Warning message
More fun with SPA500S - Buttons all light, then go out.
Sep 20th, 2011
On one install, we have a UC320W with a dozen phones, mostly SPA504's but a few SPA525s too.
We also have 3 SPA500S sidecars on the SPA525s.
Every once in a while, all 32 buttons on a sidecar will light up orange, and remain lit for a period of time (a couple minutes to 10 minutes).
The buttons seem to work from what the client tells us, but they are showing orange.
The phones that correspond to those extensions also appear to be working during this time.
One one phone/sidecar that this is happening on, it is connected to the UC320W wirelessly (and the UC320W is only about 10 ft from the phone).
Anyone seen this issue before?
Firmware is 2.1.1
David Trad Thu, 09/22/2011 - 15:05
  • Gold, 750 points or more
  • Cisco Designated VIP,
    2013 Small Business
Hi John,
It almost sounds like a resync is happening, does the phone itself do a quick refresh during this period?
Cheers,
David.
John Hoyt Fri, 09/23/2011 - 09:36
David...  I'm not sure whether it is refreshing when it happens. The person/s this is happening to have made no mention of anything other than the buttons acting wonky. I will ask them to keep their eyes open!
Thanks!   Have a great weekend!!!
Christopher Edg... Thu, 09/22/2011 - 15:31
  • Silver, 250 points or more
Hi John,
New in the 2.1.1 firmware at the bottom of the Wireless page is the ability to force the UC320W to use a different WiFi channel.  You might try forcing to a channel (APPLY required) to see if that helps (start with 6 or 11 then move to others).  I saw this in our lab but thought it might be due to the 30+ other Access Points in the same area.
Chris
John Hoyt Fri, 09/23/2011 - 09:39
Chris,
Ohhhhh good thinking.... They have a number of very high output Cisco APs there, could be causing adjacent channel interference...
I will see if your suggestion doesn't help and let you know!
Thank you,
John
