Save configuration in ASA 5505
Answered Question
Oct 24th, 2011
Hi all,  I have this issue, I save the configuration in the ASA 5505 using write memory or using copy run start but whe i unplug the power cord and plug it back in the ASA gets its factory default configuration.... then what i do is a copy start run to get the configuration active....
why is this so? even though i saved the config to flash ... regards!
Correct Answer by Eugene Khabarov about 5 years 4 months ago
You have incorrect boot register:
Please follow up the following document:
http://www.cisco.com/en/US/docs/security/asa/asa71/configuration/guide/trouble.html#wp1062992
You need to set up default value 0x1
___
HTH. Please rate this post if it was helpful. If this solves your problem, please mark this post as "Correct Answer"
Overall Rating: 5 (1 ratings)
Correct Answer
Eugene Khabarov Fri, 10/28/2011 - 01:49
  • Silver, 250 points or more
___
adavila03 Fri, 10/28/2011 - 07:07
I never changed the config register. the default value was 0x41 . I switched it back to 0x1.
Thanks for your response!
