ASR 9006 BGP Idle to active
HI, yesterday at night, I try to migrate a JUNIPER to ASR. The BGP configuration is very simple, but the BGP n never UP,  with show bgp nei every time  stay en ACTVE mode.  Attached the configuration and the  show log.  TOday I will be do Labs   between  JUnipero and ASR 9006.
router bgp 20299
address-family ipv4 unicast
  network 186.32.128.0/19
  network 186.32.224.0/20
  network 190.4.31.92/30
  network ...............
  net....etc
neighbor 190.4.31.93
  remote-as 23383
  description BGP - NAVEGA 3xSTM1
   route-policy out-navega out
   remove-private-AS
neighbor 190.4.32.25
  remote-as 23383
  description BGP - NAVEGA 1xSTM1
   remove-private-AS
prefix-set amnet-sps-cable-out-navega
  186.32.128.0/19,
  186.32.224.0/20,
  190.53.48.0/20,
  190.53.192.0/19
  end-set
prefix-set home-sps-out-navega-columbus
  205.211.192.0/22,
  205.211.201.0/24,
  205.211.218.0/23,
  205.211.220.0/23,
  205.211.244.0/22,
  205.211.248.0/21,
  205.211.222.0/23,
  205.211.233.0/24,
  200.12.227.0/24,
  190.53.48.0/20
  end-set
  if destination in amnet-sps-cable-out-navega then
    pass
  endif
  end-policy
route-policy out-navega-1xSTM1
  if destination in home-sps-out-navega-columbus then
    pass
  else
    drop
  endif
  end-policy
sho log
RP/0/RSP1/CPU0:Sep 23 09:47:11.897 : tcp[378]: [t9] Lpts set the drop flag for 445 ->3742, drop packet (pak 0xddc5b6ef) and send a RST
RP/0/RSP1/CPU0:Sep 23 09:47:12.506 : tcp[378]: [t9] Lpts set the drop flag for 445 ->3742, drop packet (pak 0xddc5763f) and send a RST
RP/0/RSP1/CPU0:Sep 23 09:47:13.108 : tcp[378]: [t9] Lpts set the drop flag for 445 ->3742, drop packet (pak 0xddc5e773) and send a RST
RP/0/RSP1/CPU0:Sep 23 09:47:48.562 : tcp[378]: [t14] Queue pak (0xddc5e20f): 190.4.31.93:50004 -> 190.4.31.94:179 len=45 FAILED
RP/0/RSP1/CPU0:Sep 23 09:47:52.609 : tcp[378]: [t13] Queue pak (0xddc5e773): 190.4.32.25:53139 -> 190.4.32.26:179 len=45 FAILED
RP/0/RSP1/CPU0:Sep 23 09:47:57.591 : tcp[378]: [t9] Lpts set the drop flag for 445 ->2029, drop packet (pak 0xddc5de77) and send a RST
RP/0/RSP1/CPU0:Sep 23 09:47:58.146 : tcp[378]: [t9] Lpts set the drop flag for 445 ->2029, drop packet (pak 0xddc5dadf) and send a RST
RP/0/RSP1/CPU0:Sep 23 09:47:58.749 : tcp[378]: [t9] Lpts set the drop flag for 445 ->2029, drop packet (pak 0xddc5d1e3) and send a RST
RP/0/RSP1/CPU0:Sep 23 09:48:16.122 : tcp[378]: [t9] Lpts set the drop flag for 445 ->3422, drop packet (pak 0xddc5b6ef) and send a RST
RP/0/RSP1/CPU0:Sep 23 09:48:16.872 : tcp[378]: [t9] Lpts set the drop flag for 445 ->3422, drop packet (pak 0xddc5e20f) and send a RST
RP/0/RSP1/CPU0:Sep 23 09:48:17.623 : tcp[378]: [t9] Lpts set the drop flag for 445 ->3422, drop packet (pak 0xddc5d1e3) and send a RST
RP/0/RSP1/CPU0:Sep 23 09:48:19.118 : tcp[378]: [t9] Lpts set the drop flag for 445 ->13919, drop packet (pak 0xddc5b6ef) and send a RST
RP/0/RSP1/CPU0:Sep 23 09:48:19.690 : tcp[378]: [t9] Lpts set the drop flag for 445 ->13919, drop packet (pak 0xddc5d1e3) and send a RST
RP/0/RSP1/CPU0:Sep 23 09:48:20.193 : tcp[378]: [t9] Lpts set the drop flag for 445 ->13919, drop packet (pak 0xddc5e773) and send a RST
RP/0/RSP1/CPU0:Sep 23 09:49:57.325 : tcp[378]: [t9] Lpts set the drop flag for 445 ->54772, drop packet (pak 0xddc5d913) and send a RST
RP/0/RSP1/CPU0:Sep 23 09:49:57.995 : tcp[378]: [t9] Lpts set the drop flag for 445 ->54772, drop packet (pak 0xddc5b6ef) and send a RST
RP/0/RSP1/CPU0:Sep 23 09:49:58.648 : tcp[378]: [t9] Lpts set the drop flag for 445 ->54772, drop packet (pak 0xddc5b6ef) and send a RST
RP/0/RSP1/CPU0:Sep 23 09:51:13.572 : tcp[378]: [t12] Queue pak (0xddc5dadf): 190.4.31.93:51562 -> 190.4.31.94:179 len=45 FAILED
RP/0/RSP1/CPU0:Sep 23 09:51:37.532 : tcp[378]: [t18] Queue pak (0xddc5dadf): 190.4.32.25:58976 -> 190.4.32.26:179 len=45 FAILED
RP/0/RSP1/CPU0:Sep 23 09:52:17.590 : tcp[378]: [t16] Queue pak (0xddc5d913): 190.4.31.93:54254 -> 190.4.31.94:179 len=45 FAILED
RP/0/RSP1/CPU0:Sep 23 09:52:41.549 : tcp[378]: [t16] Queue pak (0xddc5e043): 190.4.32.25:50350 -> 190.4.32.26:179 len=45 FAILED
