This discussion is locked
Ask the Expert: Nexus 5000, 3000 and 2000 Series
Oct 7th, 2011
  • Gold, 750 points or more
Read the bioWith Lucien Avramov
Welcome to the Cisco Support Community Ask the Expert conversation. This is an opportunity to learn about design, configuration and troubleshooting of the Cisco Nexus 2000, 3000, 5000 Series with cisco Expert Lucien Avramov. Lucien Avramov is a technical marketing engineer in the Server Access Virtualization Business Unit at Cisco, where he supports the Cisco Nexus 5000, 3000 and 2000 Series. He has several industry certifications including CCIE #19945 in Routing and Switching, CCDP, DCNIS, and VCP #66183
Remember to use the rating system to let Lucien know if you have received an adequate response.
Lucien might not be able to answer each question due to the volume expected during this event. Remember that you can continue the conversation on the Data Center sub-community   discussion forum shortly after the event.   This event lasts through October 21, 2011. Visit this forum often to view responses to your questions and the questions of other community members.
Overall Rating: 4.5 (2 ratings)
s-pirrello Sun, 10/09/2011 - 17:41
Lucien,
Can you suggest any drawbacks or any potentiall pitfalls in using a pair of Nexus 3064s for core routing/switching and a pair of 5596 switches for the access layer?
Also, do you know when to expect VPC to be available on the Nexus 3064 switches?
Thank you
Lucien Avramov Mon, 10/10/2011 - 04:06
  • Red, 2250 points or more
Thanks for your question.
There are limitations for L3 multicast type of traffic.
What would be the applications / usage of this type of design?
Any reason why you would prefer a higher tier with N3K instead of N5K with L3?
VPC is already shipping on the latest N3K code on CCO.
s-pirrello Wed, 10/12/2011 - 03:37
We have a small server room that requires 10Gig connectivity plus several 6513s.  A Nexus 7000 doesn't seem ideal for this location so I decided to use a pair 3064 switches that will be the aggregation point for approximately10 6500s via 2 x 1Gig uplinks.  The 6500s are for dense user access requirements.  I would have used the 5596 switches as an alternative for the 3064s as the fiber aggregation but I was told they will not support Netflow in the routing module nor is it in the road map.
The 5596 switches will server 10Gig access for my virtual servers.  If the Netflow feature is offered down the road I may use the 5500s instead.
Thank you Lucien!
tiwang Mon, 10/10/2011 - 04:40
Hi out there
We have a couple of nexus 5010p and are low on ports - I was considering this 10 gig 6 ports expansion-module but on the other hand I can get many extra ports trough a 10 gig fex instead - are there any drawbacks by this? how many fex can I expect a 5010 can handle and will it add som extra latency compared with the "build-in ports" ?
best regards /ti
Lucien Avramov Mon, 10/10/2011 - 05:06
You can have up to 12 Fabric Extenders on the 50x0 family. So if you go with 10 2232, that will give you up to 320 10GE ports, modulo you tolerate a 4:1 oversubscription. No drawbacks as far as capability: the 10 GE fabric extender port will provide you 10 GE ethernet or FCoE capacity as a 10GE port on the Nexus 5000. If will add around 800 ns latency. Do you have specific latency requirements?
tiwang Mon, 10/10/2011 - 05:13
hi again
Well specific latency requirements - just as fast as possibly - we are running iSCSI instead of FCoE (or FC) so as fast as possibly might be the best answer here...
My concern is just that I have a pretty fast cut-though switch here and if I add some extra latency with the fex instead of using the build-in ports it might have been better to buy the expansion module instead. I don't expect that I am going to use all the ports in the fex (we are cabling directly from the nexus to a 10gig pass-through module of a Dell M1000 bladecenter so we 10 gig all the way though to the servers) - but one newer know - better have to many ports than be low on ports..
best regards /ti
Lucien Avramov Mon, 10/10/2011 - 05:24
The latency on the 5010 is around 3.4 usec, a fex will add you 0.8 usec if you add 10G ports on the FEX instead of the 5010, so that would be a choice for you to make. So there is a trade off.. port count / port cost or port latency.
torsten.weinman... Mon, 10/10/2011 - 06:15
Hi Lucien,
i've got an problem with the Ports which are configured as 1G-Ports.
The Problem is, that the connection to other Devices are "timeouted". Ping works fine, but when data is transfered to other Devices via the 1G Port, the transfer stopped because of a timeout.
Have you got any idea? FLowcontrol?
Thanks!
