09-27-2011 06:30 AM - edited 03-11-2019 02:30 PM
Greetings,
I have a NAT set up for a sever in our DMZ.
I need to know how I can redirect port 80 calls coming into the outside NAT address - to port 443 on the DMZ sever.
Thanks.
09-27-2011 06:46 AM
You can use this nat:
static (dmz,outside) tcp 1.1.1.1 80 10.1.1.1 443
where 1.1.1.1 is outside address and 10.1.1.1 is dmz address.
You can refer this doc;
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00804708b4.shtml
Varun
show conn | in X
TCP LanFortis 81.20.15.41:10200 LanOTCEXGROUP PCFIXEREDA:50356, idle 0:00:03, bytes 102593, flags UIO
TCP LanFortis 81.20.15.41:10200 LanOTCEXGROUP PCFIXEREDA:50355, idle 0:00:00, bytes 60645324, flags UIO
TCP LanFortis 81.20.15.41:10200 LanOTCEXGROUP 192.168.77.139:58222, idle 0:00:00, bytes 308313964, flags UIO
TCP LanFortis 81.20.15.41:10200 LanOTCEXGROUP 192.168.77.139:58221, idle 0:00:00, bytes 64501258, flags UIO
TCP LanFortis 81.20.15.42:10200 LanOTCEXGROUP 192.168.77.145:58608, idle 0:00:00, bytes 131679411, flags UIO
TCP LanFortis 81.20.15.42:10200 LanOTCEXGROUP 192.168.77.145:58607, idle 0:00:00, bytes 951654849, flags UIO
TCP LanFortis 81.20.15.42:10200 LanOTCEXGROUP 192.168.177.117:3711, idle 0:00:03, bytes 262479, flags UIO
TCP LanFortis 81.20.15.42:10200 LanOTCEXGROUP 192.168.177.117:3710, idle 0:00:00, bytes 130119863, flags UIO
TCP LanFortis 81.20.15.42:10200 LanOTCEXGROUP PCVLAD:56077, idle 0:00:03, bytes 253769, flags UIO
TCP LanFortis 81.20.15.42:10200 LanOTCEXGROUP PCVLAD:56076, idle 0:00:00, bytes 130156860, flags UIO
TCP LanFortis 81.20.15.42:10200 LanOTCEXGROUP 192.168.77.162:61062, idle 0:00:04, bytes 253904, flags UIO
TCP LanFortis 81.20.15.42:10200 LanOTCEXGROUP 192.168.77.137:2237, idle 0:00:00, bytes 1186007907, flags UIO
TCP LanFortis 81.20.15.42:10200 LanOTCEXGROUP 192.168.177.61:64577, idle 0:00:00, bytes 213916, flags UIO
TCP LanFortis 81.20.15.42:10200 LanOTCEXGROUP 192.168.177.61:64576, idle 0:00:00, bytes 130229159, flags UIO
TCP LanFortis 81.20.15.42:10200 LanOTCEXGROUP 192.168.117.23:62737, idle 0:00:00, bytes 130230532, flags UIO
TCP LanFortis 81.20.15.42:10200 LanOTCEXGROUP 192.168.117.23:62736, idle 0:00:00, bytes 253760, flags UIO
TCP LanFortis 81.20.15.42:10200 LanOTCEXGROUP 192.168.117.168:60492, idle 0:00:02, bytes 213757, flags UIO
TCP LanFortis 81.20.15.42:10200 LanOTCEXGROUP 192.168.117.168:60491, idle 0:00:00, bytes 130216767, flags UIO
TCP LanFortis 81.20.15.42:10200 LanOTCEXGROUP 192.168.77.162:61060, idle 0:00:00, bytes 130159584, flags UIO
TCP LanFortis 81.20.15.42:10200 LanOTCEXGROUP 192.168.77.137:2236, idle 0:00:00, bytes 90435200, flags UIO
TCP LanLchCap 160.92.33.156:24200 LanOTCEXGROUP 172.16.40.111:1195, idle 0:00:04, bytes 47983, flags UIO
TCP LanLchCap 160.92.33.156:24205 LanOTCEXGROUP 172.16.40.111:1194, idle 0:00:02, bytes 77610, flags UIO
TCP LanReuters 10.20.0.105:8101 LanOTCEXGROUP 192.168.97.79:4653, idle 0:00:00, bytes 25064713, flags UIO
TCP LanReuters 10.20.0.105:8101 LanOTCEXGROUP 192.168.97.79:4647, idle 0:00:05, bytes 683804, flags UIO
TCP LanReuters 10.20.0.105:8101 LanOTCEXGROUP 192.168.97.133:1264, idle 0:00:00, bytes 1031712423, flags UIO
TCP LanReuters 10.20.0.105:8101 LanOTCEXGROUP 192.168.97.61:2969, idle 0:00:00, bytes 25086412, flags UIO
TCP LanReuters 10.20.0.105:8101 LanOTCEXGROUP 192.168.97.61:2968, idle 0:00:07, bytes 684314, flags UIO
TCP LanReuters 75.124.92.216:2400 LanOTCEXGROUP 192.168.77.88:4755, idle 0:00:07, bytes 144476, flags UIO
TCP LanReuters 75.124.92.216:2400 LanOTCEXGROUP 192.168.97.133:1826, idle 0:00:00, bytes 26552404, flags UIO
TCP LanReuters 75.124.92.216:2400 LanOTCEXGROUP 192.168.97.61:3110, idle 0:00:00, bytes 31121304, flags UIO
TCP LanReuters 75.124.92.216:2400 LanOTCEXGROUP 192.168.97.79:3516, idle 0:00:25, bytes 175216, flags UIO
TCP LanReuters 155.195.64.84:5100 LanOTCEXGROUP 192.168.77.88:4696, idle 0:05:13, bytes 555752, flags UIO
TCP LanReuters 155.195.66.53:7091 LanOTCEXGROUP 192.168.77.88:4692, idle 0:04:43, bytes 4005, flags UFRIO
TCP LanReuters 155.195.88.1:443 LanOTCEXGROUP 192.168.97.204:1357, idle 0:00:01, bytes 442154, flags UIO
TCP LanReuters 155.195.88.1:443 LanOTCEXGROUP 192.168.97.130:52509, idle 0:00:02, bytes 977264, flags UIO
TCP LanReuters 155.195.88.1:443 LanOTCEXGROUP 192.168.97.31:52358, idle 0:00:01, bytes 1196227, flags UIO
TCP LanReuters 155.195.88.1:443 LanOTCEXGROUP 192.168.97.122:50111, idle 0:00:01, bytes 708344, flags UIO
TCP LanReuters 155.195.88.1:443 LanOTCEXGROUP 192.168.97.100:3471, idle 0:00:26, bytes 2059965, flags UIO
TCP LanReuters 155.195.88.1:443 LanOTCEXGROUP 192.168.77.90:58058, idle 0:00:09, bytes 4978520, flags UIO
TCP LanReuters 155.195.88.1:443 LanOTCEXGROUP 192.168.117.166:50624, idle 0:01:10, bytes 1869481, flags UIO
TCP LanReuters 155.195.88.1:443 LanOTCEXGROUP 192.168.97.133:3685, idle 0:02:29, bytes 2052547, flags UIO
TCP LanReuters 155.195.88.1:443 LanOTCEXGROUP 192.168.97.117:58745, idle 0:00:25, bytes 1741867, flags UIO
TCP LanReuters 155.195.88.1:443 LanOTCEXGROUP 192.168.97.80:63423, idle 0:00:26, bytes 3852093, flags UIO
TCP LanReuters 155.195.88.1:443 LanOTCEXGROUP 192.168.97.126:2198, idle 0:02:29, bytes 4592793, flags UIO
TCP LanReuters 10.20.0.104:8101 LanOTCEXGROUP 192.168.77.88:4698, idle 0:00:00, bytes 277351, flags UIO
TCP LanReuters 10.20.0.104:8101 LanOTCEXGROUP 192.168.77.88:4697, idle 0:00:14, bytes 936, flags UIO
TCP LanReuters 10.20.0.104:8101 LanOTCEXGROUP 192.168.77.88:4694, idle 0:00:07, bytes 354413, flags UIO
TCP LanReuters 10.20.0.104:8101 LanOTCEXGROUP 192.168.77.88:3700, idle 0:00:00, bytes 163159529, flags UIO
TCP LanReuters 10.20.0.104:8101 LanOTCEXGROUP 192.168.97.79:4655, idle 0:00:00, bytes 2838886492, flags UIO
TCP LanReuters 10.20.0.104:8101 LanOTCEXGROUP 192.168.97.79:4654, idle 0:00:14, bytes 683625, flags UIO
TCP LanReuters 10.20.0.104:8101 LanOTCEXGROUP 192.168.97.133:1266, idle 0:00:01, bytes 951117, flags UIO
TCP LanReuters 10.20.0.104:8101 LanOTCEXGROUP 192.168.97.61:2974, idle 0:00:03, bytes 683906, flags UIO
TCP LanReuters 10.20.0.104:8101 LanOTCEXGROUP 192.168.97.61:2973, idle 0:00:00, bytes 2087156440, flags UIO
TCP LanReuters 10.20.0.104:8101 LanOTCEXGROUP 192.168.97.133:1263, idle 0:00:00, bytes 25062519, flags UIO
TCP LanSW 213.86.175.105:9009 LanOTCEXGROUP 192.168.77.238:2386, idle 0:03:00, bytes 393824, flags UIO
TCP LanSW 213.86.175.105:9009 LanOTCEXGROUP 192.168.97.67:60817, idle 0:00:45, bytes 1707407, flags UIO
TCP LanSW 213.86.175.105:9009 LanOTCEXGROUP 192.168.97.117:58720, idle 0:02:49, bytes 2152077, flags UIO
TCP Lanbloomberg 199.105.179.168:8292 LanOTCEXGROUP 192.168.97.128:60179, idle 0:00:00, bytes 22788167, flags UIO
TCP Lanbloomberg 199.105.179.168:8292 LanOTCEXGROUP 192.168.77.57:1600, idle 0:00:00, bytes 7349144, flags UIO
TCP Lanbloomberg 199.105.179.168:8292 LanOTCEXGROUP 192.168.77.152:8278, idle 0:00:00, bytes 65492969, flags UIO
TCP Lanbloomberg 199.105.179.168:8292 LanOTCEXGROUP 192.168.77.66:51518, idle 0:00:00, bytes 7038647, flags UIO
TCP Lanbloomberg 199.105.179.168:8292 LanOTCEXGROUP 192.168.97.136:8278, idle 0:00:00, bytes 7723030, flags UIO
TCP Lanbloomberg 199.105.181.117:8292 LanOTCEXGROUP 192.168.97.128:60177, idle 0:00:00, bytes 3533906, flags UIO
TCP Lanbloomberg 199.105.181.117:8292 LanOTCEXGROUP 192.168.77.57:1597, idle 0:00:01, bytes 2304036, flags UIO
TCP Lanbloomberg 199.105.181.117:8292 LanOTCEXGROUP 192.168.77.152:8277, idle 0:00:14, bytes 6762467, flags UIO
TCP Lanbloomberg 199.105.181.117:8292 LanOTCEXGROUP 192.168.77.66:51445, idle 0:00:13, bytes 1484762, flags UIO
TCP Lanbloomberg 199.105.181.117:8292 LanOTCEXGROUP 192.168.97.136:8277, idle 0:00:00, bytes 1574124, flags UIO
TCP Lanbloomberg 69.184.37.7:8292 LanOTCEXGROUP 192.168.77.172:54401, idle 0:00:00, bytes 16073142, flags UIO
TCP Lanbloomberg 199.105.181.172:8292 LanOTCEXGROUP 192.168.97.59:8278, idle 0:00:00, bytes 77761145, flags UIO
TCP Lanbloomberg 199.105.181.172:8292 LanOTCEXGROUP 192.168.77.62:64316, idle 0:00:00, bytes 7154543, flags UIO
TCP Lanbloomberg 199.105.181.172:8292 LanOTCEXGROUP 192.168.77.175:8278, idle 0:00:00, bytes 27503207, flags UIO
TCP Lanbloomberg 199.105.181.172:8292 LanOTCEXGROUP 192.168.97.220:61309, idle 0:00:00, bytes 49934996, flags UIO
TCP Lanbloomberg 199.105.181.172:8292 LanOTCEXGROUP 192.168.97.183:61694, idle 0:00:00, bytes 89909761, flags UIO
TCP Lanbloomberg 199.105.181.172:8292 LanOTCEXGROUP 192.168.97.92:8279, idle 0:00:00, bytes 12470528, flags UIO
TCP Lanbloomberg 69.184.37.83:8195 LanOTCEXGROUP 192.168.77.166:8200, idle 0:00:03, bytes 30432, flags UIO
TCP Lanbloomberg 69.184.37.83:8194 LanOTCEXGROUP 192.168.77.166:8196, idle 0:00:01, bytes 854001, flags UIO
TCP Lanbloomberg 69.184.37.83:8195 LanOTCEXGROUP 192.168.97.52:8201, idle 0:00:09, bytes 35436, flags UIO
TCP Lanbloomberg 69.184.37.83:8195 LanOTCEXGROUP 192.168.97.216:8200, idle 0:00:08, bytes 37044, flags UIO
TCP Lanbloomberg 69.184.37.83:8195 LanOTCEXGROUP 192.168.97.124:8200, idle 0:00:00, bytes 39680, flags UIO
TCP Lanbloomberg 69.184.37.83:8194 LanOTCEXGROUP 192.168.97.124:8199, idle 0:00:06, bytes 896420, flags UIO
TCP Lanbloomberg 69.184.37.83:8195 LanOTCEXGROUP 192.168.97.118:8201, idle 0:00:01, bytes 47946, flags UIO
TCP Lanbloomberg 69.184.37.83:8194 LanOTCEXGROUP 192.168.97.118:8200, idle 0:00:03, bytes 2551838, flags UIO
TCP Lanbloomberg 69.184.37.83:8195 LanOTCEXGROUP 192.168.97.179:8200, idle 0:00:04, bytes 58447, flags UIO
TCP Lanbloomberg 69.184.37.83:8194 LanOTCEXGROUP 192.168.97.179:8196, idle 0:00:01, bytes 16727490, flags UIO
TCP Lanbloomberg 69.184.37.83:8195 LanOTCEXGROUP 192.168.97.87:8199, idle 0:00:09, bytes 102330, flags UIO
TCP Lanbloomberg 69.184.37.83:8195 LanOTCEXGROUP 192.168.97.59:8200, idle 0:00:08, bytes 258750, flags UIO
TCP Lanbloomberg 69.184.37.83:8194 LanOTCEXGROUP 192.168.97.59:8196, idle 0:00:06, bytes 3591914, flags UIO
TCP Lanbloomberg 69.184.37.83:8195 LanOTCEXGROUP 192.168.77.92:8199, idle 0:00:08, bytes 263868, flags UIO
TCP Lanbloomberg 69.184.37.83:8195 LanOTCEXGROUP 192.168.97.183:8200, idle 0:00:00, bytes 265568, flags UIO
TCP Lanbloomberg 69.184.37.83:8194 LanOTCEXGROUP 192.168.97.183:8196, idle 0:00:03, bytes 6053334, flags UIO
TCP Lanbloomberg 69.184.37.83:8195 LanOTCEXGROUP 192.168.97.117:8201, idle 0:00:03, bytes 272724, flags UIO
TCP Lanbloomberg 69.184.37.83:8195 LanOTCEXGROUP 192.168.97.80:8200, idle 0:00:07, bytes 275202, flags UIO
TCP Lanbloomberg 69.184.37.83:8194 LanOTCEXGROUP 192.168.97.80:8199, idle 0:00:08, bytes 1776286, flags UIO
TCP Lanbloomberg 69.184.37.83:8195 LanOTCEXGROUP 192.168.97.62:8228, idle 0:00:04, bytes 346332, flags UIO
TCP Lanbloomberg 69.184.37.83:8194 LanOTCEXGROUP 192.168.77.127:8272, idle 0:00:00, bytes 3170146, flags UIO
TCP Lanbloomberg 69.184.37.83:8195 LanOTCEXGROUP 192.168.77.170:8264, idle 0:00:07, bytes 425624, flags UIO
TCP Lanbloomberg 69.184.37.83:8195 LanOTCEXGROUP 192.168.97.208:8221, idle 0:00:02, bytes 425556, flags UIO
<--- More --->
TCP Lanbloomberg 69.184.37.83:8195 LanOTCEXGROUP 192.168.77.62:8243, idle 0:00:01, bytes 426690, flags UIO
TCP Lanbloomberg 69.184.37.83:8195 LanOTCEXGROUP 192.168.77.161:8219, idle 0:00:06, bytes 426666, flags UIO
TCP Lanbloomberg 69.184.37.83:8195 LanOTCEXGROUP 192.168.97.219:8223, idle 0:00:04, bytes 425672, flags UIO
TCP Lanbloomberg 69.184.37.83:8195 LanOTCEXGROUP 192.168.77.83:8282, idle 0:00:02, bytes 425556, flags UIO
TCP Lanbloomberg 69.184.37.83:8195 LanOTCEXGROUP 192.168.77.57:8209, idle 0:00:02, bytes 449148, flags UIO
TCP Lanbloomberg 69.184.37.83:8195 LanOTCEXGROUP 192.168.97.128:8254, idle 0:00:04, bytes 426834, flags UIO
TCP Lanbloomberg 69.184.37.83:8195 LanOTCEXGROUP 192.168.97.215:8261, idle 0:00:09, bytes 426856, flags UIO
TCP Lanbloomberg 199.105.181.176:8195 LanOTCEXGROUP 192.168.77.166:8197, idle 0:00:01, bytes 9820, flags UIO
TCP Lanbloomberg 199.105.181.176:8195 LanOTCEXGROUP 192.168.97.216:8202, idle 0:00:20, bytes 22600, flags UIO
TCP Lanbloomberg 199.105.181.176:8195 LanOTCEXGROUP 192.168.97.124:8197, idle 0:00:07, bytes 9852, flags UIO
TCP Lanbloomberg 199.105.181.176:8195 LanOTCEXGROUP 192.168.97.118:8203, idle 0:00:00, bytes 142348448, flags UIO
TCP Lanbloomberg 199.105.181.176:8195 LanOTCEXGROUP 192.168.97.187:8197, idle 0:00:00, bytes 3110608, flags UIO
TCP Lanbloomberg 199.105.181.176:8195 LanOTCEXGROUP 192.168.97.179:8197, idle 0:00:01, bytes 139476, flags UIO
TCP Lanbloomberg 199.105.181.176:8195 LanOTCEXGROUP 192.168.97.122:8197, idle 0:00:16, bytes 151072, flags UIO
TCP Lanbloomberg 199.105.181.176:8195 LanOTCEXGROUP 192.168.97.87:8197, idle 0:00:00, bytes 89147624, flags UIO
TCP Lanbloomberg 199.105.181.176:8195 LanOTCEXGROUP 192.168.97.204:8197, idle 0:00:30, bytes 44892, flags UIO
TCP Lanbloomberg 199.105.181.176:8195 LanOTCEXGROUP 192.168.87.140:8197, idle 0:00:08, bytes 45324, flags UIO
TCP Lanbloomberg 199.105.181.176:8195 LanOTCEXGROUP 192.168.97.59:8197, idle 0:00:36, bytes 46354, flags UIO
TCP Lanbloomberg 199.105.181.176:8195 LanOTCEXGROUP 192.168.77.92:8197, idle 0:00:54, bytes 47220, flags UIO
TCP Lanbloomberg 199.105.181.176:8195 LanOTCEXGROUP 192.168.77.57:8281, idle 0:00:02, bytes 203869, flags UIO
TCP Lanbloomberg 199.105.181.176:8195 LanOTCEXGROUP 192.168.97.128:8221, idle 0:00:56, bytes 140604, flags UIO
TCP Lanbloomberg 199.105.181.176:8195 LanOTCEXGROUP 192.168.97.136:8288, idle 0:00:00, bytes 140628, flags UIO
TCP Lanbloomberg 199.105.181.176:8195 LanOTCEXGROUP 192.168.87.119:8195, idle 0:00:02, bytes 140766, flags UIO
TCP Lanbloomberg 199.105.181.176:8195 LanOTCEXGROUP 192.168.77.83:8254, idle 0:00:12, bytes 140652, flags UIO
<--- More --->
TCP Lanbloomberg 199.105.181.176:8195 LanOTCEXGROUP 192.168.77.161:8196, idle 0:00:17, bytes 140652, flags UIO
TCP Lanbloomberg 199.105.181.175:8195 LanOTCEXGROUP 192.168.97.86:8197, idle 0:00:06, bytes 5480, flags UIO
TCP Lanbloomberg 199.105.181.175:8195 LanOTCEXGROUP 192.168.97.52:8202, idle 0:00:03, bytes 160672, flags UIO
TCP Lanbloomberg 199.105.181.175:8195 LanOTCEXGROUP 192.168.97.173:8197, idle 0:00:08, bytes 9444, flags UIO
TCP Lanbloomberg 199.105.181.175:8195 LanOTCEXGROUP 192.168.97.195:8197, idle 0:00:23, bytes 94782, flags UIO
TCP Lanbloomberg 199.105.181.175:8195 LanOTCEXGROUP 192.168.97.100:8202, idle 0:00:00, bytes 15162, flags UIO
TCP Lanbloomberg 199.105.181.175:8195 LanOTCEXGROUP 192.168.77.163:8197, idle 0:00:00, bytes 52165, flags UIO
TCP Lanbloomberg 199.105.181.175:8195 LanOTCEXGROUP 192.168.97.106:8197, idle 0:00:00, bytes 450160140, flags UIO
TCP Lanbloomberg 199.105.181.175:8195 LanOTCEXGROUP 192.168.77.67:8197, idle 0:00:01, bytes 66409, flags UIO
TCP Lanbloomberg 199.105.181.175:8195 LanOTCEXGROUP 192.168.97.183:8197, idle 0:00:00, bytes 81072656, flags UIO
TCP Lanbloomberg 199.105.181.175:8195 LanOTCEXGROUP 192.168.97.67:8197, idle 0:00:23, bytes 888492, flags UIO
TCP Lanbloomberg 199.105.181.175:8195 LanOTCEXGROUP 192.168.97.117:8197, idle 0:00:00, bytes 33229988, flags UIO
TCP Lanbloomberg 199.105.181.175:8195 LanOTCEXGROUP 192.168.97.80:8197, idle 0:00:51, bytes 48948, flags UIO
TCP Lanbloomberg 199.105.181.175:8195 LanOTCEXGROUP 192.168.97.62:8224, idle 0:00:00, bytes 1205749896, flags UIO
TCP Lanbloomberg 199.105.181.175:8195 LanOTCEXGROUP 192.168.77.153:8268, idle 0:00:00, bytes 203562, flags UIO
TCP Lanbloomberg 199.105.181.175:8195 LanOTCEXGROUP 192.168.97.208:8199, idle 0:00:00, bytes 168847348, flags UIO
TCP Lanbloomberg 199.105.181.175:8195 LanOTCEXGROUP 192.168.97.215:8227, idle 0:00:00, bytes 8108260, flags UIO
TCP Lanbloomberg 199.105.181.175:8195 LanOTCEXGROUP 192.168.77.127:8265, idle 0:00:12, bytes 31831536, flags UIO
TCP Lanbloomberg 199.105.181.175:8195 LanOTCEXGROUP 192.168.77.157:8210, idle 0:00:16, bytes 140652, flags UIO
TCP Lanbloomberg 199.105.181.175:8195 LanOTCEXGROUP 192.168.97.219:8197, idle 0:00:17, bytes 141810, flags UIO
TCP Lanbloomberg 199.105.181.175:8195 LanOTCEXGROUP 192.168.77.62:8218, idle 0:00:47, bytes 155058, flags UIO
TCP Lanbloomberg 199.105.181.175:8195 LanOTCEXGROUP 192.168.97.92:8288, idle 0:00:00, bytes 1759610, flags UIO
TCP Lanbloomberg 199.105.181.175:8195 LanOTCEXGROUP 192.168.77.170:8239, idle 0:00:00, bytes 7630024, flags UIO
TCP Lanbloomberg 199.105.179.172:8292 LanOTCEXGROUP 192.168.97.195:8278, idle 0:00:00, bytes 97852261, flags UIO
<--- More --->
TCP Lanbloomberg 199.105.179.176:8195 LanOTCEXGROUP 192.168.97.86:8198, idle 0:00:05, bytes 5364, flags UIO
TCP Lanbloomberg 199.105.179.176:8195 LanOTCEXGROUP 192.168.77.166:8198, idle 0:00:03, bytes 9824, flags UIO
TCP Lanbloomberg 199.105.179.176:8195 LanOTCEXGROUP 192.168.97.52:8204, idle 0:00:02, bytes 1257756, flags UIO
TCP Lanbloomberg 199.105.179.176:8195 LanOTCEXGROUP 192.168.97.173:8198, idle 0:00:07, bytes 9560, flags UIO
TCP Lanbloomberg 199.105.179.176:8195 LanOTCEXGROUP 192.168.97.124:8198, idle 0:00:14, bytes 9852, flags UIO
TCP Lanbloomberg 199.105.179.176:8195 LanOTCEXGROUP 192.168.97.187:8198, idle 0:00:00, bytes 3675712, flags UIO
TCP Lanbloomberg 199.105.179.176:8195 LanOTCEXGROUP 192.168.97.179:8198, idle 0:00:00, bytes 195471, flags UIO
TCP Lanbloomberg 199.105.179.176:8195 LanOTCEXGROUP 192.168.97.195:8198, idle 0:00:00, bytes 147640, flags UIO
TCP Lanbloomberg 199.105.179.176:8195 LanOTCEXGROUP 192.168.97.122:8198, idle 0:00:00, bytes 246900, flags UIO
TCP Lanbloomberg 199.105.179.176:8195 LanOTCEXGROUP 192.168.97.87:8198, idle 0:00:00, bytes 101047580, flags UIO
TCP Lanbloomberg 199.105.179.176:8195 LanOTCEXGROUP 192.168.97.204:8198, idle 0:00:37, bytes 44892, flags UIO
TCP Lanbloomberg 199.105.179.176:8195 LanOTCEXGROUP 192.168.97.59:8198, idle 0:00:42, bytes 46354, flags UIO
TCP Lanbloomberg 199.105.179.176:8195 LanOTCEXGROUP 192.168.97.106:8198, idle 0:00:00, bytes 405204280, flags UIO
TCP Lanbloomberg 199.105.179.176:8195 LanOTCEXGROUP 192.168.77.92:8198, idle 0:00:01, bytes 48378, flags UIO
TCP Lanbloomberg 199.105.179.176:8195 LanOTCEXGROUP 192.168.97.183:8198, idle 0:00:00, bytes 87906236, flags UIO
TCP Lanbloomberg 199.105.179.176:8195 LanOTCEXGROUP 192.168.97.80:8198, idle 0:00:51, bytes 48924, flags UIO
TCP Lanbloomberg 199.105.179.176:8195 LanOTCEXGROUP 192.168.97.62:8225, idle 0:00:22, bytes 60996, flags UIO
TCP Lanbloomberg 199.105.179.176:8195 LanOTCEXGROUP 192.168.77.153:8269, idle 0:00:01, bytes 203549, flags UIO
TCP Lanbloomberg 199.105.179.176:8195 LanOTCEXGROUP 192.168.97.219:8201, idle 0:00:27, bytes 141762, flags UIO
TCP Lanbloomberg 199.105.179.176:8195 LanOTCEXGROUP 192.168.97.136:8289, idle 0:00:47, bytes 140720, flags UIO
TCP Lanbloomberg 199.105.179.176:8195 LanOTCEXGROUP 192.168.77.57:8280, idle 0:00:00, bytes 204898, flags UIO
TCP Lanbloomberg 199.105.179.176:8195 LanOTCEXGROUP 192.168.97.128:8219, idle 0:00:34, bytes 140628, flags UIO
TCP Lanbloomberg 199.105.179.176:8195 LanOTCEXGROUP 192.168.87.119:8197, idle 0:00:40, bytes 140626, flags UIO
TCP Lanbloomberg 199.105.179.176:8195 LanOTCEXGROUP 192.168.77.127:8263, idle 0:00:00, bytes 27257812, flags UIO
<--- More --->
TCP Lanbloomberg 199.105.179.176:8195 LanOTCEXGROUP 192.168.77.157:8213, idle 0:00:13, bytes 141810, flags UIO
TCP Lanbloomberg 199.105.179.176:8195 LanOTCEXGROUP 192.168.77.161:8195, idle 0:00:17, bytes 141810, flags UIO
TCP Lanbloomberg 69.184.36.82:8195 LanOTCEXGROUP 192.168.77.166:8199, idle 0:00:01, bytes 29328, flags UIO
TCP Lanbloomberg 69.184.36.82:8195 LanOTCEXGROUP 192.168.97.52:8200, idle 0:00:07, bytes 35460, flags UIO
TCP Lanbloomberg 69.184.36.82:8195 LanOTCEXGROUP 192.168.97.173:8199, idle 0:00:01, bytes 37116, flags UIO
TCP Lanbloomberg 69.184.36.82:8195 LanOTCEXGROUP 192.168.97.187:8200, idle 0:00:04, bytes 52644, flags UIO
TCP Lanbloomberg 69.184.36.82:8194 LanOTCEXGROUP 192.168.97.187:8196, idle 0:00:02, bytes 1305538, flags UIO
TCP Lanbloomberg 69.184.36.82:8195 LanOTCEXGROUP 192.168.97.195:8200, idle 0:00:03, bytes 57394, flags UIO
TCP Lanbloomberg 69.184.36.82:8194 LanOTCEXGROUP 192.168.97.195:8196, idle 0:00:01, bytes 2903226, flags UIO
TCP Lanbloomberg 69.184.36.82:8195 LanOTCEXGROUP 192.168.77.163:8200, idle 0:00:03, bytes 214223, flags UIO
TCP Lanbloomberg 69.184.36.82:8194 LanOTCEXGROUP 192.168.77.163:8196, idle 0:00:01, bytes 1518505, flags UIO
TCP Lanbloomberg 69.184.36.82:8195 LanOTCEXGROUP 192.168.97.106:8201, idle 0:00:09, bytes 259908, flags UIO
TCP Lanbloomberg 69.184.36.82:8195 LanOTCEXGROUP 192.168.77.67:8200, idle 0:00:01, bytes 276751, flags UIO
TCP Lanbloomberg 69.184.36.82:8194 LanOTCEXGROUP 192.168.77.67:8199, idle 0:00:02, bytes 5604541, flags UIO
TCP Lanbloomberg 69.184.36.82:8194 LanOTCEXGROUP 192.168.87.119:8199, idle 0:00:07, bytes 1568038, flags UIO
TCP Lanbloomberg 69.184.36.82:8195 LanOTCEXGROUP 192.168.97.136:8195, idle 0:00:08, bytes 824124, flags UIO
TCP Lanbloomberg 69.184.36.82:8195 LanOTCEXGROUP 192.168.97.92:8197, idle 0:00:06, bytes 824194, flags UIO
TCP Lanbloomberg 69.184.36.82:8195 LanOTCEXGROUP 192.168.77.153:8267, idle 0:00:02, bytes 876053, flags UIO
TCP Lanbloomberg 69.184.36.82:8194 LanOTCEXGROUP 192.168.97.92:8196, idle 0:00:05, bytes 6772204, flags UIO
TCP Lanbloomberg 69.184.36.82:8194 LanOTCEXGROUP 192.168.97.219:8199, idle 0:00:05, bytes 3081930, flags UIO
TCP Lanbloomberg 69.184.36.82:8195 LanOTCEXGROUP 192.168.97.219:8198, idle 0:00:07, bytes 824412, flags UIO
TCP Lanbloomberg 69.184.36.82:8195 LanOTCEXGROUP 192.168.77.170:8242, idle 0:00:08, bytes 824364, flags UIO
TCP Lanbloomberg 69.184.36.82:8195 LanOTCEXGROUP 192.168.77.157:8212, idle 0:00:06, bytes 824412, flags UIO
TCP Lanbloomberg 69.184.36.82:8195 LanOTCEXGROUP 192.168.77.127:8261, idle 0:00:00, bytes 31150488, flags UIO
<--- More --->
TCP Lanbloomberg 69.184.36.82:8195 LanOTCEXGROUP 192.168.87.119:8289, idle 0:00:00, bytes 824410, flags UIO
TCP Lanbloomberg 69.184.36.82:8195 LanOTCEXGROUP 192.168.77.161:8288, idle 0:00:01, bytes 824412, flags UIO
TCP Lanbloomberg 199.105.179.175:8195 LanOTCEXGROUP 192.168.97.216:8203, idle 0:00:50, bytes 22300, flags UIO
TCP Lanbloomberg 199.105.179.175:8195 LanOTCEXGROUP 192.168.97.118:8199, idle 0:00:00, bytes 147624036, flags UIO
TCP Lanbloomberg 199.105.179.175:8195 LanOTCEXGROUP 192.168.97.100:8198, idle 0:00:11, bytes 14120, flags UIO
TCP Lanbloomberg 199.105.179.175:8195 LanOTCEXGROUP 192.168.77.163:8198, idle 0:00:02, bytes 52154, flags UIO
TCP Lanbloomberg 199.105.179.175:8195 LanOTCEXGROUP 192.168.87.140:8198, idle 0:00:22, bytes 45348, flags UIO
TCP Lanbloomberg 199.105.179.175:8195 LanOTCEXGROUP 192.168.77.67:8198, idle 0:00:02, bytes 67452, flags UIO
TCP Lanbloomberg 199.105.179.175:8195 LanOTCEXGROUP 192.168.97.67:8198, idle 0:00:07, bytes 529384, flags UIO
TCP Lanbloomberg 199.105.179.175:8195 LanOTCEXGROUP 192.168.97.117:8198, idle 0:00:00, bytes 40765296, flags UIO
TCP Lanbloomberg 199.105.179.175:8195 LanOTCEXGROUP 192.168.97.92:8289, idle 0:00:14, bytes 141784, flags UIO
TCP Lanbloomberg 199.105.179.175:8195 LanOTCEXGROUP 192.168.97.215:8224, idle 0:00:00, bytes 21702324, flags UIO
TCP Lanbloomberg 199.105.179.175:8195 LanOTCEXGROUP 192.168.77.83:8253, idle 0:00:23, bytes 141670, flags UIO
TCP Lanbloomberg 199.105.179.175:8195 LanOTCEXGROUP 192.168.77.170:8241, idle 0:00:00, bytes 6669452, flags UIO
TCP Lanbloomberg 199.105.179.175:8195 LanOTCEXGROUP 192.168.97.208:8195, idle 0:00:00, bytes 113205672, flags UIO
TCP Lanbloomberg 199.105.179.175:8195 LanOTCEXGROUP 192.168.77.62:8217, idle 0:00:58, bytes 144544, flags UIO
TCP Lanbloomberg 199.105.181.174:8292 LanOTCEXGROUP 192.168.87.119:8280, idle 0:00:00, bytes 116598962, flags UIO
