11-04-2011 01:46 AM
I have a CNA in my server connected to cisco nexus 5000 interfcae. I Want to genearate pause frames for FCOE class of traffic using the default class class-fcoe and cos value 3, the firmware version running is 5.0(3) N1 (1b). Can anyone tell me how can i configure it ?
Manju
11-04-2011 10:42 AM
PFC is something which gets negotiated automatically during initial LLDP handshake. Is it not happenning in your case?
11-07-2011 08:42 PM
No its not happening and i dont see any configuration as such over the switch interface i am connected to, can you tell me how can i configure it manually ?
11-11-2011 06:18 AM
I suggest that you focus on why its not negotiated via LLDP. Can you attach output of following commands from the switch which connects to the CNA?
show mod
show run
show system internal dcbx info interface ethernet x/y
Also if your switch is 55xx model, make sure you have FCOE QoS configured.
switch (config-sys-qos)# service-policy type qos input fcoe-default-in-policy
switch (config-sys-qos)# service-policy type queuing inputfcoe-default-in-policy
switch (config-sys-qos)# service-policy type queuing output fcoe-default-out-policy
switch (config-sys-qos)# service-policy type network-qos fcoe-default-nq-policy
12-01-2011 12:53 AM
Sorry for the delayed response, Here is what you asked
Cisco-5020# sh mod
Mod Ports Module-Type Model Status
1 40 40x10GE/Supervisor N5K-C5020P-BF-SUP active *
2 8 4x10GE + 4x1/2/4G FC Module N5K-M1404 ok
Mod Sw Hw World-Wide-Name(s) (WWN)
1 5.0(3)N1(1b) 1.2 --
2 5.0(3)N1(1b) 1.0 20:41:00:0d:ec:b2:15:40 to 20:44:00:0d:ec:b2:15:40
Mod MAC-Address(es) Serial-Num
1 000d.ecb2.1548 to 000d.ecb2.156f JAF1303ACES
2 000d.ecb2.1570 to 000d.ecb2.1577 JAF1245AJLF
Cisco-5020#
Cisco-5020#
Cisco-5020# sh run
!Command: show running-config
!Time: Fri Oct 28 17:40:02 2005
version 5.0(3)N1(1b)
feature fcoe
feature npiv
feature telnet
feature lldp
username admin password 5 $1$v9Tm8Y77$ZSdbOfBxe1.Z9Oz1V9V2B0 role network-admin
no password strength-check
ip domain-lookup
hostname Cisco-5020
logging event link-status default
service unsupported-transceiver
class-map type qos class-fcoe
class-map type queuing class-all-flood
match qos-group 2
class-map type queuing class-ip-multicast
match qos-group 2
class-map type network-qos class-all-flood
match qos-group 2
class-map type network-qos class-ip-multicast
match qos-group 2
policy-map type network-qos jumbo
class type network-qos class-fcoe
pause no-drop
mtu 2158
class type network-qos class-default
mtu 9216
system qos
service-policy type network-qos jumbo
snmp-server user admin network-admin auth md5 0x2694501fdfbe5abed9e85d51e4e31038 priv 0x2694501fdfbe5abed9e85d51e4e31038 localizedkey
snmp-server host 138.239.198.184 traps version 2c public udp-port 1163
snmp-server host 138.239.198.184 traps version 2c public udp-port 1164
snmp-server host 138.239.198.200 traps version 2c public udp-port 1163