Lucien Avramov Mon, 10/10/2011 - 14:22
What type of end to end speed do you have? Are you oversubcribing a 1 GE link? Flow control does not create timeouts.
torsten.weinman... Wed, 10/12/2011 - 02:36
Hi Lucien,
the end-to-end connection ist 1Gbit to 10Gbit.
Torsten
Lucien Avramov Thu, 10/13/2011 - 01:36
Do you have a 5500 serie? If so, can you  make sure you are running 5.0.3 code on Nexus 5000, since that is the version that supports 1GE on 5500 series.
tiwang Mon, 10/10/2011 - 07:31
Hi again
Another question - I have added a vpc between 2 nx5010 where I have a 20 g peerlink between and a mgmt-interface acting as keepalive link. Now I add another vpc between a remote set of nexus (similary) and has tested if this can be used as failover between two sites - works fine. but - what happens if my keepaliave link fails (uplinket it to a 3. switch where we run all the management links on)
best regards /ti
tiwang Mon, 10/10/2011 - 23:51
hi again
ok - now I try to understand what you are telling me - the secondary will suspends its vpc ports - this means that the the primary will continue to forward packets and the other nexus - the secondary - will suspend its vpc similary as if I run into a blocked port (spt) - so that I f.ex in my case here with a vpc between a local and remote set of nexus will only run on one link?
Lucien Avramov Thu, 10/13/2011 - 01:38
Correct that is in case you have a failure of N5K. If you have a fabric extender that is dual homed to two nexus 5000 switches, then this will allow you to have active / active
areanetsenato Tue, 10/11/2011 - 08:57
Hi Lucien,
I've some doubts about stability and reliability of Nexus 5000 firmware...
4.2(1)N2(1)  Release Date: 30/JUL/2010
5.0(2)N1(1)  Release Date: 18/OCT/2010
5.0(2)N2(1)  Release Date: 20/DEC/2010
5.0(3)N1(1)  Release Date: 03/MAR/2011 --> deferred
5.0(3)N1(1c) Release Date: 07/MAY/2011
5.0(3)N2(1)  Release Date: 13/JUN/2011
5.0(3)N2(2)  Release Date: 09/SEP/2011
After 4 update in 5 month and after a deferred version i've stopped upgrade on 5.0(3)N2(1) because i can stop my network so often...
Nexus firmware 5.0(3)N1(1c) automatically reboot our two Nexus 5010 every 12/15 days; support suggestion was  update to 5.0(3)N2(1) and the new version was up for 28 days... a great improvement !!!
And then I've read incomplete Release Notes or caveat resolved but not listed...
What is happening ?!?
I've installed 4 Nexus 5010 and 12 N2K-C2248TP and every firmware upgrade is a conflict with my management due to real cause and resolution for the new firmware update ...
I cannot continue with this level of service...
Any suggestion ?!?
Marco
Lucien Avramov Thu, 10/13/2011 - 08:36
I'd suggest to work with our TAC engineers and escalation team to exactly find the issues you were running into and you can have them also involve me so I can work with you on a get well plan. There were reasons for the deferral and we had introduced new platforms and new software features which required to have a few releases in 5.0.3 code. In general due to the high feature velocity, the latest version is the greatest, here for instance 5.0(3)N2(2), but I would suggest to first identify precisely the root cause of your current issue(s).
mleinio Tue, 10/11/2011 - 09:00
Hi Lucien! What is the maximum number of hardware port-channels in Nexus 5548 and 5596? If I remember correctly it was 16 in 5010 and 5020. Is the hw port-channel allocation logic also the same as in 5010 and 5020?
Lucien Avramov Thu, 10/13/2011 - 01:48
I'm glad you asked, it's a higher number on the 5500 series generation of switches.
There is no limitation besides the number of ports here.
You can have up to 48 port-channels on 5548 and 96 on the 5596.
We have a document that shows limits on both platforms here, it's called configuration limits:
http://www.cisco.com/en/US/products/ps9670/products_installation_and_configuration_guides_list.html
GarryGlendown Wed, 10/12/2011 - 00:37
we have just put a new core switch up for a customer, currently one 5548 feeding L2 into several 2960S switches, as well as 4 FEX 2248 (with 2x10GE each) for Data Center access in two locations. The 5548 and two 2248 are in one data center, the other two 2248 are in the second DC. Early next year the customer will be adding a second 5548 for full redundancy (currently, the servers in the DCs are connected to both 2248's in DC, which doesn't help if the 5548 crashes or dies). I've seen docs about doing a dual 5548 configuration with the FEXes connected to two N5K's. What do I need to watch out for when extending the current configuration? How is the configuration of the N5k's handled in respect of the FEX ports? Manually I assume?
