1801 router with dual WAN - one subnet for WAN1, other for WAN2
Oct 19th, 2011
Hi all
I'm trying to set up an 1801 router with two WAN interfaces, fastethernet0 and fastethernet1. On the LAN side, I have two subnets. One subnet's internet traffic should be routed over fastethernet0, the other over fastethernet1.
I've setup some route maps to accomplish this. I can surf the internet using subnet 192.168.2.0/24 fine, all traffic goes out of fastethernet0. However, and this is where the problem is, if I try to reach the internet using subnet 192.168.3.0/24, all packets go out interface fastethernet0 with the source address of fastethernet1!
When I'm surfing the internet, from subnet 192.168.3.0/24, packets should be going out fastethernet1, now they're going out fastethernet0.
This is my running-config:
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
no ip source-route
ip cef
no ipv6 cef
license udi pid CISCO1811/K9 sn xxx
vtp version 2
interface FastEthernet0
ip address 192.168.0.110 255.255.255.0
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface FastEthernet1
ip address 192.168.1.2 255.255.255.0
ip nat outside
duplex auto
speed auto
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
ip address 192.168.3.254 255.255.255.0 secondary
ip address 192.168.2.254 255.255.255.0
ip nat inside
interface Async1
no ip address
encapsulation slip
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map NAT1 interface FastEthernet0 overload
ip nat inside source route-map NAT2 interface FastEthernet1 overload
ip route 0.0.0.0 0.0.0.0 FastEthernet0
ip route 0.0.0.0 0.0.0.0 FastEthernet1 255
logging esm config
access-list 1 permit 192.168.2.0 0.0.0.255
access-list 2 permit 192.168.3.0 0.0.0.255
route-map NAT2 permit 10
match ip address 2
set interface FastEthernet1
route-map NAT1 permit 10
match ip address 1
set interface FastEthernet0
route-map LAN1 permit 10
match ip address 1
route-map LAN1 permit 20
match ip address 2
control-plane
line con 0
speed 115200
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
login
transport input all
end
Best regards,
cadet alain Wed, 10/19/2011 - 12:42
  • Purple, 4500 points or more
1) remove second static default route with AD of 255
no ip route 0.0.0.0 0.0.0.0 FastEthernet1 255
ip route 0.0.0.0 0.0.0.0 fastethernet1
You should configure the static routes via next-hop and not outgoing interfaces as these are multipoint
because the router will be arping for every outside destination in your case
2) in your NAT route-maps change the set command by the match command:
match ip address 2
match interface FastEthernet1
3) you must configure PBR:
if 3.0 must go via f1 and 2.0 via f0
ip prefix-list LAN1 permit 192.168.3.0/24
ip prefix-list LAN2 permit 192.168.2.0/24
route-map PBR permit 10
match ip address prefix-list LAN1
set interface f1
route-map PBR permit 20
match ip prefix-list LAN2
set interface f0
int vlan1
ip policy route-map PBR
Regards.
Alain.
Glenn Matthys Wed, 10/19/2011 - 13:28
I tried your modifications, unfortunately the result is the same.
I removed the route-maps for NAT1 & 2 as they are no longer needed this way.
This is my updated configuration:
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
no ip source-route
ip cef
no ipv6 cef
vtp version 2
ip nat outside
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
interface Async1
no ip address
encapsulation slip
no ip http server
ip nat inside source list 1 interface FastEthernet0 overload
ip nat inside source list 2 interface FastEthernet1 overload
ip prefix-list LAN1 seq 10 permit 192.168.2.0/24
ip prefix-list LAN2 seq 5 permit 192.168.3.0/24
logging esm config
match ip address prefix-list LAN2
control-plane
line con 0
speed 115200
line 1
modem InOut
stopbits 1
speed 115200
line aux 0
line vty 0 4
login
transport input all
end
cadet alain Wed, 10/19/2011 - 13:45
change this in your config:
by this:
ip nat inside source route-map NAT1 f0
ip nat inside source route-map NAT2 f1
route-map NAT1
match interface f0
route-map NAT2
match interface f1
To test it issue some traffic from a PC in vlan1 with ip address in .2 subnet and then with .3 subnet, don't test with locally originated traffic from router
because in this case you need global config ip local-policy route-map PBR command then.