RP/0/RSP1/CPU0:Sep 23 09:53:21.607 : tcp[378]: [t15] Queue pak (0xddc5e043): 190.4.31.93:50893 -> 190.4.31.94:179 len=45 FAILED
RP/0/RSP1/CPU0:Sep 23 09:54:05.567 : tcp[378]: [t15] Queue pak (0xddc5e773): 190.4.32.25:64285 -> 190.4.32.26:179 len=45 FAILED
RP/0/RSP1/CPU0:Sep 23 09:54:25.629 : tcp[378]: [t18] Queue pak (0xddc5763f): 190.4.31.93:51608 -> 190.4.31.94:179 len=45 FAILED
RP/0/RSP1/CPU0:Sep 23 09:55:09.587 : tcp[378]: [t13] Queue pak (0xddc5b6ef): 190.4.32.25:62523 -> 190.4.32.26:179 len=45 FAILED
6 Replies 6
dpothier
hi Luis,
For eBGP you need an inbound and outbound RPL route-policy or by default we will drop everything. This is only for eBGP, not required for iBGP.
http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.1/routing/configuration/guide/routing_cg41asr9k_chapter1.html#con_1750580
example:
route-policy ebgp
pass
end-policy
apply in and out for the eBGP neighbor.
regards,
David Pothier
Cisco Systems
Hi David and thanks i configured  this in the  bgp neigbor configure
  remote-as 23383
   remove-private-AS
in this policy I try to delimit  which network want advertise  to my bgp neighbor. In my firts post   copie the complete config but I don't  if my  route policy is wrong.
dpothier
hi Luis,
You have an outbound route-policy, but your missing an inbound route-policy.
You need to add an inbound route-policy for the eBGP neighbor.
Also - please send the output of  "sho run lpts pifib hardware police flow", I want to verify that you are using the default lpts policer flows.
regards,
David Pothier
Cisco Systems
HI, about the  inboudn policy i will the configure in afew minutes  in a litle labs, and the command doesn't work  check the  output
RP/0/RSP1/CPU0:ASRAmnet#sho run lpts pifib hardware police flow
% Invalid input detected at '^' marker.
RP/0/RSP1/CPU0:ASRAmnet#sho run lpts pifib hardware police?
police
RP/0/RSP1/CPU0:ASRAmnet#sho run lpts pifib hardware police ?
  location  Location Specification RP/0/RSP1/CPU0:ASRAmnet#sho run lpts pifib hardware police flow
police
RP/0/RSP1/CPU0:ASRAmnet#sho run lpts pifib hardware ?
  police  ingress policers configuration command
  tcam    pre-ifib tcam configuration commands
RP/0/RSP1/CPU0:ASRAmnet#sho run lpts pifib hardware tcam ?
  limit  Set upper TCAM size limit
RP/0/RSP1/CPU0:ASRAmnet#sho run lpts pifib hardware police location ?
  0/2/CPU0     Enter Location
  0/RSP0/CPU0  Enter Location
  0/RSP1/CPU0  Enter Location
  WORD         Enter Location
RP/0/RSP1/CPU0:ASRAmnet#sho run lpts pifib hardware police location 0/RSP0/CPU0
RP/0/RSP1/CPU0:ASRAmnet#sho run lpts pifib hardware police location 0/RSP1/CPU0
RP/0/RSP1/CPU0:ASRAmnet#sho run lpts pifib hardware police location 0/2/CPU0
Fri Sep 23 19:58:24.728 UTC
% No such configuration item(s)
RP/0/RSP1/CPU0:ASRAmnet#sho run lpts pifib hardware police location flow
Hi Luis,
Check this command:
RP/0/RSP0/CPU0:A9K-BNG#show lpts pifib hardware police location 0/0/CPU0 | i BGP
that will tell us the police rate for the BGP flows
Also can you show us the configuration for the interface that holds the ip address
190.4.32.26 and 190.4.31.94
The issue is that the BGP packets from the peer don't reach the 9k's bgp process hence it'll toggle between idle/active state.
I have also seen this error when the capabilities from the peer are different then ours like for isntance the remote side wants to initiate the AF for ipv6 or mismatched GR config on either side.
One thing to easily verify is from the peer to do a "telnet 179" and see if the telnet wants to establish, if it does, then everything up to TCP is perfectly fine.
In that case a debug on the bgp neighborship establishment would be helpful:
debug bgp
debug bgp io
debug bgp
debug bgp events
xander
Hi Guys
The last saturday  we found a post about problems with ASR  interconnection  with Juniper M10i and  the solution was the router id configuration. We configured  ROUTER ID and the BGP  pass  the active to establish status immediately and wonrking good.
Thanks alot for all your help.
