SNMP configuration backup
I am doing daily backup on our IOS platforms with command:
snmpset -r 3 -t 30 -v2c -c COMM HOST .1.3.6.1.4.1.9.2.1.55.XXX.XXX.XXX.XXX s HOST-confg
There is no mib for this in IOS XR.
Is there any other solution for automatic config backup ?
Alexei Kiritchenko
Hello Dragoljub,
XR supports  CISCO-CONFIG-COPY-MIB instead to copy config files.
Here is an example. (777 is a random session number)
Create an Entry and Wait
               snmpset -v2c -c COMMUNITY HOST .1.3.6.1.4.1.9.9.96.1.1.1.1.14.777 i 5
Set Copy protocol to tftp
                snmpset -v2c -c COMMUNITY HOST .1.3.6.1.4.1.9.9.96.1.1.1.1.2.777 i 1
Set copy to tftp server
              snmpset -v2c -c COMMUNITY HOST .1.3.6.1.4.1.9.9.96.1.1.1.1.3.777 i 4
Set copy from config
                snmpset -v2c -c COMMUNITY HOST .1.3.6.1.4.1.9.9.96.1.1.1.1.4.777 i 1
Set tftp server address
               snmpset -v2c -c COMMUNITY HOST .1.3.6.1.4.1.9.9.96.1.1.1.1.5.777 a 1.1.1.1
Set destination file name
                snmpset -v2c -c COMMUNITY HOST .1.3.6.1.4.1.9.9.96.1.1.1.1.6.777 s runningTest.txt
Activate the entry
                snmpset -v2c -c COMMUNITY HOST .1.3.6.1.4.1.9.9.96.1.1.1.1.14.777 i 1
Verify the copy was successful
                snmpwalk -v2c -c COMMUNITY HOST ccCopyState
Once successful, destroy the entry
               snmpset -v2c -c COMMUNITY HOST .1.3.6.1.4.1.9.9.96.1.1.1.1.14.777 i 6
/A
Vadim Zhovtanyuk
Hi Dragoljub,
you may use EEM script to run daily operations.
http://www.cisco.com/en/US/docs/routers/crs/software/crs_r4.1/system_monitoring/configuration/guide/sysmon_cg41crs_chapter2.html
Other solutoin may be script running on PC wich will be connecting to XR-based devices and run the commands
BWR
V.
Alexei Kiritchenko
Hello Dragoljub,
Activate the entry
/A
I just want to add that i have problems with "Verify step".
So just use OID ...
snmpwalk -v2c -c COMMUNITY HOST .1.3.6.1.4.1.9.9.96.1.1.1.1.10
