Warning message
PROBLEM in 1040AP getting registered with AIR-WLC2112-K9
Nov 3rd, 2011
Iam facing the issue with Cisco LAP getting registered with WLC 2112. Running version of WLC is 7.0.116.0. LAP is rebooting repeatedly.
sh log
Syslog logging: enabled (1 messages dropped, 2 messages rate-limited,
                0 flushes, 0 overruns, xml disabled, filtering disabled)
    Console logging: level debugging, 47 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging: level debugging, 47 messages logged, xml disabled,
                    filtering disabled
    Logging Exception size (4096 bytes)
    Count and timestamp logging messages: disabled
    Trap logging: level errors, 21 message lines logged
        Logging to 255.255.255.255(global) (udp port 514, audit disabled,  link up), 5 message lines logged, xml disabled,
               filtering disabled
--More--
Log Buffer (1048576 bytes):
*Mar  1 00:00:09.904: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:09.916: *** CRASH_LOG = YES
*Mar  1 00:00:10.216: Port 1 is not presentSecurity Core found.
Base Ethernet MAC address: C8:9C:1D:1B:15:16
*Mar  1 00:00:11.254: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:11.347: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 1024 messages)
*Mar  1 00:00:11.377:  status of voice_diag_test from WLC is false
*Mar  1 00:00:12.408: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:13.495: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:13.549: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1040 Software (C1140-K9W8-M), Version 12.4(23c)JA2, RELEASE SOFTWARE (fc3)
--More--                           Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 13-Apr-11 12:50 by prod_rel_team
*Mar  1 00:08:26.085: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:08:27.085: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:08:36.080: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:08:36.080: bsnInitRcbSlot: slot 1 has NO radio
*Mar  1 00:08:36.831: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:08:44.886: %PARSER-4-BADCFG: Unexpected end of configuration file.
*Mar  1 00:08:44.887:  status of voice_diag_test from WLC is false
*Mar  1 00:08:44.955: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:08:50.164: %CDP_PD-4-POWER_OK: Full power - INJECTOR_CONFIGURED_ON_SOURCE inline power source
*Mar  1 00:08:50.186: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:08:51.172: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:08:51.173: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
--More--                           *Nov  3 20:26:12.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.10.19 peer_port: 5246
*Nov  3 20:26:15.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Nov  3 20:26:52.000: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2017 Max retransmission count reached!
*Nov  3 20:26:52.000: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 192.168.10.19 is reached.
*Nov  3 20:27:12.044: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.10.19:5246
*Nov  3 20:27:12.040: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.10.19:5246
*Nov  3 20:27:15.083: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Nov  3 20:27:15.084: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Nov  3 20:27:15.084: bsnInitRcbSlot: slot 1 has NO radio
*Nov  3 20:27:15.143: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Nov  3 20:27:15.176: %PARSER-4-BADCFG: Unexpected end of configuration file.
--More--
*Nov  3 20:27:15.185: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Nov  3 20:27:15.198: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Nov  3 20:27:24.177:  status of voice_diag_test from WLC is false
*Nov  3 20:28:41.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.10.19 peer_port: 5246
*Nov  3 20:28:44.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Nov  3 20:29:21.000: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2017 Max retransmission count reached!
*Nov  3 20:29:21.000: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 192.168.10.19 is reached.
*Nov  3 20:29:41.041: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.10.19:5246
Can anyone help me resolve this issue plz.
Salil Prabhu Thu, 11/03/2011 - 13:13
  • Cisco Employee,
Max retransmit count = AP did not hear back from WLC. So why ?
-Is the AP plugged behind WLC ?
-How many ports are used on 2106 ?
-Whats the network path between AP and WLC ? Can you put as close to WLC and see if issue goes away ?
-What do show traplog, show msglog show on WLC.
Thanks..Salil
Leo Laohoo Thu, 11/03/2011 - 14:05
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
1.  How many WAP does your WLC currently have?
2.  Can you please check if the WLC and the AP are on the same Regulatory Domain (as in Europe or US)?
