Warning message
What is the difference between hit count and refcount in prefix-list
Answered Question
Oct 31st, 2011
didn't get the answer anywhere else, so please help.
Correct Answer by nkarpysh about 5 years 9 months ago
Hi Arpit,
Refcount:
When a prefix is created, its reference is set to 1. And the last deletion/insertion prefix list's reference is incremented
by 1.
If a prefix list is referred by a routing process like "distribute-list prefix pl1 out", its reference is incremented by 1. The reference counter is a common concept of IOS. It shows how many objects uses the memory block. You can imagine that objects are functions like show commands and data structures like configurations.
Each entry's refcount is more complicated. Some entries refers other entries. This is because prefix-list entries form
a kind of tree data structure and some of entries cannot be deleted without changing links from child entries.
Hits: Preaty straightforward - number of times this prefix-list was called for action - hit.
Rate if this is what you searched for. Can help others further.
Nik,
Overall Rating: 5 (2 ratings)
Alexander Maroukian Mon, 10/31/2011 - 08:33
  • Bronze, 100 points or more
Hit count is how many times maches are found for this prefix in the prefix list.
Refcount is number of times list or seq is used in policy settings.
Best regards,
Alex
arpit.gpandit Mon, 10/31/2011 - 09:55
Hi Alex,
Thank you very much for your information...........it was really helpful
Correct Answer
nkarpysh Mon, 10/31/2011 - 08:37
  • Cisco Employee,
Hi Arpit,
Refcount:
by 1.
Nik,
arpit.gpandit Mon, 10/31/2011 - 09:56
Hi Nik,
Thank you very much for your reply............it was simple and straightforward........thanks again.
cggveritas.cco Tue, 05/13/2014 - 00:41
Thanks for your explanation on hitcount, but how can I have a refcount of 0 then ?
seq 2000 permit 0.0.0.0/0 le 24 (hit count: 85589, refcount: 0)
Thomas
Related Content
