Warning message
CUBE router stops processing calls
Nov 3rd, 2011
I have a 2901 router configured to act as a Unified Boarder Element Controller (CUBE)
I am working with a telco to test SIP trunking.
Problem is that after a fresh reboot of the Router the inbound and outbound SIP calls work correctly.  After a "while" (not sure how much time it takes) the router stops processing calls.  Debugs show the the calls are not trigging dial peer debug outputs so its failing.
If I reboot the router calls will work again, proving that the Telco is not a fault.
Is this a know issue and I missed a timer or something somewhere ?
Config attached with IP's and passwords cleaned out.
acampbell Thu, 11/03/2011 - 08:30
  • Green, 3000 points or more
I am not sure if it could be your dial peers are clashing an running away with CPU trying process these.
They are very similar
dial-peer voice 100 voip
description ***Back & Forth From CUCM***
destination-pattern ..........
dial-peer voice 200 voip
description ***Back & Forth From SIP Provider***
destination-pattern .T
For the dial peer to the CUCM can you at leat pick a match with the 1st digit or even more would be better.
Do all your CUCM DNs start with E.G. "5"
Change the peer to be
destination-pattern 5.........
Alex