Lucien Avramov Thu, 10/13/2011 - 08:44
When you will extend the configuration, you will be able to dual home the FEX to the Nexus 5000s, each FEX being dual connected to both upstream Nexus 5000. This will be what we call a vPC design. Depending on the number of ports free on your 2960 / 2248s, you could first configure both Nexus 5000s in vPC, then one FEX on each side dual home in vPC at the time. Migrate the server ports to the other FEX or on the 2960, then when the FEX comes back online in ''vpc'' topology you can move servers to this FEX and upgrade the other one in each site. This would minimize the down time in the design topology change.
Here is a document about quick start on vPC, a design guide and a operations guide:
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/configuration_guide_c07-543563.html
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/C07-572834-00_STDG_NX-OS_vPC_DG.pdf
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/operations/n5k_vpc_ops.html
ike1cisco Wed, 10/12/2011 - 21:21
Hello I have a question about vPCs ..relating to being visble to the third switch via port-channel.Correct me if am wrong and expand on this staement please " Allows a single device to use port channel across two upstream devices'. Am trying to grasp the main comcept of vPCs and how to verify them in a live environment on the involved devices assuming its spannoing through more than two Nexus switches
Lucien Avramov Thu, 10/13/2011 - 08:48
vPC always works for a pair of Nexus switches (7ks, 5ks, 3ks). The pair of switches will be configured as vPC and will then appear as a ''single'' logical switch from the point of view of the device you port-channel to them (one or more link to each).
Here is more information about the vPC design:
Some documentation about how it's configured can clarify the concept:
Here is also a webcast about 5k and vPC (the concept applies as well to N7k and N3k):
https://supportforums.cisco.com/videos/1228
smartboy2255 Wed, 10/12/2011 - 21:27
HI Lucien,
   I have one problem , I have two N5k with single Nortel Core switch.My uplink is 1G ports.I was able to ping the outside the network.But when access data ,it wont work. If I remove the redundant link it is working fine.Now I have upgraded firmware from 5.0(2) to 5.0(3). Now everything is working fine.What could be the problem.Can you pls explain ?
Ajith
Lucien Avramov Thu, 10/13/2011 - 08:50
I'm guessing you have Nexus 5548. On the 5500 series, we started supporting 1G speed from 5.0.3 version.
cnrs-dsi Thu, 10/13/2011 - 01:54
Hello Lucien
We will buy a pair of Nexus 5000 to interconnect racks containing  Dell chassis. They each contain a pair of switches 3130X. In a rack  there are four chassis.
We would like to make a stack of 3130X inside the rack and connect it with the pair of Nexus using VPC.
The goal is to have a switch at the logical level (the stacks of 8  3130X) connected to a swicth (the pair of Nexus). These two technologies  can be combined?
Lucien Avramov Thu, 10/13/2011 - 08:51
As long as it's compliant with dot1q and lacp there should be no problem.
tiwang Thu, 10/13/2011 - 02:24
hi lucien
even though it is not a vpc forum I'll try this question - how do I verify load-balancing between the nexus boxes in a vpc domain? I have a set of nx5020 which holds a vpc domain - this vpc is interconnected to another set of nexus boxes which also holds another vpc domain. These two vpc domains are interconnected with  2 10 gig links - and I hoped that I somewhere/somehow could verify load-balancing and see how many links participate in this vpc etc - but hmm - ? - well as far as I can see it is a bit cumbersome to verify which links participate into a vpc and the traffic- the boxes exchange a lot of info about the state - are there some commands here I don't know about or something on the road map?
best regards /ti
Lucien Avramov Thu, 10/13/2011 - 09:01
Ti, from a server or a switch attached in a vPC to both Nexus switches, this is then the principle of hashing: the device will hash to either one of it's link going to the Nexus switches. When a packet comes through the Nexus Switches going to this end device depending on which one received the packet it will send it on that link.
You can see the interface bw usage via the regular show commands.
Please take a look at the vPC section on this webcast:
tiwang Fri, 10/14/2011 - 01:04
hi again lucien - is there a reason why you not "promote" a vPC solution between two set of nexus there? - In all the design-guides I have seen the vPC is used to bundle channels on fexes to hosts - but today many blade-servers are equipped with 10 gig interfaces so it make more sense to me to look for the vPC between pairs of nexus boxes instead - in our case we are using vPC to implement a DCI with 4 10G black-fiber connections (distance 50km) between 4 pair of nexus boxes (2 pairs for "user-data" and 2 pairs for iSCSI) - any comments on this? Are there any pitfalls ?
