CUBE SIP RINGING WITH SDP
patcbr600
Hi all,
Hi have a CUBE with 12.4.24T that as the folowing issue :
When i call to the same number i have two diferent behavior from the SIP provider and from the CUBE.
The first call i have the folowing call flow and the call is OK
Receive INVITE(SDP) from ALU 4400  (G711u)
SEND trying to ALU 4400
Send SIP INVIDE(SDP) to SIP PROVIDER (G711u)
Receive  trying from SIP Provider
Receive  183 with SDP from privider  (G711u)
Send 183 with SDP to ALU 4400   (G711u)
Receive  180 with SDP from privider  (G711u)
The second call i have the folowing call flow and the call reject from the CUBE
Send 183 with SDP to ALU 4400  (G729)
Send a Cancel to the Provider
Send a SIP/2.0 500 Internal Server Error  to the ALU 4400
Is seams that the CUBE is not converting the 180 with SDP to 183 with SDP.
Does any ibne have the same issue ?
patcbr600
Steven Smith
Level 7
Level 7
Is there some transcoding setup here?  Are you doing media flow through?  My guess is that it isn't a problem going from 180 to 183, but a problem with the codecs.
