10-24-2011 01:04 PM - edited 03-14-2019 08:46 AM
HI
In UCCX 8.0.2 during the call agent state is flickring & service is also toggle between in service & partial service.
sametime in CSD also Agent state keep on flickring.
we oberver one more thing chat service also disconnected from the Agent when answes the call with error message like call /chat service is failure.
is the known issue ? how we proceed further ?
10-25-2011 06:15 AM
I've seen this behaviour after an upgrade from 8.0(2) to 8.0(2) SU3. Have you upgraded from a previous version? If so, your agent and supervisor desktops need to be updated. This should happen automatically after an upgrade, but sometimes windows user permissions, proxies etc may stop it from happening.
Check your clients against the compatibility matrix here ...
Brian
10-25-2011 07:11 AM
Hi Brain,
Thanks for your reply.
We have upgraded directly from 7.0 to 8.0.2 SU3 .
Verified the CAD Version 80.2.400 which is compatible with UCCX.What is the resolution for this ?
10-25-2011 07:26 AM
Ensure all your agents and supervisors are on the correct version. I've seen issues where just 1 or 2 agents did not upgrade successfully
My only other suggestions would be to check there are no firewall or ACL that would cause ports to be blocked ... failing all that you will need to open a TAC.
Brian
10-26-2011 04:13 AM
I have seen a few cases with this type of flickering problem. If you look at CAD and Service Release version, all seems ok.
My fix:
Uninstall Service Release. Then start CAD. It will detect there is a new version on the server. It download and install Service Release. Then CAD should work without flickering.
Wenqian
10-28-2011 05:18 AM
Please run this command on UCCX primary command line and see the output.
admin:show network status listen
Make sure your uccx server is listening on
There are some upgrade issue's TAC is aware of, where the upgraded 8.x server continues to communicate on the old 59xxx ports for CAD/Desktop services. If this is the case, you have to open a TAC case to get this corrected on both the Server's in the cluster.
10-28-2011 04:12 AM
If all the agents and supervisors are running the proper version. Please check that firewall or anti virus is not blocking the chat ports
