UCCX SMTP Logs
Oct 6th, 2011
Anyone have any ideas which logs I should be searching to find outbound smtp logs?  Looking for logging from a UCCX Script when an email is sent.  Looked through a number of logs but not seen anything I could id as smtp.
Nathan
Aaron Harrison Thu, 10/06/2011 - 07:11
  • Community Spotlight Award,
    Member's Choice, May 2015
This step should be logged in the MIVR logs like any other step. If there's no failure, then you might not see anything on the default logging levels. Try turning up the traces...
Do you have some kind of failure?
Aaron
Related Content