snmp-server host 138.239.198.200 traps version 2c public udp-port 1164
snmp-server host 138.239.200.118 traps version 2c public udp-port 1163
snmp-server enable traps entity fru
snmp-server community snmpv3 group network-operator
vrf context management
ip route 0.0.0.0/0 10.192.207.254
vlan 1-2,8
vlan 10
fcoe vsan 10
vlan 20
fcoe vsan 20
vlan 30
vlan 35
fcoe vsan 35
vlan 40,50
vlan 52
fcoe vsan 52
vsan database
vsan 20
vsan 52
fcdomain fcid database
vsan 52 wwn 10:00:00:00:c9:b1:e5:3d fcid 0x180000 dynamic
vsan 52 wwn 10:00:00:00:c9:b1:e5:3b fcid 0x180001 dynamic
vsan 52 wwn 10:00:00:00:c9:5b:4d:e3 fcid 0x180002 dynamic
vsan 52 wwn 10:00:00:00:c9:5b:ab:ad fcid 0x180003 dynamic
vsan 52 wwn 10:00:00:00:c9:ad:ac:41 fcid 0x180004 dynamic
vsan 52 wwn 10:00:00:00:c9:ad:ac:b9 fcid 0x180005 dynamic
vsan 52 wwn 10:00:00:00:c9:ad:ac:b5 fcid 0x180006 dynamic
vsan 52 wwn 10:00:00:00:c9:f2:73:d1 fcid 0x180007 dynamic
vsan 52 wwn 10:00:00:00:c9:5b:4d:e1 fcid 0x180008 dynamic
vsan 52 wwn 10:00:00:00:c9:5b:ab:a9 fcid 0x180009 dynamic
vsan 52 wwn 10:00:00:00:c9:f2:73:d5 fcid 0x18000a dynamic
vsan 52 wwn 10:00:00:00:c9:b1:e5:5d fcid 0x18000b dynamic
vsan 52 wwn 10:00:00:00:c9:5b:ab:9b fcid 0x18000c dynamic
vsan 52 wwn 10:00:00:00:c9:5b:ab:99 fcid 0x18000d dynamic
vsan 52 wwn 10:00:00:00:c9:b1:e5:5b fcid 0x18000e dynamic
vsan 1 wwn 10:00:00:00:c9:f2:73:b3 fcid 0x050000 dynamic
vsan 52 wwn 10:00:00:00:c9:ad:ac:47 fcid 0x18000f dynamic
vsan 52 wwn 10:00:00:00:c9:5b:a7:93 fcid 0x180010 dynamic
vsan 52 wwn 10:00:00:00:c9:91:f8:19 fcid 0x180011 dynamic
vsan 52 wwn 10:00:00:00:c9:9c:e0:77 fcid 0x180012 dynamic
vsan 52 wwn 10:00:00:00:c9:5b:a7:d3 fcid 0x180013 dynamic
vsan 52 wwn 10:00:00:00:c9:5b:a3:bb fcid 0x180014 dynamic
vsan 52 wwn 10:00:00:00:c9:97:3b:c5 fcid 0x180015 dynamic
vsan 52 wwn 10:00:00:00:c9:f2:73:91 fcid 0x180016 dynamic
vsan 52 wwn 10:00:00:00:c9:a4:00:91 fcid 0x180017 dynamic
vsan 52 wwn 10:00:00:00:c9:f2:73:8d fcid 0x180018 dynamic
vsan 52 wwn 20:0f:00:11:0d:7f:a8:00 fcid 0x180019 dynamic
vsan 52 wwn 20:0f:00:11:0d:7f:a8:01 fcid 0x18001a dynamic
vsan 52 wwn 10:00:00:00:c9:5b:a3:b7 fcid 0x18001b dynamic
vsan 52 wwn 10:00:00:00:c9:5b:a5:27 fcid 0x18001c dynamic
vsan 52 wwn 10:00:00:00:c9:5b:a3:53 fcid 0x18001d dynamic
vsan 52 wwn 10:00:00:00:c9:bb:c8:37 fcid 0x18001e dynamic
vsan 52 wwn 10:00:00:00:c9:5b:76:e5 fcid 0x18001f dynamic
vsan 20 wwn 10:00:00:00:c9:5b:a3:83 fcid 0xd30000 dynamic
vsan 52 wwn 10:00:00:00:c9:91:00:00 fcid 0x180020 dynamic
vsan 52 wwn 10:00:00:00:00:91:f7:f1 fcid 0x180021 dynamic
vsan 1 wwn 10:00:00:00:c9:5b:4d:e3 fcid 0x050001 dynamic
vsan 52 wwn 10:00:00:00:c9:97:3b:0f fcid 0x180022 dynamic
vsan 52 wwn 10:00:00:00:c9:3c:8e:21 fcid 0x180023 dynamic
vsan 52 wwn 10:00:00:00:c9:97:3b:11 fcid 0x180024 dynamic
vsan 20 wwn 10:00:00:00:c9:b1:e6:b7 fcid 0xd30001 dynamic
vsan 52 wwn 10:00:f8:19:00:91:f8:19 fcid 0x180025 dynamic
