Configuring Cisco Air 1142N Access point.
Sep 26th, 2011
Hi Guys
I have been struggling to configure a cisco airnet AIR-LAP1142N-E-K9 access point.
this is not my first time as I have configured similar accesspoints before.
the access point gets an IP from the dhcp server. I can ping the access point over the network.
However, when I type in the ip in the web browser, nothing comes up. there is no proxy issue.
the console(hyperterminal, connected through serial cable) shows the following error message:
%CAPWAP-3-ERRORLOG: COULD NOT RESOLVE CISCO-LWAPP-CONTROLLER
Many thanks
Mo
Overall Rating: 5 (2 ratings)
George Stefanick Mon, 09/26/2011 - 14:53
You see the "LAP" in AIR-LAP1142N-E-K9 this means its a LWAPP/CAPWAP access point and you need a WLC to control it. This doesnt me you cant use this as an autonomous access point as you can. HOWEVER, you will need to chnage the code on it ..
Please remember to rate helpful post!
mohibul.hasan Tue, 09/27/2011 - 05:14
thanks!
where do i get the image file from?
can I extract one off my other access point?
thanks for your help
George Stefanick Tue, 09/27/2011 - 07:13
Mohibul,
Do you have a WLC controller? Yes or no ?
You can getthe image from teh cisco software download site. Click on access poins then model and download the latest autonomous code. Then set up TEFT and set your PC to 10.0.0.5. Reset the ap by holding down the mode button for 20 seconds. After which time, the AP will take ip address 10.0.0.1..
Oh, and changee your software name to
c1140-k9w7-tar.default.tar
When you reset the AP 2 things happen. It looks for that file name and it gives itself ip 10.0.0.1
You cool now?
Dont forget to rate helpful post!
mohibul.hasan Tue, 09/27/2011 - 07:51
This is what I am getting:
To Download this software, you must have a valid service contract associated to your Cisco.com user ID.
  • If you do not have a service contract you can get one through:
    • Your Cisco Account Team if you have a direct purchase agreement with Cisco
    • Your Cisco Partner or Reseller
I thought downloading the ios image was free! is there any other way?
mohibul.hasan Thu, 10/27/2011 - 07:19
We only have 3 APs that requires LWAPP controller. Is there any issue with 2106?
thanks
Mo
Leo Laohoo Thu, 10/27/2011 - 14:18
Cisco just announced the end-of-sale of the 2100 on 27 October 2011.  Do you really want to purchase one of those?  I know I wouldn't.
If memory serves me correct, the 2100 can't load firmware above 6.X so which means you'll be using APs that support this firmware like 1130, 1140, 1230, 1240, 1250, old 1000/1100 and old 1200 WAPs.
mohibul.hasan Fri, 10/28/2011 - 04:57
What would be ideal in terms of cost and performance? We only have 3 LWAP. Each will serve upto 30 computers at a time.
Mo
Salil Prabhu Fri, 10/28/2011 - 20:30
2106/12/25 will support 7.0.xx code. It will also support all existing APs including 3500,1140,1040.
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn7_0_116_0.html
I don't think it is EOS atleast does not say on the website :
http://www.cisco.com/en/US/products/ps7206/prod_eol_notices_list.html
Deciding on whether you need a WLC or not is upto your budget and what features you need on your Wireless Infrastructure.. If you have $$ to spend I would recommend going in for 2504. If not you can configure them in standalone and you can always buy a WLC based system in future given you only have 3 APs.
If you need IOS code, you can either approach
1) Your reseller or
2) Cisco SE
3) Call TAC support and ask CIN agent to grant access to CCO code based on what you purchased. Also explain your situation.
Link: http://www.cisco.com/en/US/support/tsd_cisco_worldwide_contacts.html
You can also follow this thread to upgrade :
https://supportforums.cisco.com/message/3477595#3477595
Thanks..salil
mohibul.hasan Mon, 10/31/2011 - 03:40
Hi Salil
Thanks for the most acurate reply. Since I bought 3 x 1142N, would like to get a controller. Just doublechecking with you if 1142N is compatible with 2106?
Will contact the right people to gain access to the download section.
Many thanks guys!
Mo
Salil Prabhu Mon, 10/31/2011 - 07:45
Hi Mo,
Yes 2106 will work !! If your question was answered would you also mark it as "answered" so others can benefit.
Thanks.Salil
Leo Laohoo Fri, 10/28/2011 - 21:02
Me bad.  Salil is correct.  2100 support firmware version 7.0.X code.
Scott Fella Mon, 10/31/2011 - 05:04
The 1142's will work with the 2106 WLC if you decide to go with that model.
mohibul.hasan Thu, 11/03/2011 - 07:41
I bought myself a 2106 controller. it can see the access points fine. How do I go about setting up a WPA2 code for client access? if i try to join the AP now, it comes up wih a user name and password request and i am not sure which user account details i have to use.
thanks
Mo
