v8.3 and above & NAT
Answered Question
Oct 5th, 2011
I have looked in the books I have (Cisco ASA, PIX and FWSM; ASA 8.0) and googled a good bit but can't seem to find any specific mention of how to do NAT exemption with v8.4. It seems NAT exemption (NAT 0 access-list) was deprecated. Using ASDM, there's no corresponding menu item for this that is obvious.
We have public addresses inside the ASA and want to allow in/outbound connections using these IP's without NAT. The ASA is a 5550.
Correct Answer by varrao about 5 years 9 months ago
For Static nat:
static(inside, outside) 192.168.1.5 192.168.1.5 netmask 255.255.255.255
becomes:
object network obj_test
  host 192.168.1.5
nat (inside,outside) source static obj_test obj-test     ------------> Manual nat
or
  host 192.168.1.5
  nat (inside,outside) static 192.168.1.5                         ------------> Auto nat (this is done inside the object only)
Nat exemption:
access-list exempt1 permit ip 192.168.1.0 255.255.255.0 any
nat(inside) 0 access-list exempt1
becomes:
object network obj_test1
  subnet 192.168.1.0 255.255.255.0
object network obj_any
  subnet 0.0.0.0 0.0.0.0
nat (inside,any) source static obj_test1 obj_test1 destination static obj_any obj_any
I hope I was able to clear your doubts.
Varun
Overall Rating: 5 (1 ratings)
Bob MacLean Wed, 10/05/2011 - 08:54
The pdf is a good document to have so thanks for putting it up, but there's nothing in it on NAT exemption. I have seen all these documents and none discuss NAT exemption (NAT 0 access-list).
Specifically, how do you move from either of these 2 methods used to avoid NAT:
(note: the IP's involved here are actually public IP's, not private)
OR
to 8.3 or higher NAT notation?
Correct Answer
varrao Wed, 10/05/2011 - 09:13
  • Red, 2250 points or more
For Static nat:
becomes:
  host 192.168.1.5
or
  host 192.168.1.5
Nat exemption:
becomes:
Varun
Bob MacLean Wed, 10/05/2011 - 09:41
Many thanks. I have to add my vote to those who say this new syntax in 8.3+ is not great but so what, we have to adapt to it.
varrao Wed, 10/05/2011 - 09:44
Sure, thanks I work with the 8.3 nat day in and day out and I feel it is far better than the earlier ones, it seems more logical, although yes there might be some things like creating objects but overall its a thumbs up from me.
Cheers,
Varun
Related Content