Lucien Avramov Sun, 10/16/2011 - 23:49
In case of 10 GE servers, you have 2 options: either you go to the Nexus Switch directly or, you can also use the 2232 fabric extender if you like. No really comments on dark-fiber connection. Are you going through a DWDM provider to interconnect?
tiwang Mon, 10/17/2011 - 07:54
hi lucien
Well - now - I am not that familar with the different technologies on the fiber-connection - we get 4 10G fiber-connections from the service-provider and I try not to worry about how they are connected (but as far as I can guess from what they have put into our rack we are going trough a DWDM)
But - I have but these 2 x 2 10G fiber-connections into to sets of nexus 5k's which support iSCSI on the one set of 10G fibers and "data" on the other set. I have tried to isolate each set of nexus in a seperate STP domain as described in the Cisco DCI doc 2.0 (BPDU filter on each of the vPC's) and this also looks ok. Testing failover from one link to the other with a "ping" is almost 100% - but what do I have to be aware of in this setup? Everything looks ok so what I am looking for are there pitfalls or what I have to be aware of ? Tuning - or "not to do"...
best regards /ti
Lucien Avramov Tue, 10/18/2011 - 00:00
For FCOE, the distance between N5ks for synchronous storage is 3 km. If you are running Ethernet only type of traffic (including NFS / iSCSI) then thee is no specific caveats to interconnect your data-centers.
Saravanan Mani Fri, 10/14/2011 - 05:25
  • Cisco Employee,
Hi.,
    We are using Nexus 7k & 5K in our lab. I have created new VLAN in AGG(N7k VDC) and configured hsrp and created the interface vlan for routing aslo. now the problem is existing VLAN's traffic are going via N5k from UCS without any problem , but the newly created vlan is not hitting. Pin group, VLAN , Uplink is configured in UCS FI(6140xp) correctly. And also added the new vlan to the existing portchannels.
NOTE:If i connect a uplink from FI to N7k all the trraffic is going. But VIA N5k the new Vlan is not  going.
Kindly help me to solve this issue.
Please find the topology below.
Thanks & Regards
Saravanan.M
tiwang Fri, 10/14/2011 - 12:18
short question which I cannot find a 100% answer on from the websites - are the n7k compatible with the n2k fex - and if so - also the 10 gig ? and if so - any linitations - what about if using the L3 features?
best regards /ti
smartboy2255 Mon, 10/17/2011 - 02:16
hi Lucien,
   While I upgrading NX-OS from 4.0(0)N1(2) to 4.0.1a.N1.1a , I am getting  SRG error.
show install all impact kickstart bootflash:n5000-uk9-kickstaart.4.0.1a.N1.1a.bin system bootflash:n5000-uk9.4.0.1a.N1.1a.bin
Verifying image bootflash:/n5000-uk9-kickstart.4.0.1a.N1.1a.bin for boot variabl
e "kickstart".
[#                   ]   0%[####################] 100% -- SUCCESS
Verifying image bootflash:/n5000-uk9.4.0.1a.N1.1a.bin for boot variable "system"
Verifying image package type.
[#                   ]   0%[#####               ]  20%[####################] 100% -- SUCCESS
Extracting "system" version from image bootflash:/n5000-uk9.4.0.1a.N1.1a.bin.
[#                   ]   0%[#                   ]   0% -- FAIL. Return code 0x404F0003 (SRG file not present/cannot be opened).Version Compatibility check failed. Return code 0x40930012 (SRG extraction failed).
Ajith
Lucien Avramov Mon, 10/17/2011 - 02:52
I assume you have checked the MD5 check-sum of the file and compared to the file you have downloaded and make sure the file size matches on N5K.
Can you run a reload to clear some of the temp space? And then try again?
If that still does not help, can you please send me the output of show system internal flash?
smartboy2255 Mon, 10/17/2011 - 03:02
HI Lucien,
MD5 is correct and same OS we have upraded in a different N5k and it is working fine. It is very difficult to get the downtime for reload..pls find the logs..Also we have tried with different version NX-OS.
Tried versions: 4.0.1a.N2.1
                              4.0.1a.N1.1a
                              4.2.1.N2.1
nexus1# cop [Jy tf [Jtp: bo [Jotflash:
Enter source filename: n5000-uk9-kickstart.4.0.1a.N1.1a.bin
Enter vrf (If no input, default vrf is considered): management
Enter hostname for the tftp server: 3.235.236.5
Trying to connect to tftp server......
Connection to server Established.