TCP Lanbloomberg 69.184.36.81:8195 LanOTCEXGROUP 192.168.97.86:8199, idle 0:00:05, bytes 12636, flags UIO
TCP Lanbloomberg 69.184.36.81:8194 LanOTCEXGROUP 192.168.97.216:8204, idle 0:00:09, bytes 5987880, flags UIO
TCP Lanbloomberg 69.184.36.81:8195 LanOTCEXGROUP 192.168.97.124:8201, idle 0:00:03, bytes 39612, flags UIO
TCP Lanbloomberg 69.184.36.81:8195 LanOTCEXGROUP 192.168.97.118:8202, idle 0:00:04, bytes 46860, flags UIO
TCP Lanbloomberg 69.184.36.81:8195 LanOTCEXGROUP 192.168.97.179:8199, idle 0:00:04, bytes 58465, flags UIO
TCP Lanbloomberg 69.184.36.81:8195 LanOTCEXGROUP 192.168.87.140:8201, idle 0:00:03, bytes 252444, flags UIO
TCP Lanbloomberg 69.184.36.81:8195 LanOTCEXGROUP 192.168.97.59:8199, idle 0:00:03, bytes 258730, flags UIO
<--- More --->
TCP Lanbloomberg 69.184.36.81:8195 LanOTCEXGROUP 192.168.77.92:8200, idle 0:00:01, bytes 263964, flags UIO
TCP Lanbloomberg 69.184.36.81:8194 LanOTCEXGROUP 192.168.77.92:8196, idle 0:00:03, bytes 1977460, flags UIO
TCP Lanbloomberg 69.184.36.81:8195 LanOTCEXGROUP 192.168.97.183:8199, idle 0:00:05, bytes 265452, flags UIO
TCP Lanbloomberg 69.184.36.81:8195 LanOTCEXGROUP 192.168.97.117:8200, idle 0:00:09, bytes 272748, flags UIO
TCP Lanbloomberg 69.184.36.81:8194 LanOTCEXGROUP 192.168.97.117:8199, idle 0:00:01, bytes 12411778, flags UIO
TCP Lanbloomberg 69.184.36.81:8195 LanOTCEXGROUP 192.168.97.62:8226, idle 0:00:02, bytes 346544, flags UIO
TCP Lanbloomberg 69.184.36.81:8194 LanOTCEXGROUP 192.168.77.153:8205, idle 0:00:02, bytes 1618305, flags UIO
TCP Lanbloomberg 69.184.36.81:8194 LanOTCEXGROUP 192.168.77.157:8238, idle 0:00:02, bytes 5284908, flags UIO
TCP Lanbloomberg 69.184.36.81:8194 LanOTCEXGROUP 192.168.97.128:8247, idle 0:00:00, bytes 1592826, flags UIO
TCP Lanbloomberg 69.184.36.81:8194 LanOTCEXGROUP 192.168.97.208:8198, idle 0:00:05, bytes 8855470, flags UIO
TCP Lanbloomberg 69.184.36.81:8195 LanOTCEXGROUP 192.168.97.215:8225, idle 0:00:00, bytes 824362, flags UIO
TCP Lanbloomberg 69.184.36.81:8195 LanOTCEXGROUP 192.168.77.62:8220, idle 0:00:02, bytes 824412, flags UIO
TCP Lanbloomberg 69.184.36.81:8194 LanOTCEXGROUP 192.168.77.62:8219, idle 0:00:04, bytes 8350362, flags UIO
TCP Lanbloomberg 69.184.36.81:8195 LanOTCEXGROUP 192.168.97.208:8196, idle 0:00:08, bytes 824388, flags UIO
TCP Lanbloomberg 69.184.36.81:8194 LanOTCEXGROUP 192.168.77.57:8278, idle 0:00:02, bytes 3137472, flags UIO
TCP Lanbloomberg 69.184.36.81:8194 LanOTCEXGROUP 192.168.77.83:8252, idle 0:00:08, bytes 3086104, flags UIO
TCP Lanbloomberg 69.184.36.81:8194 LanOTCEXGROUP 192.168.77.161:8289, idle 0:00:00, bytes 6773536, flags UIO
TCP Lanbloomberg 69.184.36.81:8194 LanOTCEXGROUP 192.168.97.136:8286, idle 0:00:02, bytes 3083964, flags UIO
TCP Lanbloomberg 199.105.181.169:8292 LanOTCEXGROUP 192.168.77.189:8278, idle 0:00:00, bytes 7496459, flags UIO
TCP Lanbloomberg 199.105.181.169:8292 LanOTCEXGROUP 192.168.97.100:8278, idle 0:00:00, bytes 99525794, flags UIO
TCP Lanbloomberg 199.105.181.169:8292 LanOTCEXGROUP 192.168.77.196:59402, idle 0:00:00, bytes 106319272, flags UIO
TCP Lanbloomberg 199.105.181.169:8292 LanOTCEXGROUP 192.168.97.216:64966, idle 0:00:00, bytes 27024690, flags UIO
TCP Lanbloomberg 199.105.179.174:8292 LanOTCEXGROUP 192.168.97.117:8278, idle 0:00:00, bytes 60824052, flags UIO
TCP Lanbloomberg 199.105.179.174:8292 LanOTCEXGROUP 192.168.97.215:8282, idle 0:00:00, bytes 30229651, flags UIO
<--- More --->
TCP Lanbloomberg 199.105.181.54:8292 LanOTCEXGROUP 192.168.77.166:8277, idle 0:00:02, bytes 3128012, flags UIO
TCP Lanbloomberg 199.105.181.54:8292 LanOTCEXGROUP 192.168.97.31:8277, idle 0:00:12, bytes 3322318, flags UIO
TCP Lanbloomberg 199.105.181.54:8292 LanOTCEXGROUP 192.168.77.170:63343, idle 0:00:00, bytes 7403902, flags UIO
TCP Lanbloomberg 199.105.181.54:8292 LanOTCEXGROUP 192.168.97.67:60146, idle 0:00:02, bytes 4472176, flags UIO
TCP Lanbloomberg 199.105.181.54:8292 LanOTCEXGROUP 192.168.77.157:61348, idle 0:00:01, bytes 5778297, flags UIO
TCP Lanbloomberg 199.105.181.67:8195 LanOTCEXGROUP 192.168.97.86:8200, idle 0:00:05, bytes 12660, flags UIO
TCP Lanbloomberg 199.105.181.67:8194 LanOTCEXGROUP 192.168.97.86:8196, idle 0:00:03, bytes 994738, flags UIO
TCP Lanbloomberg 199.105.181.67:8195 LanOTCEXGROUP 192.168.97.100:8200, idle 0:00:03, bytes 64500, flags UIO
TCP Lanbloomberg 199.105.181.67:8194 LanOTCEXGROUP 192.168.97.100:8199, idle 0:00:09, bytes 3625940, flags UIO
TCP Lanbloomberg 199.105.181.67:8195 LanOTCEXGROUP 192.168.97.122:8199, idle 0:00:02, bytes 66948, flags UIO
TCP Lanbloomberg 199.105.181.67:8195 LanOTCEXGROUP 192.168.77.163:8199, idle 0:00:01, bytes 211152, flags UIO
TCP Lanbloomberg 199.105.181.67:8195 LanOTCEXGROUP 192.168.97.204:8200, idle 0:00:07, bytes 249900, flags UIO
TCP Lanbloomberg 199.105.181.67:8194 LanOTCEXGROUP 192.168.97.204:8196, idle 0:00:00, bytes 1687214, flags UIO
TCP Lanbloomberg 199.105.181.67:8195 LanOTCEXGROUP 192.168.97.106:8200, idle 0:00:00, bytes 259956, flags UIO
TCP Lanbloomberg 199.105.181.67:8194 LanOTCEXGROUP 192.168.97.106:8199, idle 0:00:06, bytes 3355240, flags UIO
TCP Lanbloomberg 199.105.181.67:8195 LanOTCEXGROUP 192.168.97.67:8200, idle 0:00:05, bytes 265524, flags UIO
TCP Lanbloomberg 199.105.181.67:8194 LanOTCEXGROUP 192.168.97.67:8196, idle 0:00:08, bytes 3156950, flags UIO
TCP Lanbloomberg 199.105.181.67:8194 LanOTCEXGROUP 192.168.97.215:8263, idle 0:00:08, bytes 3024754, flags UIO
TCP Lanbloomberg 199.105.181.67:8195 LanOTCEXGROUP 192.168.77.157:8248, idle 0:00:08, bytes 424572, flags UIO
TCP Lanbloomberg 199.105.181.67:8195 LanOTCEXGROUP 192.168.77.153:8215, idle 0:00:02, bytes 446411, flags UIO
TCP Lanbloomberg 199.105.181.171:8292 LanOTCEXGROUP 192.168.97.187:60424, idle 0:00:00, bytes 50369657, flags UIO
TCP Lanbloomberg 199.105.181.171:8292 LanOTCEXGROUP 192.168.97.122:49580, idle 0:00:00, bytes 21567072, flags UIO
TCP Lanbloomberg 199.105.181.45:8292 LanOTCEXGROUP 192.168.97.187:60423, idle 0:00:02, bytes 5918240, flags UIO
TCP Lanbloomberg 199.105.181.45:8292 LanOTCEXGROUP 192.168.97.122:49579, idle 0:00:02, bytes 3984216, flags UIO
<--- More --->
TCP Lanbloomberg 199.105.181.37:8292 LanOTCEXGROUP 192.168.87.119:8277, idle 0:00:00, bytes 7211482, flags UIO
TCP Lanbloomberg 199.105.179.167:8292 LanOTCEXGROUP 192.168.77.82:49396, idle 0:00:00, bytes 118003451, flags UIO
TCP Lanbloomberg 199.105.179.167:8292 LanOTCEXGROUP 192.168.97.130:8279, idle 0:00:00, bytes 33002159, flags UIO
TCP Lanbloomberg 199.105.179.167:8292 LanOTCEXGROUP 192.168.77.161:51261, idle 0:00:00, bytes 6982179, flags UIO
TCP Lanbloomberg 199.105.179.167:8292 LanOTCEXGROUP 192.168.77.83:8281, idle 0:00:00, bytes 52250520, flags UIO
TCP Lanbloomberg 199.105.179.167:8292 LanOTCEXGROUP 192.168.97.184:8279, idle 0:00:00, bytes 15601297, flags UIO
TCP Lanbloomberg 199.105.179.169:8292 LanOTCEXGROUP 192.168.77.80:8278, idle 0:00:00, bytes 7114470, flags UIO
TCP Lanbloomberg 199.105.179.169:8292 LanOTCEXGROUP 192.168.97.198:56818, idle 0:00:00, bytes 67897320, flags UIO
TCP Lanbloomberg 199.105.179.169:8292 LanOTCEXGROUP 192.168.97.118:64489, idle 0:00:00, bytes 14925205, flags UIO
TCP Lanbloomberg 199.105.179.166:8292 LanOTCEXGROUP 192.168.97.217:8280, idle 0:00:00, bytes 79213829, flags UIO
TCP Lanbloomberg 199.105.181.93:8292 LanOTCEXGROUP 192.168.97.195:8277, idle 0:00:00, bytes 6615966, flags UIO
TCP Lanbloomberg 199.105.181.93:8292 LanOTCEXGROUP 192.168.97.124:63419, idle 0:00:05, bytes 9443760, flags UIO
TCP Lanbloomberg 199.105.181.93:8292 LanOTCEXGROUP 192.168.97.204:8277, idle 0:00:04, bytes 2888441, flags UIO
TCP Lanbloomberg 199.105.181.93:8292 LanOTCEXGROUP 192.168.77.67:8278, idle 0:00:00, bytes 11750241, flags UIO
TCP Lanbloomberg 199.105.181.3:8195 LanOTCEXGROUP 192.168.97.216:8201, idle 0:00:00, bytes 37116, flags UIO
TCP Lanbloomberg 199.105.181.3:8195 LanOTCEXGROUP 192.168.97.100:8201, idle 0:00:02, bytes 64500, flags UIO
TCP Lanbloomberg 199.105.181.3:8195 LanOTCEXGROUP 192.168.97.122:8200, idle 0:00:00, bytes 66948, flags UIO
TCP Lanbloomberg 199.105.181.3:8194 LanOTCEXGROUP 192.168.97.122:8196, idle 0:00:00, bytes 15332738, flags UIO
TCP Lanbloomberg 199.105.181.3:8195 LanOTCEXGROUP 192.168.97.87:8200, idle 0:00:01, bytes 319680, flags UIO
TCP Lanbloomberg 199.105.181.3:8194 LanOTCEXGROUP 192.168.97.87:8196, idle 0:00:05, bytes 1510516, flags UIO
TCP Lanbloomberg 199.105.181.3:8195 LanOTCEXGROUP 192.168.97.204:8199, idle 0:00:08, bytes 249900, flags UIO
TCP Lanbloomberg 199.105.181.3:8195 LanOTCEXGROUP 192.168.97.67:8199, idle 0:00:06, bytes 265524, flags UIO
TCP Lanbloomberg 199.105.181.3:8195 LanOTCEXGROUP 192.168.97.80:8201, idle 0:00:09, bytes 274116, flags UIO
TCP Lanbloomberg 199.105.181.3:8194 LanOTCEXGROUP 192.168.77.170:8265, idle 0:00:06, bytes 2997694, flags UIO
<--- More --->
TCP Lanbloomberg 199.105.181.3:8195 LanOTCEXGROUP 192.168.97.128:8222, idle 0:00:08, bytes 824196, flags UIO
TCP Lanbloomberg 199.105.181.3:8195 LanOTCEXGROUP 192.168.77.57:8279, idle 0:00:01, bytes 872623, flags UIO
TCP Lanbloomberg 199.105.181.3:8195 LanOTCEXGROUP 192.168.77.83:8251, idle 0:00:09, bytes 824412, flags UIO
TCP Lanbloomberg 199.105.181.170:8292 LanOTCEXGROUP 192.168.77.166:8278, idle 0:00:00, bytes 7353291, flags UIO
TCP Lanbloomberg 199.105.181.170:8292 LanOTCEXGROUP 192.168.97.31:8278, idle 0:00:00, bytes 66255559, flags UIO
TCP Lanbloomberg 199.105.181.170:8292 LanOTCEXGROUP 192.168.77.170:63344, idle 0:00:00, bytes 79035650, flags UIO
TCP Lanbloomberg 199.105.181.170:8292 LanOTCEXGROUP 192.168.77.157:61349, idle 0:00:00, bytes 62410437, flags UIO
TCP Lanbloomberg 199.105.181.170:8292 LanOTCEXGROUP 192.168.97.67:60158, idle 0:00:00, bytes 79144539, flags UIO
TCP Lanbloomberg 199.105.181.165:8292 LanOTCEXGROUP 192.168.77.68:8278, idle 0:00:00, bytes 88100494, flags UIO
TCP Lanbloomberg 199.105.181.165:8292 LanOTCEXGROUP 192.168.77.141:8281, idle 0:00:19, bytes 229814, flags UIO
TCP Lanbloomberg 199.105.181.165:8292 LanOTCEXGROUP 192.168.97.87:63460, idle 0:00:00, bytes 96228811, flags UIO
TCP Lanbloomberg 208.134.161.151:8292 LanOTCEXGROUP 192.168.77.70:8278, idle 0:00:00, bytes 5764017, flags UIO
TCP Lanbloomberg 199.105.181.60:8292 LanOTCEXGROUP 192.168.77.68:8277, idle 0:00:00, bytes 4997031, flags UIO
TCP Lanbloomberg 199.105.181.60:8292 LanOTCEXGROUP 192.168.77.141:8277, idle 0:00:01, bytes 449933, flags UIO
TCP Lanbloomberg 199.105.181.60:8292 LanOTCEXGROUP 192.168.97.87:63459, idle 0:00:02, bytes 6639183, flags UIO
TCP Lanbloomberg 199.105.179.165:8292 LanOTCEXGROUP 192.168.97.124:63421, idle 0:00:00, bytes 217580282, flags UIO
TCP Lanbloomberg 199.105.179.165:8292 LanOTCEXGROUP 192.168.97.204:8278, idle 0:00:00, bytes 7026983, flags UIO
TCP Lanbloomberg 199.105.179.165:8292 LanOTCEXGROUP 192.168.77.67:8281, idle 0:00:00, bytes 31534020, flags UIO
TCP Lanbloomberg 199.105.179.170:8292 LanOTCEXGROUP 192.168.97.106:58739, idle 0:00:00, bytes 22872507, flags UIO
TCP Lanbloomberg 199.105.179.170:8292 LanOTCEXGROUP 192.168.97.73:8278, idle 0:00:00, bytes 13636140, flags UIO
TCP Lanbloomberg 199.105.179.170:8292 LanOTCEXGROUP 192.168.97.86:49642, idle 0:00:00, bytes 95311504, flags UIO
TCP Lanbloomberg 199.105.179.170:8292 LanOTCEXGROUP 192.168.97.52:8278, idle 0:00:00, bytes 7044324, flags UIO
TCP Lanbloomberg 199.105.179.170:8292 LanOTCEXGROUP 192.168.97.219:8279, idle 0:00:00, bytes 60974698, flags UIO
TCP Lanbloomberg 199.105.181.20:8292 LanOTCEXGROUP 192.168.97.209:8277, idle 0:00:00, bytes 13093569, flags UIO
<--- More --->
TCP Lanbloomberg 199.105.181.20:8292 LanOTCEXGROUP 192.168.97.173:8277, idle 0:00:04, bytes 3908252, flags UIO
TCP Lanbloomberg 199.105.181.20:8292 LanOTCEXGROUP 192.168.97.179:49632, idle 0:00:05, bytes 4690771, flags UIO
TCP Lanbloomberg 199.105.181.20:8292 LanOTCEXGROUP 192.168.87.140:8287, idle 0:00:03, bytes 5934010, flags UIO
TCP Lanbloomberg 199.105.181.20:8292 LanOTCEXGROUP 192.168.97.80:8277, idle 0:00:19, bytes 3306263, flags UIO
TCP Lanbloomberg 199.105.181.20:8292 LanOTCEXGROUP 192.168.77.153:8278, idle 0:00:02, bytes 6033545, flags UIO
TCP Lanbloomberg 199.105.181.20:8292 LanOTCEXGROUP 192.168.97.74:8278, idle 0:00:02, bytes 473600, flags UIO
TCP Lanbloomberg 199.105.181.24:8292 LanOTCEXGROUP 192.168.77.127:8277, idle 0:00:00, bytes 4692113, flags UIO
TCP Lanbloomberg 199.105.181.24:8292 LanOTCEXGROUP 192.168.97.62:8277, idle 0:00:00, bytes 7934510, flags UIO
TCP Lanbloomberg 199.105.181.24:8292 LanOTCEXGROUP 192.168.97.88:8278, idle 0:00:00, bytes 3126386, flags UIO
TCP Lanbloomberg 199.105.181.24:8292 LanOTCEXGROUP 192.168.97.208:55786, idle 0:00:00, bytes 5720731, flags UIO
TCP Lanbloomberg 199.105.181.24:8292 LanOTCEXGROUP 192.168.77.92:55148, idle 0:00:00, bytes 2457788, flags UIO
TCP Lanbloomberg 199.105.181.173:8292 LanOTCEXGROUP 192.168.77.127:8279, idle 0:00:00, bytes 178809208, flags UIO
TCP Lanbloomberg 199.105.181.173:8292 LanOTCEXGROUP 192.168.97.62:8278, idle 0:00:00, bytes 69828653, flags UIO
TCP Lanbloomberg 199.105.181.173:8292 LanOTCEXGROUP 192.168.97.88:8280, idle 0:00:00, bytes 20226942, flags UIO
TCP Lanbloomberg 199.105.181.173:8292 LanOTCEXGROUP 192.168.77.92:55149, idle 0:00:00, bytes 57978882, flags UIO
TCP Lanbloomberg 199.105.181.173:8292 LanOTCEXGROUP 192.168.97.208:55787, idle 0:00:00, bytes 110257362, flags UIO
TCP Lanbloomberg 199.105.181.113:8292 LanOTCEXGROUP 192.168.77.82:49395, idle 0:00:00, bytes 10010126, flags UIO
TCP Lanbloomberg 199.105.181.113:8292 LanOTCEXGROUP 192.168.97.130:8278, idle 0:00:00, bytes 62450110, flags UIO
TCP Lanbloomberg 199.105.181.113:8292 LanOTCEXGROUP 192.168.77.161:51260, idle 0:00:04, bytes 5240741, flags UIO
TCP Lanbloomberg 199.105.181.113:8292 LanOTCEXGROUP 192.168.77.83:8278, idle 0:00:00, bytes 4668986, flags UIO
TCP Lanbloomberg 199.105.181.113:8292 LanOTCEXGROUP 192.168.97.184:8278, idle 0:00:00, bytes 2342470, flags UIO
TCP Lanbloomberg 199.105.181.86:8292 LanOTCEXGROUP 192.168.97.217:8279, idle 0:00:03, bytes 3772634, flags UIO
TCP Lanbloomberg 199.105.181.86:8292 LanOTCEXGROUP 192.168.77.163:8278, idle 0:00:00, bytes 4682648, flags UIO
TCP Lanbloomberg 199.105.181.17:8292 LanOTCEXGROUP 192.168.77.189:8277, idle 0:00:00, bytes 1804628, flags UIO
<--- More --->
TCP Lanbloomberg 199.105.181.17:8292 LanOTCEXGROUP 192.168.97.100:8277, idle 0:00:05, bytes 4039499, flags UIO
TCP Lanbloomberg 199.105.181.17:8292 LanOTCEXGROUP 192.168.77.196:59401, idle 0:00:05, bytes 12077837, flags UIO
TCP Lanbloomberg 199.105.181.17:8292 LanOTCEXGROUP 192.168.97.216:64965, idle 0:00:00, bytes 4040026, flags UIO
TCP Lanbloomberg 199.105.181.35:8292 LanOTCEXGROUP 192.168.97.59:8277, idle 0:00:00, bytes 15444567, flags UIO
TCP Lanbloomberg 199.105.181.35:8292 LanOTCEXGROUP 192.168.77.62:64315, idle 0:00:00, bytes 2421696, flags UIO
TCP Lanbloomberg 199.105.181.35:8292 LanOTCEXGROUP 192.168.77.175:8277, idle 0:00:00, bytes 1968437, flags UIO
TCP Lanbloomberg 199.105.181.35:8292 LanOTCEXGROUP 192.168.97.220:61308, idle 0:00:12, bytes 3288843, flags UIO
TCP Lanbloomberg 199.105.181.35:8292 LanOTCEXGROUP 192.168.97.183:61693, idle 0:00:01, bytes 6502132, flags UIO
TCP Lanbloomberg 199.105.181.35:8292 LanOTCEXGROUP 192.168.97.92:8277, idle 0:00:07, bytes 6170028, flags UIO
TCP Lanbloomberg 199.105.179.173:8292 LanOTCEXGROUP 192.168.77.172:54402, idle 0:00:00, bytes 4243992, flags UIO
TCP Lanbloomberg 199.105.179.173:8292 LanOTCEXGROUP 192.168.77.163:8279, idle 0:00:00, bytes 16608225, flags UIO
TCP Lanbloomberg 199.105.179.173:8292 LanOTCEXGROUP 192.168.77.70:8280, idle 0:00:00, bytes 15382572, flags UIO
TCP Lanbloomberg 199.105.181.168:8292 LanOTCEXGROUP 192.168.97.209:8278, idle 0:00:00, bytes 3732340, flags UIO
TCP Lanbloomberg 199.105.181.168:8292 LanOTCEXGROUP 192.168.97.173:8278, idle 0:00:00, bytes 25213338, flags UIO
TCP Lanbloomberg 199.105.181.168:8292 LanOTCEXGROUP 192.168.97.179:49633, idle 0:00:00, bytes 39678142, flags UIO
TCP Lanbloomberg 199.105.181.168:8292 LanOTCEXGROUP 192.168.87.140:8277, idle 0:00:00, bytes 36302314, flags UIO
TCP Lanbloomberg 199.105.181.168:8292 LanOTCEXGROUP 192.168.97.80:8278, idle 0:00:00, bytes 69710317, flags UIO
TCP Lanbloomberg 199.105.181.168:8292 LanOTCEXGROUP 192.168.97.74:8279, idle 0:00:14, bytes 249647, flags UIO
TCP Lanbloomberg 199.105.181.168:8292 LanOTCEXGROUP 192.168.77.153:8282, idle 0:00:00, bytes 76384769, flags UIO
TCP Lanbloomberg 199.105.181.98:8292 LanOTCEXGROUP 192.168.77.80:8277, idle 0:00:10, bytes 2347720, flags UIO
TCP Lanbloomberg 199.105.181.98:8292 LanOTCEXGROUP 192.168.97.198:56817, idle 0:00:01, bytes 2309877, flags UIO
TCP Lanbloomberg 199.105.181.98:8292 LanOTCEXGROUP 192.168.97.117:8277, idle 0:00:12, bytes 2328438, flags UIO
TCP Lanbloomberg 199.105.181.98:8292 LanOTCEXGROUP 192.168.97.215:8278, idle 0:00:01, bytes 4695435, flags UIO
TCP Lanbloomberg 199.105.181.98:8292 LanOTCEXGROUP 192.168.97.118:64488, idle 0:00:09, bytes 4754213, flags UIO
<--- More --->
TCP Lanbloomberg 199.105.181.87:8292 LanOTCEXGROUP 192.168.97.106:58738, idle 0:00:00, bytes 3039637, flags UIO
TCP Lanbloomberg 199.105.181.87:8292 LanOTCEXGROUP 192.168.97.73:8277, idle 0:00:00, bytes 3991186, flags UIO
TCP Lanbloomberg 199.105.181.87:8292 LanOTCEXGROUP 192.168.97.86:49641, idle 0:00:00, bytes 6952658, flags UIO
TCP Lanbloomberg 199.105.181.87:8292 LanOTCEXGROUP 192.168.97.52:8277, idle 0:00:16, bytes 3549402, flags UIO
TCP Lanbloomberg 199.105.181.87:8292 LanOTCEXGROUP 192.168.97.219:8278, idle 0:00:16, bytes 6572100, flags UIO
TCP Lanbloomberg 69.184.37.84:8194 LanOTCEXGROUP 192.168.97.52:8203, idle 0:00:04, bytes 2277104, flags UIO
TCP Lanbloomberg 69.184.37.84:8195 LanOTCEXGROUP 192.168.97.173:8200, idle 0:00:04, bytes 38346, flags UIO
TCP Lanbloomberg 69.184.37.84:8194 LanOTCEXGROUP 192.168.97.173:8196, idle 0:00:08, bytes 896654, flags UIO
TCP Lanbloomberg 69.184.37.84:8195 LanOTCEXGROUP 192.168.97.187:8199, idle 0:00:00, bytes 53850, flags UIO
TCP Lanbloomberg 69.184.37.84:8195 LanOTCEXGROUP 192.168.97.195:8199, idle 0:00:09, bytes 57466, flags UIO
TCP Lanbloomberg 69.184.37.84:8195 LanOTCEXGROUP 192.168.87.140:8200, idle 0:00:02, bytes 253626, flags UIO
TCP Lanbloomberg 69.184.37.84:8194 LanOTCEXGROUP 192.168.87.140:8199, idle 0:00:08, bytes 1693766, flags UIO
TCP Lanbloomberg 69.184.37.84:8195 LanOTCEXGROUP 192.168.77.67:8201, idle 0:00:01, bytes 273591, flags UIO
TCP Lanbloomberg 69.184.37.84:8194 LanOTCEXGROUP 192.168.97.62:8227, idle 0:00:06, bytes 2518908, flags UIO
TCP Lanbloomberg 69.184.37.84:8195 LanOTCEXGROUP 192.168.87.119:8221, idle 0:00:03, bytes 417558, flags UIO
TCP Lanbloomberg 69.184.37.84:8195 LanOTCEXGROUP 192.168.97.92:8219, idle 0:00:07, bytes 417582, flags UIO
TCP Lanbloomberg 69.184.37.84:8195 LanOTCEXGROUP 192.168.97.136:8217, idle 0:00:07, bytes 418602, flags UIO
TCP Lanbloomberg 69.184.37.84:8195 LanOTCEXGROUP 192.168.77.127:8198, idle 0:00:02, bytes 417540, flags UIO
TCP LanInternet 199.43.13.100:31976 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:00, bytes 242, flags UIOB
TCP LanInternet 212.159.225.71:58345 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:10, bytes 0, flags UfrB
TCP LanInternet 212.159.225.70:56313 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:23, bytes 0, flags UfrB
TCP LanInternet 194.209.217.130:38526 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:16, bytes 135344, flags UIOB
TCP LanInternet 80.241.69.90:18427 LanOTCEXGROUP Trayportsrv01:443, idle 0:07:35, bytes 2086, flags UfrIOB
TCP LanInternet 80.241.69.90:37863 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:43, bytes 11914, flags UIOB
<--- More --->
TCP LanInternet 80.241.69.90:37394 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:55, bytes 4556, flags UIOB
TCP LanInternet 80.241.69.90:37125 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:09, bytes 5276, flags UIOB
TCP LanInternet 80.241.69.90:36671 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:15, bytes 170956, flags UIOB
TCP LanInternet 213.140.23.6:7496 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:44, bytes 185523, flags UIOB
TCP LanInternet 213.140.23.6:52731 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:52, bytes 5465, flags UIOB
TCP LanInternet 213.140.23.6:11236 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:52, bytes 5685, flags UIOB
TCP LanInternet 213.140.23.6:54230 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:52, bytes 5410, flags UIOB
TCP LanInternet 213.140.23.6:39157 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:52, bytes 5686, flags UIOB
TCP LanInternet 213.140.23.6:37971 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:52, bytes 5541, flags UIOB
TCP LanInternet 213.140.23.6:15998 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:52, bytes 5429, flags UIOB
TCP LanInternet 93.62.225.156:46110 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:22, bytes 5091679, flags UIOB
TCP LanInternet 213.244.25.123:36236 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:49, bytes 219093, flags UIOB
TCP LanInternet 193.86.3.179:49794 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:42, bytes 202681, flags UIOB
TCP LanInternet 93.62.225.156:65425 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:01, bytes 5250266, flags UIOB
TCP LanInternet 93.62.225.156:34337 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:41, bytes 157972, flags UIOB
TCP LanInternet 194.126.209.9:16822 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:21, bytes 253195, flags UIOB
TCP LanInternet 77.93.226.226:37019 LanOTCEXGROUP Trayportsrv01:443, idle 0:01:56, bytes 259451, flags UIOB
TCP LanInternet 62.190.14.254:50448 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:48, bytes 284149, flags UIOB
TCP LanInternet 62.190.14.254:50440 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:00, bytes 10765, flags UIOB
TCP LanInternet 62.190.14.254:50428 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:00, bytes 10685, flags UIOB
TCP LanInternet 62.190.14.254:50409 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:00, bytes 10464, flags UIOB
TCP LanInternet 62.190.14.254:50403 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:00, bytes 10519, flags UIOB
TCP LanInternet 62.190.14.254:50389 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:03, bytes 11090, flags UIOB
TCP LanInternet 62.190.14.254:50376 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:48, bytes 26573, flags UIOB
<--- More --->
TCP LanInternet 62.190.14.254:50370 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:00, bytes 10731, flags UIOB
TCP LanInternet 62.190.14.254:50359 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:00, bytes 10720, flags UIOB
TCP LanInternet 62.190.14.254:50338 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:10, bytes 10773, flags UIOB
TCP LanInternet 62.190.14.254:50329 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:00, bytes 10495, flags UIOB
TCP LanInternet 62.190.14.254:50319 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:00, bytes 10716, flags UIOB
TCP LanInternet 62.190.14.254:50303 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:00, bytes 10717, flags UIOB
TCP LanInternet 62.190.14.254:50272 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:00, bytes 11469, flags UIOB
TCP LanInternet 62.190.14.254:50225 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:00, bytes 10719, flags UIOB
TCP LanInternet 62.190.14.254:50214 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:00, bytes 10742, flags UIOB
