Inter-vlan routing and HSRP
Steve_Oake
I'm hoping someone can help me with a lab project I'm am trying to figure out. I am running a router (A) as a DHCP server, Nat translation to the internet, and inter-vlan routing. The problem with this set up is, if the router goes out, it knocks out the whole network. I've done a little research and discovered a possible solution, which is to set up an identical router off the core switch, and use HSRP. But, I am unsure how to do so. I have done a very basic diagram below, leaving of the irrelivant details such as redundant core switch and stp priorities. All links pictured are trunked with dot1q. Below that, I have copied the config file for router A. Currently, router b is just sitting there with nothing programmed on it, as I'm not quite sure what to program. Each of the vlans' default-gateway is set to 200.100.50.1 255.255.255.240. Any help will be appreciated.
Router A                           Router B
2811                                   2811
  |                core                    |
  ----------------2950--------------------
2950------------     ---------------2950
Vlan 1 native                      vlan 1 native
vlan 10                              vlan10
vlan 20                              vlan 20
vlan 30                              vlan 30
Router A Config file
en
conf t
hostname Core_Router
ip dhcp pool vlan10
network 200.100.50.16 255.255.255.240
default-router 200.100.50.17
dns-server 164.106.1.1
ip dhcp pool vlan20
network 200.100.50.32 255.255.255.240
default-router 200.100.50.33
ip dhcp pool vlan30
network 200.100.50.48 255.255.255.240
default-router 200.100.50.49
exit
ip nat inside source list 1 interface FastEthernet0/1 overload
access-list 1 permit any
interface fa0/0
no shut
interface fa0/0.1
encapsulation dot1Q 1 native
ip address 200.100.50.1 255.255.255.240
ip nat in
NO shut
interface fa0/0.10
encapsulation dot1Q 10
ip address 200.100.50.17 255.255.255.240
ip nat in
No shut
interface fa0/0.20
encapsulation dot1Q 20
ip address 200.100.50.33 255.255.255.240
ip nat in
No shut
interface fa0/0.30
encapsulation dot1Q 30
ip address 200.100.50.49 255.255.255.240
ip nat in
no shut
ip address 192.168.0.200 255.255.255.0
ip nat outside
no shutdown
interface Vlan1
no shut
router eigrp 1
network 200.100.50.0 0.0.0.15
network 200.100.50.16 0.0.0.15
network 200.100.50.32 0.0.0.15
network 200.100.50.48 0.0.0.15
ip route 0.0.0.0 0.0.0.0 200.100.50.8
line con 0
logging syn
end
3 Accepted Solutions
kozorezdi
Hi Steve,
I suppose it should look like this:
##############  router A ############
ip dhcp pool vlan10
ip dhcp pool vlan20
ip dhcp pool vlan30
ip dhcp excluded-address 200.100.50.17
ip dhcp excluded-address 200.100.50.30
ip dhcp excluded-address 200.100.50.29
ip dhcp excluded-address 200.100.50.33
ip dhcp excluded-address 200.100.50.46
ip dhcp excluded-address 200.100.50.45
ip dhcp excluded-address 200.100.50.49
ip dhcp pool vlan10
ip dhcp pool vlan20
ip dhcp pool vlan30
interface FastEthernet0/0.1
ip address 200.100.50.14 255.255.255.240
ip nat inside
standby 1 ip 200.100.50.1
standby 1 priority 150
standby 1 preempt delay minimum 30
interface FastEthernet0/0.10
ip address 200.100.50.30 255.255.255.240
ip nat inside
  standby 10 ip 200.100.50.17
standby 10 priority 150
standby 10 preempt delay minimum 30
interface FastEthernet0/0.20
ip address 200.100.50.46 255.255.255.240
ip nat inside
standby 20 ip 200.100.50.33
standby 20 priority 150
standby 20 preempt delay minimum 30
interface FastEthernet0/0.30
ip address 200.100.50.62 255.255.255.240
ip nat inside
standby 30 ip 200.100.50.49
standby 30 priority 150
standby 30 preempt delay minimum 30
#############  Router B ################
ip address 200.100.50.13 255.255.255.240
ip nat inside
standby 1 priority 120
ip address 200.100.50.29 255.255.255.240
ip nat inside
standby 10 priority 120
ip address 200.100.50.45 255.255.255.240
ip nat inside
standby 20 priority 120
ip address 200.100.50.61 255.255.255.240
ip nat inside
standby 30 priority 120
tracking:
on R1:
int fas0/0.1
standby 1 track fastEthernet 0/1 40
! 150-40=110 < 120 on R2 - R2 will be Active.
