ASA 5520 cable based Failover
Answered Question
Oct 3rd, 2011
What kind of cable is used for failover in asa 5520 ?  Thanks guys
Manesh
Correct Answer by Jennifer Halim about 2 years 6 months ago
With ASA, you will just be using one of the LAN interface on the ASA for failover, ie: straight through cable.
Average Rating: 5 (1 ratings)
Correct Answer
Jennifer Halim Mon, 10/03/2011 - 02:13
ManeshRajan Mon, 10/03/2011 - 02:18
Ha.. that’s great I thought it needs a special cable for failover. Also I have seen that cable based failover is only available in PIX. Is that true?
Thanks Jennifer..
ManeshRajan Mon, 10/03/2011 - 04:02
Hi Varun,
So this kind of configuration is not possible with ASA 5520? Please clear my doubts
varrao Mon, 10/03/2011 - 04:53
Yes, thats right Manish, not with any model of ASA.
Varun
ManeshRajan Mon, 10/03/2011 - 05:01
Hi Varun,
Can you just confirm that ASA 5520 supports cable based Active/Active Failover.
varrao Mon, 10/03/2011 - 05:17
HI Manesh,
Cisco ASA 5520 does not support cable based failover:
Note:
Cable-based failover is available only on the PIX 500 Series Security Appliance.
Varun
hobbe Mon, 10/03/2011 - 06:00
The PIX do have a special failover cable. it is a special cable that are for this purpose only.
The ASA 5520 does NOT have a special failover cable, instead you (or atleast you should) set aside and use one of the Ethernet interfaces to be used as the special failover lan. = normal RJ45 cabeling rules apply. no special cable needed.
Result in both pix and ASA case will be thesame = stateful failover.
So if the question is do you use a special cable then the answer is no, there is nothing special about the cable for the asa, its a normal RJ45 cable.
in the case of pix it is a special cable.
Can you do Active/Active stateful failover with the ASA ? Yes you can.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080834058.shtml#act1
Good luck
ManeshRajan Mon, 10/03/2011 - 09:34
Cable-Based Active/Active Failover is ONLY supported on PIX 500 series security appliance. To answer your question, no, ASA 5500 series cannot do Cable-Based Active/Active Failover,
When the security appliance is configured for Active/Active stateful failover, you cannot enable IPSec or SSL VPN. These features are unavailable. VPN failover is available for Active/Standby failover configurations only.
Login or Register to take actions
Posted October 3, 2011 at 1:50 AM
Stats:
Replies:11 Avg. Rating:5
Views:1789 Votes:0
Shares:0
Tags: asa, asa_5520
Related Content
Discussions Leaderboard
Rank Username Points
1 7,861
2 6,140
3 3,170
4 1,473
5 1,446