TCP LanInternet 62.190.14.254:50204 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:00, bytes 10421, flags UIOB
TCP LanInternet 188.202.52.57:55670 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:08, bytes 4803549, flags UIOB
TCP LanInternet 144.98.85.8:34146 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:04, bytes 277442, flags UIOB
TCP LanInternet 144.98.85.8:34144 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:04, bytes 276960, flags UIOB
TCP LanInternet 144.98.85.8:34132 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:40, bytes 13457, flags UIOB
TCP LanInternet 153.100.131.14:37217 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:04, bytes 479336, flags UIOB
TCP LanInternet 145.46.220.6:34658 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:43, bytes 12001, flags UIOB
TCP LanInternet 145.46.220.6:37858 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:23, bytes 11287, flags UIOB
TCP LanInternet 212.161.10.8:47991 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:04, bytes 253073, flags UIOB
TCP LanInternet 212.161.10.8:63460 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:17, bytes 227900, flags UIOB
TCP LanInternet 213.244.25.123:3781 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:04, bytes 378148, flags UIOB
TCP LanInternet 193.109.83.1:44240 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:04, bytes 275911, flags UIOB
TCP LanInternet 193.109.83.1:44233 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:44, bytes 11926, flags UIOB
TCP LanInternet 193.109.83.1:44225 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:44, bytes 12008, flags UIOB
TCP LanInternet 193.109.83.1:44219 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:44, bytes 12255, flags UIOB
<--- More --->
TCP LanInternet 193.109.83.1:44211 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:44, bytes 11921, flags UIOB
TCP LanInternet 193.109.83.1:44202 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:44, bytes 12193, flags UIOB
TCP LanInternet 193.109.83.1:44199 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:41, bytes 12948, flags UIOB
TCP LanInternet 193.109.83.1:44193 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:44, bytes 12243, flags UIOB
TCP LanInternet 160.83.57.37:36034 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:04, bytes 256937, flags UIOB
TCP LanInternet 145.46.220.6:17408 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:50, bytes 11770, flags UIOB
TCP LanInternet 145.46.220.6:30345 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:29, bytes 11787, flags UIOB
TCP LanInternet 193.228.216.18:9535 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:04, bytes 256867, flags UIOB
TCP LanInternet 193.228.216.18:9533 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:48, bytes 12190, flags UIOB
TCP LanInternet 193.228.216.18:9530 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:49, bytes 12117, flags UIOB
TCP LanInternet 192.193.116.138:54406 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:04, bytes 255815, flags UIOB
TCP LanInternet 192.193.116.138:62455 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:51, bytes 12171, flags UIOB
TCP LanInternet 193.228.216.18:9527 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:51, bytes 12164, flags UIOB
TCP LanInternet 193.228.216.18:9525 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:52, bytes 12194, flags UIOB
TCP LanInternet 192.193.116.138:62311 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:29, bytes 12984, flags UIOB
TCP LanInternet 192.193.116.138:54049 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:53, bytes 12182, flags UIOB
TCP LanInternet 193.228.216.18:9523 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:32, bytes 12853, flags UIOB
TCP LanInternet 192.193.116.138:62970 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:54, bytes 12240, flags UIOB
TCP LanInternet 193.228.216.18:9521 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:54, bytes 12167, flags UIOB
TCP LanInternet 192.193.116.138:53650 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:55, bytes 12178, flags UIOB
TCP LanInternet 145.46.220.6:54220 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:45, bytes 12048, flags UIOB
TCP LanInternet 195.238.253.100:4759 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:04, bytes 277568, flags UIOB
TCP LanInternet 195.238.253.100:4753 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:19, bytes 12894, flags UIOB
TCP LanInternet 195.238.253.100:4746 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:27, bytes 12892, flags UIOB
<--- More --->
TCP LanInternet 195.238.253.100:4739 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:27, bytes 13030, flags UIOB
TCP LanInternet 195.238.253.100:4729 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:27, bytes 12948, flags UIOB
TCP LanInternet 195.238.253.100:4718 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:27, bytes 12649, flags UIOB
TCP LanInternet 141.228.106.149:61476 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:04, bytes 257901, flags UIOB
TCP LanInternet 141.228.106.149:49422 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:51, bytes 13204, flags UIOB
TCP LanInternet 141.228.106.149:52411 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:51, bytes 13251, flags UIOB
TCP LanInternet 141.228.106.149:50846 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:51, bytes 12998, flags UIOB
TCP LanInternet 141.228.106.149:52880 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:51, bytes 13279, flags UIOB
TCP LanInternet 141.228.106.149:53865 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:51, bytes 13272, flags UIOB
TCP LanInternet 141.228.106.149:52483 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:51, bytes 13175, flags UIOB
TCP LanInternet 141.228.106.149:58913 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:51, bytes 13211, flags UIOB
TCP LanInternet 141.228.106.149:55043 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:51, bytes 13456, flags UIOB
TCP LanInternet 145.46.220.6:59127 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:01, bytes 12457, flags UIOB
TCP LanInternet 57.66.53.197:23354 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:04, bytes 256016, flags UIOB
TCP LanInternet 57.66.53.197:23341 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:05, bytes 13179, flags UIOB
TCP LanInternet 57.66.53.197:23200 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:07, bytes 13133, flags UIOB
TCP LanInternet 212.243.100.103:36721 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:04, bytes 278633, flags UIOB
TCP LanInternet 212.243.100.103:36715 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:54, bytes 13703, flags UIOB
TCP LanInternet 212.243.100.103:36708 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:54, bytes 14029, flags UIOB
TCP LanInternet 212.243.100.103:36701 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:54, bytes 13820, flags UIOB
TCP LanInternet 212.243.100.103:36694 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:34, bytes 14472, flags UIOB
TCP LanInternet 212.243.100.103:36687 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:20, bytes 16348, flags UIOB
TCP LanInternet 212.243.100.103:36680 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:54, bytes 13825, flags UIOB
TCP LanInternet 212.243.100.103:36675 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:58, bytes 13845, flags UIOB
<--- More --->
TCP LanInternet 212.243.100.103:36671 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:58, bytes 13826, flags UIOB
TCP LanInternet 193.86.3.179:61510 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:06, bytes 14218, flags UIOB
TCP LanInternet 193.86.3.179:61503 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:06, bytes 14253, flags UIOB
TCP LanInternet 193.86.3.179:61494 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:03, bytes 18271, flags UIOB
TCP LanInternet 193.86.3.179:61484 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:06, bytes 14631, flags UIOB
TCP LanInternet 193.86.3.179:61480 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:06, bytes 14532, flags UIOB
TCP LanInternet 193.86.3.179:61477 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:06, bytes 14264, flags UIOB
TCP LanInternet 91.192.15.72:42868 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:09, bytes 259440, flags UIOB
TCP LanInternet 91.192.15.72:21686 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:40, bytes 14422, flags UIOB
TCP LanInternet 91.192.15.72:48782 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:12, bytes 13753, flags UIOB
TCP LanInternet 91.192.15.72:29751 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:14, bytes 13777, flags UIOB
TCP LanInternet 91.192.15.72:40806 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:16, bytes 13756, flags UIOB
TCP LanInternet 91.192.15.72:46078 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:17, bytes 13778, flags UIOB
TCP LanInternet 91.192.15.72:50802 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:19, bytes 13736, flags UIOB
TCP LanInternet 91.192.15.72:37073 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:21, bytes 13752, flags UIOB
TCP LanInternet 91.192.15.72:50459 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:22, bytes 13846, flags UIOB
TCP LanInternet 91.192.15.72:37862 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:24, bytes 13761, flags UIOB
TCP LanInternet 91.192.15.72:28047 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:27, bytes 14316, flags UIOB
TCP LanInternet 91.192.15.72:58232 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:27, bytes 13794, flags UIOB
TCP LanInternet 91.192.15.72:49569 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:28, bytes 13704, flags UIOB
TCP LanInternet 91.192.15.72:24447 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:30, bytes 13758, flags UIOB
TCP LanInternet 91.192.15.72:50346 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:31, bytes 13706, flags UIOB
TCP LanInternet 91.192.15.72:26917 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:13, bytes 14782, flags UIOB
TCP LanInternet 91.192.15.72:10987 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:33, bytes 13792, flags UIOB
<--- More --->
TCP LanInternet 91.192.15.72:58130 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:34, bytes 13755, flags UIOB
TCP LanInternet 193.105.136.101:23773 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:08, bytes 259847, flags UIOB
TCP LanInternet 193.105.136.101:31242 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:03, bytes 16079, flags UIOB
TCP LanInternet 193.105.136.101:29397 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:50, bytes 14203, flags UIOB
TCP LanInternet 193.105.136.101:23015 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:50, bytes 14196, flags UIOB
TCP LanInternet 193.105.136.101:3515 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:49, bytes 15217, flags UIOB
TCP LanInternet 193.105.136.101:55950 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:50, bytes 14442, flags UIOB
TCP LanInternet 193.105.136.101:41245 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:09, bytes 14504, flags UIOB
TCP LanInternet 193.105.136.101:39424 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:50, bytes 14189, flags UIOB
TCP LanInternet 80.78.1.240:6938 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:09, bytes 258228, flags UIOB
TCP LanInternet 80.78.1.240:20105 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:29, bytes 14349, flags UIOB
TCP LanInternet 80.78.1.240:39767 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:13, bytes 14030, flags UIOB
TCP LanInternet 80.78.1.240:13241 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:14, bytes 14055, flags UIOB
TCP LanInternet 80.78.1.240:62638 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:14, bytes 14011, flags UIOB
TCP LanInternet 80.78.1.240:23456 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:15, bytes 14012, flags UIOB
TCP LanInternet 80.78.1.240:31360 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:18, bytes 14774, flags UIOB
TCP LanInternet 80.78.1.240:29901 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:16, bytes 14059, flags UIOB
TCP LanInternet 80.78.1.240:29894 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:17, bytes 14095, flags UIOB
TCP LanInternet 80.78.1.240:44993 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:18, bytes 14106, flags UIOB
TCP LanInternet 212.243.100.103:57100 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:13, bytes 14838, flags UIOB
TCP LanInternet 212.243.100.103:56989 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:05, bytes 317270, flags UIOB
TCP LanInternet 213.156.50.116:26875 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:18, bytes 17141, flags UIOB
TCP LanInternet 213.156.50.116:10324 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:19, bytes 14736, flags UIOB
TCP LanInternet 213.156.50.116:28531 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:08, bytes 369776, flags UIOB
<--- More --->
TCP LanInternet 193.172.150.134:26106 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:08, bytes 302075, flags UIOB
TCP LanInternet 160.83.57.37:33916 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:13, bytes 16956, flags UIOB
TCP LanInternet 160.83.57.37:33903 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:18, bytes 17090, flags UIOB
TCP LanInternet 160.83.57.37:33878 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:38, bytes 16310, flags UIOB
TCP LanInternet 160.83.57.37:33868 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:38, bytes 16597, flags UIOB
TCP LanInternet 160.83.57.37:33856 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:46, bytes 22388, flags UIOB
TCP LanInternet 159.168.7.200:39098 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:55, bytes 16726, flags UIOB
TCP LanInternet 159.168.7.200:39008 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:00, bytes 17015, flags UIOB
TCP LanInternet 159.168.7.200:39007 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:00, bytes 16677, flags UIOB
TCP LanInternet 159.168.7.200:38971 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:03, bytes 16708, flags UIOB
TCP LanInternet 159.168.7.200:38707 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:08, bytes 278338, flags UIOB
TCP LanInternet 146.133.157.254:47714 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:17, bytes 298542, flags UIOB
TCP LanInternet 146.133.157.254:47692 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:49, bytes 16920, flags UIOB
TCP LanInternet 146.133.157.254:47674 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:43, bytes 16676, flags UIOB
TCP LanInternet 146.133.157.254:47657 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:43, bytes 16671, flags UIOB
TCP LanInternet 146.133.157.254:47640 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:43, bytes 16632, flags UIOB
TCP LanInternet 146.133.157.254:47631 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:43, bytes 16898, flags UIOB
TCP LanInternet 146.133.157.254:47604 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:43, bytes 16901, flags UIOB
TCP LanInternet 146.133.157.254:47559 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:43, bytes 16855, flags UIOB
TCP LanInternet 146.133.157.254:47520 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:43, bytes 16881, flags UIOB
TCP LanInternet 146.133.157.254:47507 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:43, bytes 17010, flags UIOB
TCP LanInternet 146.133.157.254:47490 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:43, bytes 16662, flags UIOB
TCP LanInternet 146.133.157.254:47454 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:43, bytes 16672, flags UIOB
TCP LanInternet 146.133.157.254:47439 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:43, bytes 16998, flags UIOB
<--- More --->
TCP LanInternet 146.133.157.254:47422 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:43, bytes 16932, flags UIOB
TCP LanInternet 194.9.188.3:42609 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:52, bytes 17150, flags UIOB
TCP LanInternet 194.9.188.3:42510 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:17, bytes 283110, flags UIOB
TCP LanInternet 194.9.188.3:40707 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:53, bytes 17924, flags UIOB
TCP LanInternet 194.9.188.3:40686 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:45, bytes 17128, flags UIOB
TCP LanInternet 194.9.188.3:40662 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:41, bytes 31989, flags UIOB
TCP LanInternet 194.29.98.70:31888 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:08, bytes 278262, flags UIOB
TCP LanInternet 194.29.98.70:31882 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:12, bytes 17297, flags UIOB
TCP LanInternet 194.29.98.70:31879 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:17, bytes 17309, flags UIOB
TCP LanInternet 194.29.98.70:31874 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:21, bytes 17278, flags UIOB
TCP LanInternet 194.29.98.70:31863 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:26, bytes 17273, flags UIOB
TCP LanInternet 194.29.98.70:31860 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:32, bytes 17306, flags UIOB
TCP LanInternet 194.29.98.70:31848 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:37, bytes 17233, flags UIOB
TCP LanInternet 194.29.98.70:31838 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:41, bytes 17224, flags UIOB
TCP LanInternet 194.29.98.70:31833 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:46, bytes 17261, flags UIOB
TCP LanInternet 194.29.98.70:31827 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:51, bytes 17246, flags UIOB
TCP LanInternet 212.243.72.197:36211 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:24, bytes 172053, flags UIOB
TCP LanInternet 212.243.72.197:60831 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:53, bytes 18274, flags UIOB
TCP LanInternet 144.98.85.8:20427 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:17, bytes 384914, flags UIOB
TCP LanInternet 144.98.85.8:20408 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:02, bytes 20550, flags UIOB
TCP LanInternet 144.98.85.8:20389 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:44, bytes 18608, flags UIOB
TCP LanInternet 144.98.85.8:20370 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:44, bytes 18606, flags UIOB
TCP LanInternet 144.98.85.8:20350 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:44, bytes 18267, flags UIOB
TCP LanInternet 144.98.85.8:20330 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:44, bytes 18295, flags UIOB
<--- More --->
TCP LanInternet 144.98.85.8:20303 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:44, bytes 18614, flags UIOB
TCP LanInternet 80.78.0.155:7475 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:06, bytes 306296, flags UIOB
TCP LanInternet 147.89.224.75:63423 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:55, bytes 20171, flags UIOB
TCP LanInternet 147.89.224.75:54472 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:56, bytes 20109, flags UIOB
TCP LanInternet 147.89.224.75:54840 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:54, bytes 20161, flags UIOB
TCP LanInternet 147.89.224.75:52087 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:54, bytes 20132, flags UIOB
TCP LanInternet 147.89.224.75:52014 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:56, bytes 20113, flags UIOB
TCP LanInternet 147.89.224.75:61526 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:27, bytes 27199, flags UIOB
TCP LanInternet 147.89.224.75:63163 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:55, bytes 20193, flags UIOB
TCP LanInternet 147.89.224.75:60861 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:54, bytes 20104, flags UIOB
TCP LanInternet 147.89.224.75:51921 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:54, bytes 20169, flags UIOB
TCP LanInternet 147.89.224.75:55448 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:54, bytes 20155, flags UIOB
TCP LanInternet 147.89.224.75:49862 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:54, bytes 20084, flags UIOB
TCP LanInternet 147.89.224.75:52817 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:55, bytes 20134, flags UIOB
TCP LanInternet 147.89.224.75:51444 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:57, bytes 20127, flags UIOB
TCP LanInternet 147.89.224.75:54718 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:55, bytes 20101, flags UIOB
TCP LanInternet 147.89.224.75:52616 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:08, bytes 20102, flags UIOB
TCP LanInternet 147.89.224.75:54301 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:08, bytes 20139, flags UIOB
TCP LanInternet 147.89.224.75:58126 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:17, bytes 36756, flags UIOB
TCP LanInternet 147.89.224.75:57090 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:17, bytes 288799, flags UIOB
TCP LanInternet 147.89.224.75:56099 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:03, bytes 20792, flags UIOB
TCP LanInternet 195.47.211.7:53416 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:17, bytes 167102, flags UIOB
TCP LanInternet 195.47.211.7:2894 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:17, bytes 166888, flags UIOB
TCP LanInternet 194.121.48.2:20433 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:06, bytes 169320, flags UIOB
<--- More --->
TCP LanInternet 195.47.211.7:53392 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:22, bytes 171291, flags UIOB
TCP LanInternet 194.121.48.2:44016 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:20, bytes 178550, flags UIOB
TCP LanInternet 145.46.220.6:59110 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:26, bytes 305123, flags UIOB
TCP LanInternet 213.244.25.123:52879 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:26, bytes 194751, flags UIOB
TCP LanInternet 213.244.25.123:35509 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:26, bytes 4910526, flags UIOB
TCP LanInternet 77.74.248.129:25609 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:15, bytes 249558, flags UIOB
TCP LanInternet 205.228.82.172:57870 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:12, bytes 399370, flags UIOB
TCP LanInternet 205.228.82.172:53342 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:14, bytes 33028, flags UIOB
TCP LanInternet 205.228.82.138:57606 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:14, bytes 33097, flags UIOB
TCP LanInternet 205.228.82.172:51255 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:14, bytes 33080, flags UIOB
TCP LanInternet 205.228.82.138:65103 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:14, bytes 33200, flags UIOB
TCP LanInternet 205.228.82.172:58705 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:14, bytes 33082, flags UIOB
TCP LanInternet 188.202.52.57:60678 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:16, bytes 4921929, flags UIOB
TCP LanInternet 213.244.25.123:38452 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:26, bytes 417127, flags UIOB
TCP LanInternet 151.11.145.132:12567 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:26, bytes 4930458, flags UIOB
