Possibilities for IPv4 oder IPv6
Answered Question
Oct 29th, 2011
Hello Community,
I found a lot of information to handle an IPv6 over IPv4 communication, but almost nothing about IPv4 over IPv6.
Which possibilities exists integrating IPv4 over IPv6 on a Cisco Router (e.g. 881, or perhaps a Layer 3 Switch)?
Are there tunnel modes like for 6over4 (ipv6ip, gre)?
I attached a little topology to show my thoughts.
Thank you!
Kyle
Correct Answer by Marcin Latosiewicz about 5 years 5 months ago
Kyle,
GRE IPv6 is what you're looking for.
Either:
tunnel mode gre multipoint ipv6
or
tunnel mode gre ipv6
You can do on top IPv6 GRE over IPsec with IPv4 payload.
On ASA on top exist the possibility to have IPv4 traffic natively in IPv6 when doing IPsec (limited support)
Marcin
Overall Rating: 5 (1 ratings)
Correct Answer
Marcin Latosiewicz Sat, 10/29/2011 - 04:00
  • Cisco Employee,
Kyle,
Either:
or
Marcin
Kyle Lenderlof Sat, 10/29/2011 - 06:07
Thank you Marcin for your answer.
So an easy example could be a configration like this? But I didnt' run so far. Any mistakes? Have I overlooked anything?
Router_A
int fa0/0
ip add 10.1.1.1  255.255.255.0
no shut
s0/3/0
ipv6 en
ipv6 add 2001:2:2:2::1/64
no shut
int tunnel 0
ipv6 add 2001:1:1:1::1/64
tunnel source fa0/0
tunnel destination 2001:2:2:2::2
tunnel mode gre ipv6    (tunnel mode gre multipoint ipv6)
Router_B
int fa0/0
ip add 10.2.1.1  255.255.255.0
no shut
s0/3/0
ipv6 en
ipv6 add 2001:2:2:2::2/64
no shut
int tunnel 0
ipv6 add 2001:1:1:1::2/64
tunnel source fa0/0
tunnel destination 2001:2:2:2::1
Do you have documents for the ASA solution, too?
Kyle Lenderlof Wed, 11/16/2011 - 06:18
Thanks, now I have established a communication between two IPv4 Hosts over a IPv6 network!
But I couldn't manage to get ipsec running on Router_A and Router_B, so the gre tunnel is secure.
Router_A
int tunnel0
ip add 192.169.1.1 255.255.255.0
tunnel source s1/0
tunnel destination 2001:1:1:1::2
Router_B
int tunnel0
ip add 192.169.1.2 255.255.255.0
tunnel source s1/0
tunnel destination 2001:1:1:1::1
It's difficult because I have IPv6 addresses for source and destination and IPv4 for the tunnel.
With which commands can I establish IPv6 GRE over IPsec with IPv4 payload as Marcin described?
Marcin Latosiewicz Wed, 11/16/2011 - 08:14
  • Cisco Employee,
Kyle,
The's the beauty of GRE configuration ,you don't care what's inside. In can by IPX if you choose to :-)
I would suggest using tunnel protection configuration, it's by far the easiest.
cryp ipsec pro NAME_OF_PROFILE
set trans NAME_OF_TRANSFORM
int tu0
tunnel protection ipsec profile NAME_OF_PROFILE
This is of course assuming you have phase 1 IPsec etc configured.
An example is here, you can use it:
http://www.cisco.com/en/US/docs/ios/ipv6/configuration/guide/ip6-ipsec.html#wp1094731
Remember that this works on recent versions of IOS 15.2 M&T - AFAIR.
Marcin
Kooopobol Thu, 11/17/2011 - 01:44
Is the use of GRE mandatory for that ?
Does pure IPsec can handle IPv4 over IPv6 in tunnel mode ?
Marcin Latosiewicz Thu, 11/17/2011 - 02:22
  • Cisco Employee,
Armand,
Not on IOS. So far only ASA can natively encapsulate IPv4 into IPv6 IPsec (and vice versa).
On IOS VTI modes/crypto map will not allow IPv6 ACL in IPv4 crypto map (and vice versa) nor IPv6 traffic in IPv4 VTI (and vice versa).  (There are enhancement requests to change that
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtu09251
That's why we need intermidiate GRE encapsulation.
Marcin
Kooopobol Thu, 11/17/2011 - 02:51
Thanks a lot for your answer..
But as far as I know the use of VTI is not mandatory for setting up an IPsec Vpn tunnel on a IOS router.. isn't it ?
What if we don't use VTI ?
Marcin Latosiewicz Thu, 11/17/2011 - 03:49
  • Cisco Employee,
I'm not recommending VTI, in fact VTI will fail because of the reasons mentioned above.
I'm suggesting to use tunnel protection with GRE IPv6.
Marcin
Kooopobol Fri, 11/18/2011 - 05:38
And if I use only crypto maps ? (no tunnel interfaces)
Armand
Marcin Latosiewicz Fri, 11/18/2011 - 06:05
  • Cisco Employee,
Armand,
When you try to applu IPv6 access-list to IPv4 crypto map:
CE2_GM_875(config)#crypto map MAP 100 ipsec-isakmp
% NOTE: This new crypto map will remain disabled until a peer
        and a valid access list have been configured.
