vlans cannot ping router
Answered Question
Sep 19th, 2011
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008019e74e.shtml
we setup our switch according to the document linked above.  The nodes in the vlans can ping each other.  The switch can ping the router.  However, the nodes cannot ping the router.  I reviewed the TBS steps listed, but the issue still remains.  I think my addressing is correct because i can ping the router by logging on via terminal session and sending a ping with defaults.  However, if I set ping to use a vlan ip, it is unsuccessful.
Is there anything else I can try?
Correct Answer by Jon Marshall about 5 years 9 months ago
Curtis
So clients in one vlan can ping clients in another vlan ?
If so couple of things to check (assuming you are using static routing and not a dynamic routing protocol) -
1) on the L3 switch you need a default-route pointing to the router LAN interface ie.
ip route 0.0.0.0 0.0.0.0
2) on the router you need to add routes for each of your vlans on the L3 switch ie.
ip route 192.168.5.0 255.255.255.0
you need an ip route statement on the router for each of the L3 vlans on the switch.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Mon, 09/19/2011 - 16:01
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Curtis
Jon
csamuels99 Tue, 09/20/2011 - 06:34
Thanks, Jon.  You were right.  I was not using any dynamic routing protocol.  I was able to ping the router after adding the route int he router.  The default route was already setup.