TCP LanInternet 212.161.10.8:39007 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:02, bytes 43612, flags UIOB
TCP LanInternet 212.161.10.8:18032 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:05, bytes 43277, flags UIOB
TCP LanInternet 212.161.10.8:12929 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:14, bytes 427072, flags UIOB
TCP LanInternet 212.161.10.8:38427 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:09, bytes 375516, flags UIOB
TCP LanInternet 212.161.10.8:21603 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:05, bytes 43531, flags UIOB
TCP LanInternet 212.161.10.8:17422 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:09, bytes 50733, flags UIOB
TCP LanInternet 212.161.10.8:63726 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:08, bytes 43278, flags UIOB
TCP LanInternet 212.161.10.8:26459 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:08, bytes 43641, flags UIOB
TCP LanInternet 212.161.10.8:34729 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:08, bytes 43528, flags UIOB
<--- More --->
TCP LanInternet 155.140.133.57:58000 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:26, bytes 411349, flags UIOB
TCP LanInternet 155.140.133.57:57976 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:22, bytes 43637, flags UIOB
TCP LanInternet 155.140.133.57:57940 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:21, bytes 43608, flags UIOB
TCP LanInternet 155.140.133.57:57908 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:22, bytes 43696, flags UIOB
TCP LanInternet 155.140.133.57:57875 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:22, bytes 43669, flags UIOB
TCP LanInternet 155.140.133.57:57848 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:21, bytes 43626, flags UIOB
TCP LanInternet 155.140.133.57:57838 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:22, bytes 43631, flags UIOB
TCP LanInternet 155.140.133.57:57825 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:22, bytes 43663, flags UIOB
TCP LanInternet 87.236.64.34:24587 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:16, bytes 416946, flags UIOB
TCP LanInternet 87.236.64.34:10394 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:17, bytes 51722, flags UIOB
TCP LanInternet 87.236.64.34:17709 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:23, bytes 51749, flags UIOB
TCP LanInternet 170.148.198.156:53963 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:26, bytes 436041, flags UIOB
TCP LanInternet 170.148.198.156:56914 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:16, bytes 58118, flags UIOB
TCP LanInternet 170.148.198.156:62158 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:26, bytes 58798, flags UIOB
TCP LanInternet 170.148.198.156:56088 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:16, bytes 58163, flags UIOB
TCP LanInternet 170.148.198.156:60094 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:42, bytes 75360, flags UIOB
TCP LanInternet 170.148.198.156:52331 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:20, bytes 58577, flags UIOB
TCP LanInternet 151.22.38.1:44308 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:26, bytes 432973, flags UIOB
TCP LanInternet 151.22.38.1:44285 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:46, bytes 60368, flags UIOB
TCP LanInternet 151.22.38.1:44275 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:03, bytes 60338, flags UIOB
TCP LanInternet 151.22.38.1:44264 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:08, bytes 60371, flags UIOB
TCP LanInternet 151.22.38.1:44256 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:01, bytes 60371, flags UIOB
TCP LanInternet 151.22.38.1:44240 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:19, bytes 65229, flags UIOB
TCP LanInternet 151.22.38.1:44227 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:57, bytes 61846, flags UIOB
<--- More --->
TCP LanInternet 151.22.38.1:44211 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:15, bytes 60381, flags UIOB
TCP LanInternet 151.22.38.1:44200 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:20, bytes 60295, flags UIOB
TCP LanInternet 151.22.38.1:44192 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:25, bytes 60358, flags UIOB
TCP LanInternet 151.22.38.1:44182 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:30, bytes 60366, flags UIOB
TCP LanInternet 151.22.38.1:44164 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:35, bytes 60412, flags UIOB
TCP LanInternet 151.22.38.1:44148 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:39, bytes 60428, flags UIOB
TCP LanInternet 151.22.38.1:44134 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:44, bytes 60365, flags UIOB
TCP LanInternet 151.22.38.1:44121 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:34, bytes 61801, flags UIOB
TCP LanInternet 151.22.38.1:44111 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:06, bytes 60443, flags UIOB
TCP LanInternet 151.22.38.1:44100 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:10, bytes 60341, flags UIOB
TCP LanInternet 151.22.38.1:44090 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:03, bytes 60425, flags UIOB
TCP LanInternet 195.65.1.4:53628 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:30, bytes 469478, flags UIOB
TCP LanInternet 194.74.155.8:9060 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:30, bytes 482498, flags UIOB
TCP LanInternet 207.45.249.145:49412 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:11, bytes 466648, flags UIOB
TCP LanInternet 207.45.249.145:51242 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:10, bytes 80879, flags UIOB
TCP LanInternet 207.45.249.145:60672 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:10, bytes 81262, flags UIOB
TCP LanInternet 207.45.249.145:58506 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:10, bytes 81228, flags UIOB
TCP LanInternet 207.45.249.145:62566 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:10, bytes 81224, flags UIOB
TCP LanInternet 207.45.249.145:54050 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:10, bytes 80899, flags UIOB
TCP LanInternet 207.45.249.145:65239 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:10, bytes 80847, flags UIOB
TCP LanInternet 145.46.220.6:1415 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:30, bytes 496066, flags UIOB
TCP LanInternet 195.189.216.86:52775 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:31, bytes 95547, flags UIOB
TCP LanInternet 91.213.22.1:17535 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:02, bytes 96155, flags UIOB
TCP LanInternet 159.168.7.200:14959 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:54, bytes 94824, flags UIOB
<--- More --->
TCP LanInternet 89.111.73.141:54566 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:10, bytes 95049, flags UIOB
TCP LanInternet 195.65.1.4:40943 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:48, bytes 94447, flags UIOB
TCP LanInternet 89.111.73.141:63127 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:12, bytes 95170, flags UIOB
TCP LanInternet 91.213.22.1:17471 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:01, bytes 94345, flags UIOB
TCP LanInternet 91.213.22.1:17444 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:24, bytes 94761, flags UIOB
TCP LanInternet 193.8.222.12:54337 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:04, bytes 94136, flags UIOB
TCP LanInternet 89.111.73.141:58874 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:21, bytes 99952, flags UIOB
TCP LanInternet 195.65.1.4:40930 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:48, bytes 94524, flags UIOB
TCP LanInternet 159.168.7.200:14461 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:41, bytes 95309, flags UIOB
TCP LanInternet 91.213.22.1:17405 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:07, bytes 94358, flags UIOB
TCP LanInternet 134.146.0.20:40914 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:39, bytes 96749, flags UIOB
TCP LanInternet 194.209.217.130:20441 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:09, bytes 94281, flags UIOB
TCP LanInternet 89.111.73.141:55240 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:05, bytes 94964, flags UIOB
TCP LanInternet 193.8.222.12:54309 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:09, bytes 94885, flags UIOB
TCP LanInternet 87.116.28.148:30097 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:07, bytes 396158, flags UIOB
TCP LanInternet 159.168.7.200:14192 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:54, bytes 94966, flags UIOB
TCP LanInternet 217.86.182.29:4892 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:13, bytes 93940, flags UIOB
TCP LanInternet 91.220.4.145:31259 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:23, bytes 94821, flags UIOB
TCP LanInternet 195.65.1.4:40905 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:41, bytes 98026, flags UIOB
TCP LanInternet 91.213.22.1:17319 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:50, bytes 108553, flags UIOB
TCP LanInternet 193.8.222.12:54300 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:15, bytes 94128, flags UIOB
TCP LanInternet 159.168.7.200:14043 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:54, bytes 94830, flags UIOB
TCP LanInternet 159.168.7.200:14042 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:54, bytes 94861, flags UIOB
TCP LanInternet 159.168.7.200:14041 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:54, bytes 94860, flags UIOB
<--- More --->
TCP LanInternet 193.8.222.12:54299 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:15, bytes 94196, flags UIOB
TCP LanInternet 91.213.22.1:17310 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:23, bytes 96432, flags UIOB
TCP LanInternet 193.8.222.12:54297 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:16, bytes 94134, flags UIOB
TCP LanInternet 199.43.13.100:3557 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:11, bytes 94571, flags UIOB
TCP LanInternet 195.65.1.4:40901 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:10, bytes 98000, flags UIOB
TCP LanInternet 134.146.0.20:40892 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:18, bytes 94722, flags UIOB
TCP LanInternet 199.43.13.100:3332 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:15, bytes 98115, flags UIOB
TCP LanInternet 217.86.182.29:4891 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:18, bytes 93850, flags UIOB
TCP LanInternet 134.146.0.20:40890 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:18, bytes 94743, flags UIOB
TCP LanInternet 134.146.0.20:40888 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:18, bytes 94743, flags UIOB
TCP LanInternet 195.189.216.86:8012 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:20, bytes 94165, flags UIOB
TCP LanInternet 195.189.216.86:62811 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:20, bytes 94451, flags UIOB
TCP LanInternet 199.43.13.100:3091 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:14, bytes 94584, flags UIOB
TCP LanInternet 195.189.216.86:62994 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:20, bytes 94259, flags UIOB
TCP LanInternet 195.189.216.86:24982 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:20, bytes 94264, flags UIOB
TCP LanInternet 195.189.216.86:2744 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:20, bytes 94255, flags UIOB
TCP LanInternet 195.189.216.86:40202 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:20, bytes 94289, flags UIOB
TCP LanInternet 199.29.247.15:58381 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:19, bytes 94857, flags UIOB
TCP LanInternet 199.29.247.15:49305 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:19, bytes 509836, flags UIOB
TCP LanInternet 91.220.4.145:30865 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:18, bytes 525989, flags UIOB
TCP LanInternet 194.209.217.130:20260 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:24, bytes 94215, flags UIOB
TCP LanInternet 194.209.217.130:20258 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:25, bytes 94269, flags UIOB
TCP LanInternet 194.209.217.130:20257 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:47, bytes 95647, flags UIOB
TCP LanInternet 194.209.217.130:20256 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:33, bytes 94519, flags UIOB
<--- More --->
TCP LanInternet 194.209.217.130:20255 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:33, bytes 94546, flags UIOB
TCP LanInternet 194.209.217.130:20254 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:33, bytes 94517, flags UIOB
TCP LanInternet 194.209.217.130:20252 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:33, bytes 94228, flags UIOB
TCP LanInternet 194.209.217.130:20251 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:33, bytes 94479, flags UIOB
TCP LanInternet 194.209.217.130:20250 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:33, bytes 94393, flags UIOB
TCP LanInternet 194.209.217.130:20248 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:33, bytes 94545, flags UIOB
TCP LanInternet 194.209.217.130:20247 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:33, bytes 94291, flags UIOB
TCP LanInternet 193.8.222.12:54284 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:31, bytes 94085, flags UIOB
TCP LanInternet 91.213.22.1:17209 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:23, bytes 95716, flags UIOB
TCP LanInternet 89.111.73.141:62739 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:39, bytes 523190, flags UIOB
TCP LanInternet 89.111.73.141:50496 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:29, bytes 95112, flags UIOB
TCP LanInternet 213.156.61.78:22747 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:38, bytes 524495, flags UIOB
TCP LanInternet 195.65.1.4:40879 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:06, bytes 95849, flags UIOB
TCP LanInternet 195.65.1.4:40878 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:02, bytes 94654, flags UIOB
TCP LanInternet 193.8.222.12:54281 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:34, bytes 94113, flags UIOB
TCP LanInternet 91.213.22.1:17187 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:13, bytes 96237, flags UIOB
TCP LanInternet 193.8.222.12:54278 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:35, bytes 94254, flags UIOB
TCP LanInternet 194.209.217.130:20211 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:36, bytes 94280, flags UIOB
TCP LanInternet 194.209.217.130:20209 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:36, bytes 94322, flags UIOB
TCP LanInternet 194.209.217.130:20208 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:36, bytes 94340, flags UIOB
TCP LanInternet 194.209.217.130:20207 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:36, bytes 94304, flags UIOB
TCP LanInternet 194.209.217.130:20206 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:36, bytes 94270, flags UIOB
TCP LanInternet 194.209.217.130:20205 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:36, bytes 94353, flags UIOB
TCP LanInternet 194.209.217.130:20204 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:36, bytes 94308, flags UIOB
<--- More --->
TCP LanInternet 194.209.217.130:20203 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:36, bytes 94304, flags UIOB
TCP LanInternet 194.209.217.130:20202 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:36, bytes 94334, flags UIOB
TCP LanInternet 194.209.217.130:20201 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:36, bytes 94234, flags UIOB
TCP LanInternet 194.209.217.130:20200 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:13, bytes 94628, flags UIOB
TCP LanInternet 159.168.7.200:12914 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:02, bytes 94748, flags UIOB
TCP LanInternet 195.189.216.86:3770 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:39, bytes 508656, flags UIOB
TCP LanInternet 159.168.7.200:11371 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:38, bytes 94564, flags UIOB
TCP LanInternet 193.8.222.12:54273 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:36, bytes 94667, flags UIOB
TCP LanInternet 134.146.0.20:40882 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:38, bytes 510906, flags UIOB
TCP LanInternet 193.8.222.12:54272 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:38, bytes 94143, flags UIOB
TCP LanInternet 159.168.7.200:12790 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:38, bytes 94544, flags UIOB
TCP LanInternet 199.29.247.15:51612 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:38, bytes 94463, flags UIOB
TCP LanInternet 199.29.247.15:58636 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:38, bytes 94512, flags UIOB
TCP LanInternet 199.29.247.15:57046 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:38, bytes 94421, flags UIOB
TCP LanInternet 91.220.4.145:30566 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:34, bytes 94773, flags UIOB
TCP LanInternet 199.29.247.15:60102 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:38, bytes 94747, flags UIOB
TCP LanInternet 212.159.225.71:58811 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:25, bytes 94398, flags UIOB
TCP LanInternet 86.188.188.132:8868 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:32, bytes 94338, flags UIOB
TCP LanInternet 195.65.1.4:40870 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:28, bytes 95186, flags UIOB
TCP LanInternet 195.189.216.86:62795 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:49, bytes 94447, flags UIOB
TCP LanInternet 195.189.216.86:63895 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:28, bytes 95165, flags UIOB
TCP LanInternet 159.168.7.200:12603 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:39, bytes 534005, flags UIOB
TCP LanInternet 159.168.7.200:12565 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:42, bytes 94811, flags UIOB
TCP LanInternet 159.168.7.200:12554 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:42, bytes 94761, flags UIOB
<--- More --->
TCP LanInternet 159.168.7.200:12551 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:39, bytes 527990, flags UIOB
TCP LanInternet 199.43.12.100:52260 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:31, bytes 105059, flags UIOB
TCP LanInternet 159.168.7.200:12520 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:42, bytes 94458, flags UIOB
TCP LanInternet 159.168.7.200:12519 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:42, bytes 94543, flags UIOB
TCP LanInternet 159.168.7.200:12518 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:42, bytes 94613, flags UIOB
TCP LanInternet 159.168.7.200:12516 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:58, bytes 94900, flags UIOB
TCP LanInternet 159.168.7.200:12517 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:42, bytes 94777, flags UIOB
TCP LanInternet 212.159.225.71:58801 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:28, bytes 94681, flags UIOB
TCP LanInternet 159.168.7.200:11019 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:04, bytes 384384, flags UIOB
TCP LanInternet 193.8.222.12:54267 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:43, bytes 94125, flags UIOB
TCP LanInternet 193.8.222.12:54265 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:44, bytes 94104, flags UIOB
TCP LanInternet 159.168.7.200:10428 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:00, bytes 94530, flags UIOB
TCP LanInternet 86.188.188.132:22101 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:42, bytes 527328, flags UIOB
TCP LanInternet 212.159.225.71:58722 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:36, bytes 527036, flags UIOB
TCP LanInternet 193.8.222.12:54262 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:13, bytes 95093, flags UIOB
TCP LanInternet 194.209.217.130:20097 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:47, bytes 516914, flags UIOB
TCP LanInternet 86.188.188.132:13222 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:44, bytes 94221, flags UIOB
TCP LanInternet 195.65.1.4:40836 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:56, bytes 95353, flags UIOB
TCP LanInternet 91.213.22.1:17057 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:52, bytes 97456, flags UIOB
TCP LanInternet 91.213.22.1:17053 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:37, bytes 94290, flags UIOB
TCP LanInternet 193.8.222.12:54258 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:06, bytes 94138, flags UIOB
TCP LanInternet 199.43.12.100:50865 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:47, bytes 94531, flags UIOB
TCP LanInternet 212.159.225.71:58685 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:46, bytes 100802, flags UIOB
TCP LanInternet 194.209.217.130:19980 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:40, bytes 101391, flags UIOB
<--- More --->
TCP LanInternet 2.228.126.3:1118 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:17, bytes 391789, flags UIOB
TCP LanInternet 212.159.225.71:58684 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:42, bytes 94795, flags UIOB
TCP LanInternet 89.111.77.140:57999 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:10, bytes 95156, flags UIOB
TCP LanInternet 89.111.77.140:53061 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:10, bytes 95506, flags UIOB
TCP LanInternet 91.213.22.1:16894 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:10, bytes 114659, flags UIOB
TCP LanInternet 83.137.32.135:43352 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:06, bytes 504463, flags UIOB
TCP LanInternet 199.43.12.100:49592 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:00, bytes 95252, flags UIOB
TCP LanInternet 89.111.77.140:54376 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:32, bytes 96418, flags UIOB
TCP LanInternet 159.168.7.200:12192 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:06, bytes 94570, flags UIOB
TCP LanInternet 193.8.222.12:54233 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:03, bytes 519225, flags UIOB
TCP LanInternet 86.188.188.132:62556 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:47, bytes 94237, flags UIOB
TCP LanInternet 194.209.217.130:20005 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:00, bytes 95440, flags UIOB
TCP LanInternet 91.213.22.1:16971 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:38, bytes 513339, flags UIOB
TCP LanInternet 89.111.77.140:56103 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:12, bytes 95175, flags UIOB
TCP LanInternet 199.43.12.100:51410 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:47, bytes 535824, flags UIOB
TCP LanInternet 193.8.222.12:54238 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:09, bytes 94158, flags UIOB
TCP LanInternet 217.86.182.29:4890 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:03, bytes 503241, flags UIOB
TCP LanInternet 134.146.0.20:40870 LanOTCEXGROUP Trayportsrv01:11997, idle 0:00:56, bytes 94672, flags UIOB
TCP LanInternet 89.111.77.140:53468 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:58, bytes 97041, flags UIOB
TCP LanInternet 207.45.249.139:57097 LanOTCEXGROUP Trayportsrv01:443, idle 0:00:47, bytes 505368, flags UIOB
TCP LanInternet 80.169.216.189:50851 LanOTCEXGROUP 192.168.77.247:25, idle 0:00:45, bytes 5008, flags UfFrIOB
