CE 500 Port Configuration
Oct 3rd, 2011
Hi All,
I have the following set-up(see attachment). All the ports are in trunk mode and have the same native vlan. But i can't remotely access switch B from my PC.
I 've tried to resolve the problem by putting the Fa 0/1 port in the router mode but it didn't change a thing.Th switch remained inaccesible.
Can someone give some tips to help me solve the issue?
Thanks.
cadet alain Mon, 10/03/2011 - 03:26
  • Purple, 4500 points or more
leave the port as L2 port and configure an interface vlan with an ip address on the device.
interface vlan x
ip address x.x.x.x
that's all you've got to do if the pc is in same subnet as your vlan interface.
Regards.
Alain.
Bethuelle Mon, 10/03/2011 - 03:47
Hi Alain,
it's worth while noting that I can access Switch A and the CE 500 remotely (that is through SSH  and Telnet) but not switch B so i have the feeling that is has something to do with the configuration of the CE 500.
Regards.
Julie
Alexander Maroukian Mon, 10/03/2011 - 04:27
  • Bronze, 100 points or more
Hi Julie,
Can you ping switch B? If yes are you sure you have enabled ssh and/or telnet and management access is accesible by the PC's network on switch B? If yes please provide sanitized config of ce500 and switch B.
Best regards,
Alex
Bethuelle Mon, 10/03/2011 - 05:34
Hi Alex,
I can't ping B. SSH and Telnet + Access Management has been configured on B. The management of all switches is 10. Ports Gi 0/1, Gi 0/2 and Fa0/1 of the CE 500 are all in native vlan 10. The ports to which the CE 500 connect to on A, B and C have as native vlan 10.
Best Regards.
Julie
cadet alain Mon, 10/03/2011 - 05:50
can you provide output of followings on B:
-sh ip int brief | i Vlan
- sh int trunk
-sh int  x/x status
-sh int x/x switchport  where x/x is port connected to CE500
-Does sh ip arp shows the PC mac address?
Regards.
Alain.
Alexander Maroukian Mon, 10/03/2011 - 06:42
Ok, if you try to connect from switch C command line not from the PC to switch B what is the result?
Best regards,
Alex
cadet alain Mon, 10/03/2011 - 05:13
Hi Julie,
Oups sorry I misread the original post.
Regards.
Alain.
