Cpam- Door State Inconsistent
Nov 3rd, 2011
Anyone know why on earth I would get this error?
I have a couple doors showing alarms for  "Door State Inconsistent"
I can not seem to figure out why. All the devices associated to the door are functioning properly...
Thanks!
Phil
mcwalter Fri, 11/04/2011 - 11:36
Which input triggering the door state inconsistent event?
philtraylor Fri, 11/04/2011 - 11:38
I can not tell. Further examination of the alarm does not seem to specify which input point is causing the issue.
What am I missing?
mcwalter Fri, 11/04/2011 - 11:58
You may want to run a system sanity report. It may tell you where the error is. Good luck.
Finbarr Rogers Thu, 08/02/2012 - 03:46
I have the same issue at the minute. Have you had any further help on this?
Kind regards,
Finbarr
philtraylor Thu, 08/02/2012 - 06:06
I have not gotten much luck in this area, I ended up disabling this alarm entirely.
wsmith3212 Wed, 08/29/2012 - 17:56
Generally I have found that a motion REX that is incorrectly configured to trip the lock in a high traffic area can pop the lock when the door isnt being used causing that alarm.