TCP LanInternet 193.252.22.210:27078 LanOTCEXGROUP 192.168.77.247:25, idle 0:02:07, bytes 7444, flags UfFrIOB
TCP LanInternet 171.68.227.73:61764 LanOTCEXGROUP 192.168.77.247:25, idle 0:07:47, bytes 8394, flags UfFrIOB
TCP LanInternet 80.169.216.89:34481 LanOTCEXGROUP 192.168.77.247:25, idle 0:08:17, bytes 5004, flags UfFrIOB
<--- More --->
TCP LanInternet 41.252.60.80:31974 LanOTCEXGROUP 192.168.77.247:25, idle 0:09:07, bytes 230, flags UfFROB
TCP LanInternet 80.12.242.132:45270 LanOTCEXGROUP 192.168.77.247:25, idle 0:09:12, bytes 81869, flags UfFrIOB
TCP LanInternet 192.168.217.37:60272 LanOTCEXGROUP 192.168.177.2:445, idle 0:00:47, bytes 24524, flags UIOB
TCP LanInternet 192.168.217.42:54587 LanOTCEXGROUP 192.168.177.2:445, idle 0:01:17, bytes 39529329, flags UIOB
TCP LanInternet 192.168.217.3:64413 LanOTCEXGROUP 192.168.77.2:445, idle 0:00:59, bytes 6176, flags UIOB
TCP LanInternet 192.168.217.52:58886 LanOTCEXGROUP 192.168.77.2:445, idle 0:01:05, bytes 5756, flags UIOB
TCP LanInternet dnshk:51937 LanOTCEXGROUP 192.168.77.2:445, idle 0:00:00, bytes 9099, flags UIOB
TCP LanInternet 192.168.217.3:64302 LanOTCEXGROUP 192.168.77.2:1030, idle 0:00:03, bytes 147954, flags UIOB
TCP LanInternet dnshk:55005 LanOTCEXGROUP 192.168.77.2:42, idle 0:02:40, bytes 363810, flags UIOB
TCP LanInternet dnshk:54176 LanOTCEXGROUP 192.168.77.2:1030, idle 0:00:28, bytes 44539104, flags UIOB
TCP LanInternet 90.84.146.218:50248 LanOTCEXGROUP 192.168.77.20:443, idle 0:00:00, bytes 855, flags UIOB
TCP LanInternet 80.214.4.176:53618 LanOTCEXGROUP 192.168.77.20:443, idle 0:00:37, bytes 823, flags UIOB
TCP LanInternet 82.124.100.126:53315 LanOTCEXGROUP 192.168.77.20:443, idle 0:01:04, bytes 823, flags UIOB
TCP LanInternet 178.100.203.76:50377 LanOTCEXGROUP 192.168.77.20:443, idle 0:01:07, bytes 839, flags UIOB
TCP LanInternet 90.84.146.227:55236 LanOTCEXGROUP 192.168.77.20:443, idle 0:01:52, bytes 3382, flags UIOB
TCP LanInternet 213.3.9.8:42462 LanOTCEXGROUP 192.168.77.20:443, idle 0:02:02, bytes 3382, flags UIOB
TCP LanInternet 213.55.131.48:56950 LanOTCEXGROUP 192.168.77.20:443, idle 0:02:04, bytes 3483, flags UIOB
TCP LanInternet 90.84.144.76:42712 LanOTCEXGROUP 192.168.77.20:443, idle 0:02:09, bytes 823, flags UIOB
TCP LanInternet 192.168.217.37:65510 LanOTCEXGROUP 192.168.77.20:54382, idle 0:00:31, bytes 72834, flags UIOB
TCP LanInternet 81.134.121.150:50124 LanOTCEXGROUP 192.168.77.20:443, idle 0:02:56, bytes 855, flags UIOB
TCP LanInternet 88.189.31.208:50558 LanOTCEXGROUP 192.168.77.20:443, idle 0:03:10, bytes 839, flags UIOB
TCP LanInternet 90.84.144.254:41408 LanOTCEXGROUP 192.168.77.20:443, idle 0:03:32, bytes 823, flags UIOB
TCP LanInternet 80.214.0.82:45071 LanOTCEXGROUP 192.168.77.20:443, idle 0:04:47, bytes 3483, flags UIOB
TCP LanInternet 90.84.144.219:42117 LanOTCEXGROUP 192.168.77.20:443, idle 0:04:58, bytes 3382, flags UIOB
<--- More --->
TCP LanInternet 90.84.146.217:34020 LanOTCEXGROUP 192.168.77.20:443, idle 0:06:10, bytes 3483, flags UIOB
TCP LanInternet 213.3.9.8:42413 LanOTCEXGROUP 192.168.77.20:443, idle 0:06:59, bytes 871, flags UIOB
TCP LanInternet 82.132.211.93:46781 LanOTCEXGROUP 192.168.77.20:443, idle 0:08:06, bytes 5024, flags UIOB
TCP LanInternet 202.4.201.58:24479 LanOTCEXGROUP 192.168.77.20:443, idle 0:08:12, bytes 839, flags UIOB
TCP LanInternet 90.84.146.215:50521 LanOTCEXGROUP 192.168.77.20:443, idle 0:08:22, bytes 3531, flags UIOB
TCP LanInternet 84.103.143.225:50982 LanOTCEXGROUP 192.168.77.20:443, idle 0:09:30, bytes 940, flags UIOB
TCP LanInternet 90.84.146.211:37481 LanOTCEXGROUP 192.168.77.20:443, idle 0:10:07, bytes 839, flags UIOB
TCP LanInternet 81.93.24.34:52587 LanOTCEXGROUP 192.168.77.20:443, idle 0:21:02, bytes 3867, flags UIOB
TCP LanInternet 80.254.166.250:56244 LanOTCEXGROUP 192.168.77.20:443, idle 0:00:19, bytes 37204, flags UIOB
TCP LanInternet 192.168.217.17:49764 LanOTCEXGROUP 192.168.77.20:443, idle 0:00:13, bytes 79328, flags UIOB
TCP LanInternet 192.168.217.17:49762 LanOTCEXGROUP 192.168.77.20:443, idle 0:00:18, bytes 555217, flags UIOB
TCP LanInternet 192.168.217.17:49743 LanOTCEXGROUP 192.168.77.20:54382, idle 0:00:48, bytes 8792790, flags UIOB
TCP LanInternet 192.168.217.53:65298 LanOTCEXGROUP 192.168.77.20:54382, idle 0:00:48, bytes 347377, flags UIOB
TCP LanInternet 192.168.217.53:65296 LanOTCEXGROUP 192.168.77.20:54382, idle 0:00:48, bytes 680708, flags UIOB
TCP LanInternet 192.168.217.42:63152 LanOTCEXGROUP 192.168.77.20:54382, idle 0:00:54, bytes 2821638, flags UIOB
TCP LanInternet 192.168.217.42:63146 LanOTCEXGROUP 192.168.77.20:54382, idle 0:00:48, bytes 1405848, flags UIOB
TCP LanInternet 91.135.234.165:0 LanOTCEXGROUP 192.168.77.15:4839, idle 0:00:00, bytes 0, flags i
TCP LanInternet 192.168.217.52:58885 LanOTCEXGROUP 192.168.77.1:445, idle 0:01:17, bytes 4827, flags UIOB
TCP LanInternet 192.168.217.3:60424 LanOTCEXGROUP 192.168.77.1:49159, idle 0:01:07, bytes 142722, flags UIOB
TCP LanInternet dnshk:55004 LanOTCEXGROUP 192.168.77.1:42, idle 0:02:45, bytes 281406, flags UIOB
TCP LanInternet dnshk:54326 LanOTCEXGROUP 192.168.177.3:49158, idle 0:00:31, bytes 26725766, flags UIOB
TCP LanInternet 192.168.217.3:56835 LanOTCEXGROUP 192.168.177.3:49158, idle 0:03:13, bytes 26707155, flags UIOB
TCP LanInternet dnshk:52167 LanOTCEXGROUP 192.168.77.32:49155, idle 0:00:03, bytes 17780, flags UIOB
TCP LanInternet dnshk:52087 LanOTCEXGROUP 192.168.77.32:49155, idle 0:01:51, bytes 3480, flags UIOB
<--- More --->
TCP LanInternet 192.168.217.3:56814 LanOTCEXGROUP 192.168.77.32:49155, idle 0:00:06, bytes 100626814, flags UIOB
TCP LanInternet 66.220.151.74:80 LanOTCEXGROUP 192.168.97.67:57536, idle 0:00:10, bytes 38858, flags UIOX
TCP LanInternet 66.220.151.86:80 LanOTCEXGROUP 192.168.77.66:64668, idle 0:00:21, bytes 41440, flags UIOX
TCP LanInternet 66.220.151.86:80 LanOTCEXGROUP 192.168.77.66:64667, idle 0:00:21, bytes 41436, flags UIOX
TCP LanInternet 66.220.151.86:80 LanOTCEXGROUP 192.168.77.66:64666, idle 0:00:21, bytes 41435, flags UIOX
TCP LanInternet 66.220.151.86:443 LanOTCEXGROUP 192.168.97.117:56015, idle 0:00:10, bytes 150441, flags UIO
TCP LanInternet 194.78.100.198:443 LanOTCEXGROUP 192.168.77.166:54840, idle 0:00:20, bytes 31653529, flags UIO
TCP LanInternet 85.233.59.80:80 LanOTCEXGROUP 192.168.87.140:55780, idle 0:01:58, bytes 12704276, flags UIOX
TCP LanInternet 91.188.68.25:80 LanOTCEXGROUP 192.168.77.166:58695, idle 0:00:10, bytes 1748, flags UIOX
UDP LanInternet 70.166.88.168:23166 LanOTCEXGROUP 192.168.117.23:23231, idle 0:01:46, bytes 133, flags -
UDP LanInternet 203.145.121.218:443 LanOTCEXGROUP 192.168.117.166:19552, idle 0:00:03, bytes 44, flags -
TCP LanInternet 46.137.171.9:80 LanOTCEXGROUP 192.168.97.208:60113, idle 0:02:37, bytes 3241, flags UFRIOX
TCP LanInternet 46.137.171.9:80 LanOTCEXGROUP 192.168.97.208:60112, idle 0:02:39, bytes 4136, flags UFRIOX
TCP LanInternet 194.78.100.137:80 LanOTCEXGROUP 192.168.97.124:53851, idle 0:00:45, bytes 234060, flags UIOX
TCP LanInternet 194.78.100.137:80 LanOTCEXGROUP 192.168.97.208:60268, idle 0:00:34, bytes 7730, flags UIOX
TCP LanInternet 194.78.100.137:80 LanOTCEXGROUP 192.168.97.208:60267, idle 0:01:03, bytes 7137, flags UIOX
TCP LanInternet 194.78.100.137:80 LanOTCEXGROUP 192.168.97.208:60266, idle 0:00:35, bytes 10703, flags UIOX
TCP LanInternet 194.78.100.137:80 LanOTCEXGROUP 192.168.77.83:1873, idle 0:09:29, bytes 3181, flags UFRIOX
TCP LanInternet 69.171.228.40:80 LanOTCEXGROUP 192.168.77.147:3776, idle 0:00:12, bytes 8745, flags UIOX
TCP LanInternet 69.171.228.40:80 LanOTCEXGROUP 192.168.77.147:3773, idle 0:00:12, bytes 19908, flags UIOX
TCP LanInternet 69.171.228.40:80 LanOTCEXGROUP 192.168.77.66:49486, idle 0:00:15, bytes 14565, flags UIOX
TCP LanInternet 69.171.228.40:80 LanOTCEXGROUP 192.168.97.219:63849, idle 0:00:21, bytes 17638, flags UIOX
TCP LanInternet 69.171.228.40:80 LanOTCEXGROUP 192.168.77.166:58689, idle 0:00:22, bytes 8868, flags UIOX
TCP LanInternet 69.171.228.40:80 LanOTCEXGROUP 192.168.77.166:58688, idle 0:00:22, bytes 8870, flags UIOX
<--- More --->
TCP LanInternet 69.171.228.40:80 LanOTCEXGROUP 192.168.77.166:58687, idle 0:00:22, bytes 8600, flags UIOX
TCP LanInternet 69.171.228.40:80 LanOTCEXGROUP 192.168.77.166:58686, idle 0:00:22, bytes 8908, flags UIOX
TCP LanInternet 69.171.228.40:80 LanOTCEXGROUP 192.168.77.166:58685, idle 0:00:22, bytes 8876, flags UIOX
TCP LanInternet 69.171.228.40:80 LanOTCEXGROUP 192.168.77.166:58683, idle 0:00:22, bytes 20718, flags UIOX
TCP LanInternet 69.171.228.40:443 LanOTCEXGROUP 192.168.77.62:53746, idle 0:00:42, bytes 5347, flags UIO
TCP LanInternet 69.171.228.40:443 LanOTCEXGROUP 192.168.77.62:53733, idle 0:00:42, bytes 31909, flags UIO
TCP LanInternet 69.171.228.40:80 LanOTCEXGROUP 192.168.77.138:54046, idle 0:01:00, bytes 2420, flags UIOX
TCP LanInternet 69.171.228.40:443 LanOTCEXGROUP 192.168.77.62:53723, idle 0:00:42, bytes 19060, flags UIO
TCP LanInternet 69.171.228.40:80 LanOTCEXGROUP 192.168.97.178:49923, idle 0:01:25, bytes 25723, flags UIOX
TCP LanInternet 207.46.0.104:80 LanOTCEXGROUP 192.168.77.147:3735, idle 0:00:15, bytes 9422, flags UIOX
TCP LanInternet 94.127.72.180:80 LanOTCEXGROUP 192.168.97.195:55386, idle 0:00:37, bytes 6656, flags UIOX
TCP LanInternet 94.127.72.180:80 LanOTCEXGROUP 192.168.97.195:55387, idle 0:00:45, bytes 6669, flags UIOX
TCP LanInternet 94.127.72.180:80 LanOTCEXGROUP 192.168.97.195:55385, idle 0:00:45, bytes 4873, flags UIOX
TCP LanInternet 94.127.72.180:80 LanOTCEXGROUP 192.168.97.195:55375, idle 0:00:45, bytes 3734, flags UIOX
TCP LanInternet 94.127.72.180:80 LanOTCEXGROUP 192.168.97.52:58734, idle 0:07:37, bytes 11413, flags UFRIOX
TCP LanInternet 94.127.72.180:80 LanOTCEXGROUP 192.168.97.52:58735, idle 0:07:37, bytes 7431, flags UFRIOX
TCP LanInternet 94.127.72.180:80 LanOTCEXGROUP 192.168.97.52:58725, idle 0:07:37, bytes 2851, flags UFRIOX
TCP LanInternet 66.220.158.53:443 LanOTCEXGROUP 192.168.77.153:2363, idle 0:00:12, bytes 11510, flags UIO
TCP LanInternet 66.220.158.53:80 LanOTCEXGROUP 192.168.97.208:60114, idle 0:03:02, bytes 20794, flags UFRIOX
TCP LanInternet 213.146.189.205:12350 LanOTCEXGROUP 192.168.117.166:52631, idle 0:00:52, bytes 1546, flags UIO
TCP LanInternet 66.196.66.212:80 LanOTCEXGROUP 192.168.77.62:53701, idle 0:03:53, bytes 50839, flags UFRIOX
TCP LanInternet 64.12.28.151:443 LanOTCEXGROUP 192.168.77.70:61627, idle 0:03:09, bytes 585086, flags UIO
TCP LanInternet 111.221.96.251:80 LanOTCEXGROUP 192.168.77.166:58691, idle 0:00:28, bytes 1664, flags UIOX
TCP LanInternet 83.231.216.140:80 LanOTCEXGROUP 192.168.77.72:3503, idle 0:00:01, bytes 6519, flags UIOX
<--- More --->
TCP LanInternet 83.231.216.140:80 LanOTCEXGROUP 192.168.77.66:49530, idle 0:00:01, bytes 135939, flags UIOX
TCP LanInternet 83.231.216.140:80 LanOTCEXGROUP 192.168.97.111:3695, idle 0:00:03, bytes 50656, flags UIOX
TCP LanInternet 83.231.216.140:80 LanOTCEXGROUP 192.168.77.196:55719, idle 0:00:08, bytes 313472, flags UIOX
TCP LanInternet 83.231.216.140:80 LanOTCEXGROUP 192.168.77.140:61980, idle 0:00:01, bytes 185131, flags UIOX
TCP LanInternet 83.231.216.140:80 LanOTCEXGROUP 192.168.97.73:58518, idle 0:00:05, bytes 459091, flags UIOX
TCP LanInternet 83.231.216.140:80 LanOTCEXGROUP 192.168.77.144:59787, idle 0:00:13, bytes 272562, flags UIOX
TCP LanInternet 83.231.216.140:80 LanOTCEXGROUP 192.168.97.59:52816, idle 0:00:00, bytes 252584, flags UIOX
TCP LanInternet 83.231.216.140:80 LanOTCEXGROUP 192.168.97.118:54169, idle 0:00:00, bytes 874121, flags UIOX
TCP LanInternet 83.231.216.140:80 LanOTCEXGROUP 192.168.77.88:4644, idle 0:00:01, bytes 511814, flags UIOX
TCP LanInternet 83.231.216.140:80 LanOTCEXGROUP 192.168.97.148:1245, idle 0:00:12, bytes 2199777, flags UIOX
TCP LanInternet 83.231.216.140:80 LanOTCEXGROUP 192.168.77.196:55701, idle 0:00:10, bytes 466337, flags UIOX
TCP LanInternet 72.46.233.201:80 LanOTCEXGROUP 192.168.77.147:3662, idle 0:00:04, bytes 59401, flags UIOX
TCP LanInternet 72.46.233.201:80 LanOTCEXGROUP 192.168.77.82:51769, idle 0:00:04, bytes 616126, flags UIOX
TCP LanInternet 213.205.104.165:80 LanOTCEXGROUP 192.168.77.189:2946, idle 0:00:13, bytes 1561, flags UFRIOX
TCP LanInternet 91.198.174.224:80 LanOTCEXGROUP 192.168.77.74:4155, idle 0:00:08, bytes 4283, flags UIOX
TCP LanInternet 91.198.174.224:80 LanOTCEXGROUP 192.168.77.74:4151, idle 0:00:08, bytes 8577, flags UIOX
TCP LanInternet 67.195.186.86:23 LanOTCEXGROUP 192.168.97.35:54151, idle 0:00:09, bytes 557167, flags UIO
TCP LanInternet 173.201.149.1:80 LanOTCEXGROUP 192.168.97.173:57904, idle 0:02:24, bytes 2088, flags UFRIOX
TCP LanInternet 173.201.149.1:80 LanOTCEXGROUP 192.168.97.173:57903, idle 0:02:24, bytes 2336, flags UFRIOX
TCP LanInternet 173.201.149.1:80 LanOTCEXGROUP 192.168.97.173:57902, idle 0:02:24, bytes 46895, flags UFRIOX
TCP LanInternet 173.201.149.1:80 LanOTCEXGROUP 192.168.97.173:57901, idle 0:02:24, bytes 6011, flags UFRIOX
TCP LanInternet 173.201.149.1:80 LanOTCEXGROUP 192.168.97.173:57900, idle 0:02:24, bytes 26001, flags UFRIOX
TCP LanInternet 173.201.149.1:80 LanOTCEXGROUP 192.168.97.173:57898, idle 0:02:24, bytes 41040, flags UFRIOX
TCP LanInternet 98.138.26.86:5050 LanOTCEXGROUP 192.168.117.24:56873, idle 0:00:00, bytes 9149, flags UIO
<--- More --->
TCP LanInternet 157.55.15.32:80 LanOTCEXGROUP 192.168.97.219:63826, idle 0:00:33, bytes 1470, flags UIOX
TCP LanInternet 84.100.158.97:18076 LanOTCEXGROUP 192.168.117.166:51130, idle 0:01:40, bytes 145567, flags UIO
TCP LanInternet 69.171.242.14:443 LanOTCEXGROUP 192.168.97.117:57053, idle 0:00:51, bytes 4865, flags UIO
TCP LanInternet 216.23.226.194:2189 LanOTCEXGROUP 192.168.117.24:49297, idle 0:00:00, bytes 1627126230, flags UIO
TCP LanInternet dnshk:49155 LanOTCEXGROUP 192.168.77.32:64815, idle 0:00:12, bytes 4370, flags UIO
TCP LanInternet dnshk:445 LanOTCEXGROUP 192.168.77.20:25271, idle 0:00:55, bytes 6683, flags UIO
TCP LanInternet dnshk:3268 LanOTCEXGROUP 192.168.77.20:39997, idle 0:08:38, bytes 13206, flags UIO
TCP LanInternet dnshk:3268 LanOTCEXGROUP 192.168.77.20:34760, idle 0:01:13, bytes 1372436, flags UIO
TCP LanInternet dnshk:3268 LanOTCEXGROUP 192.168.77.20:34752, idle 0:01:45, bytes 854671, flags UIO
TCP LanInternet dnshk:3268 LanOTCEXGROUP 192.168.77.20:34697, idle 0:00:31, bytes 17793146, flags UIO
TCP LanInternet dnshk:3268 LanOTCEXGROUP 192.168.77.20:34694, idle 0:00:23, bytes 258901, flags UIO
TCP LanInternet dnshk:3268 LanOTCEXGROUP 192.168.77.20:34686, idle 0:01:07, bytes 317021, flags UIO
TCP LanInternet dnshk:3268 LanOTCEXGROUP 192.168.77.20:34682, idle 0:01:11, bytes 457818, flags UIO
TCP LanInternet dnshk:3268 LanOTCEXGROUP 192.168.77.20:34676, idle 0:00:27, bytes 1728021, flags UIO
TCP LanInternet dnshk:3268 LanOTCEXGROUP 192.168.77.20:34671, idle 0:00:12, bytes 5892420, flags UIO
TCP LanInternet dnshk:3268 LanOTCEXGROUP 192.168.77.20:34629, idle 0:00:01, bytes 2312354, flags UIO
TCP LanInternet dnshk:3268 LanOTCEXGROUP 192.168.77.20:34627, idle 0:00:11, bytes 12402831, flags UIO
TCP LanInternet dnshk:3268 LanOTCEXGROUP 192.168.77.20:34618, idle 0:00:00, bytes 9649182, flags UIO
TCP LanInternet dnshk:42 LanOTCEXGROUP 192.168.77.2:21784, idle 0:16:36, bytes 76358, flags UIO
TCP LanInternet dnshk:42 LanOTCEXGROUP 192.168.77.1:54232, idle 0:27:17, bytes 77566, flags UIO
TCP LanInternet dnshk:49155 LanOTCEXGROUP 192.168.177.3:54734, idle 0:03:13, bytes 660950, flags UIO
TCP LanInternet dnshk:49155 LanOTCEXGROUP 192.168.77.2:21295, idle 0:00:06, bytes 2123736, flags UIO
TCP LanInternet 217.174.203.4:80 LanOTCEXGROUP 192.168.97.52:58985, idle 0:00:00, bytes 49186, flags UIOX
TCP LanInternet 217.174.203.4:80 LanOTCEXGROUP 192.168.97.52:58980, idle 0:00:08, bytes 49186, flags UFRIOX
<--- More --->
TCP LanInternet 65.54.89.41:80 LanOTCEXGROUP 192.168.97.122:57197, idle 0:00:01, bytes 4699, flags UIOX
TCP LanInternet 74.125.230.89:80 LanOTCEXGROUP 192.168.77.58:53292, idle 0:02:22, bytes 2708, flags UFRIOX
UDP LanInternet 134.129.80.239:47368 LanOTCEXGROUP 192.168.117.23:23231, idle 0:01:52, bytes 50, flags -
TCP LanInternet 65.55.57.251:80 LanOTCEXGROUP 192.168.77.64:58547, idle 0:02:03, bytes 2772, flags UFRIOX
TCP LanInternet 65.55.57.251:80 LanOTCEXGROUP 192.168.77.53:57492, idle 0:02:33, bytes 837, flags UFRIOX
TCP LanInternet 65.55.57.251:80 LanOTCEXGROUP 192.168.97.208:60083, idle 0:03:42, bytes 3302, flags UFRIOX
TCP LanInternet 65.55.57.251:80 LanOTCEXGROUP 192.168.77.70:49860, idle 0:07:42, bytes 2758, flags UFRIOX
TCP LanInternet 66.220.151.89:80 LanOTCEXGROUP 192.168.77.127:4522, idle 0:00:23, bytes 10659, flags UIOX
TCP LanInternet 66.220.151.89:80 LanOTCEXGROUP 192.168.97.52:58373, idle 0:00:01, bytes 62856, flags UIOX
UDP LanInternet 86.144.237.205:59747 LanOTCEXGROUP 192.168.117.23:23231, idle 0:00:02, bytes 249, flags -
TCP LanInternet 209.85.169.95:80 LanOTCEXGROUP 192.168.77.166:58710, idle 0:00:03, bytes 273358, flags UIOX
TCP LanInternet 209.85.169.95:80 LanOTCEXGROUP 192.168.97.35:53822, idle 0:00:23, bytes 72912, flags UIOX
TCP LanInternet 209.85.169.95:80 LanOTCEXGROUP 192.168.97.219:63863, idle 0:00:28, bytes 272248, flags UIOX
TCP LanInternet 209.85.169.95:80 LanOTCEXGROUP 192.168.97.92:57489, idle 0:01:03, bytes 272175, flags UIOX
TCP LanInternet 83.231.216.216:80 LanOTCEXGROUP 192.168.97.118:54206, idle 0:09:40, bytes 203861, flags UFRIOX
TCP LanInternet 83.231.216.216:80 LanOTCEXGROUP 192.168.97.118:54203, idle 0:09:41, bytes 28137, flags UFRIOX
TCP LanInternet 83.231.216.216:80 LanOTCEXGROUP 192.168.97.118:62118, idle 0:00:58, bytes 77455, flags UIOX
TCP LanInternet 205.203.140.1:80 LanOTCEXGROUP 192.168.77.147:3690, idle 0:00:30, bytes 14931, flags UIOX
TCP LanInternet 205.203.140.1:80 LanOTCEXGROUP 192.168.77.147:3689, idle 0:00:31, bytes 8639, flags UIOX
TCP LanInternet 205.203.140.1:80 LanOTCEXGROUP 192.168.77.147:3688, idle 0:00:30, bytes 70296, flags UIOX
TCP LanInternet 205.203.140.1:80 LanOTCEXGROUP 192.168.77.147:3687, idle 0:00:30, bytes 13031, flags UIOX
TCP LanInternet 205.203.140.1:80 LanOTCEXGROUP 192.168.77.147:3665, idle 0:00:31, bytes 169106, flags UIOX
TCP LanInternet 205.203.140.1:80 LanOTCEXGROUP 192.168.77.147:3503, idle 0:00:29, bytes 1495283, flags UIOX
TCP LanInternet 209.85.169.102:80 LanOTCEXGROUP 192.168.77.66:49635, idle 0:00:06, bytes 1357, flags UIOX
<--- More --->
TCP LanInternet 209.85.169.102:80 LanOTCEXGROUP 192.168.97.52:58986, idle 0:00:08, bytes 2924, flags UIOX
TCP LanInternet 209.85.169.102:443 LanOTCEXGROUP 192.168.77.58:53314, idle 0:03:52, bytes 6545, flags UIO
TCP LanInternet 209.85.169.102:80 LanOTCEXGROUP 192.168.97.52:58717, idle 0:07:17, bytes 34049, flags UFRIOX
TCP LanInternet 209.85.169.102:80 LanOTCEXGROUP 192.168.77.83:1788, idle 0:09:46, bytes 67987, flags UFRIOX
TCP LanInternet 85.234.222.177:80 LanOTCEXGROUP 192.168.97.219:64015, idle 0:00:23, bytes 1688, flags UIOX
UDP LanInternet 98.211.95.192:38481 LanOTCEXGROUP 192.168.117.23:23231, idle 0:00:25, bytes 132, flags -
TCP LanInternet 46.226.152.14:80 LanOTCEXGROUP 192.168.77.166:58928, idle 0:00:00, bytes 0, flags UX
TCP LanInternet 216.23.225.132:2194 LanOTCEXGROUP 192.168.117.24:49292, idle 0:00:08, bytes 1640798, flags UIO
TCP LanInternet 194.78.100.136:80 LanOTCEXGROUP 192.168.97.92:57762, idle 0:00:02, bytes 3020, flags UIOX
TCP LanInternet 194.78.100.136:80 LanOTCEXGROUP 192.168.97.195:55402, idle 0:00:53, bytes 2898, flags UIOX
TCP LanInternet 64.4.34.217:80 LanOTCEXGROUP 192.168.77.157:50420, idle 0:00:14, bytes 70738, flags UIOX
TCP LanInternet 66.235.132.232:80 LanOTCEXGROUP 192.168.87.140:61938, idle 0:01:51, bytes 4106, flags UFRIOX
TCP LanInternet 66.220.151.92:443 LanOTCEXGROUP 192.168.77.140:58901, idle 0:00:04, bytes 55740, flags UIO
TCP LanInternet 66.220.151.92:443 LanOTCEXGROUP 192.168.77.157:50313, idle 0:00:12, bytes 187404, flags UIO
TCP LanInternet 194.78.100.193:80 LanOTCEXGROUP 192.168.77.66:49633, idle 0:00:07, bytes 774, flags UFRIOX
TCP LanInternet 194.78.100.193:80 LanOTCEXGROUP 192.168.77.147:3777, idle 0:00:28, bytes 11811, flags UIOX
TCP LanInternet 194.78.100.193:80 LanOTCEXGROUP 192.168.97.219:63856, idle 0:00:37, bytes 16058, flags UIOX
TCP LanInternet 194.78.100.193:80 LanOTCEXGROUP 192.168.97.219:63855, idle 0:00:37, bytes 15220, flags UIOX
TCP LanInternet 194.78.100.193:80 LanOTCEXGROUP 192.168.97.219:63854, idle 0:00:37, bytes 161582, flags UIOX
TCP LanInternet 194.78.100.193:80 LanOTCEXGROUP 192.168.97.219:63850, idle 0:00:37, bytes 297440, flags UIOX
TCP LanInternet 194.78.100.193:80 LanOTCEXGROUP 192.168.97.195:55381, idle 0:00:53, bytes 59810, flags UIOX
TCP LanInternet 194.78.100.193:80 LanOTCEXGROUP 192.168.97.195:55379, idle 0:00:52, bytes 96448, flags UIOX
TCP LanInternet 194.78.100.193:80 LanOTCEXGROUP 192.168.97.195:55380, idle 0:00:52, bytes 294558, flags UIOX
TCP LanInternet 194.78.100.193:80 LanOTCEXGROUP 192.168.97.195:55378, idle 0:00:52, bytes 89693, flags UIOX
<--- More --->
TCP LanInternet 194.78.100.193:80 LanOTCEXGROUP 192.168.97.195:55362, idle 0:00:52, bytes 266161, flags UIOX
TCP LanInternet 194.78.100.193:80 LanOTCEXGROUP 192.168.77.58:53321, idle 0:02:22, bytes 21327, flags UFRIOX
TCP LanInternet 194.78.100.193:80 LanOTCEXGROUP 192.168.77.58:53320, idle 0:02:22, bytes 187780, flags UFRIOX
TCP LanInternet 194.78.100.193:80 LanOTCEXGROUP 192.168.97.208:60129, idle 0:03:11, bytes 25067, flags UFRIOX
TCP LanInternet 194.78.100.193:80 LanOTCEXGROUP 192.168.97.208:60128, idle 0:03:11, bytes 14860, flags UFRIOX
TCP LanInternet 194.78.100.193:80 LanOTCEXGROUP 192.168.97.208:60120, idle 0:03:11, bytes 64497, flags UFRIOX
TCP LanInternet 194.78.100.193:80 LanOTCEXGROUP 192.168.97.208:60119, idle 0:03:11, bytes 119206, flags UFRIOX
TCP LanInternet 194.78.100.193:80 LanOTCEXGROUP 192.168.97.208:60118, idle 0:03:11, bytes 152114, flags UFRIOX
TCP LanInternet 194.78.100.193:80 LanOTCEXGROUP 192.168.97.208:60117, idle 0:03:11, bytes 26611, flags UFRIOX
TCP LanInternet 194.78.100.193:80 LanOTCEXGROUP 192.168.97.208:60116, idle 0:03:12, bytes 38938, flags UFRIOX
TCP LanInternet 194.78.100.193:80 LanOTCEXGROUP 192.168.97.208:60115, idle 0:03:11, bytes 67569, flags UFRIOX
TCP LanInternet 194.78.100.193:80 LanOTCEXGROUP 192.168.77.83:1870, idle 0:09:53, bytes 284748, flags UFRIOX
TCP LanInternet 194.78.100.193:80 LanOTCEXGROUP 192.168.77.83:1868, idle 0:09:53, bytes 77295, flags UFRIOX
TCP LanInternet 194.78.100.193:80 LanOTCEXGROUP 192.168.77.83:1866, idle 0:09:53, bytes 158521, flags UFRIOX
TCP LanInternet 194.78.100.193:80 LanOTCEXGROUP 192.168.77.83:1867, idle 0:09:53, bytes 73384, flags UFRIOX
TCP LanInternet 209.85.148.103:80 LanOTCEXGROUP 192.168.97.174:2199, idle 0:06:56, bytes 0, flags UFRX
TCP LanInternet 209.85.148.103:80 LanOTCEXGROUP 192.168.97.174:2194, idle 0:07:05, bytes 0, flags UFRX
TCP LanInternet 209.85.148.103:80 LanOTCEXGROUP 192.168.97.174:2163, idle 0:07:29, bytes 0, flags UFRX
TCP LanInternet 209.85.148.103:80 LanOTCEXGROUP 192.168.97.174:2161, idle 0:07:37, bytes 0, flags UFRX
TCP LanInternet 69.171.228.19:443 LanOTCEXGROUP 192.168.77.62:53763, idle 0:00:01, bytes 1703, flags UIO
TCP LanInternet 69.171.228.19:443 LanOTCEXGROUP 192.168.77.62:53761, idle 0:00:02, bytes 9992, flags UIO
TCP LanInternet 69.171.228.19:443 LanOTCEXGROUP 192.168.77.62:53760, idle 0:00:02, bytes 8671, flags UIO
TCP LanInternet 69.171.228.19:443 LanOTCEXGROUP 192.168.77.62:53759, idle 0:00:02, bytes 8659, flags UIO
TCP LanInternet 69.171.228.19:443 LanOTCEXGROUP 192.168.77.62:53758, idle 0:00:01, bytes 8657, flags UIO
