ASA 5505 license installation
Oct 18th, 2011
on a 5505, i try to install L-ASA-SSL-10= ASA 5500 SSL VPN 10 Premium User License i just bought
on the CLI i type activation-key  xxxxx xxxxx xxxxx xxxxx
the response is :
The requested key is the SAME as the flash activation key.
The flash activation key will not be modified.
The requested key is the SAME as the running activation key.
The running activation key will not be modified. The requested key is the SAME as the flash activation key.
and nothing is installed !
may someone help me ?
thanks
Pierre
Jennifer Halim Tue, 10/18/2011 - 23:41
  • Cisco Employee,
Can you please share the existing "show version" output, and also did you receive email of the activation key, can you please check if there is 2 different activation key listed in the email, or just the one?
barreplilly Fri, 10/21/2011 - 07:06
hi,
show version :
Failover                     : Disabled
VPN-DES                      : Enabled
VPN-3DES-AES                 : Enabled
VPN Peers                    : 10
WebVPN Peers                 : 10
Dual ISPs                    : Disabled
VLAN Trunk Ports             : 0
AnyConnect for Mobile        : Disabled
AnyConnect for Linksys phone : Disabled
Advanced Endpoint Assessment : Disabled
UC Proxy Sessions            : 2
This platform has a Base license.
Serial Number: JMX1421Z1QL
Running Activation Key: 0x722aed64 0x94f8bd64 0x6022497c 0x96fce468 0xc1201b89
Configuration register is 0x1
Configuration last modified by enable_15 at 11:22:55.522 CEDT Thu Sep 22 2011
i confirm there's just ONE activation key
and it's the same as the running activation key (that's my problem :-)
thanks for your help
Pierre
varrao Fri, 10/21/2011 - 07:11
  • Red, 2250 points or more
Hi Pierre,
You already have the WebVPN and VPN users as 10 , so installing that license won't make any difference.
Varun
barreplilly Fri, 10/21/2011 - 07:18
i bought a L ASA SSL 10    SSL VPN 10 Premuim User Licence
in my mind, this license allow me connecting with AnyConnect Mobility Client (in my case for Iphone)
this license is not included in the base license
Pierre
