Crypto Map on Tunnel interface
Sep 29th, 2011
hi guys, when i trying to apply crypto map on tunnel interface , debug is (
crypto map is configured on tunnel interface.  Currently only GDOI crypto map is supported on tunnel interface )
why i can't apply simple crypto map on tunnel interface? anyone knows?
thanks
Marcin Latosiewicz Fri, 09/30/2011 - 08:08
This was proven to break CEF in the past and is a bad design choice by default.
Newer release do not allow you to configure this.
If you're curious if it will work for you check releases prior to 15.x.
M.
