ME-3800-X : Problèm Flappin @mac on vpls
a.auvinet
I have a network based on ME-3800-X
I use MPLS/Vpls technologie and too VRF/MPLS
The VPLS works but at times, there has @mac flapping between tunnel EoMPLS of VPLS.
For exemple :
Oct 13 05:52:46: %SW_MATM-4-MACFLAP_NOTIF: Host 0016.177b.17e1 in vlan 3990 is flapping between port VP6 and port VP7
Oct 13 05:52:59: %SW_MATM-4-MACFLAP_NOTIF: Host 0016.177b.17e1 in vlan 3990 is flapping between port VP9 and port VP5
Oct 13 06:02:56: %SW_MATM-4-MACFLAP_NOTIF: Host 0016.177b.17e1 in vlan 3990 is flapping between port VP5 and port VP8
Oct 13 06:03:58: %SW_MATM-4-MACFLAP_NOTIF: Host 0016.177b.17e1 in vlan 3990 is flapping between port VP9 and port VP6
Oct 13 06:04:49: %SW_MATM-4-MACFLAP_NOTIF: Host 001c.c436.6410 in vlan 3990 is flapping between port VP7 and port VP5
Oct 13 06:08:27: %SW_MATM-4-MACFLAP_NOTIF: Host 0016.1780.68df in vlan 3990 is flapping between port VP5 and port VP8
Oct 13 06:11:14: %SW_MATM-4-MACFLAP_NOTIF: Host 001e.0b62.4990 in vlan 3990 is flapping between port VP7 and port VP5
Oct 13 06:26:28: %SW_MATM-4-MACFLAP_NOTIF: Host 001e.0b62.4990 in vlan 3990 is flapping between port VP7 and port VP5
Oct 13 06:43:38: %SW_MATM-4-MACFLAP_NOTIF: Host 0016.1726.0459 in vlan 3990 is flapping between port VP1 and port VP5
Oct 13 07:07:44: %SW_MATM-4-MACFLAP_NOTIF: Host 001e.0b62.4990 in vlan 3990 is flapping between port VP7 and port VP5
Oct 13 07:07:46: %SW_MATM-4-MACFLAP_NOTIF: Host 001e.0b62.4990 in vlan 3990 is flapping between port VP5 and port VP9
Oct 13 08:48:58: %SW_MATM-4-MACFLAP_NOTIF: Host 0016.1780.6c03 in vlan 3990 is flapping between port VP7 and port VP1
Oct 13 08:50:07: %SW_MATM-4-MACFLAP_NOTIF: Host 0090.ec08.0f66 in vlan 3990 is flapping between port VP7 and port VP1
Oct 13 09:23:52: %SW_MATM-4-MACFLAP_NOTIF: Host 001d.920c.0bd2 in vlan 3990 is flapping between port VP7 and port VP1
Spit-horizon is OK on VPLS.
I think a bug
An other question :
How to see who is the end for VP xx ??
ME-3800-X , Version 15.1(2)EY
Configuration for VPLS, ( E-BGP
l2 vfi L2_NM_L2 autodiscovery
vpn id 3990
interface GigabitEthernet0/1
description Inerco L3 - DSI
switchport trunk allowed vlan none
switchport mode trunk
service instance 3990 ethernet
  encapsulation dot1q 225,256,726,728,733-737,741,743,755,1000
  bridge-domain 3990
interface Vlan3990
description VPLS_VOIP_SIA
no ip address
xconnect vfi L2_NM_L2
end
7 Replies 7
Anand Ram
Hello Auvinet,
You could check you VFI status and the neighbors it connects through using the command
1) show mpls l2 vc - if you know the vpn id, you should see all the neighbors for that VFI
2) show vfi "VFI name"
As for the MAC flaps, there seems to be some STP issue happening in the L2 VLAN somewhere. I would suggest checking your sites for STP loop
Anand
hi Anand,
No information for VP
There 's no loop in the network, No spanning tree.
