Show vpn-sessiondb detail l2l . How to clear connections by Tunnel ID?
Answered Question
With "show-vpndessiondb detail l2l" , i obtain this output
IPsec:
  Tunnel ID    : 107.2
  Local Addr   : 172.20.18.0/255.255.255.0/0/0
  Remote Addr  : 172.20.24.0/255.255.255.0/0/0
  Encryption   : 3DES                   Hashing      : MD5
  Encapsulation: Tunnel
  Rekey Int (T): 28800 Seconds          Rekey Left(T): 28259 Seconds
  Rekey Int (D): 4608000 K-Bytes        Rekey Left(D): 4607996 K-Bytes
  Idle Time Out: 30 Minutes             Idle TO Left : 21 Minutes
  Bytes Tx     : 5016                   Bytes Rx     : 0
  Pkts Tx      : 38                     Pkts Rx      : 0
IPsec:
  Tunnel ID    : 107.3
  Local Addr   : 172.20.19.0/255.255.255.0/0/0
  Rekey Int (T): 28800 Seconds          Rekey Left(T): 28257 Seconds
  Rekey Int (D): 4608000 K-Bytes        Rekey Left(D): 4607998 K-Bytes
  Bytes Tx     : 2244                   Bytes Rx     : 0
  Pkts Tx      : 17                     Pkts Rx      : 0
Is there a way to clear the IPsec connection by "Tunnel ID"? I am familiar with "clear ip sec sa <peer ip>", but that will bring down the whole tunnel. I am looking in how to be more granular clearing connections  coming from Local Addr 172.20.19.0/255.255.255.0/0/0 , for example -see output above-
John
Correct Answer by Jennifer Halim about 5 years 9 months ago
No, unfortunately you can't just clear the connection for 1 specific SA within a tunnel.
The only option with "vpn-sessiondeb logoff" is as follows:
http://www.cisco.com/en/US/docs/security/asa/asa84/command/reference/uz.html#wp1726098
which is pretty much the same as what you can achieve via "clear cry ipsec sa " command.
Overall Rating: 5 (1 ratings)
sachinga.hcl Wed, 02/08/2012 - 01:17
  • Silver, 250 points or more
Hi John,
First, review some of the available commands with vpn-sessiondb:
ciscoasa# vpn-sess logoff ?
  all           All sessions
  email-proxy   Email-Proxy sessions
  index         Index specific session
  ipaddress     IP Address specific sessions
  l2l           IPsec LAN-to-LAN sessions
  name          Username specific sessions
  protocol      Protocol specific sessions
  remote        IPsec Remote Access sessions
  svc           SSL VPN Client sessions
  tunnel-group  Tunnel-group sessions
  vpn-lb        VPN Load Balancing Mgmt sessions
  webvpn        WebVPN sessions
Here’s how I log off a VPN session from an ASA.
You can also log off all sessions.
For Logging off single session,  it can be done based on index.
First, get the index.
# show vpn-sessiondb remote
Username     : remoteuser1               Index        : 10030
Assigned IP  : 172.16.0.182           Public IP    : 1.2.3.4
Protocol     : IKE IPsecOverNatT
License      : IPsec
Encryption   : DES 3DES               Hashing      : MD5 SHA1
Bytes Tx     : 220                    Bytes Rx     : 844
Group Policy : MyGroupPolicy         Tunnel Group : tpm
Login Time   : 09:59:32 EDT Wed Sep 21 2011
Duration     : 0h:01m:15s
Inactivity   : 0h:00m:00s
NAC Result   : Unknown
VLAN Mapping : N/A                    VLAN         : none
Look for the user and associated index ID (in bold). In the above example the Index is 10030.
SO to Log off  only one session for that specific index ID 10030 kindly use the below mentioned command on your cisco asa:
# vpn-sessiondb logoff index 10030
Do you want to logoff the VPN session(s)? [confirm] INFO: Session with Index = 10030 has been logged off
Note, you can also logoff a specific sesson based on name (as well as index) if you know the name.
You can log off all sessions by simply using
vpn-sessiondb logoff all
There are several other options for particular type of sessions to be logged off, based on the type of connection, and then depend only one session based on index or all session for taht particular tyope like only webvpn or only remote, but remeber first get the session Index before moving ahead.
ciscoasa#vpn-sessiondb logoff name ssluser1
Do you want to logoff the VPN session(s)? [confirm] Y
INFO: Number of sessions with name "ssluser1" logged off : 1
ciscoasa#Called vpn_remove_uauth: success!
webvpn_svc_np_tear_down: no ACL
webvpn_svc_np_tear_down: no IPv6 ACL
np_svc_destroy_session(0xB000)
show vpn-sessiondb
To display information about VPN sessions, use the show vpn-sessiondb command  in privileged EXEC mode. The command includes options for displaying  information in full or in detail, lets you specify type of sessions to  display, and provides options to filter and sort the information. The  syntax table and usage notes organize the choices accordingly.
