About ASR9010
Sep 26th, 2011
Now, I will upgrade two 6509 devices to ASR9010,but I don,t know some problem
Can I migrate the switching configuration to the ASR9010 ?
ASR9010 with the A9K-40GE-B line card
Can I Create vlan interface in the ASR9010.
Can I type the switching configuration on the ASR9010 ?
for example
vlan xxx
interface g0/0/0/0
switchport
switch mo access
swithc acc vlan xxx
Chenjiannan Mon, 09/26/2011 - 01:18
There are many L2 trunk port on the 6509,
can i mirate below configuration to the A9K?
interface GigabitEthernet6/2
switchport
switchport trunk allowed vlan 2-7,9-12,14-20,22,24-26,31-39,51-149,151-204,206
switchport trunk allowed vlan add 207,209-708,711-717,719-733,737-741,743
switchport trunk allowed vlan add 745-747,750,751,756,758,759,761,763-768
switchport trunk allowed vlan add 770-779,782-784,786,788-791,794,795,901-959
switchport trunk allowed vlan add 961-1019,1021-1102,1104,1105,1108,1109
switchport trunk allowed vlan add 1111-1113,1123,1125-1127,1129,1130,1132
switchport trunk allowed vlan add 1134-1136,1141,1142,1144-1200,2005-2050
switchport trunk allowed vlan add 2052-2060,2066-2070,2104-2110,2117-2119
switchport trunk allowed vlan add 2121-2130,2144-2150,2152-2170,2174-2191
switchport trunk allowed vlan add 2193-3020,3022,3023,3025-3100,3105,3109-3203
switchport trunk allowed vlan add 3205,3206,3209,3210,3212-3900,3902-3999
switchport mode trunk
speed nonegotiate
udld port aggressive
Dragoljub Spasojevic Mon, 09/26/2011 - 01:41
Yes it is possible but configuration will be huge.
I think that ASR maybe is not best solution for your needs.
Dragoljub Spasojevic Mon, 09/26/2011 - 01:04
There is no classical L2 ports on ASR (IOS XR) platform.
You can use next configuration for access ports with etherchannel:
interface BVI1
description servers
ipv4 address xx.xx.xx.xx xx.xx.xx.xx
interface GigabitEthernet0/0/0/2
description server1 #1
bundle id 11 mode active
interface GigabitEthernet0/0/0/3
description server1 #2
interface GigabitEthernet0/0/0/4
description server2 #1
bundle id 12 mode active
interface GigabitEthernet0/0/0/5
description server #2
l2vpn
bridge group servers
  bridge-domain servers
   interface Bundle-Ether11
   interface Bundle-Ether12
   routed interface BVI1
Access port configuration is :
l2vpn
bridge group NAME
  bridge-domain 2
   interface GigabitEthernet0/0/0/5.2
     description bh-mgt
     encapsulation dot1q 2
     rewrite ingress tag pop 1 symmetric
Trunk port configuration is :
l2vpn
bridge group NAME
  bridge-domain 2
     description bh-mgt
Bryan Garland Tue, 09/27/2011 - 11:17
  • Cisco Employee,
So are you saying you need the equivalent of a inteface vlan for all these as well?  Or are you trying to make these just l2 ports through the A9k?
As already mentioned the config example will work.  It will be a lot of config work to get this for all those vlans.  Is it not possible to terminate L3 on this port for those vlans or do you need multiple ports in those vlans, thus needing IRB?
Just becuase you are replacing a 6500 (switch) with an A9k (router) doesn't mean you can't change the over all design to leverage the capabilities of the newer platform.
The below doc describes how IRB adn the EVC model works in XR.
https://supportforums.cisco.com/docs/DOC-15556
Bryan
Related Content
