HSRP... little problem :)
My topology is like this :
FAI1 --- Router1 (fa1/0) ---------- Switch1
   (fa2/0) iBGP (fa2/0)                         |
FAI2 --- Router2 (fa1/0) ---------- Switch2
     Note : for some networks I use Router2 as default route if Router2 is UP. If Router2 is down, Router1 is the only external way. If Router1 is      down, Router2 is the ony external way.
My HSRP conf is simple as possible :
     Router1 (fa1/0)
ip add 192.168.0.10
standby 1 ip 192.168.0.1
standby 1 timer 2 6
standby 1 priority 200
standby 1 preempt delay minimum 120
     Router2 (fa1/0)
ip add 192.168.0.11
standby 1 timers 2 6
standby 1 preempy
If Switch1 and Switch2 are up. Router1 is active, Router2 is in standby. Ok that work.
If Switch1 or Switch2 is down, HSRP is active on the two routers. Is it possible to use the link used by iBGP to set the state of HSRP (I have trying with standby 1 track but that doesnt work) ?
Jerome
Kishore Chennupati Thu, 10/27/2011 - 04:15
  • Gold, 750 points or more
HSRP relies on a L2 network for communicating the hellos. So, in your case when one of the switch dies then both the routers cant talk to each other and hence they go Active/Active.
The simple solution to this is to have a a trunk from each router into both the switches. let me explain you.
Have a trunk between between 2960A and 2851B.   So, if the link between 2851A and 2960A goes down you have redundancy  via 2851B. Also have a trunk between the switches. The diagram is not showing it.
1. so imagine if switch A goes down. then the HSRP hellos from RouterA will still be going to Router B via switch 2.
2.  imagine switch dies then the hsrp hellos still go to router 1 via switch 1.
3. If the trunk link between the switces goes down. No problem the hellos will still be goin across.
Hope this answers your question. Please feel free to ask any more q's
BGP doesnt help in transmitting HSRP hellos
Kishore
Vaibhava Varma Thu, 10/27/2011 - 04:30
  • Silver, 250 points or more
Hi Jerome
As put forward by Kishore to transmit HSRP Hellos we need L2 Link and hence the iBGP Protocol itself can not pass HSRP Hellos.
Kishore I was wondering one thing that if we are using an ISR such as 2811,2821 or 2851 they have by default on board routed ethernet ports only and no ethenet switch ports and hence the above design presents a limitation of  using Ethernet Switch Ports on the routers as we will need to create SVIs here not dot1q subinterfaces since we have multiple trunk links coming onto the same device carrying same VLANs.
If at all we are going for Ethernet Switched Cards then why not directly create an L2 Trunk between the routers ?
Whats your take on this ? Just a thought
Varma
Kishore Chennupati Thu, 10/27/2011 - 05:13
All I can say Varma is that I agree with you completely .I just imprvised on the existing network. But , yes if you were to start from scratch buying new gear and set it up Then yes what you said is true.
offtopic: Did you check ur private msgs?
Kishore
Vaibhava Varma Thu, 10/27/2011 - 05:21
Hi Kishore
I did it now and you made me smile
Varma
Kishore, Varma,
I dont want to use iBGP protocol but the link used by this protocol .
There are juste one thing I dont understand.
In your diagram each router need two L3 port on the LAN side (and one on the WAN side). I can add a new L3 port, it's not a problem I have a wic module for that. But what the conf for the two new port because I can't use the same subnet on two interfaces...
Jérôme
Vaibhava Varma Thu, 10/27/2011 - 08:16
Hi Jerome
The Link used for iBGP is an :L3 Link and hence can not be used to send L2 HSRP Hellos ,
Yes you are correct as I have mentioned above we can not use the above topology if we have routed ethernet ports ; As we would not be able to configure SVIs and hence we can not configure same IP on 2 Intefaces
Now coming back to your scenario if Switch 1 and Switch 2 are down the LAN users would be only connected to one Switch and despite of the fact there are two HSRP Active routers in Networks users connect to only one switch and Switch is only connected to one HSRP Router and hence there is no issue
Hope this helps to answer your query.