<--- More --->
TCP LanInternet 69.171.228.19:443 LanOTCEXGROUP 192.168.77.62:53757, idle 0:00:02, bytes 8645, flags UIO
TCP LanInternet 69.171.228.19:443 LanOTCEXGROUP 192.168.77.62:53756, idle 0:00:01, bytes 8656, flags UIO
TCP LanInternet 213.199.181.12:80 LanOTCEXGROUP 192.168.97.219:63827, idle 0:00:39, bytes 3575, flags UIOX
TCP LanInternet 69.171.229.37:80 LanOTCEXGROUP 192.168.77.127:4431, idle 0:00:05, bytes 263563, flags UIOX
TCP LanInternet 46.137.162.76:80 LanOTCEXGROUP 192.168.77.83:2198, idle 0:00:04, bytes 41259, flags UIOX
TCP LanInternet 46.137.162.76:80 LanOTCEXGROUP 192.168.97.219:63971, idle 0:00:32, bytes 130460, flags UIOX
TCP LanInternet 199.47.217.144:80 LanOTCEXGROUP PCVLAD:49633, idle 0:01:09, bytes 5311, flags UIOX
TCP LanInternet 194.78.100.169:80 LanOTCEXGROUP 192.168.97.219:64013, idle 0:00:31, bytes 3336, flags UIOX
TCP LanInternet 194.78.100.169:80 LanOTCEXGROUP 192.168.97.219:64012, idle 0:00:31, bytes 4199, flags UIOX
TCP LanInternet 194.78.100.169:80 LanOTCEXGROUP 192.168.97.219:64010, idle 0:00:31, bytes 3336, flags UIOX
TCP LanInternet 194.78.100.169:80 LanOTCEXGROUP 192.168.97.219:64009, idle 0:00:31, bytes 6640, flags UIOX
TCP LanInternet 194.78.100.169:80 LanOTCEXGROUP 192.168.97.219:64008, idle 0:00:31, bytes 26664, flags UIOX
TCP LanInternet 194.78.100.169:80 LanOTCEXGROUP 192.168.97.124:54026, idle 0:01:09, bytes 12180, flags UIOX
TCP LanInternet 69.171.227.44:80 LanOTCEXGROUP 192.168.97.100:4498, idle 0:00:50, bytes 38014, flags UIOX
TCP LanInternet 69.171.227.44:80 LanOTCEXGROUP 192.168.77.166:54879, idle 0:00:32, bytes 39462, flags UIOX
TCP LanInternet 66.220.151.79:80 LanOTCEXGROUP 192.168.97.216:53504, idle 0:00:12, bytes 40140, flags UIOX
UDP LanInternet 46.72.31.184:24178 LanOTCEXGROUP 192.168.117.23:23231, idle 0:00:28, bytes 146, flags -
TCP LanInternet 193.149.47.99:443 LanOTCEXGROUP 192.168.97.88:59873, idle 0:00:14, bytes 9367, flags UIO
TCP LanInternet 195.234.39.173:443 LanOTCEXGROUP 192.168.77.127:4642, idle 0:00:00, bytes 41522, flags UIO
TCP LanInternet 213.146.189.202:12350 LanOTCEXGROUP PCVLAD:63918, idle 0:01:12, bytes 2334, flags UIO
TCP LanInternet 91.135.234.165:443 LanOTCEXGROUP 192.168.77.144:59832, idle 0:00:01, bytes 57435, flags UIO
TCP LanInternet 217.109.67.132:80 LanOTCEXGROUP 192.168.77.58:53312, idle 0:02:30, bytes 55215, flags UFRIOX
TCP LanInternet 217.109.67.132:80 LanOTCEXGROUP 192.168.77.58:53311, idle 0:02:30, bytes 405488, flags UFRIOX
TCP LanInternet 217.109.67.132:80 LanOTCEXGROUP 192.168.77.58:53310, idle 0:02:30, bytes 74046, flags UFRIOX
<--- More --->
TCP LanInternet 217.109.67.132:80 LanOTCEXGROUP 192.168.77.58:53309, idle 0:02:29, bytes 137285, flags UFRIOX
TCP LanInternet 217.109.67.132:80 LanOTCEXGROUP 192.168.77.58:53307, idle 0:02:29, bytes 118796, flags UFRIOX
TCP LanInternet 217.109.67.132:80 LanOTCEXGROUP 192.168.77.58:53305, idle 0:02:29, bytes 165651, flags UFRIOX
TCP LanInternet 94.127.72.120:80 LanOTCEXGROUP 192.168.77.189:2940, idle 0:00:50, bytes 15335, flags UFRIOX
TCP LanInternet 94.127.72.120:80 LanOTCEXGROUP 192.168.77.189:2939, idle 0:00:50, bytes 20784, flags UFRIOX
TCP LanInternet 213.146.189.201:12350 LanOTCEXGROUP PCFIXEREDA:50625, idle 0:01:06, bytes 1624, flags UIO
TCP LanInternet 87.248.112.181:80 LanOTCEXGROUP 192.168.117.24:57788, idle 0:00:01, bytes 4059, flags UIOX
TCP LanInternet 216.23.234.120:2190 LanOTCEXGROUP 192.168.117.24:49301, idle 0:00:11, bytes 3986539, flags UIO
TCP LanInternet 216.23.234.120:2190 LanOTCEXGROUP 192.168.117.24:49295, idle 0:00:12, bytes 3220218, flags UIO
TCP LanInternet 66.220.151.84:80 LanOTCEXGROUP 192.168.97.184:63544, idle 0:00:16, bytes 108373, flags UIOX
TCP LanInternet 94.127.72.70:80 LanOTCEXGROUP 192.168.77.189:2895, idle 0:00:53, bytes 2054550, flags UFRIOX
TCP LanInternet 83.244.214.40:18247 LanOTCEXGROUP 192.168.77.141:2786, idle 0:00:00, bytes 438005, flags UIO
TCP LanInternet 83.244.214.40:18247 LanOTCEXGROUP 192.168.77.74:2704, idle 0:00:00, bytes 675956927, flags UIO
TCP LanInternet 83.244.214.40:18247 LanOTCEXGROUP 192.168.77.72:1562, idle 0:00:00, bytes 906170468, flags UIO
TCP LanInternet 66.220.149.47:443 LanOTCEXGROUP 192.168.77.127:4351, idle 0:00:35, bytes 49528, flags UIO
TCP LanInternet 67.195.187.253:5050 LanOTCEXGROUP 192.168.117.166:63119, idle 0:00:06, bytes 571852, flags UIO
TCP LanInternet 74.120.188.125:80 LanOTCEXGROUP 192.168.77.166:58701, idle 0:00:13, bytes 103253, flags UFRIOX
TCP LanInternet 74.125.230.91:80 LanOTCEXGROUP 192.168.77.83:2152, idle 0:00:05, bytes 55475, flags UIOX
TCP LanInternet 74.125.230.91:80 LanOTCEXGROUP 192.168.77.166:58934, idle 0:00:07, bytes 1551, flags UIOX
TCP LanInternet 74.125.230.91:80 LanOTCEXGROUP 192.168.77.166:58931, idle 0:00:07, bytes 6806, flags UIOX
TCP LanInternet 74.125.230.91:80 LanOTCEXGROUP 192.168.97.122:57200, idle 0:00:09, bytes 61072, flags UIOX
TCP LanInternet 74.125.230.91:80 LanOTCEXGROUP 192.168.97.122:57199, idle 0:00:09, bytes 8680, flags UIOX
TCP LanInternet 74.125.230.91:80 LanOTCEXGROUP 192.168.97.208:60354, idle 0:00:25, bytes 1224, flags UIOX
TCP LanInternet 74.125.230.91:80 LanOTCEXGROUP 192.168.97.208:60345, idle 0:00:29, bytes 2188, flags UIOX
<--- More --->
TCP LanInternet 74.125.230.91:80 LanOTCEXGROUP 192.168.97.35:53948, idle 0:00:32, bytes 1411, flags UIOX
TCP LanInternet 74.125.230.91:80 LanOTCEXGROUP 192.168.77.147:3765, idle 0:00:42, bytes 1829, flags UIOX
TCP LanInternet 74.125.230.91:80 LanOTCEXGROUP 192.168.77.147:3751, idle 0:00:43, bytes 3788, flags UIOX
TCP LanInternet 74.125.230.91:80 LanOTCEXGROUP 192.168.77.147:3750, idle 0:00:43, bytes 6827, flags UIOX
TCP LanInternet 74.125.230.91:80 LanOTCEXGROUP 192.168.77.147:3748, idle 0:00:43, bytes 1819, flags UIOX
TCP LanInternet 74.125.230.91:80 LanOTCEXGROUP 192.168.77.147:3749, idle 0:00:43, bytes 7324, flags UIOX
TCP LanInternet 74.125.230.91:80 LanOTCEXGROUP 192.168.97.219:63842, idle 0:00:52, bytes 793, flags UIOX
TCP LanInternet 74.125.230.91:80 LanOTCEXGROUP 192.168.77.166:58618, idle 0:00:57, bytes 99733, flags UIOX
TCP LanInternet 74.125.230.91:80 LanOTCEXGROUP 192.168.77.166:58617, idle 0:00:57, bytes 8527, flags UIOX
TCP LanInternet 74.125.230.91:443 LanOTCEXGROUP 192.168.97.88:59865, idle 0:00:18, bytes 9040, flags UIO
TCP LanInternet 74.125.230.91:80 LanOTCEXGROUP 192.168.77.58:53290, idle 0:02:35, bytes 2418, flags UFRIOX
TCP LanInternet 74.125.230.91:80 LanOTCEXGROUP 192.168.97.208:60108, idle 0:03:25, bytes 3678, flags UFRIOX
TCP LanInternet 194.78.100.176:80 LanOTCEXGROUP 192.168.97.58:2286, idle 0:00:08, bytes 2524, flags UIOX
UDP LanInternet 78.141.179.9:34035 LanOTCEXGROUP 192.168.117.23:23231, idle 0:01:59, bytes 51, flags -
TCP LanInternet 66.196.65.174:80 LanOTCEXGROUP 192.168.117.30:60688, idle 0:00:02, bytes 16717, flags UIOX
UDP LanInternet 213.106.162.247:56652 LanOTCEXGROUP 192.168.117.23:23231, idle 0:00:21, bytes 138, flags -
TCP LanInternet 199.47.217.146:80 LanOTCEXGROUP PCFIXEREDA:52380, idle 0:00:52, bytes 5341, flags UIOX
TCP LanInternet 69.171.242.39:80 LanOTCEXGROUP 192.168.97.58:2285, idle 0:00:08, bytes 4724, flags UIOX
TCP LanInternet 69.171.242.39:80 LanOTCEXGROUP 192.168.97.52:58928, idle 0:00:33, bytes 81033, flags UIOX
UDP LanInternet 149.5.45.8:43051 LanOTCEXGROUP 192.168.117.23:23231, idle 0:01:17, bytes 135, flags -
TCP LanInternet 94.23.228.77:80 LanOTCEXGROUP 192.168.97.209:2018, idle 0:00:00, bytes 15297, flags UIOX
TCP LanInternet 193.57.219.36:80 LanOTCEXGROUP 192.168.97.88:59927, idle 0:00:40, bytes 22612, flags UIOX
TCP LanInternet 193.57.219.36:80 LanOTCEXGROUP 192.168.97.88:59926, idle 0:00:23, bytes 24612, flags UIOX
TCP LanInternet 193.57.219.36:80 LanOTCEXGROUP 192.168.97.88:59910, idle 0:00:40, bytes 221285, flags UIOX
<--- More --->
TCP LanInternet 193.57.219.36:80 LanOTCEXGROUP 192.168.97.88:59862, idle 0:00:40, bytes 282295, flags UIOX
TCP LanInternet 193.57.219.36:80 LanOTCEXGROUP 192.168.97.88:59859, idle 0:00:40, bytes 158311, flags UIOX
TCP LanInternet 209.85.169.120:80 LanOTCEXGROUP 192.168.77.189:2968, idle 0:00:00, bytes 0, flags UX
TCP LanInternet 209.85.169.120:443 LanOTCEXGROUP 192.168.77.66:49592, idle 0:00:22, bytes 1240, flags UIO
TCP LanInternet 209.85.169.120:443 LanOTCEXGROUP 192.168.97.195:55434, idle 0:01:03, bytes 7304, flags UIO
TCP LanInternet 209.85.169.120:443 LanOTCEXGROUP 192.168.97.195:55430, idle 0:01:03, bytes 52312, flags UIO
TCP LanInternet 209.85.169.120:443 LanOTCEXGROUP 192.168.77.58:53316, idle 0:00:04, bytes 58979, flags UFRIO
TCP LanInternet 209.85.169.120:80 LanOTCEXGROUP 192.168.97.174:2236, idle 0:06:44, bytes 15949, flags UFRIOX
TCP LanInternet 209.85.169.120:80 LanOTCEXGROUP 192.168.77.83:1768, idle 0:09:56, bytes 118060, flags UFRIOX
TCP LanInternet 69.63.180.44:80 LanOTCEXGROUP 192.168.77.136:53743, idle 0:00:51, bytes 28894, flags UIOX
TCP LanInternet 69.63.180.44:80 LanOTCEXGROUP 192.168.77.138:53985, idle 0:00:41, bytes 54223, flags UIOX
TCP LanInternet 64.4.34.38:80 LanOTCEXGROUP 192.168.97.117:56331, idle 0:00:18, bytes 38099, flags UIOX
TCP LanInternet 195.24.247.162:80 LanOTCEXGROUP 192.168.97.195:55413, idle 0:01:05, bytes 4777, flags UIOX
TCP LanInternet 195.24.247.162:80 LanOTCEXGROUP 192.168.97.195:55412, idle 0:01:05, bytes 3082, flags UIOX
TCP LanInternet 195.24.247.162:80 LanOTCEXGROUP 192.168.97.195:55411, idle 0:01:05, bytes 4668, flags UIOX
TCP LanInternet 195.24.247.162:80 LanOTCEXGROUP 192.168.97.195:55408, idle 0:01:05, bytes 13979, flags UIOX
TCP LanInternet 195.24.247.162:80 LanOTCEXGROUP 192.168.97.195:55409, idle 0:01:05, bytes 8229, flags UIOX
TCP LanInternet 195.24.247.162:80 LanOTCEXGROUP 192.168.97.195:55407, idle 0:01:05, bytes 4152, flags UIOX
UDP LanInternet 41.190.179.219:58668 LanOTCEXGROUP 192.168.117.166:19552, idle 0:00:22, bytes 194, flags -
TCP LanInternet 208.81.234.97:80 LanOTCEXGROUP 192.168.77.66:49616, idle 0:00:22, bytes 1585, flags UIOX
TCP LanInternet 208.81.234.97:80 LanOTCEXGROUP 192.168.97.52:58716, idle 0:07:29, bytes 1418, flags UFRIOX
TCP LanInternet 91.212.207.28:443 LanOTCEXGROUP 192.168.77.58:53353, idle 0:00:02, bytes 29179, flags UIO
TCP LanInternet 91.212.207.28:443 LanOTCEXGROUP 192.168.77.189:2867, idle 0:00:03, bytes 75040, flags UIO
TCP LanInternet 91.212.207.28:443 LanOTCEXGROUP 192.168.77.74:4087, idle 0:00:00, bytes 82156, flags UIO
<--- More --->
TCP LanInternet 91.212.207.28:443 LanOTCEXGROUP 192.168.77.62:53715, idle 0:00:00, bytes 81902, flags UIO
TCP LanInternet 91.212.207.28:443 LanOTCEXGROUP 192.168.77.157:50458, idle 0:00:01, bytes 127555, flags UIO
TCP LanInternet 69.63.190.18:443 LanOTCEXGROUP 192.168.77.157:50465, idle 0:00:06, bytes 9970, flags UIO
TCP LanInternet 69.63.190.18:80 LanOTCEXGROUP 192.168.77.57:3024, idle 0:00:25, bytes 23239, flags UIOX
TCP LanInternet 194.78.100.184:80 LanOTCEXGROUP 192.168.97.195:55420, idle 0:01:05, bytes 3734, flags UIOX
TCP LanInternet 194.78.100.184:80 LanOTCEXGROUP 192.168.97.195:55419, idle 0:01:05, bytes 7124, flags UIOX
TCP LanInternet 194.78.100.184:80 LanOTCEXGROUP 192.168.97.195:55417, idle 0:01:05, bytes 11157, flags UIOX
TCP LanInternet 194.78.100.184:80 LanOTCEXGROUP 192.168.97.195:55418, idle 0:01:05, bytes 9746, flags UIOX
TCP LanInternet 194.78.100.184:80 LanOTCEXGROUP 192.168.97.195:55415, idle 0:01:05, bytes 4171, flags UIOX
TCP LanInternet 194.78.100.184:80 LanOTCEXGROUP 192.168.97.195:55416, idle 0:01:05, bytes 6700, flags UIOX
TCP LanInternet 194.78.100.184:80 LanOTCEXGROUP 192.168.97.208:60125, idle 0:03:24, bytes 7269, flags UFRIOX
TCP LanInternet 194.78.100.184:80 LanOTCEXGROUP 192.168.97.208:60126, idle 0:03:32, bytes 6374, flags UFRIOX
TCP LanInternet 194.78.100.184:80 LanOTCEXGROUP 192.168.97.208:60122, idle 0:03:32, bytes 4051, flags UFRIOX
TCP LanInternet 194.78.100.184:80 LanOTCEXGROUP 192.168.97.208:60124, idle 0:03:32, bytes 7209, flags UFRIOX
TCP LanInternet 194.78.100.184:80 LanOTCEXGROUP 192.168.97.208:60123, idle 0:03:32, bytes 6759, flags UFRIOX
TCP LanInternet 194.78.100.184:80 LanOTCEXGROUP 192.168.97.208:60121, idle 0:03:32, bytes 6413, flags UFRIOX
TCP LanInternet 209.85.169.139:80 LanOTCEXGROUP 192.168.77.166:58985, idle 0:00:18, bytes 33569, flags UIOX
TCP LanInternet 209.85.169.139:443 LanOTCEXGROUP 192.168.97.195:55432, idle 0:01:11, bytes 21196, flags UIO
TCP LanInternet 209.85.169.139:443 LanOTCEXGROUP 192.168.97.195:55431, idle 0:01:11, bytes 8894, flags UIO
TCP LanInternet 82.112.113.51:80 LanOTCEXGROUP 192.168.77.83:2190, idle 0:00:17, bytes 4621, flags UIOX
TCP LanInternet 194.78.100.147:80 LanOTCEXGROUP 192.168.77.147:3669, idle 0:00:53, bytes 134853, flags UIOX
TCP LanInternet 194.78.100.147:80 LanOTCEXGROUP 192.168.77.147:3668, idle 0:00:53, bytes 116820, flags UIOX
TCP LanInternet 194.78.100.147:80 LanOTCEXGROUP 192.168.77.147:3667, idle 0:00:53, bytes 228290, flags UIOX
TCP LanInternet 194.78.100.147:80 LanOTCEXGROUP 192.168.77.166:58607, idle 0:01:06, bytes 908, flags UIOX
<--- More --->
TCP LanInternet 69.63.181.67:443 LanOTCEXGROUP 192.168.77.62:53554, idle 0:00:43, bytes 276313, flags UIO
TCP LanInternet 66.235.143.118:80 LanOTCEXGROUP 192.168.77.58:53296, idle 0:04:02, bytes 6309, flags UFRIOX
TCP LanInternet 209.85.148.105:80 LanOTCEXGROUP 192.168.77.189:2969, idle 0:00:07, bytes 7341, flags UIOX
TCP LanInternet 209.85.148.105:80 LanOTCEXGROUP 192.168.77.189:2967, idle 0:00:07, bytes 299142, flags UIOX
TCP LanInternet 209.85.148.105:80 LanOTCEXGROUP 192.168.77.189:2966, idle 0:00:07, bytes 119642, flags UIOX
TCP LanInternet 209.85.148.105:80 LanOTCEXGROUP 192.168.77.189:2965, idle 0:00:07, bytes 12852, flags UIOX
TCP LanInternet 209.85.148.105:80 LanOTCEXGROUP 192.168.77.189:2963, idle 0:00:07, bytes 113533, flags UIOX
TCP LanInternet 69.171.227.39:443 LanOTCEXGROUP 192.168.97.198:53113, idle 0:00:33, bytes 116248, flags UIO
TCP LanInternet 83.138.191.140:80 LanOTCEXGROUP highlevel:1934, idle 0:00:02, bytes 409468, flags UIOX
TCP LanInternet 209.85.169.133:80 LanOTCEXGROUP 192.168.77.162:49447, idle 0:04:22, bytes 560, flags UFRIOX
TCP LanInternet 209.85.169.133:80 LanOTCEXGROUP 192.168.77.162:65343, idle 0:00:15, bytes 7112360, flags UIOX
TCP LanInternet 209.85.169.96:80 LanOTCEXGROUP 192.168.77.166:59039, idle 0:00:00, bytes 454, flags UOX
TCP LanInternet 209.85.169.96:80 LanOTCEXGROUP 192.168.97.122:57210, idle 0:00:10, bytes 2068, flags UIOX
TCP LanInternet 209.85.169.96:80 LanOTCEXGROUP 192.168.77.58:53289, idle 0:02:43, bytes 2234, flags UFRIOX
TCP LanInternet 195.72.134.129:443 LanOTCEXGROUP 192.168.97.35:53859, idle 0:00:42, bytes 961, flags UIO
TCP LanInternet 195.72.134.129:443 LanOTCEXGROUP 192.168.97.35:53857, idle 0:00:42, bytes 4815, flags UIO
TCP LanInternet 194.78.100.154:80 LanOTCEXGROUP 192.168.97.195:55443, idle 0:01:10, bytes 5825, flags UIOX
TCP LanInternet 194.78.100.154:80 LanOTCEXGROUP 192.168.97.209:1836, idle 0:07:26, bytes 87243, flags UFRIOX
TCP LanInternet 209.85.169.101:80 LanOTCEXGROUP 192.168.97.195:55426, idle 0:01:03, bytes 35229, flags UIOX
TCP LanInternet 208.89.13.133:80 LanOTCEXGROUP 192.168.77.140:58233, idle 0:00:15, bytes 77919, flags UIOX
TCP LanInternet 194.78.100.152:80 LanOTCEXGROUP 192.168.97.88:59973, idle 0:00:01, bytes 6805, flags UIOX
TCP LanInternet 194.78.100.152:80 LanOTCEXGROUP 192.168.97.35:53976, idle 0:00:39, bytes 52380, flags UIOX
TCP LanInternet 194.78.100.152:80 LanOTCEXGROUP 192.168.97.35:53975, idle 0:00:39, bytes 97314, flags UIOX
TCP LanInternet 194.78.100.152:80 LanOTCEXGROUP 192.168.97.35:53973, idle 0:00:39, bytes 19792, flags UIOX
<--- More --->
TCP LanInternet 194.78.100.152:80 LanOTCEXGROUP 192.168.97.35:53961, idle 0:00:39, bytes 277748, flags UIOX
TCP LanInternet 194.78.100.152:80 LanOTCEXGROUP 192.168.77.166:58690, idle 0:00:58, bytes 11480, flags UIOX
TCP LanInternet 194.78.100.152:80 LanOTCEXGROUP 192.168.77.166:58684, idle 0:00:58, bytes 20997, flags UIOX
TCP LanInternet 194.78.100.152:80 LanOTCEXGROUP 192.168.97.208:60265, idle 0:00:05, bytes 924536, flags UIOX
TCP LanInternet 194.78.100.152:80 LanOTCEXGROUP 192.168.97.208:60264, idle 0:00:06, bytes 698495, flags UIOX
TCP LanInternet 194.78.100.152:80 LanOTCEXGROUP 192.168.97.208:60263, idle 0:00:05, bytes 376553, flags UIOX
TCP LanInternet 194.78.100.152:80 LanOTCEXGROUP 192.168.77.150:54785, idle 0:00:14, bytes 366968, flags UIOX
TCP LanInternet 194.78.100.152:80 LanOTCEXGROUP 192.168.77.150:54784, idle 0:00:15, bytes 393928, flags UIOX
TCP LanInternet 194.78.100.152:80 LanOTCEXGROUP 192.168.77.150:54783, idle 0:00:14, bytes 347862, flags UIOX
TCP LanInternet 74.125.230.78:80 LanOTCEXGROUP 192.168.97.88:59974, idle 0:00:02, bytes 1730, flags UIOX
TCP LanInternet 74.125.230.78:80 LanOTCEXGROUP 192.168.97.88:59965, idle 0:00:01, bytes 17421, flags UIOX
TCP LanInternet 205.251.205.31:80 LanOTCEXGROUP 192.168.97.208:60102, idle 0:03:35, bytes 13901, flags UFRIOX
TCP LanInternet 66.220.151.75:443 LanOTCEXGROUP 192.168.77.153:2278, idle 0:00:00, bytes 114771, flags UIO
TCP LanInternet 91.103.138.62:80 LanOTCEXGROUP 192.168.97.35:53959, idle 0:00:40, bytes 10574, flags UIOX
TCP LanInternet 95.172.69.41:80 LanOTCEXGROUP 192.168.77.166:59041, idle 0:00:00, bytes 1599, flags UIOX
TCP LanInternet 95.172.69.41:80 LanOTCEXGROUP 192.168.77.83:2147, idle 0:00:19, bytes 1037, flags UIOX
TCP LanInternet 194.78.100.161:80 LanOTCEXGROUP 192.168.97.208:60377, idle 0:00:15, bytes 683486, flags UIOX
TCP LanInternet 194.78.100.161:80 LanOTCEXGROUP 192.168.97.208:60375, idle 0:00:15, bytes 719207, flags UIOX
TCP LanInternet 194.78.100.161:80 LanOTCEXGROUP 192.168.97.208:60374, idle 0:00:06, bytes 7644, flags UIOX
TCP LanInternet 194.78.100.161:80 LanOTCEXGROUP 192.168.97.208:60373, idle 0:00:15, bytes 32198, flags UIOX
TCP LanInternet 194.78.100.161:80 LanOTCEXGROUP 192.168.97.208:60372, idle 0:00:15, bytes 684183, flags UIOX
TCP LanInternet 194.78.100.161:80 LanOTCEXGROUP 192.168.97.208:60321, idle 0:00:39, bytes 1522, flags UIOX
TCP LanInternet 194.78.100.161:80 LanOTCEXGROUP 192.168.97.208:60104, idle 0:03:33, bytes 309622, flags UFRIOX
TCP LanInternet 194.78.100.161:80 LanOTCEXGROUP 192.168.97.208:60103, idle 0:03:41, bytes 79351, flags UFRIOX
<--- More --->
TCP LanInternet 194.78.100.161:80 LanOTCEXGROUP 192.168.97.208:60101, idle 0:03:41, bytes 126101, flags UFRIOX
TCP LanInternet 194.78.100.161:80 LanOTCEXGROUP 192.168.97.208:60100, idle 0:03:41, bytes 815500, flags UFRIOX
TCP LanInternet 194.78.100.161:80 LanOTCEXGROUP 192.168.97.208:60099, idle 0:03:41, bytes 101155, flags UFRIOX
TCP LanInternet 194.78.100.161:80 LanOTCEXGROUP 192.168.97.208:60098, idle 0:03:42, bytes 230709, flags UFRIOX
TCP LanInternet 212.25.232.60:80 LanOTCEXGROUP 192.168.97.122:57209, idle 0:00:06, bytes 41551, flags UFRIOX
TCP LanInternet 212.25.232.60:80 LanOTCEXGROUP 192.168.97.122:57207, idle 0:00:06, bytes 129670, flags UFRIOX
TCP LanInternet 212.25.232.60:80 LanOTCEXGROUP 192.168.97.122:57206, idle 0:00:06, bytes 47423, flags UFRIOX
TCP LanInternet 212.25.232.60:80 LanOTCEXGROUP 192.168.97.122:57205, idle 0:00:08, bytes 65917, flags UFRIOX
TCP LanInternet 212.25.232.60:80 LanOTCEXGROUP 192.168.97.122:57204, idle 0:00:06, bytes 218809, flags UFRIOX
TCP LanInternet 212.25.232.60:80 LanOTCEXGROUP 192.168.97.122:57203, idle 0:00:06, bytes 175474, flags UFRIOX
UDP LanInternet 89.75.48.130:61911 LanOTCEXGROUP PCFIXEREDA:43080, idle 0:00:05, bytes 48, flags -
TCP LanInternet 82.238.165.99:32813 LanOTCEXGROUP 192.168.117.23:64181, idle 0:00:08, bytes 747290, flags UIO
TCP LanInternet 87.98.161.211:80 LanOTCEXGROUP 192.168.97.178:49933, idle 0:02:04, bytes 671, flags UFRIOX
TCP LanInternet 194.78.100.186:443 LanOTCEXGROUP 192.168.77.132:4137, idle 0:00:02, bytes 3545, flags UIO
TCP LanInternet 194.78.100.186:443 LanOTCEXGROUP 192.168.77.132:4136, idle 0:00:02, bytes 7121, flags UIO
TCP LanInternet 194.78.100.186:443 LanOTCEXGROUP 192.168.77.132:4135, idle 0:00:02, bytes 7448, flags UIO
TCP LanInternet 194.78.100.186:443 LanOTCEXGROUP 192.168.77.132:4133, idle 0:00:02, bytes 21679, flags UIO
TCP LanInternet 194.78.100.186:443 LanOTCEXGROUP 192.168.77.132:4132, idle 0:00:02, bytes 25789, flags UIO
TCP LanInternet 194.78.100.186:80 LanOTCEXGROUP 192.168.97.88:59946, idle 0:00:13, bytes 49517, flags UIOX
TCP LanInternet 194.78.100.186:80 LanOTCEXGROUP 192.168.97.219:63837, idle 0:01:09, bytes 1583, flags UIOX
TCP LanInternet 74.125.230.93:443 LanOTCEXGROUP 192.168.97.216:53555, idle 0:00:23, bytes 3740, flags UIO
TCP LanInternet 74.125.230.93:443 LanOTCEXGROUP 192.168.97.208:60093, idle 0:00:08, bytes 7279, flags UIO
TCP LanInternet 74.125.230.93:443 LanOTCEXGROUP 192.168.77.161:53063, idle 0:00:07, bytes 11222, flags UIO
TCP LanInternet 74.125.230.93:443 LanOTCEXGROUP 192.168.97.216:53515, idle 0:03:35, bytes 11604, flags UIO
<--- More --->
TCP LanInternet 74.125.230.93:443 LanOTCEXGROUP PCVLAD:49579, idle 0:00:14, bytes 26174, flags UIO
TCP LanInternet 74.125.230.93:443 LanOTCEXGROUP 192.168.97.183:49505, idle 0:00:07, bytes 92703, flags UIO
TCP LanInternet 74.125.230.93:443 LanOTCEXGROUP 192.168.97.126:3063, idle 0:00:03, bytes 55892, flags UIO
TCP LanInternet 74.125.230.93:443 LanOTCEXGROUP 192.168.97.209:4920, idle 0:00:25, bytes 185705, flags UIO
TCP LanInternet 74.125.230.93:443 LanOTCEXGROUP 192.168.77.196:62180, idle 0:00:05, bytes 349677, flags UIO
TCP LanInternet 74.125.230.93:443 LanOTCEXGROUP 192.168.77.57:2446, idle 0:00:14, bytes 390168, flags UIO
TCP LanInternet 74.125.230.93:443 LanOTCEXGROUP 192.168.97.59:58732, idle 0:00:17, bytes 524154, flags UIO
TCP LanInternet 80.239.205.195:443 LanOTCEXGROUP 192.168.77.132:4131, idle 0:00:16, bytes 41982, flags UIO
TCP LanInternet 80.239.205.195:443 LanOTCEXGROUP 192.168.77.132:4130, idle 0:00:02, bytes 45662, flags UIO
TCP LanInternet 66.220.158.32:443 LanOTCEXGROUP 192.168.77.140:63585, idle 0:00:25, bytes 6444, flags UIO
TCP LanInternet 195.8.214.1:80 LanOTCEXGROUP 192.168.77.82:62808, idle 0:01:22, bytes 2016623, flags UIOX
TCP LanInternet 82.226.65.126:51153 LanOTCEXGROUP PCVLAD:59092, idle 0:00:04, bytes 107935, flags UIO
TCP LanInternet 66.114.171.88:443 LanOTCEXGROUP PCFIXEREDA:52148, idle 0:00:00, bytes 759242, flags UIO
TCP LanInternet 66.114.171.88:443 LanOTCEXGROUP PCFIXEREDA:52147, idle 0:00:00, bytes 74110265, flags UIO
TCP LanInternet 69.63.180.46:443 LanOTCEXGROUP 192.168.77.132:4012, idle 0:00:14, bytes 205773, flags UIO
TCP LanInternet 194.78.100.64:80 LanOTCEXGROUP 192.168.77.166:59018, idle 0:00:08, bytes 26717, flags UIOX
TCP LanInternet 31.12.64.12:80 LanOTCEXGROUP 192.168.97.58:2283, idle 0:00:43, bytes 3868, flags UIOX
UDP LanInternet 50.90.55.13:443 LanOTCEXGROUP 192.168.117.166:19552, idle 0:00:48, bytes 44, flags -
TCP LanInternet 64.152.208.66:80 LanOTCEXGROUP 192.168.77.83:2205, idle 0:00:24, bytes 908, flags UIOX
TCP LanInternet 64.152.208.66:80 LanOTCEXGROUP 192.168.77.83:2201, idle 0:00:24, bytes 1818, flags UIOX
TCP LanInternet 64.152.208.66:80 LanOTCEXGROUP 192.168.77.166:58926, idle 0:00:28, bytes 923, flags UIOX
TCP LanInternet 64.152.208.66:80 LanOTCEXGROUP 192.168.77.166:58919, idle 0:00:28, bytes 1847, flags UIOX
TCP LanInternet 64.152.208.66:80 LanOTCEXGROUP 192.168.97.219:64004, idle 0:00:52, bytes 917, flags UIOX
TCP LanInternet 64.152.208.66:80 LanOTCEXGROUP 192.168.97.219:63977, idle 0:00:52, bytes 1835, flags UIOX
<--- More --->
TCP LanInternet 217.110.44.86:443 LanOTCEXGROUP 192.168.77.127:3633, idle 0:00:00, bytes 950650, flags UIO
TCP LanInternet 69.63.189.16:80 LanOTCEXGROUP 192.168.97.208:60110, idle 0:03:41, bytes 2082, flags UFRIOX
