rate limit not working for vlan
Answered Question
Oct 21st, 2011
Hi Guyz,
I want to restrict internet traffic for guests on a free SSID to 1MB.
I configured my CORE Switch as follows. all seems well but traffic is never dropped.
any help to solve this is highly appreciated.
I want this vlan (50) to be restricted to 1 MB for outgoing and incoming traffic.
configuration for vlan 50
interface Vlan50
description ***  Interface for VLAN 50
ip address 10.1.22.1 255.255.255.0
ip access-group 105 in
rate-limit input 1000000 1000000 1000000 conform-action transmit exceed-action drop
rate-limit output 1000000 1000000 1000000 conform-action transmit exceed-action drop
end
no traffic is dropped
SW-3560-1#sh int vlan 50 rate-limit
Vlan50 *** Interface for VLAN 50
  Input
    matches: all traffic
      params:  1000000 bps, 1000000 limit, 1000000 extended limit
      conformed 0 packets, 0 bytes; action: transmit
      exceeded 0 packets, 0 bytes; action: drop
      last packet: 2853770291ms ago, current burst: 0 bytes
      last cleared 2w0d ago, conformed 0 bps, exceeded 0 bps
  Output
thanks in advance.
Correct Answer by Kishore Chennupati about 5 years 9 months ago
you can apply this to trunk interfaces as well. you just need to put the trunk interface in the  "match input-interface"
class-map vlan50
and just put the mls qos vlan-based under the trunk interfaces and it will work.
abukuru95 wrote:
thanks Kishore,
the configuration is successfully applied, but helas no traffic is dropped. i have three trunk interfaces on my core switch where i need to apply this. I guess i can only apply it on physical interfaces? thanks w bunch anyway. i am still awaiting new ideas.
You cannot apply service-policy output to physical interfaces on 3560 due to ASIC limitations
Kishore
Overall Rating: 5 (1 ratings)
abukuru95 Mon, 10/24/2011 - 00:52
Hello Smitesh,
I cannot apply some commands that are on the link you provided such as
match class-map class -default
I am running version (C3560-IPSERVICESK9-M), Version 12.2(35)SE5
any more ideas?
regards.
Latchum Naidu Mon, 10/24/2011 - 02:11
  • Blue, 1500 points or more
Try below may help you...
Policy a specific VLAN number on VLAN interface.
class-map vlan5
match vlan 5
match class-map class-default
policy-map vlan5-limit
class vlan5
police 2000000 250000 exceed-action drop
int vlan5
service-policy input vlan5-limit
After you apply this configuration, the traffic with VLAN 5 coming from any will be policed at 2Mbps.
Hope this will help you.
Please rate the helpfull posts.
Naidu.
abukuru95 Mon, 10/24/2011 - 10:12
Hi Latchum,
when i apply the command
int vlan5
service-policy input vlan5-limit,
i receive this error %QoS: policy-map with police action at parent level not supported on Vlan5 interface.
i am running ios version 12.2(35)SE5
any ideas on a way out ?
Marwan ALshawi Mon, 10/24/2011 - 14:03
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
What you can do use same policy suggest above as child policy
Example
Policy-map p1
Class-class default
Service-policy vlan5-limit
Then apply the p1 policy at the clan interface level
You mY need to change the behavour of the qos to vlan based on the physical interface level
Using the command mls qos vlan-based
Hope this help
If helpful rate
abukuru95 Tue, 10/25/2011 - 01:06
Hi Marwanshawi,
I dont get you quiet well using the same policy as child policy?
thanks for the help.
Latchum Naidu Tue, 10/25/2011 - 01:21
What that meant is...
configure everything like in my previous post then configure the child policy like below and apply to the vlan interface.
Policy-map p1
Class-class default
int vlan5
Policy-map p1
Naidu.
abukuru95 Tue, 10/25/2011 - 02:26
Hi Natchum,
i do not have this command under the interface vlan options
interface vlan 5
policy-map p1
when i go to the
conf t
interface vlan 5
it does not exist on the ios
thanks for the help anyway.
Kishore Chennupati Tue, 10/25/2011 - 03:35
  • Gold, 750 points or more
Latchum meant
int vlan 5
service-policy input p1
Kishore
abukuru95 Tue, 10/25/2011 - 03:47
hi Kishore, yes.
this is the output i am getting now.
3560(interface vlan 5
3560(config-if)#service-policy input p1
%QoS: policy-map vlan_5-limit with MATCH INPUT-INTERFACE matching non-physical interfaces or other unsupported
Service Policy attachment failed
3560(config-if)#
3560(config-if)#
thanks for your help guys.
Kishore Chennupati Tue, 10/25/2011 - 05:39
Ah the reason is that the match statement under the class-map is not correct.
match vlan 5  is only available on 6500's 4500's and metro ethernet switches. not on a 3560
please remember the following points while using child policy's
Key things to remember:
    Child classes use match input-interface
    Child policies use police
    Parent classes match ACL (I think you can also match dscp, maybe others)
    Parent policies must have an action (e.g. set or trust)
    Apply parent policies to SVI
So you need to use match input-interface and match all the interfaces where vlan 50 is configured.
For eg: lets assume that you have vlan 50 configured on interface fa1/0/1 then the class-map will be like this
access-list 100 permit ip any any
class-map match-any cm-1
match access-group 100
class-map vlan50
match input-interface fa1/0/1
policy-map vlan50-limit
class vlan50
policy-map vlan-50-limit-2Mbps
class cm-1
trust dscp
service-policy vlan50-limit
int vlan50
service-policy input vlan-50-limit-2Mbps
int fa1/0/1
mls qos vlan-based
Please apply the above and let me know how you go
Ksihore
Please rate if helps
abukuru95 Tue, 10/25/2011 - 06:35
thanks Kishore,
Correct Answer
Kishore Chennupati Tue, 10/25/2011 - 13:30
class-map vlan50
abukuru95 wrote:
thanks Kishore,
Kishore