vsan 52 wwn 10:00:00:00:c9:5b:a3:8b fcid 0x180026 dynamic
vsan 52 wwn 10:00:00:00:c9:b1:e4:ff fcid 0x180027 dynamic
vsan 52 wwn 10:00:00:00:c9:3c:8e:25 fcid 0x180028 dynamic
vsan 52 wwn 50:06:01:61:44:60:23:4f fcid 0x1800ef dynamic
vsan 52 wwn 10:00:00:00:c9:5b:d6:b9 fcid 0x180029 dynamic
vsan 52 wwn 10:00:00:00:c9:ad:ac:43 fcid 0x18002a dynamic
vsan 52 wwn 20:01:00:00:c9:5b:ab:99 fcid 0x18002b dynamic
vsan 52 wwn 20:02:00:00:c9:5b:ab:99 fcid 0x18002c dynamic
vsan 52 wwn 50:06:01:60:44:60:23:4f fcid 0x1801ef dynamic
vsan 52 wwn 10:00:00:00:c9:9d:1f:bf fcid 0x18002d dynamic
vsan 52 wwn 10:00:00:00:c9:9d:1f:c1 fcid 0x18002e dynamic
vsan 52 wwn 10:00:00:00:c9:f2:73:d3 fcid 0x18002f dynamic
vsan 20 wwn 10:00:00:00:c9:bb:c8:37 fcid 0xd30002 dynamic
vsan 52 wwn 10:00:00:00:c9:12:34:56 fcid 0x180030 dynamic
vsan 52 wwn 10:00:00:00:c9:12:34:57 fcid 0x180031 dynamic
vsan 52 wwn 10:00:00:00:c9:b1:ea:81 fcid 0x180032 dynamic
vsan 52 wwn 10:00:00:00:c9:b1:ea:7f fcid 0x180033 dynamic
vsan 20 wwn 10:00:00:00:c9:12:34:56 fcid 0xd30003 dynamic
vsan 52 wwn 10:00:00:00:c9:b1:e5:1b fcid 0x180034 dynamic
vsan 52 wwn 10:00:00:00:c9:b1:e5:1d fcid 0x180035 dynamic
vsan 52 wwn 10:00:00:00:c9:bb:c7:8f fcid 0x180036 dynamic
vsan 52 wwn 10:00:00:00:c9:bb:cb:8f fcid 0x180037 dynamic
vsan 52 wwn 10:00:00:00:c9:bb:cb:93 fcid 0x180038 dynamic
vsan 52 wwn 10:00:00:00:c9:bb:c7:93 fcid 0x180039 dynamic
vsan 20 wwn 10:00:00:00:c9:12:34:57 fcid 0xd30004 dynamic
vsan 52 wwn 10:00:00:00:c9:5b:ab:c4 fcid 0x18003a dynamic
vsan 52 wwn 10:00:00:00:c9:bb:17:b7 fcid 0x18003b dynamic
vsan 52 wwn 10:00:00:00:c9:a0:ce:2d fcid 0x18003c dynamic
vsan 52 wwn 10:00:00:00:c9:91:f7:f1 fcid 0x18003d dynamic
vsan 52 wwn 10:00:00:00:c9:5b:ab:c0 fcid 0x18003e dynamic
vsan 52 wwn 10:00:00:00:c9:b1:e5:5f fcid 0x18003f dynamic
vsan 52 wwn 10:00:00:00:c9:e3:06:89 fcid 0x180040 dynamic
vsan 52 wwn 50:06:01:68:44:60:23:4f fcid 0x1802ef dynamic
vsan 1 wwn 50:06:01:61:44:60:23:4f fcid 0x0500ef dynamic
vsan 52 wwn 10:00:00:00:c9:d1:16:24 fcid 0x180041 dynamic
vsan 52 wwn 10:00:00:00:c9:d1:16:25 fcid 0x180042 dynamic
vsan 52 wwn 10:00:00:00:c9:d1:0a:6d fcid 0x180043 dynamic
vsan 20 wwn 10:00:00:00:c9:d1:16:25 fcid 0xd30005 dynamic
vsan 20 wwn 10:00:00:00:c9:d1:16:24 fcid 0xd30006 dynamic
vsan 20 wwn ff:f2:00:00:c9:12:34:78 fcid 0xd30007 dynamic
vsan 20 wwn ff:f2:00:00:c9:d1:16:46 fcid 0xd30008 dynamic
vsan 52 wwn ff:f2:00:00:c9:d1:0a:8c fcid 0x180044 dynamic
vsan 20 wwn ff:f3:00:00:c9:d1:16:46 fcid 0xd30009 dynamic
vsan 52 wwn ff:f0:00:00:c9:d1:0a:8c fcid 0x180045 dynamic
vsan 52 wwn 10:00:00:00:c9:d1:0a:6c fcid 0x180046 dynamic
vsan 20 wwn ff:f2:00:00:c9:d1:0a:8c fcid 0xd3000a dynamic
vsan 20 wwn 10:00:00:00:c9:d1:0a:6d fcid 0xd3000b dynamic
vsan 52 wwn ff:f2:00:00:c9:d1:16:46 fcid 0x180047 dynamic
vsan 20 wwn ff:f3:00:00:c9:12:34:78 fcid 0xd3000c dynamic
vsan 52 wwn ff:f3:00:00:c9:12:34:78 fcid 0x180048 dynamic
vsan 52 wwn 50:06:01:69:44:60:23:4f fcid 0x1803ef dynamic