TCP LanInternet 66.220.158.11:443 LanOTCEXGROUP 192.168.97.198:55086, idle 0:00:13, bytes 8566, flags UIO
TCP LanInternet 209.85.169.138:80 LanOTCEXGROUP 192.168.97.122:57212, idle 0:00:18, bytes 34278, flags UIOX
TCP LanInternet 209.85.169.138:80 LanOTCEXGROUP 192.168.77.127:4648, idle 0:00:43, bytes 1621, flags UIOX
TCP LanInternet 209.85.169.138:80 LanOTCEXGROUP 192.168.97.69:62166, idle 0:00:17, bytes 6563, flags UFRIOX
TCP LanInternet 209.85.169.138:443 LanOTCEXGROUP 192.168.77.58:53322, idle 0:00:21, bytes 21030, flags UFRIO
TCP LanInternet 209.85.169.138:443 LanOTCEXGROUP 192.168.77.58:53317, idle 0:00:21, bytes 8814, flags UFRIO
TCP LanInternet 209.85.169.138:443 LanOTCEXGROUP 192.168.77.83:1878, idle 0:07:44, bytes 21136, flags UFRIO
TCP LanInternet 209.85.169.138:443 LanOTCEXGROUP 192.168.77.83:1877, idle 0:07:44, bytes 8655, flags UFRIO
TCP LanInternet 50.19.108.122:80 LanOTCEXGROUP 192.168.87.140:61972, idle 0:00:00, bytes 0, flags UX
TCP LanInternet 212.95.67.222:80 LanOTCEXGROUP 192.168.97.73:59929, idle 0:00:00, bytes 1049, flags UfFrRIOX
TCP LanInternet 212.95.67.222:80 LanOTCEXGROUP 192.168.97.73:59893, idle 0:00:00, bytes 2880, flags UIOX
TCP LanInternet 212.95.67.222:80 LanOTCEXGROUP 192.168.97.73:59889, idle 0:00:00, bytes 1425, flags UIOX
TCP LanInternet 212.95.67.222:80 LanOTCEXGROUP 192.168.97.73:59888, idle 0:00:00, bytes 1425, flags UIOX
TCP LanInternet 212.95.67.222:80 LanOTCEXGROUP 192.168.97.73:59887, idle 0:00:00, bytes 1425, flags UIOX
TCP LanInternet 212.95.67.222:80 LanOTCEXGROUP 192.168.97.73:59885, idle 0:00:00, bytes 5672, flags UIOX
TCP LanInternet 212.95.67.222:80 LanOTCEXGROUP 192.168.97.73:59883, idle 0:00:00, bytes 1430, flags UIOX
TCP LanInternet 212.95.67.222:80 LanOTCEXGROUP 192.168.97.173:58536, idle 0:00:01, bytes 3014, flags UFRIOX
TCP LanInternet 212.95.67.222:80 LanOTCEXGROUP 192.168.97.173:58490, idle 0:00:01, bytes 3058, flags UFRIOX
TCP LanInternet 212.95.67.222:80 LanOTCEXGROUP 192.168.97.173:58488, idle 0:00:01, bytes 6130, flags UFRIOX
TCP LanInternet 212.95.67.222:80 LanOTCEXGROUP 192.168.97.173:58487, idle 0:00:00, bytes 6124, flags UFRIOX
TCP LanInternet 212.95.67.222:80 LanOTCEXGROUP 192.168.97.173:58480, idle 0:00:01, bytes 6154, flags UFRIOX
TCP LanInternet 212.95.67.222:80 LanOTCEXGROUP 192.168.97.173:58479, idle 0:00:00, bytes 9937, flags UFRIOX
<--- More --->
TCP LanInternet 178.236.5.31:80 LanOTCEXGROUP 192.168.97.208:60109, idle 0:03:45, bytes 12698, flags UFRIOX
TCP LanInternet 195.154.193.235:80 LanOTCEXGROUP 192.168.77.58:53328, idle 0:02:54, bytes 995, flags UFRIOX
TCP LanInternet 66.220.151.82:443 LanOTCEXGROUP 192.168.97.220:49794, idle 0:00:14, bytes 95244, flags UIO
TCP LanInternet 194.78.100.168:80 LanOTCEXGROUP 192.168.77.141:2790, idle 0:00:00, bytes 72179, flags UIOX
TCP LanInternet 194.78.100.168:80 LanOTCEXGROUP 192.168.97.35:53950, idle 0:00:53, bytes 12222, flags UIOX
TCP LanInternet 194.78.100.168:80 LanOTCEXGROUP 192.168.77.166:58620, idle 0:01:18, bytes 12281, flags UIOX
TCP LanInternet 194.78.100.168:80 LanOTCEXGROUP 192.168.97.209:1828, idle 0:08:02, bytes 6858, flags UFRIOX
TCP LanInternet 72.21.211.165:80 LanOTCEXGROUP 192.168.97.122:57236, idle 0:00:10, bytes 803, flags UFRIOX
TCP LanInternet 184.73.211.238:443 LanOTCEXGROUP 192.168.77.172:54991, idle 0:00:02, bytes 82162, flags UFRIO
TCP LanInternet PromarkTrader1:20000 LanOTCEXGROUP 192.168.117.172:62484, idle 0:00:04, bytes 55390025, flags UIO
UDP LanInternet 213.182.241.78:50046 LanOTCEXGROUP 192.168.117.166:19552, idle 0:00:52, bytes 44, flags -
TCP LanInternet 74.125.230.87:443 LanOTCEXGROUP 192.168.97.208:60075, idle 0:00:16, bytes 132484, flags UIO
TCP LanInternet 87.248.221.45:1935 LanOTCEXGROUP PCVLAD:53021, idle 0:00:00, bytes 3277798598, flags UIO
TCP LanInternet 66.220.151.87:443 LanOTCEXGROUP 192.168.77.62:53735, idle 0:00:39, bytes 7985, flags UIO
TCP LanInternet 66.220.151.87:443 LanOTCEXGROUP 192.168.77.62:53650, idle 0:00:14, bytes 23567, flags UIO
TCP LanInternet 109.205.186.36:80 LanOTCEXGROUP 192.168.97.73:59923, idle 0:00:00, bytes 1900, flags UIOX
TCP LanInternet 109.205.186.36:80 LanOTCEXGROUP 192.168.97.173:58538, idle 0:00:01, bytes 0, flags UX
TCP LanInternet 64.4.61.164:1863 LanOTCEXGROUP PCVLAD:49358, idle 0:00:24, bytes 173585, flags UIO
TCP LanInternet 213.212.74.250:80 LanOTCEXGROUP 192.168.77.152:61787, idle 0:00:18, bytes 1348, flags UFRIOX
TCP LanInternet 213.212.74.250:80 LanOTCEXGROUP 192.168.77.152:61786, idle 0:00:18, bytes 1351, flags UFRIOX
TCP LanInternet 213.212.74.250:80 LanOTCEXGROUP 192.168.77.152:61785, idle 0:00:18, bytes 2702, flags UFRIOX
UDP LanInternet 146.188.18.146:4500 LanOTCEXGROUP 192.168.77.58:52777, idle 0:00:00, bytes 718899125, flags -
UDP LanInternet 146.188.18.146:4500 LanOTCEXGROUP 172.16.40.109:3408, idle 0:00:00, bytes 35595830, flags -
UDP LanInternet 69.248.238.136:16326 LanOTCEXGROUP 192.168.117.166:19552, idle 0:00:52, bytes 44, flags -
<--- More --->
TCP LanInternet 62.23.175.19:80 LanOTCEXGROUP highlevel:1936, idle 0:00:05, bytes 2266, flags UIOX
TCP LanInternet 62.23.175.19:80 LanOTCEXGROUP 192.168.77.62:53505, idle 0:00:01, bytes 634800, flags UIOX
TCP LanInternet 62.23.175.19:80 LanOTCEXGROUP 192.168.77.166:54876, idle 0:00:00, bytes 898527, flags UIOX
TCP LanInternet 209.197.193.73:443 LanOTCEXGROUP PCFIXEREDA:52161, idle 0:00:02, bytes 30212, flags UIO
TCP LanInternet 209.197.193.73:443 LanOTCEXGROUP PCFIXEREDA:52160, idle 0:00:00, bytes 154326, flags UIO
TCP LanInternet 66.220.158.25:443 LanOTCEXGROUP 192.168.97.220:50186, idle 0:00:29, bytes 9173, flags UIO
TCP LanInternet 66.220.158.25:80 LanOTCEXGROUP 192.168.97.184:63592, idle 0:00:09, bytes 4252, flags UIOX
TCP LanInternet 194.78.100.155:80 LanOTCEXGROUP 192.168.97.73:59927, idle 0:00:00, bytes 2759, flags UIOX
TCP LanInternet 194.78.100.155:80 LanOTCEXGROUP 192.168.77.147:3786, idle 0:00:15, bytes 1042, flags UIOX
TCP LanInternet 194.78.100.155:80 LanOTCEXGROUP 192.168.77.166:58932, idle 0:00:31, bytes 7530, flags UIOX
TCP LanInternet 194.78.100.155:80 LanOTCEXGROUP 192.168.77.166:58594, idle 0:01:19, bytes 1182, flags UIOX
TCP LanInternet 69.171.227.37:80 LanOTCEXGROUP 192.168.97.58:2232, idle 0:00:25, bytes 76870, flags UIOX
TCP LanInternet 199.47.216.172:443 LanOTCEXGROUP 192.168.77.172:55011, idle 0:00:48, bytes 52902, flags UFRIO
TCP LanInternet 217.73.4.51:443 LanOTCEXGROUP 192.168.117.170:52247, idle 0:00:04, bytes 8225104, flags UIO
TCP LanInternet 205.251.205.199:80 LanOTCEXGROUP 192.168.77.166:58996, idle 0:00:22, bytes 2451, flags UIOX
TCP LanInternet 208.71.123.131:80 LanOTCEXGROUP 192.168.77.166:59057, idle 0:00:10, bytes 1473, flags UIOX
TCP LanInternet 208.71.123.131:443 LanOTCEXGROUP 192.168.77.166:59053, idle 0:00:11, bytes 6102, flags UIO
TCP LanInternet 93.186.25.33:3101 LanOTCEXGROUP 192.168.77.40:51895, idle 0:00:12, bytes 37823222, flags UIO
TCP LanInternet 98.138.26.82:5050 LanOTCEXGROUP 192.168.117.170:54341, idle 0:00:02, bytes 194369, flags UIO
TCP LanInternet 205.188.93.194:80 LanOTCEXGROUP 192.168.97.122:57235, idle 0:00:11, bytes 2799, flags UIOX
TCP LanInternet 64.12.28.67:443 LanOTCEXGROUP 192.168.77.67:4376, idle 0:02:05, bytes 362078, flags UIO
TCP LanInternet 91.225.248.80:80 LanOTCEXGROUP 192.168.77.166:58666, idle 0:01:15, bytes 1089, flags UIOX
TCP LanInternet 91.225.248.80:80 LanOTCEXGROUP 192.168.77.166:58665, idle 0:01:16, bytes 1102, flags UIOX
TCP LanInternet 91.225.248.80:80 LanOTCEXGROUP 192.168.77.166:58664, idle 0:01:24, bytes 1135, flags UIOX
<--- More --->
TCP LanInternet 91.225.248.80:80 LanOTCEXGROUP 192.168.77.166:58425, idle 0:01:24, bytes 4617, flags UIOX
TCP LanInternet 64.4.34.52:80 LanOTCEXGROUP 192.168.77.140:58224, idle 0:00:06, bytes 43739, flags UIOX
TCP LanInternet 64.4.34.52:80 LanOTCEXGROUP 192.168.77.70:49849, idle 0:00:17, bytes 62515, flags UIOX
TCP LanInternet 209.85.169.105:443 LanOTCEXGROUP 192.168.97.178:49914, idle 0:02:46, bytes 3392, flags UIO
TCP LanInternet 209.85.169.105:443 LanOTCEXGROUP 192.168.97.178:49913, idle 0:02:46, bytes 3934, flags UIO
TCP LanInternet 88.221.189.32:443 LanOTCEXGROUP 192.168.97.88:59875, idle 0:00:47, bytes 6123, flags UIO
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.140:63600, idle 0:00:17, bytes 2545, flags UIOX
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.140:63598, idle 0:00:16, bytes 10442, flags UIOX
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.140:63595, idle 0:00:16, bytes 211118, flags UIOX
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.140:63594, idle 0:00:16, bytes 4892, flags UIOX
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.140:63591, idle 0:00:17, bytes 208393, flags UIOX
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.189:2961, idle 0:00:49, bytes 1053, flags UIOX
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.189:2960, idle 0:00:49, bytes 1605, flags UIOX
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.189:2959, idle 0:00:49, bytes 9570, flags UIOX
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.189:2958, idle 0:00:50, bytes 31123, flags UIOX
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.58:53348, idle 0:00:01, bytes 2916709, flags UIOX
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.166:57841, idle 0:00:00, bytes 1050471, flags UIOX
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.72:3456, idle 0:00:02, bytes 859013, flags UIOX
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.57:2909, idle 0:00:01, bytes 2808041, flags UIOX
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.64:58522, idle 0:00:02, bytes 2963508, flags UIOX
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.140:63225, idle 0:00:01, bytes 3416978, flags UIOX
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.97.174:2207, idle 0:00:01, bytes 168747, flags UIOX
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.58:53177, idle 0:00:01, bytes 3850552, flags UIOX
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.147:3605, idle 0:00:00, bytes 508842, flags UIOX
<--- More --->
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.157:50455, idle 0:00:01, bytes 447020, flags UIOX
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.189:2741, idle 0:00:01, bytes 1756077, flags UIOX
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.62:53669, idle 0:00:02, bytes 560876, flags UIOX
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.74:4054, idle 0:00:00, bytes 1831677, flags UIOX
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.163:1943, idle 0:00:00, bytes 384384, flags UIOX
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.88:4678, idle 0:00:00, bytes 384384, flags UIOX
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.92:60314, idle 0:00:02, bytes 389879, flags UIOX
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.74:4050, idle 0:08:06, bytes 732, flags UFRIOX
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.74:4049, idle 0:07:11, bytes 4980, flags UFRIOX
TCP LanInternet 212.100.227.19:80 LanOTCEXGROUP 192.168.77.74:4047, idle 0:07:12, bytes 140448, flags UFRIOX
UDP LanInternet 109.104.161.230:54663 LanOTCEXGROUP PCVLAD:41008, idle 0:00:24, bytes 476, flags -
TCP LanInternet 67.195.187.57:80 LanOTCEXGROUP 192.168.77.166:58991, idle 0:00:36, bytes 2673, flags UOX
TCP LanInternet 67.195.187.57:80 LanOTCEXGROUP 192.168.97.34:3346, idle 0:00:40, bytes 1433, flags UOX
TCP LanInternet 67.195.187.57:80 LanOTCEXGROUP 192.168.97.198:55058, idle 0:00:22, bytes 2341, flags UOX
TCP LanInternet 67.195.187.57:80 LanOTCEXGROUP 192.168.97.58:2280, idle 0:00:53, bytes 12379, flags UIOX
TCP LanInternet 95.172.69.37:80 LanOTCEXGROUP 192.168.77.166:59043, idle 0:00:13, bytes 14310, flags UFRIOX
TCP LanInternet 95.172.69.37:80 LanOTCEXGROUP 192.168.77.166:59042, idle 0:00:11, bytes 10832, flags UFRIOX
TCP LanInternet 69.171.242.40:80 LanOTCEXGROUP 192.168.97.73:59980, idle 0:00:06, bytes 14297, flags UIOX
TCP LanInternet 69.171.242.40:80 LanOTCEXGROUP 192.168.77.138:54047, idle 0:00:15, bytes 2821, flags UIOX
TCP LanInternet 69.171.242.40:80 LanOTCEXGROUP 192.168.97.88:59971, idle 0:00:00, bytes 5860, flags UIOX
TCP LanInternet 69.171.242.40:443 LanOTCEXGROUP 192.168.77.132:4129, idle 0:00:14, bytes 19943, flags UIO
TCP LanInternet 69.171.242.40:80 LanOTCEXGROUP 192.168.97.122:57185, idle 0:00:47, bytes 1133, flags UIOX
TCP LanInternet 69.171.242.40:80 LanOTCEXGROUP 192.168.97.122:57184, idle 0:00:47, bytes 1168, flags UIOX
TCP LanInternet 69.171.242.40:80 LanOTCEXGROUP 192.168.97.35:53918, idle 0:01:00, bytes 42152, flags UIOX
<--- More --->
TCP LanInternet 69.171.242.40:443 LanOTCEXGROUP 192.168.77.132:4128, idle 0:00:14, bytes 151880, flags UIO
TCP LanInternet 67.195.187.206:5050 LanOTCEXGROUP 192.168.117.170:54322, idle 0:00:30, bytes 371810, flags UIO
UDP LanInternet 24.203.88.139:41645 LanOTCEXGROUP PCFIXEREDA:43080, idle 0:01:07, bytes 50, flags -
TCP LanInternet 65.55.17.39:80 LanOTCEXGROUP PCFIXEREDA:53298, idle 0:00:08, bytes 2318, flags UIOX
TCP LanInternet 65.55.17.39:80 LanOTCEXGROUP 192.168.77.136:53829, idle 0:00:15, bytes 22385, flags UIOX
TCP LanInternet 69.63.190.10:80 LanOTCEXGROUP 192.168.77.58:53355, idle 0:00:06, bytes 5633, flags UIOX
TCP LanInternet 69.63.190.10:80 LanOTCEXGROUP 192.168.97.67:58244, idle 0:00:43, bytes 2952, flags UIOX
TCP LanInternet 69.63.190.10:80 LanOTCEXGROUP 192.168.77.74:4157, idle 0:00:49, bytes 4635, flags UIOX
TCP LanInternet 69.63.190.10:80 LanOTCEXGROUP 192.168.97.122:57162, idle 0:00:38, bytes 8993, flags UIOX
TCP LanInternet 69.63.190.10:80 LanOTCEXGROUP 192.168.77.64:58866, idle 0:00:00, bytes 13470, flags UIOX
TCP LanInternet 69.63.190.10:80 LanOTCEXGROUP 192.168.97.92:57481, idle 0:01:01, bytes 99266, flags UIOX
TCP LanInternet 69.63.190.10:80 LanOTCEXGROUP 192.168.97.100:4792, idle 0:00:15, bytes 51129, flags UIOX
TCP LanInternet 74.125.230.85:443 LanOTCEXGROUP 192.168.97.183:49567, idle 0:00:24, bytes 3193, flags UIO
TCP LanInternet 74.125.230.85:443 LanOTCEXGROUP 192.168.97.73:50218, idle 0:00:18, bytes 1386525, flags UIO
TCP LanInternet 74.125.230.85:443 LanOTCEXGROUP 192.168.77.172:51903, idle 0:00:04, bytes 14182874, flags UIO
TCP LanInternet 95.172.69.34:80 LanOTCEXGROUP 192.168.77.166:59052, idle 0:00:17, bytes 12876, flags UFRIOX
TCP LanInternet 195.24.247.129:80 LanOTCEXGROUP 192.168.77.58:53301, idle 0:03:12, bytes 128512, flags UFRIOX
TCP LanInternet 195.24.247.129:80 LanOTCEXGROUP 192.168.77.58:53300, idle 0:03:13, bytes 333260, flags UFRIOX
TCP LanInternet 195.24.247.129:80 LanOTCEXGROUP 192.168.77.58:53298, idle 0:03:12, bytes 171049, flags UFRIOX
TCP LanInternet 195.24.247.129:80 LanOTCEXGROUP 192.168.77.58:53297, idle 0:03:12, bytes 46502, flags UFRIOX
TCP LanInternet 12.178.144.109:10200 LanOTCEXGROUP 192.168.117.166:64220, idle 0:00:00, bytes 124781927, flags UIO
TCP LanInternet 12.178.144.109:10200 LanOTCEXGROUP 192.168.117.166:64218, idle 0:00:07, bytes 228385, flags UIO
TCP LanInternet 94.127.72.80:80 LanOTCEXGROUP 192.168.77.147:3785, idle 0:00:32, bytes 1896, flags UIOX
TCP LanInternet 66.220.146.50:443 LanOTCEXGROUP 192.168.77.127:4081, idle 0:00:07, bytes 108934, flags UIO
<--- More --->
TCP LanInternet 66.220.146.50:443 LanOTCEXGROUP 192.168.77.127:4056, idle 0:00:07, bytes 164362, flags UIO
TCP LanInternet 66.220.146.50:443 LanOTCEXGROUP 192.168.77.127:4055, idle 0:00:07, bytes 160682, flags UIO
TCP LanInternet 66.220.146.50:443 LanOTCEXGROUP 192.168.77.127:4054, idle 0:00:07, bytes 160915, flags UIO
TCP LanInternet 66.220.146.50:443 LanOTCEXGROUP 192.168.77.127:4053, idle 0:00:07, bytes 153251, flags UIO
TCP LanInternet 66.220.146.50:443 LanOTCEXGROUP 192.168.77.127:4052, idle 0:00:07, bytes 167184, flags UIO
TCP LanInternet 66.220.146.50:443 LanOTCEXGROUP 192.168.77.127:4051, idle 0:00:07, bytes 128499, flags UIO
TCP LanInternet 66.220.145.36:80 LanOTCEXGROUP 192.168.97.186:56961, idle 0:00:37, bytes 35605, flags UIOX
TCP LanInternet 94.245.117.52:80 LanOTCEXGROUP 192.168.97.50:50369, idle 0:00:08, bytes 2665, flags UIOX
TCP LanInternet 2.20.246.13:80 LanOTCEXGROUP 192.168.97.206:3905, idle 0:04:11, bytes 84483, flags UFRIOX
TCP LanInternet 66.235.142.57:80 LanOTCEXGROUP 192.168.97.122:57213, idle 0:00:31, bytes 3793, flags UFRIOX
TCP LanInternet 67.195.187.214:5050 LanOTCEXGROUP 192.168.117.30:65067, idle 0:00:35, bytes 32655, flags UIO
TCP LanInternet 2.17.2.110:443 LanOTCEXGROUP 192.168.77.132:4134, idle 0:00:34, bytes 7221, flags UIO
TCP LanInternet 157.55.40.126:80 LanOTCEXGROUP 192.168.97.88:59947, idle 0:00:36, bytes 8707, flags UIOX
TCP LanInternet 94.245.117.47:80 LanOTCEXGROUP 192.168.97.50:50380, idle 0:00:09, bytes 1740, flags UIOX
TCP LanInternet 94.245.117.47:80 LanOTCEXGROUP 192.168.97.50:50374, idle 0:00:10, bytes 4607, flags UIOX
TCP LanInternet 94.245.117.47:80 LanOTCEXGROUP 192.168.97.50:50373, idle 0:00:09, bytes 3207, flags UIOX
TCP LanInternet 94.245.117.47:80 LanOTCEXGROUP 192.168.97.122:57190, idle 0:00:51, bytes 4490, flags UIOX
TCP LanInternet 79.125.112.39:80 LanOTCEXGROUP 192.168.97.122:57240, idle 0:00:27, bytes 1186, flags UIOX
TCP LanInternet 79.125.112.39:80 LanOTCEXGROUP 192.168.97.122:57239, idle 0:00:27, bytes 1005, flags UIOX
UDP LanInternet 178.156.39.153:50032 LanOTCEXGROUP 192.168.117.166:19552, idle 0:02:00, bytes 441, flags -
UDP LanInternet 212.186.73.59:46396 LanOTCEXGROUP 192.168.117.166:19552, idle 0:01:09, bytes 226, flags -
TCP LanInternet 88.121.108.16:32114 LanOTCEXGROUP PCFIXEREDA:53148, idle 0:01:16, bytes 102728, flags UIO
TCP LanInternet 66.220.151.71:443 LanOTCEXGROUP 192.168.77.189:2644, idle 0:00:00, bytes 121771, flags UIO
TCP LanInternet 66.220.145.37:80 LanOTCEXGROUP 192.168.77.58:53161, idle 0:00:13, bytes 48727, flags UIOX
<--- More --->
TCP LanInternet 74.125.230.72:80 LanOTCEXGROUP 192.168.97.88:59978, idle 0:00:31, bytes 5503, flags UIOX
TCP LanInternet 74.125.230.72:80 LanOTCEXGROUP 192.168.97.88:59977, idle 0:00:31, bytes 11233, flags UIOX
TCP LanInternet 74.125.230.72:80 LanOTCEXGROUP 192.168.97.88:59976, idle 0:00:31, bytes 18978, flags UIOX
TCP LanInternet 74.125.230.72:80 LanOTCEXGROUP 192.168.97.88:59975, idle 0:00:31, bytes 10218, flags UIOX
TCP LanInternet 188.165.14.81:80 LanOTCEXGROUP 192.168.97.216:53556, idle 0:00:05, bytes 47898, flags UIOX
TCP LanInternet 194.78.100.138:443 LanOTCEXGROUP 192.168.77.189:2973, idle 0:00:29, bytes 4554, flags UIO
TCP LanInternet 194.78.100.138:443 LanOTCEXGROUP 192.168.77.189:2972, idle 0:00:29, bytes 4233, flags UIO
TCP LanInternet 194.78.100.138:443 LanOTCEXGROUP 192.168.77.189:2971, idle 0:00:29, bytes 4170, flags UIO
UDP LanInternet 111.223.187.34:4114 LanOTCEXGROUP PCFIXEREDA:43080, idle 0:00:22, bytes 62, flags -
TCP LanInternet 66.220.151.72:80 LanOTCEXGROUP 192.168.77.57:2853, idle 0:00:28, bytes 264187, flags UIOX
TCP LanInternet 192.168.217.52:445 LanOTCEXGROUP 192.168.77.32:64702, idle 0:00:46, bytes 4530, flags UIO
TCP LanInternet 2.16.15.86:80 LanOTCEXGROUP 192.168.97.88:59964, idle 0:00:09, bytes 387874, flags UIOX
TCP LanInternet 2.16.15.86:80 LanOTCEXGROUP 192.168.97.88:59963, idle 0:00:09, bytes 81341, flags UIOX
TCP LanInternet 2.16.15.86:80 LanOTCEXGROUP 192.168.97.88:59962, idle 0:00:09, bytes 398332, flags UIOX
TCP LanInternet 2.16.15.86:80 LanOTCEXGROUP 192.168.97.88:59961, idle 0:00:09, bytes 39270, flags UIOX
TCP LanInternet 2.16.15.86:80 LanOTCEXGROUP 192.168.97.88:59960, idle 0:00:10, bytes 30890, flags UIOX
TCP LanInternet 2.16.15.86:80 LanOTCEXGROUP 192.168.97.88:59959, idle 0:00:09, bytes 1364003, flags UIOX
UDP LanInternet 213.175.145.30:45852 LanOTCEXGROUP 192.168.117.166:19552, idle 0:01:06, bytes 220, flags -
TCP LanInternet 64.4.34.129:80 LanOTCEXGROUP 192.168.77.166:55169, idle 0:00:14, bytes 55806, flags UIOX
TCP LanInternet 69.63.190.14:80 LanOTCEXGROUP 192.168.97.52:58711, idle 0:08:05, bytes 8893, flags UFRIOX
TCP LanInternet 209.85.169.141:80 LanOTCEXGROUP 192.168.97.208:60107, idle 0:04:02, bytes 15023, flags UFRIOX
TCP LanInternet 94.245.115.209:80 LanOTCEXGROUP 192.168.97.67:58268, idle 0:00:05, bytes 31763, flags UIOX
TCP LanInternet 94.245.115.209:80 LanOTCEXGROUP 192.168.77.64:58549, idle 0:03:12, bytes 31619, flags UFRIOX
TCP LanInternet 94.245.115.209:80 LanOTCEXGROUP 192.168.77.53:57494, idle 0:03:27, bytes 31576, flags UFRIOX
<--- More --->
TCP LanInternet 94.245.115.209:80 LanOTCEXGROUP 192.168.97.208:60088, idle 0:04:36, bytes 31620, flags UFRIOX
TCP LanInternet 94.245.115.209:80 LanOTCEXGROUP 192.168.77.70:49862, idle 0:08:36, bytes 31658, flags UFRIOX
TCP LanInternet 69.171.227.48:80 LanOTCEXGROUP 192.168.97.92:57474, idle 0:00:03, bytes 73179, flags UIOX
TCP LanInternet 66.150.29.208:80 LanOTCEXGROUP 192.168.77.83:2171, idle 0:00:50, bytes 33556, flags UIOX
TCP LanInternet 98.138.26.50:5050 LanOTCEXGROUP 192.168.117.168:61522, idle 0:00:27, bytes 47394, flags UIO
TCP LanInternet 84.16.67.133:80 LanOTCEXGROUP 192.168.97.99:63338, idle 0:00:00, bytes 17941474, flags UIOX
TCP LanInternet 65.55.33.135:80 LanOTCEXGROUP 192.168.97.122:57188, idle 0:00:55, bytes 12917, flags UIOX
TCP LanInternet 65.55.33.135:80 LanOTCEXGROUP 192.168.97.122:57187, idle 0:00:55, bytes 35209, flags UIOX
TCP LanInternet 69.171.228.30:443 LanOTCEXGROUP 192.168.77.62:53730, idle 0:00:15, bytes 10237, flags UIO
TCP LanInternet 69.171.228.30:443 LanOTCEXGROUP 192.168.77.62:53729, idle 0:00:26, bytes 9105, flags UIO
TCP LanInternet 69.171.228.30:443 LanOTCEXGROUP 192.168.77.62:53720, idle 0:00:36, bytes 68427, flags UIO
TCP LanInternet 69.171.228.30:443 LanOTCEXGROUP 192.168.77.62:53680, idle 0:00:05, bytes 92212, flags UIO
TCP LanInternet 98.138.26.107:443 LanOTCEXGROUP 192.168.117.30:65075, idle 0:01:22, bytes 8348, flags UIO
TCP LanInternet 87.248.221.84:1935 LanOTCEXGROUP PCFIXEREDA:51961, idle 0:00:02, bytes 181121681, flags UIO
TCP LanInternet 216.23.224.96:4002 LanOTCEXGROUP 192.168.117.24:51749, idle 0:00:12, bytes 622108, flags UIO
TCP LanInternet 203.77.190.242:80 LanOTCEXGROUP 192.168.77.166:58704, idle 0:01:03, bytes 743, flags UFRIOX
TCP LanInternet 203.77.190.242:80 LanOTCEXGROUP 192.168.77.166:58703, idle 0:00:58, bytes 1481, flags UFRIOX
TCP LanInternet 203.77.190.242:80 LanOTCEXGROUP 192.168.77.166:58702, idle 0:00:58, bytes 1481, flags UFRIOX
TCP LanInternet PromarkTrader3:20001 LanOTCEXGROUP 192.168.117.172:62485, idle 0:00:00, bytes 185736426, flags UIO
TCP LanInternet 79.125.6.93:80 LanOTCEXGROUP 192.168.97.50:50412, idle 0:00:02, bytes 1760, flags UIOX
TCP LanInternet 79.125.6.93:80 LanOTCEXGROUP 192.168.97.50:50394, idle 0:00:02, bytes 2188, flags UIOX
TCP LanInternet 69.171.242.53:80 LanOTCEXGROUP 192.168.97.208:60382, idle 0:00:11, bytes 61059, flags UIOX
TCP LanInternet 69.171.242.53:80 LanOTCEXGROUP 192.168.97.208:60381, idle 0:00:11, bytes 40131, flags UIOX
TCP LanInternet 69.171.242.53:80 LanOTCEXGROUP 192.168.77.58:53313, idle 0:03:16, bytes 26097, flags UFRIOX
<--- More --->
TCP LanInternet 209.85.169.100:80 LanOTCEXGROUP 192.168.77.152:61803, idle 0:00:00, bytes 34054, flags UIOX
TCP LanInternet 209.85.169.100:80 LanOTCEXGROUP 192.168.97.73:59947, idle 0:00:20, bytes 1141, flags UIOX
TCP LanInternet 209.85.169.100:80 LanOTCEXGROUP 192.168.97.59:53206, idle 0:00:32, bytes 34118, flags UIOX
TCP LanInternet 209.85.169.100:80 LanOTCEXGROUP 192.168.97.209:2005, idle 0:00:02, bytes 203033, flags UIOX
TCP LanInternet 209.85.169.100:80 LanOTCEXGROUP 192.168.77.58:53306, idle 0:03:16, bytes 33694, flags UFRIOX
TCP LanInternet 209.85.169.100:80 LanOTCEXGROUP 192.168.77.58:53198, idle 0:03:58, bytes 235748, flags UFRIOX
