09-19-2011 09:22 AM - edited 03-07-2019 02:18 AM
First off let me apologize if this question is annoying or unworthy. I am simply lost. I have no Cisco skills.
That said, I have a Catalyst 2950 switch that a 3rd party managed but I own that is no longer in use that I would like to sell. I am attempting to reset it back to factory defaults using whatever instructions i can find on the web, however when I attempt to connect to the console I get a password prompt. I have no idea what the password is and contacting the (ex)vendor is not an option. Any assistance I receive is very much appreciated.
I wish I new the basics but I don't. Frankly command line interfaces are my enemy so kudos to those who have worked hard to wrap their minds around it.
Solved! Go to Solution.
09-19-2011 09:26 AM
Hi Doug,
Try doing a password recovery on the switch
have a look at this link for step-by-step instructions:
09-19-2011 09:26 AM
Hi Doug,
09-16-2016 07:07 AM
Hello Reza,
After doing the procedure on 2950 Catalyst, the config.text file still remains in the flash memory.
How could I solve this issue?
Directory of flash:/
2 -rwx 109 <date> info
3 -rwx 270 <date> env_vars
4 -rwx 3834 <date> config.old
5 -rwx 5 <date> private-config.text
6 -rwx 1036 <date> vlan.dat
7 -rwx 3097872 <date> c2950-i6q4l2-mz.121-22.EA4.bin
8 drwx 4032 <date> html
362 -rwx 109 <date> info.ver
364 -rwx 3051 <date> config.text