TFTP get operation was successful
nexus1# dir boo [Jtflash:
      49152     Mar 14 15:47:30 2011  lost+found/
   20058112     Mar 14 14:35:58 2011  n5000-uk9-kickstart.4.0.0.N1.2.bin
   20217856     Oct 15 10:09:08 2011  n5000-uk9-kickstart.4.0.1a.N1.1a.bin
   76930262     Mar 14 15:08:30 2011  n5000-uk9.4.0.0.N1.2.bin
   85704356     Oct 15 10:06:02 2011  n5000-uk9.4.0.1a.N1.1a.bin
    3416570     Mar 16 21:00:50 2011  output_k.file
       4096     Jan 01 05:33:41 2005  routing-sw/
Usage for bootflash://sup-local
  266833920 bytes used
  587804672 bytes free
  854638592 bytes total
Show Version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2008, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software may be covered under the GNU Public
License or the GNU Lesser General Public License. A copy of
each such license is available at
http://www.gnu.org/licenses/gpl.html and
http://www.gnu.org/licenses/lgpl.html
Software
  BIOS:      version 1.2.0
  kickstart: version 4.0(0)N1(2)
  system:    version 4.0(0)N1(2)
  BIOS compile time:       06/19/08
  kickstart image file is: bootflash:/n5000-uk9-kickstart.4.0.0.N1.2.bin
  kickstart compile time:  8/3/2008 2:00:00 [08/03/2008 15:13:03]
  system image file is:    bootflash:/n5000-uk9.4.0.0.N1.2.bin
  system compile time:     8/3/2008 2:00:00 [08/03/2008 15:42:21]
[7m--More-- [m
[K
Hardware
  cisco Nexus5020 Chassis ("40x10GE/Supervisor")
  Intel(R) Celeron(R) M CPU   with 2074164 kB of memory.
  Processor Board ID JAF1246BAFC
  bootflash:  974848 kB
geitc-energynexus1   kernel uptime is 920 days 20 hours 28 minute(s) 5 second(s)
  Last reset
    Reason: Unknown
    System version: 4.0(0)N1(2)
    Service:
smartboy2255 Mon, 10/17/2011 - 03:05
Is there any Bios revision number dependency for the upgrade.
Lucien Avramov Mon, 10/17/2011 - 03:13
Can you please send me the output "show system internal flash"
smartboy2255 Mon, 10/17/2011 - 03:30
"show system internal flash" will send after some time..
dir bootflash:
         46     Oct 15 12:58:57 2011  ..tmp-kickstart
         36     Oct 15 12:58:57 2011  ..tmp-system
   20058112     Oct 15 12:58:57 2011  .tmp-kickstart
   76930262     Oct 15 12:58:57 2011  .tmp-system
    2618215     Mar 16 21:47:17 2011  energynexus2.log
      49152     Oct 15 12:58:57 2011  lost+found/
   20058112     Dec 03 00:11:49 2008  n5000-uk9-kickstart.4.0.0.N1.2.bin
   20193280     Oct 15 12:45:42 2011  n5000-uk9-kickstart.4.0.1a.N2.1.bin
   76930262     Dec 03 00:13:15 2008  n5000-uk9.4.0.0.N1.2.bin
   78187520     Oct 15 13:09:37 2011  n5000-uk9.4.0.1a.N2.1.bin
       4096     Jan 01 05:33:45 2005  routing-sw/
          0     Jul 30 14:38:44 2009  test1
  355590144 bytes used
  499048448 bytes free
Lucien Avramov Mon, 10/17/2011 - 03:41
The image size doesn't seem right...
Here is what I have:
  103557265    Oct 17 10:29:06 2011  n5000-uk9.4.0.1a.N2.1.bin
smartboy2255 Mon, 10/17/2011 - 03:51
HI,
   We have tried multiple times. i think one time that has occured.pls find the below log.
dir bo [Jotflash:
      49152     Oct 15 10:49:13 2011  lost+found/
   20058112     Oct 15 10:49:24 2011  n5000-uk9-kickstart.4.0.0.N1.2.bin
   20193280     Oct 15 11:05:19 2011  n5000-uk9-kickstart.4.0.1a.N2.1.bin
   76930262     Oct 15 10:49:25 2011  n5000-uk9.4.0.0.N1.2.bin
  103557265     Oct 15 11:03:05 2011  n5000-uk9.4.0.1a.N2.1.bin
  284680192 bytes used
  569958400 bytes free
Lucien Avramov Mon, 10/17/2011 - 03:54
Okay, so when your images match, the next step is to clear the temp space.
