Cisco RV110W VPN Setup.
Answered Question
Oct 5th, 2011
We have a new RV100W Router. I would like to use it for iPhones,PC's, and MAC's to connect via IPSec (QuickVPN) or PTTP.
Everytime I go to setup VPN, it tells me I must change to a 10.x.x.1 network. How can I use VPN without doing so?
Thanks!
Correct Answer by mpyhala about 5 years 5 months ago
Hi bndbrennan,
Try changing the IP address, set up your VPN clients, then change the IP back to 192.168.1.1. The reason the router wants to change is because there are so many routers out there that have 192.168.1.1. If you ever try to connect from one of those routers the connection will fail. We see a lot of people that use 192.168.2.1 and it works fine.
Overall Rating: 5 (2 ratings)
Correct Answer
mpyhala Wed, 10/05/2011 - 16:57
  • Gold, 750 points or more
Hi bndbrennan,
bndbrennan Thu, 10/06/2011 - 17:54
Thank You. That worked to allow me to add users and setup vpn. Now, I cannot connect via the iPhones PPTP Client.
Would the address for the vpn service just be the public ip of our router? Do I have to open any ports?
Router is at 192.168.1.1 for private use
VPN Server is set to 192.168.1.9
with clients going to 192.168.1.200 to 214
Any other suggestions?
mpyhala Thu, 10/06/2011 - 18:37
Hi bndbrennan,
The address is the public IP address of the router. If that changes frequently, consider using a free service such as dyndns.com to give you a permanent URL to connect to instead of the IP. (You can also pay your ISP for a static IP)
I'm not sure why your iPhone is not connecting. It sounds like you have it set up right. You may wish to reach out to the Apple community and see if there are any known issues or special settings for the iPhone. Are you connecting from the LAN or from another location over the internet?
bndbrennan Sun, 10/09/2011 - 14:16
Thanks Again. Worked. I can connect my MacBook's to the VPN..However the iOS Devices are saying that the cannot connect to the PPP.
It is most likley an iPhone issue.
mpyhala Mon, 10/10/2011 - 14:45
Hi bndbrennan,
I'm not sure if this will make a difference or not but I just read another post where someone verified that they are now able to connect to an RV220W using PPTP with an iPhone and iPad.
https://supportforums.cisco.com/message/3462377#3462377
Apparently the only thing that changed is the firmware was upgraded on the RV220W. Do you have the latest firmware on the RV110W? (Version 1.0.1.6 was released August 10, 2011)
bndbrennan Mon, 10/10/2011 - 18:04
Thanks.
I ordered a 220w yeaturday to use.
Our RV110w is runnning 1.0.0.2, so I will update it as soon as the nextwork has some downtimes. I didnt think of checking that.
nbasanes Fri, 01/22/2016 - 15:30
  • Cisco Employee,
Did you read the quick start, or call the tech support numbers?
I would start with that, first.
The quick start guide is here:
http://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv110w/quick_start...
There's also an admin guide, here:
http://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv110w/administrat...
Just a quick word of general advice, if you're having trouble connecting to this, maybe try a different browser or two. That actually has helped me with this model.
