.3.128.0 255.255.255.0
      local ident (addr/mask/prot/port): (10.4.1.64/255.255.255.248/1/0)
      remote ident (addr/mask/prot/port): (10.3.128.0/255.255.255.0/1/0)
      current_peer: 212.89.229.xx
      #pkts encaps: 7, #pkts encrypt: 7, #pkts digest: 7
      #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
      #pkts compressed: 0, #pkts decompressed: 0
      #pkts not compressed: 7, #pkts comp failed: 0, #pkts decomp failed: 0
      #pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
      #PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
      #send errors: 0, #recv errors: 0
      local crypto endpt.: 212.89.235.115, remote crypto endpt.: 212.89.229.2
      path mtu 1500, ipsec overhead 74, media mtu 1500
      current outbound spi: 2A9B550B
    inbound esp sas:
      spi: 0xCF456F65 (3477434213)
         transform: esp-aes-256 esp-sha-hmac no compression
         in use settings ={L2L, Tunnel, }
         slot: 0, conn_id: 32768, crypto-map: outside_map0
         sa timing: remaining key lifetime (kB/sec): (4374000/28629)
         IV size: 16 bytes
         replay detection support: Y
         Anti replay bitmap:
          0x00000000 0x00000001
    outbound esp sas:
      spi: 0x2A9B550B (714822923)
         sa timing: remaining key lifetime (kB/sec): (4373999/28629)
         IV size: 16 bytes
         Anti replay bitmap:
siteA# sh logging asdm | i 10.3.128.50
6|Sep 19 2011 10:27:37|302020: Built outbound ICMP connection for faddr 10.3.128.50/0 gaddr 10.4.1.66/1024 laddr 10.4.1.66/1024
6|Sep 19 2011 10:27:39|302021: Teardown ICMP connection for faddr 10.3.128.50/0 gaddr 10.4.1.66/1024 laddr 10.4.1.66/1024
config site B:
ASA 5510 Version 8.0(4)
nameif outside
security-level 0
ip address 212.89.229.xx 255.255.255.240
ospf cost 10
interface Ethernet0/1.10
vlan 10
nameif users
security-level 50
ip address 10.3.128.0 255.255.255.0
access-list siteA extended permit ip 10.3.128.0 255.255.255.0 10.4.1.64 255.255.255.248
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto map outside_map 9 match address SiteA
crypto map outside_map 9 set peer 212.89.229.xx
crypto map outside_map 9 set transform-set ESP-AES-256-SHA
crypto map outside_map 9 set security-association lifetime seconds 28800
crypto map outside_map 9 set security-association lifetime kilobytes 4608000
crypto map outside_map 10 match address SiteA
crypto map outside_map 10 set peer 212.89.235.yy
crypto map outside_map 10 set transform-set ESP-AES-256-SHA
crypto map outside_map 10 set security-association lifetime seconds 28800
crypto map outside_map 10 set security-association lifetime kilobytes 4608000
crypto isakmp policy 20
encryption aes-256
hash sha
group 2
lifetime 86400
pre-shared-key *
tunnel-group 212.89.235.yy type ipsec-l2l
tunnel-group 212.89.235.yy ipsec-attributes
pre-shared-key *
SiteB# sh crypto isakmp sa d
   Active SA: 7
    Rekey SA: 1 (A tunnel will report 1 Active and 1 Rekey SA during rekey)
Total IKE SA: 8
8   IKE Peer: 212.89.235.115
    Lifetime Remaining: 245
SiteB# sh crypto ipsec sa | b 212.89.235.yy
      current_peer: 212.89.235.yy
      #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
      #pkts decaps: 12, #pkts decrypt: 12, #pkts verify: 12
      #pkts not compressed: 0, #pkts comp failed: 0, #pkts decomp failed: 0
      local crypto endpt.: 212.89.229.xx, remote crypto endpt.: 212.89.235.yy
      current outbound spi: CF456F65
    inbound esp sas:
         slot: 0, conn_id: 4378624, crypto-map: outside_map
         sa timing: remaining key lifetime (kB/sec): (3914999/27310)
         IV size: 16 bytes
Anti replay bitmap:
        0x00000000 0x00001FFF
    outbound esp sas:
         sa timing: remaining key lifetime (kB/sec): (3915000/27308)
         IV size: 16 bytes
siteB# sh logging asdm | i 10.4.1.66
6|Sep 19 2011 10:29:49|302021: Teardown ICMP connection for faddr 10.4.1.66/1024 gaddr 10.3.128.50/0 laddr 10.3.128.50/0
6|Sep 19 2011 10:29:50|302020: Built inbound ICMP connection for faddr 10.4.1.66/1024 gaddr 10.3.128.50/0 laddr 10.3.128.50/0
I'm glad that this answer your question, don't hesitate to mark the post as answered and rate useful posts
Have a nice day.
7 Replies 7
Bastien Migette
Hi Martin,
Did you applied crypto map in the interface of siteB ? I don't see any crypto map interface command in your config (whereas it's on siteA's config).
If you didn't applied the crypto map, also check if the output route for the SiteA is thru the interface where the crypto map is applied.
sorry, yes it is also on siteB:
crypto map outside_map interface outside
routing on siteA is working ok and crypto map is applied on bought interfaces
martin.elias
Mistake in topology on picture. I changed IP 212.89.236.xx to IP 212.89.229.xx
and IP 194.228.44 to 192.168.1.2
martin.elias
I found the problem but dont know how to fix it now!
Problem is on siteB with using the same ACL name "siteA" in both sequence numbers in cryptomap "outside_map"
If I remove:
no crypto map outside_map 9 match address SiteA
the IPSEC through 2nd ISP on siteA is working correct
Hello Martin,
The crypto maps are sequential, that means as you have the same ACL on both entry, the traffic will match every time seq #9 and be directed to the peer defined in this sequence. If you want to do active/Standby IPSEC tunnels between your two ISPs, you can use multiple peers, like:
crypto map outside_map 9 set peer 212.89.229.xx 212.89.235.yy
If you want to load balance between your two ISPs, you will need to have different ACLs, like sequence 9 is for traffic directed to remote network 1, and sequence 10 for remote network 2, but in that case, if remote peer is down, half of the traffic will be down.
many thanks, that's what i needed!
Have a nice day.
