thotsaphon Mon, 10/17/2011 - 23:52
  • Gold, 750 points or more
   You just configure L3 switch to act as gateways of all VLANs you want then turn on "ip routing" on it. You just configure trunk interfaces to connect between L2-2950 to connect to L3 switch. Don't forget to add vlan on all switches or use VTP to do so.
HTH,
Toshi
fb_webuser Tue, 10/18/2011 - 09:05
  • Silver, 250 points or more
To configure inter vilan routing between the two switch,configure sub-interface from the routers interface mode and then issue encapsulation dot1q
Posted by WebUser Kenechukwu Ogbu