This would happen with a reload. In any case your upgrade will be disruptive so I will suggest you, when you have your maintenance window, to first reload the switch and then run the install all.
Providing the show system internal flash will help confirm.
smartboy2255 Tue, 10/18/2011 - 00:43
HI Lucien ,
   pls find the logs
sh system internal flash
Mount-on  1K-blocks  Used  Available  Use-percent  Filesystem
/                            204800    131672     73128  65   /dev/root
/proc                             0         0         0   0   proc
/post                          2048         4      2044   1   none
/sys                              0         0         0   0   none
/isan                        409600    309452    100148  76   none
/var/sysmgr                  153600     36032    117568  24   none
/var/sysmgr/ftp              204800        28    204772   1   none
/dev/shm                     262144     72344    189800  28   none
/volatile                     20480         0     20480   0   none
/debug                         2048         0      2048   0   none
/dev/mqueue                       0         0         0   0   none
/mnt/cfg/0                    38327      4292     32056  12   /dev/sda5
/mnt/cfg/1                    37814      4292     31570  12   /dev/sda6
/var/sysmgr/startup-cfg       61440      2568     58872   5   none
/dev/pts                          0         0         0   0   devpts
/mnt/plog                     56320      1632     54688   3   /dev/mtdblock2
/mnt/pss                      38343      4443     31920  13   /dev/sda4
/bootflash                   834608    234832    557380  30   /dev/sda3
sh system internal log install
lock_config_mode: Acquiring config mode lock
store_modules_info: index: 0 is present, mod_type: 4 mod_state: 0, sw_card_id: 60
store_modules_info: checking to see if index 0 is fabric switch upgrade supported
store_modules_info: index: 1 is present, mod_type: 0 mod_state: 0, sw_card_id: 65
store_modules_info: index: 2 is present, mod_type: 0 mod_state: 0, sw_card_id: 65
update_srg_table_active_sup_running: check for support_loader flag
check_plugin_img: is_given_image_plugin_based: 1
tar: ./isan/plugin_img/core_plugin: Wrote only 7680 of 10240 bytes
tar: Error exit delayed from previous errors
extract_all_srgs_from_plugins: "/isan/sbin/isanadd -x /bootflash/n5000-uk9.4.0.1a.N2.1.bin . isan/plugin_img" failed
check_plugin_img: Failed to xtract SRG's from plugins within the image: -1
srv_installer_job_done: procjob operation failed. (0x404F0003)
process_srg_extraction_done: SRG extraction failed (0x404F0003).
unlock_config_mode: Releasing config mode lock
sh sys internal log install details
Starting MTS bind
MTS bind successful
MTS now ready
installer_state_init: State initialized to INSTALLER_STATE_INIT.
srv_installer: calling get_card_module_info to find out sup type
******srv_installer:  setting support_loader to FALSE*****
process_install_start: got install request: abort_installation (0), install_operation (2).
notify_global_status_change: Sending global status  notification.
process_install_start: status 0x00000000.
installer_state_change: old_state: INSTALLER_STATE_INIT, new_state: INSTALLER_STATE_PRE_VERIFICATION
installer_state_change: State changed from INSTALLER_STATE_INIT to INSTALLER_STATE_PRE_VERIFICATION.
build_bootvar_table: Starting to build the bootvar table.
build_bootvar_table: Total number of bootvars are 5.
store_modules_info: entity_index 22, mod_num 1
store_modules_info: entity_index 23, mod_num 2
store_modules_info: entity_index 24, mod_num 3
mod_num 2 mod_status 1 type 0
mod_num 3 mod_status 1 type 0
mod_num 1 mod_status 0 type 0
store_redundancy_status: admin_mode:SYSMGR_REDUN_MODE_HA operational_mode:SYSMGR_REDUN_MODE_NONE.
installer_state_change: old_state: INSTALLER_STATE_PRE_VERIFICATION, new_state: INSTALLER_STATE_NORMALIZATION
STATE_PRE_VERIFICATION to INSTALLER_STATE_NORMALIZATION.
clear_lost_found_dir: Executing command - cd /bootflash; rm -rf /bootflash/lost+found; mklost+found;
perform_uri_copy: scheme for src_uri "bootflash:/n5000-uk9-kickstart.4.0.1a.N2.1.bin" is "bootflash"
perform_uri_copy: path for src_uri "bootflash:/n5000-uk9-kickstart.4.0.1a.N2.1.bin" is "n5000-uk9-kickstart.4.0.1a.N2.1.bin".
perform_uri_copy: no copy needed for src_uri "bootflash:/n5000-uk9-kickstart.4.0.1a.N2.1.bin".
