10-04-2011 01:04 PM - edited 03-16-2019 07:19 AM
The demo license for Cisco UCM allow up to 3 nodes with 500 DLU for 90 days.
What happens if I import phones equaling 1300 DLU (around 350 phones)?
I understand it will give me licensing errors, but will it still allow me to import those phones? If it does what are some other options I can do?
BTW - This is for testing that will eventually have the appriorpriate licensing required.
Thank you!
-rya
Solved! Go to Solution.
10-07-2011 05:55 PM
Hi Rya,
A DRS restore won't care about the DLU mismatch as you would be expected
to re-license if replacing a server. So you should be good to go
Cheers!
Rob
10-07-2011 09:49 AM
any ideas?
-rya
10-07-2011 10:11 AM
Hi Rya,
When you say import, I'm guessing this means a BAT import. If so
you will receive an error like this when you reach the 500 DLU limit;
Error : 4935 Allocated licenses consumed by used and pending
and the remaining phones will not be imported
Cheers!
Rob
10-07-2011 03:04 PM
Actually its from a restore not BAT. Would it generate the same error?
Thank you!
-rya
10-07-2011 05:55 PM
Hi Rya,
Cheers!
Rob
10-09-2011 11:31 PM
Thank you Rob!
-rya
