No dependency Records after Upgrade
Answered Question
Oct 4th, 2011
We have recently upgraded from CUCM 7.15 to CUCM 8.5.1.12900-7 and right of the bat noticed that dependency records are missing when we check to see who is part of a pick-up group, I know it was there before but it’s now gone.
Is this a known bug and if so is there a fix for it?
Also whilst running RTMT we have noticed that our registered phones keep fluctuating, what I mean by that is that if I put 40 phones in the lab RTMT reports that we have lost 4 phones then around 5 minutes later they appear back; the phones never go off line at all though whilst looking at them.
Thanks all
Chet
Correct Answer by Rob Huffman about 5 years 8 months ago
Hey Chet,
I would open a TAC case to see if they can load up one of
the "fixed-in" versions for special download. You won't want to go to 8.6
this weekend I wouldn't think due to the new refresh Upgrade process
requirements.
Check it out here;
https://supportforums.cisco.com/docs/DOC-16898
Cheers!
Rob
Hi Chet,
I don't see your version in the "fixed-in" versions
CSCts02791 - Dependency records for call pickup group returns no results
Description
Symptom:
When using the dependency records for call pickup group, the result is always "
0 Record(s) are using Call Pickup Group: "
Conditions:
This is only seen as from 7.1.5.34060-1
Workaround:
Use 7.1.5.33052-2
Further Problem Description:
This issue was caused by the checkin of CSCtc66558
Details
1st Found-in:                          (1)
7.1(5)
More
Less
Status:
Fixed
Last Modified:
Oct 02,2011
Known Affected Versions:
More
Less
Fixed-in:                          (7)
8.6(2.98000.7), 8.6(2.98000.16), 8.6(1.21011.1)
8.5(1.13900.3), 8.5(1.13036.1), 8.0(3.23040.1)
7.1(5.34069.1)
More
Less
Product:
Cisco Unified Communications Manager (CallManager)
Platform:
Dependent
Severity:
3 - moderate
Customer Reported:                          (10)
I don't see any bugs for RTMT that jump out as this issue.
Cheers!
Rob
Overall Rating: 5 (2 ratings)
Correct Answer
Rob Huffman Tue, 10/04/2011 - 12:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Chet,
Description
Symptom:
Conditions:
Workaround:
Use 7.1.5.33052-2
Details
1st Found-in:                          (1)
7.1(5)
More
Less
Status:
Fixed
Last Modified:
Oct 02,2011
More
Less
Fixed-in:                          (7)
7.1(5.34069.1)
More
Less
Product:
Platform:
Dependent
Severity:
3 - moderate
Cheers!
Rob
martynch1 Tue, 10/04/2011 - 13:52
Thanks for the reply, wow got to upgrade our cluster again after only 2 days, 1 publisher 4 subscribers and a TFTP server.
Another long weekend
martynch1 Tue, 10/04/2011 - 14:00
Just been on to CCO they only have:
UCSInstall_UCOS_8.6.1.20000-1.sgn.iso, has the fix not been released yet?
Correct Answer
Rob Huffman Tue, 10/04/2011 - 14:10
  • Hall of Fame,
    Founding Member
Hey Chet,
requirements.
Check it out here;
Cheers!
Rob
