service-policy input
Answered Question
Oct 17th, 2011
Hello everyone,
my service-policy is not working on inbound.  it works on outbound, but I need to apply it on IN as well.
please check what I am doing wrong.  thank you in advance.
mls qos
ip access-list extended ACL-TEST-LIMIT50
permit ip any any
class-map match-all CLASS-TEST-LIMIT50
  match access-group name ACL-TEST-LIMIT50
policy-map MAP-TEST-LIMIT50
  class CLASS-TEST-LIMIT50
    police 50000000 40000 conform-action drop exceed-action drop violate-action drop
int vlan 103
service-policy input MAP-TEST-LIMIT50
P.S.
with traffic up to 100mb/s, I almost don't see the matches:
sh ip access-lists ACL-TEST-LIMIT50
Extended IP access list ACL-TEST-LIMIT50
    10 permit ip any any (1 match)
c7600 / Version 12.2(33)SRE2
Have a nice day,
Dmitry
Correct Answer by mlund about 5 years 5 months ago
Hi Dimity
You said " when I put it on the interface it blocked all traffic to host"
That is exactly what is going to happen, because of Your policy.
The policy states " conform-action drop"
/Mikael
Correct Answer by Balaji K about 5 years 5 months ago
hi,
do we have 'mls qos vlan-based' configured on the physical port through which the traffic is ingressing.
Overall Rating: 5 (2 ratings)
nkarpysh Wed, 10/19/2011 - 09:46
  • Cisco Employee,
Hi Dmitry,
can you please paste the following output when this policy is attached in IN direction with some traffic passing through VLAN (not sent to VLAN):
show policy-map int Vlan 103
Nik
kozorezdi Wed, 10/19/2011 - 23:07
Hi Nikolay,
Thank you for your help.
sh policy-map interface vlan 103
Vlan103
  Service-policy input: MAP-TEST-LIMIT50
    class-map: CLASS-TEST-LIMIT50 (match-all)
      Match: access-group name ACL-RODINA-LIMIT50
      police :
        50000000 bps 40000 limit 40000 extended limit
      Earl in slot 5 :
        59009454 bytes
        5 minute offered rate 0 bps
        aggregate-forwarded 0 bytes action: drop
        exceeded 59009454 bytes action: drop
        aggregate-forward 0 bps exceed 0 bps
      Earl in slot 6 :
        0 bytes
        exceeded 0 bytes action: drop
      Earl in slot 7 :
        0 bytes
      Earl in slot 9 :
        0 bytes
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      5 minute offered rate 0000 bps, drop rate 0000 bps
      Match: any
        0 packets, 0 bytes
        5 minute rate 0 bps
Dmitry
Correct Answer
Balaji K Wed, 10/19/2011 - 11:35
  • Cisco Employee,
hi,
kozorezdi Wed, 10/19/2011 - 23:20
Hi Balaji,
I see, it's the right direction.  Let me expain the scheme:
router(SVI 103---port-channel1)----------trunk-------------L2 switch(access-port)--------------host
I haven't had the connand 'mls qos vlan-based' on int port-channel1, as result the policy was not working.
When I put it on the interface, it blocked all traffic to the host.  Please give me an idea what is wrong.
some details:
interface Port-channel1
switchport
switchport mode trunk
end
interface Vlan103
bandwidth 100000
ip address *.*.*.49 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip verify unicast source reachable-via any
ip flow ingress
mls netflow sampling
end
L2 switch:
interface GigabitEthernet0/15
switchport access vlan 103
switchport mode access
speed 100
end
Thank you in advance.
Dimitry
Correct Answer
mlund Thu, 10/20/2011 - 00:18
  • Silver, 250 points or more
Hi Dimity
/Mikael
kozorezdi Thu, 10/20/2011 - 01:06
Hi Mlund,
sorry for my blindness.  yes, it is working now!  THANK YOU VERY MUCH!
Dimitry