vsan 52 wwn ff:f3:00:00:c9:d1:16:46 fcid 0x180049 dynamic
vsan 52 wwn 10:00:00:00:c9:12:34:5b fcid 0x18004a dynamic
vsan 52 wwn 10:00:00:00:c9:12:34:5a fcid 0x18004b dynamic
vsan 52 wwn ff:f2:00:00:c9:12:34:78 fcid 0x18004c dynamic
vsan 52 wwn 10:00:00:00:c9:a5:ac:f3 fcid 0x18004d dynamic
vsan 52 wwn 10:00:00:00:c9:a5:ad:15 fcid 0x18004e dynamic
vsan 52 wwn 10:00:00:00:c9:a5:ac:f5 fcid 0x18004f dynamic
vsan 52 wwn 20:01:00:00:c9:a5:ac:f3 fcid 0x180050 dynamic
vsan 52 wwn 20:02:00:00:c9:a5:ac:f3 fcid 0x180051 dynamic
vsan 52 wwn ff:f3:00:00:c9:12:34:85 fcid 0x180052 dynamic
vsan 52 wwn 20:00:00:11:0d:77:9c:00 fcid 0x180053 dynamic
vsan 52 wwn 20:01:00:11:0d:77:9d:00 fcid 0x180054 dynamic
interface port-channel3
interface vfc1
no shutdown
interface vfc4
interface vfc9
bind interface Ethernet1/9
no shutdown
interface vfc10
interface vfc11
bind interface Ethernet1/11
no shutdown
interface vfc19
bind interface Ethernet1/19
no shutdown
interface vfc21
bind interface Ethernet1/21
no shutdown
interface vfc22
bind interface Ethernet1/22
switchport trunk allowed vsan 52
no shutdown
interface vfc24
bind interface Ethernet1/24
no shutdown
interface vfc25
bind interface Ethernet1/25
no shutdown
interface vfc26
bind interface Ethernet1/26
no shutdown
interface vfc27
bind interface Ethernet1/27
no shutdown
interface vfc28
bind interface Ethernet1/28
no shutdown
interface vfc29
bind interface Ethernet1/29
no shutdown
interface vfc30
bind interface Ethernet1/30
no shutdown
interface vfc31
bind interface Ethernet1/31
shutdown
interface vfc32
bind interface Ethernet1/32
no shutdown
interface vfc33
bind interface Ethernet1/33
no shutdown
interface vfc34
bind interface Ethernet1/34
no shutdown
interface vfc35
bind interface Ethernet1/35
no shutdown
interface vfc36
bind interface Ethernet1/36
no shutdown
interface vfc37
bind interface Ethernet1/37
no shutdown
interface vfc38
bind interface Ethernet1/38
no shutdown
interface vfc39
bind interface Ethernet1/39
no shutdown
interface vfc40
bind interface Ethernet1/40
no shutdown
vsan database
vsan 52 interface vfc1
vsan 52 interface vfc9
vsan 52 interface vfc11
vsan 52 interface vfc19
vsan 52 interface vfc21
vsan 52 interface vfc22
vsan 52 interface vfc24
vsan 52 interface vfc26
vsan 52 interface vfc27
vsan 52 interface vfc28
vsan 52 interface vfc29
vsan 52 interface vfc30
vsan 52 interface vfc31
vsan 52 interface vfc32
vsan 52 interface vfc33
vsan 52 interface vfc34
vsan 20 interface vfc35
vsan 52 interface vfc36
vsan 52 interface vfc37
vsan 52 interface vfc38
vsan 52 interface vfc39
vsan 52 interface vfc40
vsan 52 interface fc2/1
vsan 52 interface fc2/2
vsan 52 interface fc2/3
vsan 52 interface fc2/4
interface fc2/1
switchport trunk allowed vsan 1
switchport trunk allowed vsan add 52
switchport trunk mode auto
no shutdown
interface fc2/2
no shutdown
interface fc2/3
no shutdown
interface fc2/4
no shutdown
speed 1000
