I have a WLC 2106 with 3 APs. Everything works and users can connect, but the throughput seem to be lower than it should (it is around 8Mbps and should be around 30-50Mbps). And all speed and duplex has been accounted for.
I need help trying to understand the stats that I see for the 802.11 MAC counters I under the Wireless APs.on the controller.
That screenshot is attached. I see high numbers for the following areas:
- Tx Failed Count
- RTS Failure Count
- FCS Error Count
Can someone explain what these mean and what could cause this? Maybe these are normal and not a concern.
And if these values could result in low throughput and higher than it should latency?
Thank you very much!
-rya