I am sure.
sw_pn_cun101_tb#show mpls l2 vc
Local intf     Local circuit              Dest address    VC ID      Status
VFI L2_NM_L2   VFI                        172.30.0.2      3990       DOWN
VFI L2_NM_mgmt  \
               VFI                        172.30.0.2      3999       DOWN
VFI L2_NM_L2   VFI                        172.30.0.3      3990       UP
VFI VPLS_TAN   VFI                        172.30.0.3      3998       DOWN
VFI L2_NM_mgmt  \
               VFI                        172.30.0.3      3999       UP
VFI L2_NM_L2   VFI                        172.30.0.4      3990       DOWN
VFI L2_NM_mgmt  \
               VFI                        172.30.0.4      3999       DOWN
VFI L2_NM_L2   VFI                        172.30.0.5      3990       UP
VFI L2_NM_mgmt  \
               VFI                        172.30.0.5      3999       UP
VFI L2_NM_L2   VFI                        172.30.0.6      3990       UP
VFI L2_NM_mgmt  \
               VFI                        172.30.0.6      3999       UP
VFI L2_NM_L2   VFI                        172.30.0.7      3990       UP
VFI L2_NM_mgmt  \
               VFI                        172.30.0.7      3999       UP
Vl959          Eth VLAN 959               172.30.0.8      959        UP
VFI L2_NM_L2   VFI                        172.30.0.8      3990       UP
VFI VPLS_TAN   VFI                        172.30.0.8      3998       DOWN
VFI L2_NM_mgmt  \
               VFI                        172.30.0.8      3999       UP
VFI L2_NM_L2   VFI                        172.30.0.9      3990       DOWN
VFI VPLS_TAN   VFI                        172.30.0.9      3998       DOWN
VFI L2_NM_mgmt  \
               VFI                        172.30.0.9      3999       UP
VFI L2_NM_L2   VFI                        172.30.0.10     3990       DOWN
VFI L2_NM_mgmt  \
               VFI                        172.30.0.10     3999       UP
VFI L2_NM_L2   VFI                        172.30.0.11     3990       UP
VFI L2_NM_mgmt  \
               VFI                        172.30.0.11     3999       UP
                                          172.30.0.12     3998       DOWN
sw_pn_cun101_tb#sh vfi name L2_NM_L2
Legend: RT=Route-target, S=Split-horizon, Y=Yes, N=No
VFI name: L2_NM_L2, state: up, type: multipoint
  VPN ID: 3990, VPLS-ID: 65000:3990
  RD: 65000:3990, RT: 65000:3990
  Local attachment circuits:
    Vlan3990
  Neighbors connected via pseudowires:
  Peer Address     VC ID        Discovered Router ID    S
  172.30.0.3       3990         172.30.0.3              Y
  172.30.0.2       3990         172.30.0.2              Y
  172.30.0.9       3990         172.30.0.9              Y
  172.30.0.10      3990         172.30.0.10             Y
  172.30.0.11      3990         172.30.0.11             Y
  172.30.0.7       3990         172.30.0.7              Y
  172.30.0.6       3990         172.30.0.6              Y
  172.30.0.5       3990         172.30.0.5              Y
  172.30.0.8       3990         172.30.0.8              Y
  172.30.0.4       3990         172.30.0.4              Y
Most probably your are hitting CSCts07998, Wait for the fix
That is very interesting. A very close match.
Auvinet,
Do you what triggered these logs? Any commands executed on any of the PEs in the VP?
Anand
Hi guys:
I have the same problem but no access to CSCts07998 details.
Could anybody please include here those details (description, severity, workaround, etc)?
Ricardo
4715575: .Feb  2 5:09:29.406: %SW_MATM-4-MACFLAP_NOTIF: Host 4c1f.cc1b.742 in vlan 1232 is flapping between port VP7 and port VP1
ME3800#sho vfi nam 3GH
VFI name: 3GH, state: up, type: multipoint
  VPN ID: 1232
    Vlan1232
  Peer Address     VC ID        S
  10.0.200.26      331916232   Y
  10.0.200.93      331913232   N
  10.0.200.46      331916232   Y
  10.0.200.29      331919232   Y
  10.0.200.11      331911232   Y
  10.0.200.10      331910232   Y
  10.0.200.208     331911232   Y
How should I do next?
I don't know....
I think macflapp occurs when a type of  multicast packets go across the MPLS VPLS.
It's a Bug.
I have also same problem.
