Layer 2 QoS Congestion management - Help
Answered Question
Oct 31st, 2011
Hello everyone.
I´ve an escenario with some cisco access switches and cisco router that support connectivity for IP telephony. But the PBX is Nortel. Suppose i am trying to manage voice and signaling traffic with the recommended values (CoS5 and CoS3), and that i´m changing DSCP values on access port so i can use DSCP 24 for signaling and DSCP 46 for voice (not trusting DSCP but remarking with a policy MAP). Then on switches i´ve the following congestion managemente config:
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 1 2 4
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 46
mls qos srr-queue output dscp-map queue 2 threshold 1 16
mls qos srr-queue output dscp-map queue 2 threshold 1 18 20 22
mls qos srr-queue output dscp-map queue 2 threshold 1 25
mls qos srr-queue output dscp-map queue 2 threshold 1 32
mls qos srr-queue output dscp-map queue 2 threshold 1 34 36 38
mls qos srr-queue output dscp-map queue 2 threshold 2 24
mls qos srr-queue output dscp-map queue 2 threshold 3 48 56
mls qos srr-queue output dscp-map queue 3 threshold 3 0
mls qos srr-queue output dscp-map queue 4 threshold 1 8
mls qos srr-queue output dscp-map queue 4 threshold 3 10 12 14
mls qos queue-set output 1 threshold 2 70 80 100 100
mls qos queue-set output 1 threshold 4 40 100 100 100
But with this config, the PBX is generating a lot of QoS error logs related to delay and jitter. Because of this i want to change how Signaling (DSCP 24 - CoS 3) will be managed by switches. Could i use this config instead?
mls qos map cos-dscp 0 8 16 24 34 46 48 56
mls qos srr-queue output cos-map queue 1 threshold 3 3 5
mls qos srr-queue output dscp-map queue 1 threshold 3 24 41 42 43 44 45 46 47
mls qos srr-queue output dscp-map queue 2 threshold 1 16 18 20 22 25 32 34 36
mls qos srr-queue output dscp-map queue 2 threshold 1 38
mls qos srr-queue output dscp-map queue 2 threshold 2 40
mls qos srr-queue output dscp-map queue 2 threshold 3 26 27 28 29 30 31 48 49
mls qos srr-queue output dscp-map queue 2 threshold 3 50 51 52 53 54 55 56 57
mls qos srr-queue output dscp-map queue 2 threshold 3 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 0 17 19 21 23 33 35 37
mls qos srr-queue output dscp-map queue 3 threshold 3 39
mls qos srr-queue output dscp-map queue 4 threshold 2 9 11 13 15
mls qos srr-queue output dscp-map queue 4 threshold 3 1 2 3 4 5 6 7 10
mls qos srr-queue output dscp-map queue 4 threshold 3 12 14
mls qos queue-set output 1 threshold 1 138 138 92 138
mls qos
What i´m trying to do here is to locate signaling traffic on output priority queue (1). What about the queue-set output, will that work?. Thanks.
Correct Answer by Marwan ALshawi about 5 years 3 months ago
well signalling is ok to be placed in diffrent queue other than the PQ
just make sure the VOIP RTP marked with cos5/dscp 46 is placed in the PQ and make sure that you have the right cos-to-dscp maping from cos 5 to dscp 46
hope this help
Overall Rating: 5 (1 ratings)
Marwan ALshawi Mon, 10/31/2011 - 19:47
mls qos srr-queue input cos-map queue 2 threshold 3 3 5
mls qos srr-queue output dscp-map queue 1 threshold 3 40 41 42 43 44 45 46 47
and on the interface level you the enable PRQ
priority-queue out
i am assuming you are using 3560 switch
Andres Franco Mon, 10/31/2011 - 20:48
Ok. Let me proccess  this to see if I understand it!
You´re telling me to manage priority for signaling only in the input priority queue (2) (does it matter if i put cos 3 in queue 2 for output?) while voice will be manage here an also y in the ouput priority queue (1)???? So  the hole thing could look like this?
mls qos
I´ve priority-queue out and queue-set 1 applied to all interfaces (including trunks) and yes, i´m usign 3560 switches. Will this be your recommended setting to prioritize signaling?
Correct Answer
Marwan ALshawi Mon, 10/31/2011 - 22:07
hope this help
Andres Franco Tue, 11/01/2011 - 06:37
Thanks again dude, thanks for your patience.
This will be my complete config taking in account your suggestions!
mls qos
class-map match-all VoIP
match ip dscp ef
class-map match-all VoIP-SIGNALING
match ip dscp cs5
policy-map QoS-SW3560
class VoIP
set dscp ef
class VoIP-SIGNALING
set dscp cs3
interface range GigabitEthernet0/X
no mls qos trust dscp
no auto qos voip trust
queue-set 1
srr-queue bandwidth share 1 70 25 5
srr-queue bandwidth shape 3 0 0 0
service-policy input QoS-SW3560
priority-queue out
Now, taking into consideration other comments you have done, what will take precedence for this interface configuration? the queue-set 1 or the priority queue out? should i remove one? and, This whole config looks ok to you?
Thanks again.
