Reason Code sometimes visible in DB when Ready or Talking
Sep 26th, 2011
System: UCCE 8.0(3)
i have the problem, that in Agent_Real_Time and Agent_State_Trace sometimes there is "the last not ready reason code" carried around through the following states like talking or ready.
If my understanding is correct, reason codes should only be visible on Not Ready and Logout states and always be 0 otherwise?
Also Ready "always" carries around the last Not Ready Reason(only in Agent_State_Trace).
Does somebody know, why that is? The Problem is that the customer has Dashboards in CUIC with this information and it now displays "Meeting" or smth. like this while Talking. Sure i could blend it out whenver not "Not Ready" but that does not really fix the root of the problem, and i would like to understand why that is or if it is just a bug.
Thanks and Regards,
Fabian
FabianSchmidt Tue, 09/27/2011 - 06:10
we checked a possibility where maybe an agent would press NotReady while talking to set the state for after the call but that is not possible to do for the agents, so im still lost on this one.
As soon as i can open a TAC Case i'll do that, but if someone has an idea, i would appreciate it
Fabian