*Nov 18 14:03:37.440: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is ON
CE2_GM_875(config-crypto-map)#match address ?
  <100-199>    IP access-list number
  <2000-2699>  IP access-list number (expanded range)
  WORD         Access-list name
CE2_GM_875(config-crypto-map)#match address ACL6
Access-list type conflicts with prior definitionERROR: "ACL6" is either an invalid name or the
        list already exists but is the wrong type.
when you try to apply IPv4 crytpo map to IPv6 acl.
CE2_GM_875(config)#crypto map ipv6 MAP6 100 ipsec-isakmp
CE2_GM_875(config-crypto-map)#match address ACL4
Access-list type conflicts with prior definitionERROR: "ACL4" is either an invalid name or the
ACL are defined:
CE2_GM_875(config-crypto-map)#do sh run | s access-list
ip access-list extended ACL4
permit ip any any
ipv6 access-list ACL6
permit ipv6 any any
M.
Kyle Lenderlof Wed, 11/23/2011 - 10:54
Thanks for the extra information, tried it myself today.
So to sum up, you can't apply a IPv6 Access-List to a IPv4 Crypto Map and also you can't apply a IPv4 Crypto Map to a IPv6 Access-List, by now.
In the next days I will try the "new requested IOS", if it will be released soon.
Kyle Lenderlof Thu, 11/24/2011 - 06:58
Is there a chance to get NAT-PT working for 4over6?
IPv4 Hosts on each side with NAT-PT for an outside IPv6 address?
I tried a few things to get this working, but no results yet.
Marcin Latosiewicz Fri, 11/25/2011 - 00:54
  • Cisco Employee,
Kyle,
My suggestion is to keep away from NAT-PT (unless it's just for fun).
NAT64 and all similar are what the industry is trying to do recently.
M.
Kyle Lenderlof Fri, 11/25/2011 - 02:37
Yeah that is what I want to test now.
I only try to show up all possibilities to establish a (secure) connection between IPv4 networks over IPv6 internet.
Would "NAT64/46?" on one network and ""NAT64/46?" on the other network work for this scenario, theoretically
and/or practically?
Kyle Lenderlof Mon, 12/05/2011 - 07:33
To come back to the gre-tunnel.
For the tunnel ip addresses I need public ip addresses on both sites for the gre-tunnel to do 4over6?
int tunnel0
ip add 192.169.1.1 255.255.255.0 ???
tunnel source s1/0
Because in a traceroute (testlab) it give me the 192.169.1.1 back, instead of the destination address 2001:1:1:1::1?
Did I do something wrong? Because it won't work in a productive system if I have a native IPv6 ISP connection.
Marcin Latosiewicz Tue, 12/06/2011 - 05:29
  • Cisco Employee,
Kyle,
It's expected that IPv4 traceroute will produce IPv4 addresses while IPv6 traceroute should produce IPv6 addresses (I guess this is what you were doing?).
You are free to assign a uniqe IPv6 address on tunnel 0.
Tunnel IP can be public or private, rfc1918 is more common since you will not waste any IP address space.
edit: Just to add, since this GRE tunnel is a "pipe" between your routers, you should not IP addresses of tunnel source and destination if you traceroute through it.
Marcin
Kyle Lenderlof Wed, 12/07/2011 - 00:58
Yes, thats what I'm done
Nevertheless, if there would be no possibility to use private IP addresses for the tunnel, it would be kind of useless for this scenario.
edit: Just to add, since this GRE tunnel is a "pipe" between your routers, you should not see? IP addresses of tunnel source and destination if you traceroute through it.
Thanks again!
edit: Do you know any specific date for the "new" IOS, yet?
edit2: The MTU for this configuration is 1456 (shown on router).
I guess thats, 4 for the gre header and 2x 20 for the ipv4 header.
But isn't the packet transported with an ipv6 header? So there would be 4(gre header)+20(ipv4 header)+40(ipv6 header)
Kooopobol Fri, 12/09/2011 - 06:07
I am also interested in the new IOS release date
Marcin Latosiewicz Fri, 12/09/2011 - 06:08
  • Cisco Employee,
Kyle,
You can in fact use any addressing you want in case of addressing the tunnel itself, it's almost nnever used by anything bu transit.
What "new" IOS do you refer to?
There should be a difference of:
- IPv4 MTU (ip mtu command)
- IPv6 MTU (ipv6 mtu command)
- IPsec MTU (seen show crypto ipsec sa)
Now a GRE IPv6 header overhead should be 44 bytes +  20 bytes of IPv4 inside (we're not calculating IPsec overhead which could be  tunnel or transport mode)
M.
Marcin Latosiewicz Fri, 12/16/2011 - 01:54
  • Cisco Employee,
Armand,
It's an enhancement request. To have it resolved you need to contact your SE and they should create a business case.
Normally those things do not get resolved by themselves (not in a decent timeline).
Marcin
Related Content