Varma
Vaibhava Varma Thu, 10/27/2011 - 10:08
Hi Jerome
As mentioned above when we think of the Switch failure scenario then the LAN Users are already isolated from the other Switch and HSRP is no more Valid. Even if we connect an L2 Link between the two routers by installing the required HWIC then what will happen is that the L2 Link will provide an alternate L2 switching path for the LAN users to reach the HSRP GW.
But I don't think its needed to have an alternate L2 path becuase its not  providing any extra layer of redundancy except to keep the HSRP topology sane and ideal.
This kind of topolofy would be recommended if we want to keep the GWRTRS in Active:Standby and want to have all the traffic exiting out from the site from one router only under normal conditions due to some BW constraints.
If the network requirements allow for an Active:Active toplogy we will not need an L2 Path between the two routers .
Hope this helps to clarify on the traffic requirements.
Varma
Kishore Chennupati Thu, 10/27/2011 - 14:59
Hi Jerome,
If all the users are connected to just one switch and it goes down then HSRP will not help at all.
you will have to move the users from that switch over to the other one. Have the second switch configured and ready for DR purposes. just make sure that any change you make in the primary swtich needs to be put on the secondary switch as well  which is a  bit of admin task
Kishore
In fact I have just servers with 2 NIC and an IP bonding feature.
So just one L2 link between the 2 routers (like the L3 used for iBGP) ? It's not needed to cross each router on each switch ?
Jerome
Kishore Chennupati Thu, 10/27/2011 - 16:29
Jerome
From what I understand from that statement is basically saying that we dont need HSRP. The routers work stand alone. So your traffic will go thru one router and one switch . If the switch goes down then you move the servers to the other switch and then the traffic will go thru the other router.
Vaibhava Varma Thu, 10/27/2011 - 19:10
Hi Jerome/Kishore
What I meant to say was that lets consider the below topology as Jerome said we have a server in teaming:
FAI1 --- Router1 (fa1/0) ---------- Switch1-------------NIC1---------
   (fa2/0) iBGP (fa2/0)                         |                                   Server(Virtual Bond IP)
FAI2 --- Router2 (fa1/0) ---------- Switch2--------------NIC2---------
Now there is no L2 Link between the Router 1 & Router 2. Lets say the Active NIC is NIC 1 and the HSRP Master is Router 1. Now the Switch 1 Crashes down and the NIC2 becomes Active and the Router 2 becomes HSRP Master now. Server is sending all its traffic to Router 2 only and thats why we do not need L2 Path between R1 & R2 in Active:Active mode.
Now if there is a requirement that whenever the Switch1 to Router1 Links goes down then still traffic should exit out of R1 only ie Active:Standby then in that case we need an L2 path between the Routers and traffic will flow like this.
After the S1-R1 Link breaks STP reconverges and activates S1-S2 Link and the Frame frommServers hits S1 and then travels from S1-S2 and then hits R2 and then travels from R2-R1 and exits out. Thats why we need L2 Link only in Active:Standby Solution.
Hope this helps to clarify your doubt.
Varma
Yes Varma it's correct.
I have try in my GNS lab to add a L2 between routers but It's always the same problem each server is active in the case or sw1/sw2 is down. Now I have 2 links between my 2 routers (1 L3 for iBGP and 1 L2 for HSRP with an NM-16ESW module).
The result:
Router1#sh standby brief
                     P indicates configured to preempt.
Interface   Grp Prio P State    Active          Standby         Virtual IP
Fa1/0       1   200  P Active   local           unknown         91.209.117.1
Router2#sh standby brief
Fa1/0       1   100  P Active   local           unknown         91.209.117.1
An idea ?