perform_uri_copy: scheme for src_uri "bootflash:/n5000-uk9.4.0.1a.N2.1.bin" is "bootflash"
perform_uri_copy: path for src_uri "bootflash:/n5000-uk9.4.0.1a.N2.1.bin" is "n5000-uk9.4.0.1a.N2.1.bin".
perform_uri_copy: no copy needed for src_uri "bootflash:/n5000-uk9.4.0.1a.N2.1.bin".
find_next_add_on_image:number of add-on images for module 2 is 0.
find_next_add_on_image:number of add-on images for module 3 is 0.
installer_state_change: old_state: INSTALLER_STATE_NORMALIZATION, new_state: INSTALLER_STATE_IMAGE_VERIFICATION
STATE_NORMALIZATION to INSTALLER_STATE_IMAGE_VERIFICATION.
perform_image_verification: verify: procjob_handle 24622 syserr "success"
installer_state_change: old_state: INSTALLER_STATE_IMAGE_VERIFICATION, new_state: INSTALLER_STATE_IMAGE_VERIFY_WAIT
installer_state_change: State changed from INSTALLER_STATE_IMAGE_VERIFICATION to INSTALLER_STATE_IMAGE_VERIFY_WAIT.
procjobcb_job_ready: Handshake done: 24622
image_verify_func: successfully able to open libbootverify.so
image_verify_func: successfully able to dlsym.
Imghdr: platform type from hardware is NUOVA
Imghdr: isan image's platform type is NUOVA
Imghdr: boot image's platform type is NUOVA
42fbe4b24a1f677c859dc42bc4d69cd4
Verify OK!!
image_verify_func: rval for verify fn 0.
procjobcb_job_done: Handle 24622 syserr "success" ret_info_size 0  ret_syserr 0 ret_info b7f70540
installer_state_change: old_state: INSTALLER_STATE_IMAGE_VERIFY_WAIT, new_state: INSTALLER_STATE_IMAGE_VERIFICATION
installer_state_change: State changed from INSTALLER_STATE_IMAGE_VERIFY_WAIT to INSTALLER_STATE_IMAGE_VERIFICATION.
perform_image_verification: verify: procjob_handle 24624 syserr "success"
procjobcb_job_ready: Handshake done: 24624
Verify OK!!
procjobcb_job_done: Handle 24624 syserr "success" ret_info_size 0  ret_syserr 0 ret_info b7f70540
installer_state_change: old_state: INSTALLER_STATE_IMAGE_VERIFICATION, new_state: INSTALLER_STATE_SRG_COLLECTION
installer_state_change: State changed from INSTALLER_STATE_IMAGE_VERIFICATION to INSTALLER_STATE_SRG_COLLECTION.
clone_local_srg: SRG Size for /isan/etc/srg.sro is 380 bytes
clone_local_srg: SRG Retrieval succeeded for /isan/etc/srg.sro
update_srg_table_active_sup_running: Got Running system SRG for active sup
clone_local_srg: SRG Size for /etc/srg-ks.sro is 244 bytes
clone_local_srg: SRG Retrieval succeeded for /etc/srg-ks.sro
update_srg_table_active_sup_running: Got Running kickstart SRG for active sup
get_bios_ver: calling get_module_bios_version_ext,mod_num 1,ver_len 7464
get_bios_ver: get_module_bios_version_ext returned, num_entries is 1, pri ver_str is   v1.0.0(04/01/08), sw_id is 11
update_srg_table_active_sup_running: Got Running bios version for active sup, primary bios:   v1.0.0(04/01/08)
update_srg_table_active_sup_running: Total number of running swids for active sup are 3
collect_running_srgs: collecting running srg's from lc(1)
update_srg_table_lc_running: Got 0 srg's for module 2
update_srg_table_lc_running: Total number of running swids for lc_mod_index 1 are 0
collect_running_srgs: collecting running srg's from lc(2)
update_srg_table_lc_running: Got 0 srg's for module 3
update_srg_table_lc_running: Total number of running swids for lc_mod_index 2 are 0
fsm_action_srg_collection: running image plugin based ?: 1
fsm_action_srg_collection: checking if tobe installed image is plugin based
check_plugin_img_async: procjob_handle 24626 syserr "success"
waiting for plugin image check to complete .
leaving_srg_collection_state: entering.. procjob_hand
le is 24626 installer_state_change: old_state: INSTALLER_STATE_SRG_COLLECTION, new_state: INSTALLER_STATE_SRG_EXTRACTION_WAIT
installer_state_change: State changed from INSTALLER_STATE_SRG_COLLECTION to INSTALLER_STATE_SRG_EXTRACTION_WAIT.
