Error opening tftp://.......................(timed out) UC500 loopback network
Answered Question
Hello all,
When I try to access areas through CCA (cisco configuration assistant) such as ringtones or backgrounds for the phones, I get an error message. I have attached a screenshot of the error I get
Anyone have any idea as to how I can fix this?
Correct Answer by acampbell about 5 years 5 months ago
Jason,
Firstly thanks for you patience.
We have located the issue to the default gateway of the PC not having ip routes to UC500/CUE.
So it is not always thye rocket science that is the issue.
Alex
Please rate and mark as correct answer if this helped
Overall Rating: 5 (1 ratings)
acampbell Sat, 10/08/2011 - 13:50
  • Green, 3000 points or more
Jason,
This looks to be a routing issue.
Can you display the running config of the router.
Regard
Alex
acampbell Mon, 10/10/2011 - 09:41
Jason,
This an ip routing issue
You have
interface Loopback0
ip address 10.1.10.2 255.255.255.252
ip nat inside
ip virtual-reassembly
This loopback consumes the whole network 10.1.10.0 (SubNet = .0 host .1-.2 broadcast. 3)
Your service module is clashing with the loopback
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
You could try deleting the loop back and use the subnet as an interface vlan instead.
Save you config as it is then try
no int loop 0
int vlan 101
desc CUE SUBNET
ip nat inside
no shut
Give it a test if it fails put it back and we can look again.
Alex
acampbell Mon, 10/10/2011 - 15:32
Jason,
Sorry.
Can you hold fire on this.
I want to check a few things from your config in the morning.
Alex
acampbell Tue, 10/11/2011 - 08:42
Jason,
Can you provide the output of
show ip route
from the UC500
I dont think it will be very big so you should be able to paste it into the blog.
I still want to check more items in your config but I need to see the ip routing table.
I am trying to keep the required changes to a minimum.
Alex
FPP-UC520-HQ01#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 69.199.54.81 to network 0.0.0.0
     69.0.0.0/29 is subnetted, 1 subnets
C       69.199.54.80 is directly connected, FastEthernet0/0
     10.0.0.0/8 is variably subnetted, 3 subnets, 3 masks
S       10.1.10.1/32 is directly connected, Integrated-Service-Engine0/0
C       10.1.10.0/30 is directly connected, Loopback0
C       10.254.0.96/27 is directly connected, Vlan999
C    192.168.1.0/24 is directly connected, Vlan10
C    192.168.100.0/24 is directly connected, Vlan100
S*   0.0.0.0/0 [1/0] via 69.199.54.81
acampbell Tue, 10/11/2011 - 08:54
Thanks Jason,
What is the IP address of your PC ?
Can you ping 10.1.10.1 ?
Can you ping 10.1.10.2 ?
Alex
My IP is    192.168.1.120
Pinging 10.1.10.1 gives me this result
Pinging 10.1.10.1 with 32 bytes of data:
Reply from 38.20.63.45: Destination host unreachable.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 10.1.10.1:
    Packets: Sent = 4, Received = 1, Lost = 3 (75% loss),
Pinging 10.1.10.2 just times out
Pinging 10.1.10.2 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 10.1.10.2:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
acampbell Tue, 10/11/2011 - 09:23
Thanks again Jason.
My last questions for today.
Is your PC default gateway 192.168.1.5 ?
Can you ping 192.168.100.1 ?
I still think the CUE service module is IP clashing with loopback 0
We need loopback0 as it is referred to by other interfaces.
We also need the 10.10.1 address as this the CUE address used for the VM dial peers & viewmail etc.
My idea is now to try some changes.
I just need more info before I send these out.
Alex
Default gateway is 192.168.1.9
IPv4 Address. . . . . . . . . . . : 192.168.1.120
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.9
Pinging 192.168.100.1 give this result:
Pinging 192.168.100.1 with 32 bytes of data:
Reply from 38.98.1.1: TTL expired in transit.
Ping statistics for 192.168.100.1:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
acampbell Tue, 10/11/2011 - 09:29
Jason
I have sent you a message via the forum mail service privately. Can you respond ?
Alex
Correct Answer
acampbell Tue, 10/11/2011 - 12:49
Jason,
Alex
