Bonding GigabitEthernet
Answered Question
Nov 2nd, 2011
On our 6504 - 12.2(33)SXH, we currently have a single connection to our ISP (GI1/1) and want to add another connection (GI1/2)  Is there a way to bond the two connections to form a single connection (a single pipe) to double the throughput?
Correct Answer by Reza Sharifi about 5 years 9 months ago
Yes, you can use Etherchanel to bundle multiple links together.
have a look at this doc for examples:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/channel.html
Overall Rating: 5 (1 ratings)
Joseph W. Doherty Wed, 11/02/2011 - 17:28
Disclaimer
The     Author of this posting offers the information contained within this     posting without consideration and with the reader's understanding  that    there's no implied or expressed suitability or fitness for any   purpose.   Information provided is for informational purposes only and   should not   be construed as rendering professional advice of any kind.   Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In     no event shall Author be liable for any damages whatsoever   (including,   without limitation, damages for loss of use, data or   profit) arising  out  of the use or inability to use the posting's   information even if  Author  has been advised of the possibility of  such  damage.
Posting
Just be aware, when you use Etherchannel you increase your aggregate bandwidth but its behavior is not the same as a single pipe.  For instance, one flow across the Etherchannel will only use one link.  Two flows might, or might not, use both links of a dual Etherchannel.