TCP LanInternet 209.85.169.100:443 LanOTCEXGROUP 192.168.77.83:1875, idle 0:08:09, bytes 6073, flags UFRIO
TCP LanInternet 64.4.61.205:80 LanOTCEXGROUP 192.168.77.132:4111, idle 0:00:58, bytes 50474, flags UIOX
TCP LanInternet 87.248.221.91:443 LanOTCEXGROUP 192.168.77.83:2206, idle 0:00:46, bytes 1974926, flags UIO
TCP LanInternet 68.233.253.153:80 LanOTCEXGROUP 192.168.77.161:53065, idle 0:00:13, bytes 13553, flags UIOX
TCP LanInternet 174.35.64.38:80 LanOTCEXGROUP 192.168.77.166:58705, idle 0:00:57, bytes 1766, flags UFRIOX
UDP LanInternet 89.216.221.24:53211 LanOTCEXGROUP PCFIXEREDA:43080, idle 0:00:26, bytes 49, flags -
TCP LanInternet 199.47.216.174:443 LanOTCEXGROUP 192.168.77.172:55010, idle 0:00:08, bytes 55700, flags UFRIO
TCP LanInternet 173.44.34.210:80 LanOTCEXGROUP 192.168.97.204:1764, idle 0:00:02, bytes 77803, flags UIOX
TCP LanInternet 194.78.100.153:443 LanOTCEXGROUP 192.168.77.62:53769, idle 0:00:31, bytes 4156, flags UIO
TCP LanInternet 194.78.100.153:443 LanOTCEXGROUP 192.168.77.62:53768, idle 0:00:29, bytes 6550, flags UIO
TCP LanInternet 194.78.100.153:443 LanOTCEXGROUP 192.168.77.62:53767, idle 0:00:29, bytes 177558, flags UIO
TCP LanInternet 194.78.100.153:443 LanOTCEXGROUP 192.168.77.62:53766, idle 0:00:30, bytes 12230, flags UIO
TCP LanInternet 194.78.100.153:443 LanOTCEXGROUP 192.168.77.62:53764, idle 0:00:30, bytes 19786, flags UIO
TCP LanInternet 98.138.26.48:443 LanOTCEXGROUP 192.168.117.166:50306, idle 0:00:08, bytes 48693, flags UIO
UDP LanInternet 203.161.68.145:58442 LanOTCEXGROUP 192.168.117.23:23231, idle 0:01:50, bytes 255, flags -
TCP LanInternet 64.12.165.106:443 LanOTCEXGROUP 192.168.77.70:61628, idle 0:01:37, bytes 15491, flags UIO
UDP LanInternet 95.27.84.74:52821 LanOTCEXGROUP 192.168.117.23:23231, idle 0:01:36, bytes 467, flags -
TCP LanInternet 69.171.242.54:80 LanOTCEXGROUP 192.168.77.136:53831, idle 0:00:00, bytes 763, flags UOX
<--- More --->
TCP LanInternet 69.63.180.48:80 LanOTCEXGROUP 192.168.77.74:3841, idle 0:00:41, bytes 33272, flags UIOX
TCP LanInternet 62.23.17.226:80 LanOTCEXGROUP 192.168.77.64:58614, idle 0:04:22, bytes 13660, flags UFRIOX
TCP LanInternet 62.23.17.226:80 LanOTCEXGROUP 192.168.97.208:60089, idle 0:06:00, bytes 13740, flags UFRIOX
TCP LanInternet 209.85.147.125:443 LanOTCEXGROUP 192.168.77.172:54855, idle 0:00:54, bytes 12941, flags UIO
TCP LanInternet 69.191.247.60:443 LanOTCEXGROUP 192.168.77.40:63629, idle 0:01:34, bytes 5855, flags UIO
TCP LanInternet 69.191.247.60:443 LanOTCEXGROUP 192.168.77.40:63550, idle 0:00:15, bytes 5547, flags UIO
TCP LanInternet 216.23.232.188:2193 LanOTCEXGROUP 192.168.117.24:49293, idle 0:00:03, bytes 1094336, flags UIO
UDP LanInternet 109.208.208.27:14417 LanOTCEXGROUP 192.168.117.23:23231, idle 0:01:22, bytes 273, flags -
TCP LanInternet 209.85.229.125:5222 LanOTCEXGROUP PCFIXEREDA:50585, idle 0:00:14, bytes 132083, flags UIO
TCP LanInternet 87.248.221.46:443 LanOTCEXGROUP 192.168.87.140:59158, idle 0:02:11, bytes 24370200, flags UFRIO
TCP LanInternet 193.178.154.162:443 LanOTCEXGROUP 192.168.97.100:1138, idle 0:06:40, bytes 1121, flags UFRIO
TCP LanInternet 98.158.194.181:80 LanOTCEXGROUP 192.168.97.122:57227, idle 0:00:04, bytes 113684, flags UIOX
UDP LanInternet 79.95.181.238:13877 LanOTCEXGROUP PCVLAD:41008, idle 0:00:36, bytes 357, flags -
TCP LanInternet 209.85.148.147:443 LanOTCEXGROUP 192.168.77.172:55012, idle 0:00:34, bytes 2150, flags UIO
TCP LanInternet 83.141.153.12:443 LanOTCEXGROUP 192.168.97.208:59615, idle 0:00:19, bytes 1969452, flags UIO
TCP LanInternet 98.138.26.113:443 LanOTCEXGROUP 192.168.97.35:61847, idle 0:08:42, bytes 42189, flags UIO
TCP LanInternet 2.16.85.55:80 LanOTCEXGROUP 192.168.97.173:58477, idle 0:00:31, bytes 3178, flags UIOX
TCP LanInternet 2.16.85.55:80 LanOTCEXGROUP 192.168.97.173:58476, idle 0:00:30, bytes 1246, flags UIOX
TCP LanInternet 2.16.85.55:80 LanOTCEXGROUP 192.168.77.166:58662, idle 0:00:16, bytes 1115, flags UFRIOX
TCP LanInternet 2.16.85.55:80 LanOTCEXGROUP 192.168.77.166:58661, idle 0:00:16, bytes 1402, flags UFRIOX
TCP LanInternet 2.16.85.55:80 LanOTCEXGROUP 192.168.77.166:58660, idle 0:00:16, bytes 1127, flags UFRIOX
TCP LanInternet 2.16.85.55:80 LanOTCEXGROUP 192.168.77.166:58659, idle 0:00:16, bytes 1169, flags UFRIOX
TCP LanInternet 2.16.85.55:80 LanOTCEXGROUP 192.168.77.166:58658, idle 0:00:16, bytes 1635, flags UFRIOX
TCP LanInternet 2.16.85.55:80 LanOTCEXGROUP 192.168.77.166:58655, idle 0:00:16, bytes 1432, flags UFRIOX
<--- More --->
TCP LanInternet 2.16.85.55:80 LanOTCEXGROUP 192.168.77.166:58654, idle 0:00:16, bytes 1480, flags UFRIOX
TCP LanInternet 2.16.85.55:80 LanOTCEXGROUP 192.168.77.166:58653, idle 0:00:16, bytes 3328, flags UFRIOX
TCP LanInternet 74.125.230.90:80 LanOTCEXGROUP 192.168.117.30:60698, idle 0:00:14, bytes 20109, flags UIOX
TCP LanInternet 74.125.230.90:80 LanOTCEXGROUP 192.168.77.166:59038, idle 0:00:40, bytes 1282, flags UIOX
TCP LanInternet 74.125.230.90:80 LanOTCEXGROUP 192.168.77.147:3787, idle 0:00:43, bytes 43417, flags UIOX
TCP LanInternet 74.125.230.90:80 LanOTCEXGROUP 192.168.97.122:57226, idle 0:00:42, bytes 11917, flags UIOX
TCP LanInternet 74.125.230.90:80 LanOTCEXGROUP 192.168.97.122:57211, idle 0:00:51, bytes 1722, flags UIOX
UDP LanInternet 192.168.217.18:32000 LanOTCEXGROUP 192.168.4.1:32128, idle 0:00:14, bytes 61984, flags -
TCP LanInternet 194.78.100.187:80 LanOTCEXGROUP 192.168.77.152:61798, idle 0:00:09, bytes 4927, flags UIOX
TCP LanInternet 194.78.100.187:80 LanOTCEXGROUP 192.168.77.152:61799, idle 0:00:09, bytes 4541, flags UIOX
TCP LanInternet 194.78.100.187:80 LanOTCEXGROUP 192.168.77.152:61797, idle 0:00:09, bytes 21490, flags UIOX
TCP LanInternet 194.78.100.187:80 LanOTCEXGROUP 192.168.77.152:61795, idle 0:00:09, bytes 2026, flags UIOX
TCP LanInternet 194.78.100.187:80 LanOTCEXGROUP 192.168.77.152:61793, idle 0:00:09, bytes 16920, flags UIOX
TCP LanInternet 194.78.100.187:80 LanOTCEXGROUP 192.168.77.152:61792, idle 0:00:09, bytes 54990, flags UIOX
TCP LanInternet 216.23.224.103:2192 LanOTCEXGROUP 192.168.117.24:49294, idle 0:00:09, bytes 1100686, flags UIO
UDP LanInternet 142.151.173.118:29072 LanOTCEXGROUP PCFIXEREDA:43080, idle 0:00:21, bytes 49, flags -
TCP LanInternet 66.220.151.90:80 LanOTCEXGROUP 192.168.77.67:3641, idle 0:00:43, bytes 47610, flags UIOX
TCP LanInternet 194.78.100.144:80 LanOTCEXGROUP 192.168.77.136:53833, idle 0:00:06, bytes 3663, flags UIOX
TCP LanInternet 194.78.100.144:80 LanOTCEXGROUP 192.168.77.136:53832, idle 0:00:06, bytes 3272, flags UIOX
TCP LanInternet 194.78.100.144:80 LanOTCEXGROUP 192.168.97.52:58999, idle 0:00:43, bytes 3351, flags UIOX
TCP LanInternet 194.78.100.171:80 LanOTCEXGROUP 192.168.87.140:61977, idle 0:00:04, bytes 1101, flags UIOX
TCP LanInternet 194.78.100.171:80 LanOTCEXGROUP 192.168.97.178:49947, idle 0:00:09, bytes 965, flags UIOX
TCP LanInternet 194.78.100.171:80 LanOTCEXGROUP 192.168.97.122:57237, idle 0:00:01, bytes 2236, flags UIOX
TCP LanInternet 194.78.100.171:80 LanOTCEXGROUP 192.168.77.166:59035, idle 0:00:41, bytes 3839, flags UIOX
<--- More --->
TCP LanInternet 2.16.15.55:80 LanOTCEXGROUP 192.168.117.30:60736, idle 0:00:13, bytes 1020, flags UIOX
TCP LanInternet 2.16.15.55:80 LanOTCEXGROUP 192.168.117.30:60735, idle 0:00:14, bytes 1302, flags UIOX
TCP LanInternet 2.16.15.55:80 LanOTCEXGROUP 192.168.97.73:59869, idle 0:00:29, bytes 3436, flags UIOX
TCP LanInternet 2.16.15.55:80 LanOTCEXGROUP 192.168.97.73:59864, idle 0:00:29, bytes 1416, flags UIOX
TCP LanInternet 209.85.169.190:80 LanOTCEXGROUP 192.168.77.72:3376, idle 0:00:17, bytes 121495, flags UIOX
TCP LanInternet 199.47.216.146:80 LanOTCEXGROUP 192.168.77.172:54903, idle 0:00:16, bytes 10162, flags UIOX
TCP LanInternet 199.47.216.146:80 LanOTCEXGROUP 192.168.77.172:54902, idle 0:00:16, bytes 10539, flags UIOX
UDP LanInternet 132.239.106.198:62377 LanOTCEXGROUP 192.168.117.23:23231, idle 0:01:17, bytes 57, flags -
TCP LanInternet 209.85.148.104:80 LanOTCEXGROUP 192.168.97.88:60006, idle 0:00:01, bytes 45358, flags UIOX
TCP LanInternet 64.4.34.223:80 LanOTCEXGROUP 192.168.77.127:4428, idle 0:00:19, bytes 40927, flags UIOX
UDP LanInternet 46.42.140.220:13837 LanOTCEXGROUP 192.168.117.166:19552, idle 0:01:21, bytes 234, flags -
TCP LanInternet 206.169.37.143:80 LanOTCEXGROUP 192.168.97.69:62168, idle 0:00:06, bytes 7217, flags UIOX
TCP LanInternet 8.12.40.62:443 LanOTCEXGROUP 192.168.77.62:53775, idle 0:00:00, bytes 5201, flags UIO
TCP LanInternet 8.12.40.62:443 LanOTCEXGROUP 192.168.77.62:53774, idle 0:00:00, bytes 18498, flags UIO
TCP LanInternet 8.12.40.62:80 LanOTCEXGROUP 192.168.77.127:4653, idle 0:00:09, bytes 151979, flags UIOX
TCP LanInternet 95.172.89.156:80 LanOTCEXGROUP 192.168.97.97:60892, idle 0:00:09, bytes 14889, flags UIOX
TCP LanInternet 78.109.83.1:80 LanOTCEXGROUP 192.168.77.74:4167, idle 0:00:06, bytes 1121, flags UIOX
UDP LanInternet 208.88.186.6:34026 LanOTCEXGROUP 192.168.117.23:23231, idle 0:01:37, bytes 137, flags -
TCP LanInternet 87.98.180.121:80 LanOTCEXGROUP 192.168.77.127:4613, idle 0:03:36, bytes 2313, flags UFRIOX
TCP LanInternet 69.171.228.20:443 LanOTCEXGROUP 192.168.77.62:53745, idle 0:00:40, bytes 27680, flags UIO
TCP LanInternet 69.171.228.20:443 LanOTCEXGROUP 192.168.77.62:53744, idle 0:00:56, bytes 27655, flags UIO
TCP LanInternet 69.171.228.20:443 LanOTCEXGROUP 192.168.77.62:53743, idle 0:00:56, bytes 26306, flags UIO
TCP LanInternet 69.171.228.20:443 LanOTCEXGROUP 192.168.77.62:53742, idle 0:00:56, bytes 24509, flags UIO
TCP LanInternet 69.171.228.20:443 LanOTCEXGROUP 192.168.77.62:53725, idle 0:00:48, bytes 35269, flags UIO
<--- More --->
TCP LanInternet 31.12.64.23:80 LanOTCEXGROUP 192.168.97.58:2284, idle 0:01:24, bytes 3901, flags UIOX
TCP LanInternet 72.21.93.36:80 LanOTCEXGROUP 192.168.97.73:60029, idle 0:00:05, bytes 746, flags UFRIOX
TCP LanInternet 72.21.93.36:80 LanOTCEXGROUP 192.168.97.73:60028, idle 0:00:05, bytes 746, flags UFRIOX
TCP LanInternet 193.108.18.194:443 LanOTCEXGROUP 192.168.97.59:58882, idle 0:00:02, bytes 3523161, flags UIO
TCP LanInternet 91.103.136.108:80 LanOTCEXGROUP 192.168.77.66:49639, idle 0:01:15, bytes 544, flags UOX
TCP LanInternet 91.103.136.108:80 LanOTCEXGROUP 192.168.77.66:49638, idle 0:01:15, bytes 544, flags UOX
TCP LanInternet 91.103.136.108:80 LanOTCEXGROUP 192.168.77.66:49637, idle 0:01:15, bytes 18597, flags UIOX
TCP LanInternet 194.78.100.146:80 LanOTCEXGROUP 192.168.77.166:59048, idle 0:00:48, bytes 9860, flags UIOX
TCP LanInternet 194.78.100.146:80 LanOTCEXGROUP 192.168.77.166:59000, idle 0:00:48, bytes 156785, flags UIOX
TCP LanInternet 12.29.100.224:80 LanOTCEXGROUP 192.168.97.122:57201, idle 0:01:11, bytes 21036, flags UIOX
TCP LanInternet 194.78.100.199:443 LanOTCEXGROUP 192.168.97.173:58594, idle 0:00:31, bytes 110928, flags UIO
TCP LanInternet 194.78.100.199:443 LanOTCEXGROUP 192.168.97.73:59979, idle 0:00:33, bytes 1247036, flags UIO
TCP LanInternet 194.78.100.199:443 LanOTCEXGROUP 192.168.77.166:58935, idle 0:01:06, bytes 110928, flags UIO
TCP LanInternet 194.78.100.199:1935 LanOTCEXGROUP 192.168.117.30:60649, idle 0:01:17, bytes 110961, flags UIO
TCP LanInternet 194.78.100.199:443 LanOTCEXGROUP 192.168.97.86:57940, idle 0:01:17, bytes 111044, flags UIO
TCP LanInternet 194.78.100.199:443 LanOTCEXGROUP 192.168.77.140:50733, idle 0:01:17, bytes 68088670, flags UFRIO
TCP LanInternet 66.220.158.47:443 LanOTCEXGROUP 192.168.77.189:2643, idle 0:00:41, bytes 231624, flags UIO
TCP LanInternet 194.78.100.179:80 LanOTCEXGROUP 192.168.77.152:61823, idle 0:00:06, bytes 31054, flags UIOX
TCP LanInternet 194.78.100.179:80 LanOTCEXGROUP 192.168.77.152:61821, idle 0:00:06, bytes 12986, flags UIOX
TCP LanInternet 194.78.100.179:80 LanOTCEXGROUP 192.168.77.152:61820, idle 0:00:06, bytes 13684, flags UIOX
TCP LanInternet 194.78.100.179:80 LanOTCEXGROUP 192.168.77.152:61817, idle 0:00:06, bytes 15398, flags UIOX
TCP LanInternet 194.78.100.179:80 LanOTCEXGROUP 192.168.77.152:61809, idle 0:00:06, bytes 14576, flags UIOX
TCP LanInternet 194.78.100.179:80 LanOTCEXGROUP 192.168.77.152:61788, idle 0:00:06, bytes 136279, flags UIOX
TCP LanInternet 193.149.47.98:80 LanOTCEXGROUP 192.168.77.58:53291, idle 0:03:32, bytes 6276, flags UFRIOX
<--- More --->
TCP LanInternet 74.125.230.88:443 LanOTCEXGROUP 192.168.77.196:55774, idle 0:00:12, bytes 12904, flags UIO
TCP LanInternet 74.125.230.88:443 LanOTCEXGROUP 192.168.97.209:1876, idle 0:00:09, bytes 33705, flags UIO
TCP LanInternet 74.125.230.88:443 LanOTCEXGROUP 192.168.97.97:59690, idle 0:00:10, bytes 1376546, flags UIO
TCP LanInternet 195.154.246.166:80 LanOTCEXGROUP 192.168.97.33:2078, idle 0:02:32, bytes 7745, flags UFRIOX
TCP LanInternet 195.154.246.166:80 LanOTCEXGROUP 192.168.97.33:2077, idle 0:02:32, bytes 13649, flags UFRIOX
TCP LanInternet 195.154.246.166:80 LanOTCEXGROUP 192.168.97.33:2076, idle 0:02:32, bytes 7911, flags UFRIOX
TCP LanInternet 195.154.246.166:80 LanOTCEXGROUP 192.168.97.33:2075, idle 0:02:32, bytes 9233, flags UFRIOX
TCP LanInternet 195.154.246.166:80 LanOTCEXGROUP 192.168.97.33:2074, idle 0:02:32, bytes 14581, flags UFRIOX
TCP LanInternet 195.154.246.166:80 LanOTCEXGROUP 192.168.97.33:2073, idle 0:02:32, bytes 28742, flags UFRIOX
TCP LanInternet 64.236.90.73:80 LanOTCEXGROUP 192.168.97.219:64046, idle 0:00:00, bytes 5741, flags UIOX
TCP LanInternet 64.4.61.209:80 LanOTCEXGROUP 192.168.97.122:57002, idle 0:00:11, bytes 30140, flags UIOX
TCP LanInternet 66.220.151.88:80 LanOTCEXGROUP 192.168.97.122:56797, idle 0:00:25, bytes 67382, flags UIOX
TCP LanInternet 208.65.75.22:443 LanOTCEXGROUP 192.168.77.40:63745, idle 0:00:01, bytes 624601, flags UIO
TCP LanInternet 194.78.100.162:80 LanOTCEXGROUP 192.168.97.219:64048, idle 0:00:00, bytes 839, flags UIOX
TCP LanInternet 194.78.100.162:80 LanOTCEXGROUP 192.168.97.219:64047, idle 0:00:00, bytes 91199, flags UIOX
TCP LanInternet 194.78.100.162:80 LanOTCEXGROUP 192.168.97.173:58550, idle 0:00:34, bytes 35849, flags UIOX
TCP LanInternet 194.78.100.162:80 LanOTCEXGROUP 192.168.77.66:49550, idle 0:01:20, bytes 723, flags UIOX
TCP LanInternet 194.78.100.162:80 LanOTCEXGROUP 192.168.77.66:49549, idle 0:01:20, bytes 723, flags UIOX
TCP LanInternet 194.78.100.162:80 LanOTCEXGROUP 192.168.77.66:49548, idle 0:01:20, bytes 723, flags UIOX
TCP LanInternet 194.78.100.162:80 LanOTCEXGROUP 192.168.97.209:1825, idle 0:08:40, bytes 8237, flags UFRIOX
TCP LanInternet 194.78.100.162:80 LanOTCEXGROUP 192.168.97.209:1823, idle 0:08:39, bytes 18541, flags UFRIOX
TCP LanInternet 194.78.100.162:80 LanOTCEXGROUP 192.168.97.209:1824, idle 0:08:40, bytes 10455, flags UFRIOX
TCP LanInternet 194.78.100.162:80 LanOTCEXGROUP 192.168.97.209:1797, idle 0:08:16, bytes 40043, flags UFRIOX
TCP LanInternet 194.78.100.162:80 LanOTCEXGROUP 192.168.97.209:1796, idle 0:08:16, bytes 43790, flags UFRIOX
<--- More --->
TCP LanInternet 91.206.232.220:80 LanOTCEXGROUP 192.168.97.88:60037, idle 0:00:01, bytes 2406, flags UIOX
TCP LanInternet 91.206.232.220:80 LanOTCEXGROUP 192.168.97.88:60019, idle 0:00:01, bytes 338272, flags UIOX
UDP LanInternet 156.48.250.6:10000 LanOTCEXGROUP 172.16.40.113:10000, idle 0:00:00, bytes 3247197, flags -
UDP LanInternet 156.48.250.6:500 LanOTCEXGROUP 172.16.40.113:3725, idle 0:00:07, bytes 116641, flags -
TCP LanInternet 89.30.102.210:80 LanOTCEXGROUP 192.168.97.52:58723, idle 0:09:44, bytes 15067, flags UFRIOX
TCP LanInternet 89.30.102.210:80 LanOTCEXGROUP 192.168.97.52:58722, idle 0:09:43, bytes 30630, flags UFRIOX
TCP LanInternet 89.30.102.210:80 LanOTCEXGROUP 192.168.97.52:58721, idle 0:09:43, bytes 43348, flags UFRIOX
TCP LanInternet 89.30.102.210:80 LanOTCEXGROUP 192.168.97.52:58720, idle 0:09:43, bytes 17560, flags UFRIOX
TCP LanInternet 89.30.102.210:80 LanOTCEXGROUP 192.168.97.52:58719, idle 0:09:44, bytes 21520, flags UFRIOX
TCP LanInternet 89.30.102.210:80 LanOTCEXGROUP 192.168.97.52:58715, idle 0:09:44, bytes 456122, flags UFRIOX
TCP LanInternet 194.78.100.185:80 LanOTCEXGROUP 192.168.77.152:61824, idle 0:00:06, bytes 17430, flags UIOX
TCP LanInternet 194.78.100.185:80 LanOTCEXGROUP 192.168.77.152:61819, idle 0:00:14, bytes 15230, flags UIOX
TCP LanInternet 194.78.100.185:80 LanOTCEXGROUP 192.168.77.152:61815, idle 0:00:14, bytes 23696, flags UIOX
TCP LanInternet 194.78.100.185:80 LanOTCEXGROUP 192.168.77.152:61814, idle 0:00:15, bytes 17298, flags UIOX
TCP LanInternet 194.78.100.185:80 LanOTCEXGROUP 192.168.77.152:61807, idle 0:00:14, bytes 17182, flags UIOX
TCP LanInternet 194.78.100.185:80 LanOTCEXGROUP 192.168.77.152:61806, idle 0:00:15, bytes 22286, flags UIOX
TCP LanInternet 194.78.100.185:80 LanOTCEXGROUP 192.168.97.59:53225, idle 0:00:56, bytes 79340, flags UIOX
TCP LanInternet 194.78.100.185:80 LanOTCEXGROUP 192.168.97.52:58724, idle 0:08:35, bytes 833, flags UFRIOX
TCP LanInternet 67.195.187.246:5050 LanOTCEXGROUP 192.168.117.24:56867, idle 0:00:02, bytes 45567, flags UIO
TCP LanInternet 195.24.247.26:80 LanOTCEXGROUP 192.168.77.58:53325, idle 0:03:40, bytes 63150, flags UFRIOX
TCP LanInternet 195.24.247.26:80 LanOTCEXGROUP 192.168.77.58:53327, idle 0:03:40, bytes 41002, flags UFRIOX
TCP LanInternet 195.24.247.26:80 LanOTCEXGROUP 192.168.77.58:53326, idle 0:03:40, bytes 26258, flags UFRIOX
TCP LanInternet 195.24.247.26:80 LanOTCEXGROUP 192.168.77.58:53324, idle 0:03:40, bytes 23132, flags UFRIOX
TCP LanInternet 91.121.188.86:80 LanOTCEXGROUP 192.168.77.58:53308, idle 0:04:56, bytes 1231, flags UFRIOX
<--- More --->
TCP LanInternet 89.30.102.201:80 LanOTCEXGROUP 192.168.97.52:58726, idle 0:09:54, bytes 103227, flags UFRIOX
TCP LanInternet 192.168.217.3:49155 LanOTCEXGROUP 192.168.77.2:60207, idle 0:01:21, bytes 10672, flags UIO
TCP LanInternet 192.168.217.3:3268 LanOTCEXGROUP 192.168.77.20:34766, idle 0:03:12, bytes 270970, flags UIO
TCP LanInternet 192.168.217.3:389 LanOTCEXGROUP 192.168.77.20:34743, idle 0:02:44, bytes 439859, flags UIO
TCP LanInternet 192.168.217.3:3268 LanOTCEXGROUP 192.168.77.20:34729, idle 0:00:03, bytes 19254121, flags UIO
TCP LanInternet 192.168.217.3:3268 LanOTCEXGROUP 192.168.77.20:34727, idle 0:00:39, bytes 1331698, flags UIO
TCP LanInternet 192.168.217.3:3268 LanOTCEXGROUP 192.168.77.20:34716, idle 0:00:34, bytes 902900, flags UIO
TCP LanInternet 192.168.217.3:3268 LanOTCEXGROUP 192.168.77.20:34695, idle 0:01:49, bytes 247888, flags UIO
TCP LanInternet 192.168.217.3:3268 LanOTCEXGROUP 192.168.77.20:34687, idle 0:01:03, bytes 442097, flags UIO
TCP LanInternet 192.168.217.3:3268 LanOTCEXGROUP 192.168.77.20:34678, idle 0:00:12, bytes 2297824, flags UIO
TCP LanInternet 192.168.217.3:3268 LanOTCEXGROUP 192.168.77.20:34674, idle 0:00:29, bytes 5863161, flags UIO
TCP LanInternet 192.168.217.3:3268 LanOTCEXGROUP 192.168.77.20:34644, idle 0:00:13, bytes 9710395, flags UIO
TCP LanInternet 192.168.217.3:3268 LanOTCEXGROUP 192.168.77.20:34638, idle 0:00:28, bytes 2398397, flags UIO
TCP LanInternet 192.168.217.3:3268 LanOTCEXGROUP 192.168.77.20:34634, idle 0:00:06, bytes 11818615, flags UIO
TCP LanInternet 192.168.217.3:49155 LanOTCEXGROUP 192.168.77.32:63877, idle 0:00:24, bytes 1160178, flags UIO
TCP LanInternet 192.168.217.3:49155 LanOTCEXGROUP 192.168.177.3:54431, idle 0:04:49, bytes 651790, flags UIO
TCP LanInternet 194.78.100.160:80 LanOTCEXGROUP 192.168.97.97:60897, idle 0:00:26, bytes 2727, flags UIOX
TCP LanInternet 194.78.100.160:80 LanOTCEXGROUP 192.168.97.35:53978, idle 0:00:41, bytes 16816, flags UIOX
TCP LanInternet 8.12.40.52:80 LanOTCEXGROUP 192.168.77.127:4666, idle 0:00:02, bytes 34332, flags UIOX
TCP LanInternet 8.17.84.107:80 LanOTCEXGROUP 192.168.97.173:58620, idle 0:00:06, bytes 0, flags UX
TCP LanInternet 217.110.110.229:80 LanOTCEXGROUP 192.168.77.58:53286, idle 0:05:04, bytes 1456, flags UFRIOX
TCP LanInternet 69.194.143.60:80 LanOTCEXGROUP 192.168.97.88:60050, idle 0:00:08, bytes 2416, flags UIOX
TCP LanInternet 66.220.151.77:80 LanOTCEXGROUP 192.168.77.64:58377, idle 0:00:34, bytes 56003, flags UIOX
TCP LanInternet 95.131.139.2:80 LanOTCEXGROUP 192.168.77.136:53834, idle 0:00:00, bytes 3886, flags UIOX
<--- More --->
TCP LanInternet 94.245.117.45:80 LanOTCEXGROUP 192.168.97.178:49950, idle 0:00:25, bytes 4194, flags UIOX
TCP LanInternet 94.245.117.45:80 LanOTCEXGROUP 192.168.97.178:49949, idle 0:00:25, bytes 5464, flags UIOX
TCP LanInternet 89.151.66.198:80 LanOTCEXGROUP 192.168.97.88:60060, idle 0:00:08, bytes 1675, flags UIOX
TCP LanInternet 89.151.66.198:80 LanOTCEXGROUP 192.168.97.88:60056, idle 0:00:08, bytes 1675, flags UIOX
TCP LanInternet 65.54.50.55:80 LanOTCEXGROUP 192.168.77.162:65202, idle 0:00:05, bytes 41264, flags UIOX
TCP LanInternet 174.129.224.33:443 LanOTCEXGROUP 192.168.77.172:54992, idle 0:00:48, bytes 82132, flags UFRIO
TCP LanInternet 209.85.148.99:443 LanOTCEXGROUP 192.168.77.152:61790, idle 0:00:29, bytes 3295, flags UIO
TCP LanInternet 209.85.148.99:80 LanOTCEXGROUP 192.168.97.174:2232, idle 0:07:50, bytes 218914, flags UFRIOX
TCP LanInternet 209.85.148.99:80 LanOTCEXGROUP 192.168.97.174:2211, idle 0:07:51, bytes 88512, flags UFRIOX
TCP LanInternet 209.85.148.99:80 LanOTCEXGROUP 192.168.97.174:2166, idle 0:08:29, bytes 0, flags UFRX
TCP LanInternet 74.125.230.86:443 LanOTCEXGROUP 192.168.77.161:53089, idle 0:00:01, bytes 3898, flags UIO
TCP LanInternet 74.125.230.86:443 LanOTCEXGROUP 192.168.97.59:53244, idle 0:00:13, bytes 3691, flags UIO
TCP LanInternet 209.85.169.113:80 LanOTCEXGROUP 192.168.97.219:64050, idle 0:00:08, bytes 25302, flags UIOX
TCP LanInternet 209.85.169.113:80 LanOTCEXGROUP 192.168.97.88:60038, idle 0:00:09, bytes 34965, flags UIOX
TCP LanInternet 209.85.169.113:80 LanOTCEXGROUP 192.168.117.30:60695, idle 0:00:32, bytes 33785, flags UIOX
TCP LanInternet 209.85.169.113:80 LanOTCEXGROUP 192.168.77.166:59037, idle 0:00:57, bytes 34069, flags UIOX
TCP LanInternet 209.85.169.113:80 LanOTCEXGROUP 192.168.77.147:3790, idle 0:00:59, bytes 33653, flags UIOX
TCP LanInternet 209.85.169.113:443 LanOTCEXGROUP 192.168.77.166:58681, idle 0:02:00, bytes 3086, flags UIO
TCP LanInternet 209.85.169.113:443 LanOTCEXGROUP 192.168.77.166:58680, idle 0:02:00, bytes 3193, flags UIO
TCP LanInternet 209.85.169.113:443 LanOTCEXGROUP 192.168.77.166:58679, idle 0:02:00, bytes 5317, flags UIO
TCP LanInternet 209.85.169.113:443 LanOTCEXGROUP 192.168.77.166:58678, idle 0:02:00, bytes 3254, flags UIO
TCP LanInternet 209.85.169.113:443 LanOTCEXGROUP 192.168.77.166:58677, idle 0:02:00, bytes 6066, flags UIO
TCP LanInternet 209.85.169.113:80 LanOTCEXGROUP 192.168.97.174:2231, idle 0:07:49, bytes 7054, flags UFRIOX
TCP LanInternet 193.178.154.164:443 LanOTCEXGROUP 192.168.97.100:1229, idle 0:06:50, bytes 2366, flags UFRIO
<--- More --->
09-27-2011 07:24 AM
Thanks Varun,
I will configure that and report back.
Tom
09-27-2011 08:42 AM
Sure, will wait for your reply.
Varun
09-27-2011 11:23 AM
Hi Varun,
Well .... did as you suggested and could not connect to the server over any port. Put standard NATs back in place and connectivity was restored.
I went ahead and opened a TAC case just to be sure there wasn't some other configured parameter that would explain this failure (and didn't want to waste your time) - but the TAC tech confirmed traffic was coming in on 80 and being redirected to 443 - but something was blocking it getting back to the host.
Not sure how that could be the since the standard NAT works fine.
At this point going forward we're looking at doing the port redirect at the server - but it would have been more convenient having this done on the ASA.
Thanks for your assistance.
Tom