procjobcb_job_ready: Handshake done: 24626
                EXTRACT
> extracting files: /isan/plugin_img/img.conf
--> /isan/plugin_img/img.conf
                EXTRACT
> extracting files: isan/plugin_img
--> isan/plugin_img
Error extracting the file
extract_all_srgs_from_plugins: Extracting all srgs within plugin(s)from the image "/bootflash/n5000-uk9.4.0.1a.N2.1.bin"
extract_all_srgs_from_plugins: /tmp/extracted-srgs directory exists
extract_all_srgs_from_plugins: clearing /tmp/extracted-srgs directory
extract_all_srgs_from_plugins: Create working dir with pid 24627
extract_all_srgs_from_plugins: Executing cmd "/isan/sbin/isanadd -x /bootflash/n
procjobcb_job_done: Handle 24626 syserr "success" ret_info_size 4  ret_syserr 0 ret_info b7f70540
process_srg_extraction_done: success
process_srg_extraction_done: plugin image check returned: 1
installer_state_change: old_state: INSTALLER_STATE_SRG_EXTRACTION_WAIT, new_state: INSTALLER_STATE_SRG_COLLECTION
installer_state_change: State changed from INSTALLER_STATE_SRG_EXTRACTION_WAIT to INSTALLER_STATE_SRG_COLLECTION.
fsm_action_srg_collection: find_next_srg_to_extract returns 1
extract_srg_async: srg extract: procjob_handle 24651 syserr "success"
Waiting for SRG extraction to complete .
extract_srg_async: leaving...
perform_srg_extraction: handle not 0, leaving
leaving_srg_collection_state: entering.. procjob_handle is 24651 installer_state_change: old_state: INSTALLER_STATE_SRG_COLLECTION, new_state: INSTALLER_STATE_SRG_EXTRACTION_WAIT
procjobcb_job_ready: Handshake done: 24651
extract_srg_file_func: extracting srg "/isan/etc/srg.sro" from image "/bootflash/n5000-uk9.4.0.1a.N2.1.bin".
search_extracted_srg_dir: Searching SRG "/isan/etc/srg.sro" in "/tmp/extracted-srgs"
extract_srg_file_func: extraction of srg "/isan/etc/srg.sro" from image "/bootflash/n5000-uk9.4.0.1a.N2.1.bin": rval (0x404F0003).
procjobcb_job_done: Handle 24651 syserr "success" ret_info_size 0  ret_syserr 1078919171 ret_info b7f70540
installer_state_change: old_state: INSTALLER_STATE_SRG_EXTRACTION_WAIT, new_state: INSTALLER_STATE_ABORTING
installer_state_change: State changed from INSTALLER_STATE_SRG_EXTRACTION_WAIT to INSTALLER_STATE_ABORTING.
fsm_action_srv_installer_aborting: Waiting for 10 secs before exiting..
tallation (0), install_operation (1).
abort_installation: We are in state "INSTALLER_STATE_ABORTING" and got a request for abort_and_exit, going to state DONE.
installer_state_change: old_state: INSTALLER_STATE_ABORTING, new_state: INSTALLER_STATE_DONE
installer_state_change: State changed from INSTALLER_STATE_ABORTING to INSTALLER_STATE_DONE.
unlock_local_module: Trying to unlock module 1
unlock_local_module: Trying to unlock module 2
unlock_local_module: Trying to unlock module 3
Lucien Avramov Tue, 10/18/2011 - 03:32
Your root partition is 65 % full, this is not enough for the upgrade to complete.
The next I suggest you here is to reload to remove all temporary cache files and then run the upgrade.
Keep us posted.
smartboy2255 Tue, 10/18/2011 - 05:37
Can you pls tell me how much disk space is required to complete the installation. Also is there any option to see the temp folder usage.
Lucien Avramov Tue, 10/18/2011 - 06:57
There is no way to see the details of the root partition on your CLI, you have to follow the reload procedure and then run the install all.
Lucien Avramov Mon, 10/17/2011 - 02:46
N7k is compatible with the FEX 2224,2248 and 2232PP. We have now L3  as well on FEX from 5.2 code, meaning you can configure a FEX port as an  L3 port if you desire.
Some FEX limitations:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/release/notes/51_nx-os_release_note.html#wp351847
Also here are the release notes for 5.2:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/release/notes/52_nx-os_release_note.html
Related Content
Trending Topics: Other DC Subjects
