Upgrading FW on 7961G-GE - CME 8.6
Answered Question
Nov 1st, 2011
Hi All,
I am a little confused on the firmware path to get my 7961s to the latest firmware. I would ultimately like to get them running 9.1(1). They are currently running fw 7.0(3) on CME 8.6. What would the version upgrade path look like to get them to 9.1(1)? I have tried upgrading them to 8.5(3)SR1S but that did not work. Do I need to upgrade to an earlier version? Instead of guessing thought I would ask here.
Thanks in advance.
Correct Answer by Rob Huffman about 5 years 9 months ago
Hi Johnny,
Did you try the "no create cnf" and "create cnf" under telephony service after removing the
.loads ??
Cheers!
Rob
Hi Johnny,
You are most correct
Firmware Upgrade Issues for SCCP
Note For all SCCP firmware upgrades from firmware release versions earlier than 8.3(3) to version 9.1(1)SR1 or greater, you must first upgrade your firmware to an intermediate version (8.3(3) - 8.5(2)) then upgrade to 9.1(1)SR1.
Note This section applies to the Cisco Unified IP Phone 7975G, 7971G-GE, 7970G, 7965G, 7962G, 7961G-GE, 7961G, 7945G, 7942G, 7941G-GE, 7941G, 7911G, and 7906G.
The following upgrade issues apply:
If you are currently running firmware earlier than 6.0(2) on a Cisco Unified IP Phone and want to upgrade to 8.x(x), you must first install an intervening 7.0(x) load to prevent upgrade failure. Cisco recommends using the most recent 7.0(3) load as the intervening load to avoid lengthy upgrade times.
If you are currently running firmware 6.0(2) to 7.0(2) on a Cisco Unified IP Phone and want to upgrade to 8.x(x), you can do so directly. However, expect the upgrade to take twice as long as usual.
Device packs are required to enable IP Phones in the Cisco Unified Communications Manager database. For Cisco Unified CallManager 4.2 and earlier, these device packs are required. For Cisco Unified CallManager 4.3 and Cisco Unified Communications Manager 6.0 and later, you must run the device pack and reboot the Cisco Unified Communications Manager server.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/firmware/9_1_1/english/release/notes/7900_911.html#wp42467
Cheers!
Rob
Overall Rating: 5 (2 ratings)
Correct Answer
Rob Huffman Tue, 11/01/2011 - 06:13
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Johnny,
Cheers!
Rob
johnnywan Tue, 11/01/2011 - 06:56
Thanks Rob,
Not sure what the issue is here now. I downloaded fw 8.5(2) and tftp to flash all 8 files. Entered all 8 tftp-server statements and added "load 7961GE SCCP41.8-5-2S.loads" under telephony service. My phones won't upgrade. Any ideas? Also did the "no create cnf" and "create cnf" under telephony service before resetting.
Rob Huffman Tue, 11/01/2011 - 07:10
  • Hall of Fame,
    Founding Member
Hi Johnny,
Can you please try (under telephony service);
without the .loads extension
Cheers!
Rob
johnnywan Tue, 11/01/2011 - 07:17
Thanks Rob. I already tried that. But, I went ahead and tried it again with the same results. They still have the old fw. Here is the "debug tftp events" output: It appears it finds the files on flash but doesn't do anything with them.
3RT-2821(config-ephone)#
.Nov  1 09:13:42.413: %IPPHONE-6-UNREGISTER_NORMAL: ephone-30:SEP001BD40BF4A7 IP:192.168.30.72 Socket:7 DeviceType:Phone has unregistered normally.
.Nov  1 09:14:23.957: TFTP: Looking for CTLSEP001BD40BF4A7.tlv
.Nov  1 09:14:24.725: TFTP: Looking for LightSaber.raw
.Nov  1 09:14:24.833: TFTP: Looking for SEP001BD40BF4A7.cnf.xml
.Nov  1 09:14:25.305: TFTP: Opened system:/its/vrf1/XMLDefault7961GE.cnf.xml, fd 10, size 1279 for process 277
.Nov  1 09:14:25.309: TFTP: Finished system:/its/vrf1/XMLDefault7961GE.cnf.xml, time 00:00:00 for process 277
.Nov  1 09:14:25.461: TFTP: Looking for SCCP41.8-5-2S.loads
.Nov  1 09:14:25.465: TFTP: Opened flash:SCCP41.8-5-2S.loads, fd 10, size 650 for process 277
.Nov  1 09:14:25.469: TFTP: Finished flash:SCCP41.8-5-2S.loads, time 00:00:00 for process 277
.Nov  1 09:14:25.989: TFTP: Looking for jar41sccp.8-5-2TH1-9.sbn
.Nov  1 09:14:25.993: TFTP: Opened flash:jar41sccp.8-5-2TH1-9.sbn, fd 10, size 1628113 for process 277
.Nov  1 09:14:31.245: TFTP: Finished flash:jar41sccp.8-5-2TH1-9.sbn, time 00:00:05 for process 277
.Nov  1 09:14:35.553: TFTP: Looking for cnu41.8-5-2TH1-9.sbn
.Nov  1 09:14:35.557: TFTP: Opened flash:cnu41.8-5-2TH1-9.sbn, fd 10, size 498984 for process 277
.Nov  1 09:14:37.129: TFTP: Finished flash:cnu41.8-5-2TH1-9.sbn, time 00:00:01 for process 277
.Nov  1 09:14:38.813: TFTP: Looking for apps41.8-5-2TH1-9.sbn
.Nov  1 09:14:38.817: TFTP: Opened flash:apps41.8-5-2TH1-9.sbn, fd 10, size 2933329 for process 277
.Nov  1 09:14:45.357: TFTP: Finished flash:apps41.8-5-2TH1-9.sbn, time 00:00:06 for process 277
.Nov  1 09:14:46.477: TFTP: Looking for English_United_States/mk-sccp.jar
.Nov  1 09:14:46.761: TFTP: Looking for United_States/g3-tones.xml
.Nov  1 09:14:47.221: %IPPHONE-6-REG_ALARM: 22: Name=SEP001BD40BF4A7 Load= 7.0(3.0S) Last=Reset-Reset
.Nov  1 09:14:47.261: %IPPHONE-6-REGISTER: ephone-30:SEP001BD40BF4A7 IP:192.168.30.72 Socket:12 DeviceType:Phone has registered.
Correct Answer
Rob Huffman Tue, 11/01/2011 - 07:40
  • Hall of Fame,
    Founding Member
Hi Johnny,
.loads ??
Cheers!
Rob
johnnywan Tue, 11/01/2011 - 07:42
yes sir. I did that before resetting the phone. thanks.
Rob Huffman Tue, 11/01/2011 - 08:21
  • Hall of Fame,
    Founding Member
Hi Johnny,
I'm sorry but I don't have access to CME in our lab
right now to test this out for you, but here are two related
threads that might help
https://supportforums.cisco.com/message/3050746#3050746
https://supportforums.cisco.com/message/3025214#3025214
Cheers!
Rob
