ACL for VOIP SIP,H323,SCCP
Nov 3rd, 2011
i have a problem in understanding the acl rule for sip h323 or SCCP.
WE will use this for connect ip Communicator to CME
The CME has the IP : 192.168.10.254
The ASA Inside Interface IP : 192.168.10.1
The ASA Outside Interface IP:  x.x.x.x (static)
I connect to the Network with Cisco annyconnect but voip not work
So i must set acl for this problem
M Problem: In the guide the outside interface is a clss B network but we have a class A networkaddress applyed by our ISP.
when i connect with anyconnect i have an internale address off 192.168.10.80 (static) applyed through the asa.
Witch IP Address i must set in the acl
access-list 100 extended permit tcp 192.168.10.0 255.255.255.0 host ? eq (sip,h323,sccp)  /  Outside Interface IP address oder host ip ?
Philipp
Marwan ALshawi Fri, 11/04/2011 - 05:51
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
You need to allow the VPN pool range to the inside cme ip
And make sure inspection is enabled for the used protocol such as sip
See the below link for more details
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008081042c.shtml
Hope this help
If helpful rate
