10-09-2011 05:06 PM - edited 03-04-2019 01:52 PM
I recently installed a new Cisco 887W router @ my place and everything is working like a charm but the Macbook Air! The devices that are working currently are: iPhone, iPad, HP laptop, Nokia mobile phone.
I have checked two Macbook Air so far and both have the same problem with the wireless network! I even manually added the SSID to "Airport Preferred network setting" but still couldn't make it to work!
So the issue is the Macbook Air can detect the SSIDs intermittently however when it detects the SSID it doesn not connect to the wireless network and it comes up with the error of "connection timeout". I have used the command "show dot11 association" to see if the Macbook air will be detected on the router side unfortunately that was in vain.
The setting that I have on the router under SSID is "guest-mode" i.e. it broadcasts the SSID, security is WPA 2 with AES encyrption.
Any ideas or thoughts how to fix the issue?
10-11-2011 01:32 PM
Post relevant config.
10-11-2011 03:23 PM
Vlan 30 >>>RadioDot 11 0.30>>>>Gigabit 0.2>>>>bridge group 2
Vlan 200>>RadioDot 11 0.200>>>Gigabit 0.1>>>>bridge group 1 (native Vlan)
Router Side:
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.30.1
ip dhcp excluded-address 192.168.200.1
ip dhcp pool ccp-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
domain-name viper
dns-server 203.12.160.35 203.12.160.36 203.12.160.37
lease 0 4
ip dhcp pool Wlan-Bitter
network 192.168.200.0 255.255.255.0
default-router 192.168.200.1
domain-name viper
lease 0 4
ip dhcp pool Wlan-Serendipity
network 192.168.30.0 255.255.255.0
default-router 192.168.30.1
domain-name viper
lease 0 4
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan200
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
switchport trunk native vlan 200
switchport mode trunk
no ip address
interface Vlan30
description WLAN-Serendipity 192.168.30.0 / 24
ip address 192.168.30.1 255.255.255.0
no ip unreachables
ip flow ingress
ip flow egress
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1360
load-interval 30
interface Vlan200
description *** BITTER LAYER 3 INTERFACE ***
ip address 192.168.200.1 255.255.255.0
no ip unreachables
ip flow ingress
ip flow egress
ip nat inside
load-interval 30
AP side
dot11 ssid Bitter
vlan 200
authentication open
authentication key-management wpa
mbssid guest-mode
wpa-psk ascii 7 xxxxxxx
dot11 ssid Serendipity
vlan 30
authentication open
authentication key-management wpa version 2
mbssid guest-mode
wpa-psk ascii 7 xxxxxxxxxxxx
interface Dot11Radio0.30
encapsulation dot1Q 30
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface Dot11Radio0.200
encapsulation dot1Q 200 native
no ip route-cache
bridge-group 1
bridge-group 1 port-protected
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
interface GigabitEthernet0.1
description $ETH-LAN$
no ip route-cache
bridge-group 1
interface GigabitEthernet0.2
no ip route-cache
bridge-group 2
interface BVI1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
ip default-gateway 192.168.200.1
ip http server
ip http authentication local
ip http secure-server
ip http help-path
http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 protocol ieee
bridge 1 route ip
bridge 2 protocol ieee
10-14-2011 01:26 PM
No dot11radio0 config ?
Anyway, should be
authentication shared
10-01-2013 06:28 PM
Hi Arsalan,
have you resolved it ? i am haveing same problem.
thanks
10-01-2013 06:54 PM
Check this link which contains the solution: https://discussions.apple.com/thread/3366331?start=0&tstart=0
Please rate replies and mark question as "answered" if applicable.
