Messaje error with IPPA
hugomdbaez
Hello to all ,
I have a Cisco Contact Center Express witth IPPA ( there,s no PCs ) , the problem is with the new agents , they cant log in , the error message is below :
Unable to connect due to a configuration error (the phone is not associated with the user ID of the RM JTAPI provider)
I will appreciatte any help or advice !
Thanks and best regards
Hugo
Hi Hugo
Just to confirm you have 9 phones for Agents to use and each phone has its own phone number.
When the Agent logs in to IP Phone Agent they use the phone number that is showing on the phone and it fails.
Graham
15 Replies 15
hugomdbaez
The version of UCCX is below
Cisco Application Administration - 7.0(2)_Build254
Package: Cisco Unified CCX Premium
Cluster: default
Copyright © 1999-2009 Cisco Systems, Inc.
All rights reserved.
Login to UCCX appadmin
Go to Subsystems/RMCM then RmCm Provider, make a note of the user ID
Login to CUCM, goto User Management/Application User and find the user ID above.
Move the Agents phone from the list of "Available Devices" to "Controlled Devices" and click save.
The technical answer is UCCX can't control the Agents phone because it does not have permission as the Agents phone is not in the list of Controlled Devices
Graham
Hello Graham ,
Thanks for the quick response . I am added the profiles to the application user and the error message still appears .
Do you know what the problem is ?
Thanks and best Regards
Hugo Baez
Not the profile you must add the Agents phone by SEP..... name
Graham
Hi Graham ,
Sorry but the error still appears
Thanks a lot !
Hugo Baez
Hello Graham ,
I have some news , the new agents have only  a profile , no a Cisco IP Phone , If I must add a MAC ADDRESS to the RmCm  Provider I can not .
I have only one phone for the supervisor  agent  , I added this MAC ADDRESS and it is working .
The question is : The agent must  include a phone ?
Thanks and regards
Hugo Baez
Hugo
The Agents must have a phone. Are they using the softphone IP Communicator?
When you added IP Communicator to CUCM you must have given it a name. You must add this name to the Rmcm user.
Graham
Hi Graham ,
I will explain to you the situation :
I have 30 agents , with a new profile each , and only 9 Cisco IP Phones , with generic directory numbers .
The people that work here must log in ( there are a 7x24 site , there are day , and night shifts ) , the supervisor must take statistics about agents work .
I was realized a lot of test with a maqueta with 3 Cisco IP Phones , but with only a profile ( without phone ) does not work .
Can you help me ?
Hugo Baez
Hugo
So you have 9 physical phones and they are in the list of controlled devices for the RMCM user on CUCM
Are your Agents using Extension Mobility, do they first login to the phone so that their Directory Number shows on the phone?
Please confirm your Phone model and your UCCX version.
Graham
Hi Graham ,
The service configured is Cisco IP Phone Agent ( IPPA ) , not extension mobility . whatever , I was realize some tests , with extension mobility and it was worked once , and no more .
I am trying to do again , and still fail .
The model of the testing Phone is Cisco 7942 , and the version of UCCX is
7.0(2)_Build254
Hugo Baez
Hi Hugo
Graham
Hello Graham ,
Each phone has your own generic number ( there are 9 ) . Each agent ( there are 30 , in day and night shifts , Its 7x24 schema  )  has a number ( a new number for each profile ) .
When I tried to log in with this new number and profile the log in fails .
Thanks for your help
Hugo
Have you checked that all the "Allow Control of Device from CTI" Boxes are ticked on CUCM.
Phone, Device profile (on directory number) and on the user profile.
Also check that the rmcm application user has "Standard CTI Enabled" in the groups. Please double check that you are looking at the correct rmcm user ID.
Graham
Try adding device profiles to 'CTI Controlled Device Profiles' on the application user .. if they're not already there.
Brian