Regards.
Alain.
Glenn Matthys Wed, 10/19/2011 - 22:52
Hello
Tried that, now the packets don't get translated at all, they leave with their original source address out f0.
Glenn
cadet alain Wed, 10/19/2011 - 23:04
how are you testing it?
can you do a debug ip policy as well as debug ip nat when you ping 8.8.8.8 either from a PC in corresponding subnet or
from the router with extended ping sourcing from an address in each corresponding subnet but not the vlan1 address.
Regards.
Alain.
Glenn Matthys Sat, 10/22/2011 - 06:09
I'm testing from a computer inside VLAN1 (the LAN side of the router). Testing using a PC that has 192.168.2.5 and one that has 192.168.3.5.
I turned on debug ip policy, these messages endlessly repeat when I keep pinging (which does not work):
*Oct 22 13:33:46.035: IP: s=192.168.2.5 (Vlan1), d=8.8.8.8 (FastEthernet0), len 84, FIB policy routed
*Oct 22 13:33:47.035: IP: s=192.168.2.5 (Vlan1), d=8.8.8.8, len 84, PBR Counted
*Oct 22 13:33:48.035: IP: s=192.168.2.5 (Vlan1), d=8.8.8.8, len 84, PBR Counted
*Oct 22 13:33:48.035: IP: s=192.168.2.5 (Vlan1), d=8.8.8.8 (FastEthernet0), len 84, FIB policy routed
*Oct 22 13:33:49.035: IP: s=192.168.2.5 (Vlan1), d=8.8.8.8, len 84, FIB policy match
*Oct 22 13:33:49.035: IP: s=192.168.2.5 (Vlan1), d=8.8.8.8, len 84, PBR Counted
*Oct 22 13:33:49.035: IP: s=192.168.2.5 (Vlan1), d=8.8.8.8 (FastEthernet0), len 84, FIB policy routed
*Oct 22 13:33:50.035: IP: s=192.168.2.5 (Vlan1), d=8.8.8.8, len 84, FIB policy match
*Oct 22 13:33:50.035: IP: s=192.168.2.5 (Vlan1), d=8.8.8.8, len 84, PBR Counted
Turning on debug ip nat doesn't show any output, probably because the packets don't get translated at all this time.
I can see the packets aren't being translated because I've connected a switch to the f0 port and set up a SPAN session. The packets leave from the router's f0 interface with their original source address.
This is my current configuration:
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
no ip source-route
ip cef
no ipv6 cef
license udi pid CISCO1811/K9 sn FHK1209233N
vtp version 2
ip nat outside
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
interface Vlan1
ip nat inside
interface Async1
no ip address
encapsulation slip
no ip http server
logging esm config
match interface FastEthernet0
control-plane
line con 0
speed 115200
line 1
modem InOut
stopbits 1
speed 115200
line aux 0
line vty 0 4
login
transport input all
end
Best regards,
Glenn
cadet alain Sat, 10/22/2011 - 07:57
gonna lab it up but it should work, I don't see why it is failing.
ok I got it; the NAT won't work with a prefix-list, just use the ACL instead. I'm really sorry I  made such a mistake.
so change the NAT stements
no route-map NAT1
no route-map NAT2
match ip address 2
match ip address 1
Regards.
Alain.
Marwan ALshawi Sat, 10/22/2011 - 20:20
  • Community Spotlight Award,
    Best Publication, December 2015
Hi Glenn
see the bellow document which will help you to do the setup also you can use IP SLA with the PBR for redundancy of both links in the case one ink is down ( optional )
https://supportforums.cisco.com/docs/DOC-8313
hope this help
if helpful Rate