show vpn-sessiondb [detail] [full] {remote | l2l | index indexnumber | webvpn | email-proxy}  [filter {name username | ipaddress IPaddr | a-ipaddress IPaddr | p-ipaddress IPaddr |  tunnel-group groupname | protocol protocol-name | encryption encryption-algo}]
[sort {name | ipaddress | a-ipaddress | p-ip address | tunnel-group | protocol | encryption}]
Viewing SSL VPN Sessions
You can view information about active sessions using the show vpn-sessiondb command in privileged EXEC mode:
show vpn-sessiondb svc
The following example shows the output of the show vpn-sessiondb svc command:
hostname# show vpn-sessiondb svc
Session Type: SSL VPN Client
Username     : lee
Index        : 1                      IP Addr      : 209.165.200.232
Protocol     : SSL VPN Client         Encryption   : 3DES
Hashing      : SHA1                   Auth Mode    : userPassword
TCP Dst Port : 443                    TCP Src Port : 54230
Bytes Tx     : 20178                  Bytes Rx     : 8662
Pkts Tx      : 27                     Pkts Rx      : 19
Client Ver   : Cisco STC 1.1.0.117
Client Type  : Internet Explorer
Group        : DfltGrpPolicy
Login Time   : 14:32:03 UTC Wed Mar 20 2007
Duration     : 0h:00m:04s
Filter Name  :
Logging Off SVC Sessions
To log off all SSL VPN sessions, use the vpn-sessiondb logoff svc command in global configuration mode:
The following example logs off all SSL VPN sessions:
hostname# vpn-sessiondb logoff svc
INFO: Number of sessions of type "svc" logged off : 1
You can log off individual sessions using either the name option, or the index option:
vpn-session-db logoff name name
vpn-session-db logoff index index
You can find both the username and the index number (established by the order of the client images) in the output of the show vpn-sessiondb svc command. The following example shows the username lee and index number 1.
Username     : lee
Login Time   : 14:32:03 UTC Wed Mar 26 2007
Filter Name  :
The following example terminates the session using the name option of the vpn-session-db logoff command:
hostname# vpn-sessiondb logoff name tester
INFO: Number of sessions with name "mkrupp" logged off : 0
hostname#
To log off all or selected VPN sessions, use the vpn-sessiondb logoff command in global configuration mode.
vpn-sessiondb logoff {remote | l2l | webvpn | email-proxy | protocol protocol-name | name  username | ipaddress IPaddr | tunnel-group groupname | index indexnumber | all}
Syntax Description
all
Logs off all VPN sessions.
email-proxy
Logs off all e-mail proxy sessions.
index indexnumber
Logs off a single session by index number. Specify the index number for the session.
ipaddress IPaddr
Logs off sessions for the IP address hat you specify.
l2l
Logs off all LAN-to-LAN sessions.
name username
Logs off sessions for the username that you specify.
Logs off sessions for protocols that you specify. The protocols include:
IKE
IMAP4S
IPSec
IPSecLAN2LAN
IPSecLAN2LANOverNatT
IPSecOverNatT
IPSecoverTCP
IPSecOverUDP
POP3S
SMTPS
userHTTPS
vcaLAN2LAN
remote
Logs off all remote-access sessions.
Logs off sessions for the tunnel group that you specify.
webvpn
Logs off all WebVPN sessions.
Similarly, you can use the vpn-sessiondb logoff svc command in order to terminate all the SVC sessions.
I find using the ASDM more accurate and less error prone if you are novice. It also gives you a summary of the login statistics at a glance.
One is to use the GUI – Cisco’s ASDM and the other by using good old CLI.
On ASDM (Version 6.2)
- Click on the monitoring tab.
- Under VPN statistics, select sessions
- On the right drop down box where it says “Filter By” select IPsec  Remote Access or if you are using SSL Client/Clientless VPN select the  one of your choice.
- Click the Logout button!
For getting details of all VPN sessions on cisco ASA box please use following :
  1. ciscoasa# show vpn-sessiondb summary
  2. Active Session Summary
  3. Sessions:
  4.                             Active : Cumulative : Peak Concurrent
  5.   SSL VPN               :          0 :          4 :               2
  6.     Clientless only     :          0 :          4 :               2
  7.     With client         :          0 :          0 :               0
  8.   Email Proxy           :          0 :          0 :               0
  9.   IPsec LAN-to-LAN      :          0 :          0 :               0
  10.   IPsec Remote Access   :          0 :        877 :               3
  11.   Totals              :          0 :        881
  12. License Information:
  13.   IPsec   :     10    Configured :     10    Active :      0    Load :   0%
  14.   SSL VPN :      2    Configured :      2    Active :      2    Load : 100%
  15.   Total   :     12    Configured :     12    Active :      2    Load :  17%
  16.                 Active : Cumulative : Peak Concurrent
  17.   IPsec   :          0 :        877 :               3
  18.   SSL VPN :          2 :          6 :               2
  19.   Totals  :          2 :        883
  20. Tunnels:
  21.                               Active : Cumulative : Peak Concurrent
  22.   IKE                   :          0 :        877 :               3
  23.   IPsec                 :          0 :        159 :               1
  24.   IPsecOverNatT         :          0 :        611 :               2
  25.   L2TPOverIPsec         :          0 :         90 :               1
  26.   L2TPOverIPsecOverNatT :          0 :        404 :               2
  27.   Clientless            :          0 :          4 :               2
  28.   Totals                :          0 :       2145
  29. Active NAC Sessions:
  30.   No NAC sessions to display
  31. Active VLAN Mapping Sessions:
  32.   No VLAN Mapping sessions to display
  33. ciscoasa#
Hope it Helps. !!!
sachinga.hcl,
I appreciate your thorough answer and how to manage granularity on the other type of VPN sessions(remote users and SSL sessions). Unfortunately, it is not that granular on "l2l" sessions. Just to bring it up, the functionality is not there yet just logoff just session "Tunnel ID    : 107.3" shown as an example in my first post on this thread,
Thanks anyway for taking the time compose a long reply . Now I now even more about how to manage the other type of sessions.
John
Varinder Singh Fri, 02/10/2012 - 10:58
  • Cisco Employee,
You can try to clear a particular tunnel ID  inbound spi value. Try this command on ASA
# clear crypto  ipsec sa entry 2.2.2.2 esp 0.fffffffff
Here 2.2.2.2 is the peer address and 0.ffffffff is the value for spi which can be taken from the following command.
# sh cry ipsec sa
You will see inbound and outbound spi for every cryoto access list.
Let me know if it works
Varinder