Jerome
Kishore Chennupati Fri, 10/28/2011 - 15:08
Hi jerome,
From your pic, you dont need 2 X L2 links between the 2 routers just one shud be enuff but It's good for redundancy though. In fact for iBGP they dont need to be directly connected, thats one of the good things about iBGP. In your diagram I can see you are using a router as a switch or are u using the ESW module on those as L2 switches. Technically it should work but not if any glitch there
May I suggest you to use the actual layer2 switch as see in in my diagram and you can confugure just like a normal layer 2 switch if you double click on it. You wont get a CLI or anything like routers because there is no image for it.
I just put QEMU host as I didnt configure one
HSRP works beautifully in GNS3.  I have done tons of labs on GNS3 for HSRP and never had a problem
Kishore
So, I have changed my conf, now my topology is like this :
With this conf :
R1 (same thing for R2) :
interface Port-channel1
switchport mode trunk
interface FastEthernet3/0
description R2
channel-group 1 mode on
interface FastEthernet3/1
description R2
interface FastEthernet3/2
description SW1
interface FastEthernet3/3
description SW2
interface Vlan10
ip address 91.209.117.10 255.255.255.0
standby 10 ip 91.209.117.1
standby 10 timers 2 6
standby 10 priority 200
SW1 (same thing for SW2) :
interface FastEthernet0/0
description R1
interface FastEthernet0/1
description R2
interface FastEthernet0/2
description Server
switchport access vlan 10
spanning-tree portfast
Now it's ok, R1 is active, R2 is in stanby. But there are little very strange problem. From server I can ping 91.209.117.10 (or R2 with 91.209.117.11) but not the HSRP virtual IP add.
If I lookat ARP table on server :
[email protected]:~$ arp
? (91.209.117.1) at 00:00:0c:07:ac:0a [ether]  on bond0
? (91.209.117.10) at cc:1d:1c:fc:00:00 [ether]  on bond0
And the mac address table on SW1 :
Switch1#sh mac-address-table
*Mar  1 00:53:39.163: %SYS-5-CONFIG_I: Configured from console by console
Destination Address  Address Type  VLAN  Destination Port
cc21.15f8.0000          Self          1     Vlan1
0000.0c07.ac0a          Dynamic      10     FastEthernet0/0
00aa.0086.fe00          Dynamic      10     FastEthernet0/2
cc1d.1cfc.0000          Dynamic      10     FastEthernet0/0
cc1d.1cfc.f302          Dynamic       1     FastEthernet0/0
cc1d.1cfc.0000          Dynamic       1     FastEthernet0/0
I have the correct VLAN/MAC for the HSRP address :
Router1#sh standby
Vlan10 - Group 10
  State is Active
    2 state changes, last state change 01:29:09
  Virtual IP address is 91.209.117.1
  Active virtual MAC address is 0000.0c07.ac0a
    Local virtual MAC address is 0000.0c07.ac0a (v1 default)
  Hello time 2 sec, hold time 6 sec
    Next hello sent in 0.248 secs
  Preemption enabled, delay min 120 secs
  Active router is local
  Standby router is unknown
  Priority 200 (configured 200)
    Track interface FastEthernet0/0 state Up decrement 10
  IP redundancy name is "hsrp-Vl10-10" (default)
Why I can't reach this address ?
Vaibhava Varma Sat, 10/29/2011 - 05:30
Hi Jerome
Can you ping the HSRP IP from R1/R2 itself ?
Varma
andrewswanson Sat, 10/29/2011 - 05:45
the standby router for vlan 10 is listed as 'unknown' in your output for R1. does vlan10 exist in the vlan databases on R1 and R2?
hth
andy
Vaibhava Varma Sat, 10/29/2011 - 22:40
Hi Jerome
"ip pim sparse-mode" is used to enable multiast routing and I don't think it has anything to do with HSRP here..Its a not so expected behaviour we are seeing for HSRP..
What series router are you using..Is it a real network or some lab setup in GNS or something ?
If R1/R2 can ping HSRP IP and User can ping R1/R2 Physical IP then I don't see any issue on HSRP Layer.
Not sure many be a weird platform/IOS behaviour...
Varma