Dimitry
Hi Steve
I have few additional inputs regarding this setup
  • The problem with this set up is, if the router goes out, it knocks out the whole network. I've done a little research and discovered a possible solution, which is to set up an identical router off the core switch, and use HSRP. But, I am unsure how to do so.
            HSRP provides Gateway Level Redundancy for the end users by having two gateway routers operate in Active/Standby mode of operation and by providing a shared virtual mac to the end users so that the end user GW is always reachable. Below is a link to Cisco Documentation for same
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.1_12c_ea1/configuration/guide/swhsrp.html
The only important thing to remember with HSRP is to track the WAN interface under HSRP for no traffic-blackholing if the WAN is down else we need to run routing between the two routers to provide an alternate routing path when the WAN of HSRP Master is down.
  • Each of the vlans' default-gateway is set to 200.100.50.1 255.255.255.240. Any help will be appreciated.
"Every VLAN will have a separate default-gateway which will be the VLAN's Interface IP in case of Single Router A or HSRP IP in case of Dual Routers A & B "
  • I'm hoping someone can help me with a lab project I'm am trying to figure out. I am running a router (A) as a DHCP server, Nat translation to the internet, and inter-vlan routing.
When using HSRP we also need to look for the redundancy for the NAT being done for which we have a feature of Stateful NAT which provides stateful nat switchover when using HSRP. You will need to check for the support of same on c2811 and your current IOS.Below is a link to Cisco Documentation for same
http://www.cisco.com/en/US/products/ps6600/products_white_paper09186a0080118b04.shtml
Now from my understanding there is no option available yet for DHCP stateful switchover in IPv4 except for Stateful DHCP Relaying so that would be a challenge as we are using only Router A as DHCP server. If we even make Router B also as DHCP Server Same time there DHCP Binding Database would not be in Sync and there might be IP Conflicts . I think better option would be keep Router A as DHCP Server and configured DHCP relay on Router B and keep two routing paths between Router A and Router B to provide reachability to the DHCP Server on Router A.
Hope this helps you to answer your queries.
Varma
Hi Steve,
Tracking will allow to switch Router A to Standby mode when Up-link down and Router B will be Active.
I think, better to read manual first:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_35_se/configuration/guide/swhsrp.pdf
Probably, better to check another solution IP SLA for it.
Dimitry
7 Replies 7
Steve_Oake
I'm thinking that if I set up HSRP on fa0/0.1, it should be enough to  shut down the redundant router  from acting as a DHCP server,  inter-vlan routing or internet access since vlan 1 on router b would be  on standby, and everything happens through vlan 1. I also was worried  that conflicts in addresses might happen if router b's dhcp came up, but  had no database of which addresses had been leased, but then I found  out that the DHCP server (on Cisco equipment) will ping an address  before assigning it to see if it is already in use, so this should not  be an issue.
Anyways, I believe on interface fa0/0.1, I could change the address  to an unused address (such as 200.100.50.10/28) and use the default  address as the standy (standby 1 200.100.50.1). So, my think is, on router A, the config would go something like this:
int fa0/0.1
ip add 200.100.50.10 255.255.255.240
standby 1 preempt
standby 1 priority 100
Router b:
int fa0/0.1
ip add 200.100.50.11 255.255.255.240
standby 1 preempt
standby 1 priority 90
If my theories are wrong, let me know
kozorezdi
Hi Steve,
ip dhcp pool vlan10
ip dhcp pool vlan20
ip dhcp pool vlan30
ip dhcp pool vlan10
ip dhcp pool vlan20
ip dhcp pool vlan30
ip nat inside
ip nat inside
ip nat inside
ip nat inside
ip nat inside
ip nat inside
ip nat inside
ip nat inside
tracking:
on R1:
int fas0/0.1
Dimitry
Thanks for replying.
The last couple of lines are confusing me.
tracking:
on R1:
int fas0/0.1
What is tracking?
The rest of it I think I get, but I want to confirm that router A will be the main router.
Hi Steve
Varma
Thanks for the help.
Hi Steve,
Dimitry