interface Ethernet1/5
interface Ethernet1/6
interface Ethernet1/7
switchport mode trunk
interface Ethernet1/8
switchport trunk allowed vlan 1,10,20,52
flowcontrol receive on
flowcontrol send on
interface Ethernet1/10
priority-flow-control mode on
switchport trunk allowed vlan 1,52
flowcontrol send on
interface Ethernet1/12
interface Ethernet1/13
flowcontrol send on
interface Ethernet1/14
flowcontrol send on
interface Ethernet1/15
flowcontrol send on
interface Ethernet1/16
flowcontrol send on
interface Ethernet1/17
interface Ethernet1/18
switchport trunk allowed vlan 1,30
switchport access vlan 10
flowcontrol send on
interface Ethernet1/20
switchport access vlan 52
flowcontrol send on
flowcontrol send on
interface Ethernet1/23
flowcontrol send on
flowcontrol send on
switchport trunk allowed vlan 1,8,30,52
flowcontrol send on
flowcontrol send on
flowcontrol send on
description line
flowcontrol send on
switchport trunk allowed vlan 1,10,52
flowcontrol send on
flowcontrol send on
flowcontrol send on
flowcontrol send on
switchport trunk allowed vlan 1,30,52
flowcontrol send on
flowcontrol send on
flowcontrol send on
shutdown
flowcontrol send on
flowcontrol send on
interface Ethernet2/1
flowcontrol send on
interface Ethernet2/2
flowcontrol send on
interface Ethernet2/3
flowcontrol send on
interface Ethernet2/4
flowcontrol send on
interface mgmt0
ip address 10.192.194.111/20
system default zone default-zone permit
system default zone distribute full
line console
line vty
boot kickstart bootflash:/n5000-uk9-kickstart.5.0.3.N1.1b.bin
boot system bootflash:/n5000-uk9.5.0.3.N1.1b.bin
interface fc2/1
interface fc2/2
interface fc2/3
interface fc2/4
zone default-zone permit vsan 20
zone default-zone permit vsan 52
zoneset distribute full vsan 1
zoneset distribute full vsan 20
zoneset distribute full vsan 52
!Full Zone Database Section for vsan 1
zone name bg-qa vsan 1
member pwwn 10:00:00:00:c9:5b:ab:ca
member pwwn 21:00:00:0c:50:c3:70:23
member pwwn 21:00:00:0c:50:c3:70:22
member pwwn 21:00:00:0c:50:c3:70:16
member pwwn 21:00:00:0c:50:c3:70:1e
member pwwn 22:00:00:0c:50:c3:70:26
member pwwn 22:00:00:18:62:06:76:8a
member pwwn 22:00:00:11:c6:17:68:c3
member pwwn 22:00:00:0c:50:c3:70:1d
member pwwn 22:00:00:0c:50:c3:6f:c2
member pwwn 22:00:00:11:c6:17:68:dc
member pwwn 21:00:00:0c:50:c3:6a:d0
member pwwn 21:00:00:0c:50:79:92:90
member pwwn 21:00:00:11:c6:17:69:a0
member pwwn 21:00:00:0c:50:79:93:af
member pwwn 22:00:00:0c:50:48:10:80
member pwwn 22:00:00:11:c6:18:46:c6
member pwwn 22:00:00:0c:50:32:2e:0f
member pwwn 22:00:00:0c:50:48:10:74
member pwwn 22:00:00:11:c6:18:46:f2
member pwwn 21:00:00:00:87:13:cb:d1
member pwwn 21:00:00:0c:50:79:91:0f
member pwwn 10:00:00:00:c9:3c:8e:49
member pwwn 10:00:00:00:c9:5b:ab:c2
member pwwn 10:00:00:00:c9:5b:af:f3
zone name sf_RAM vsan 1
member pwwn 10:00:00:00:c9:5b:af:c9
member pwwn 21:00:00:0c:50:b4:8e:20
zone name anand vsan 1
member pwwn 10:00:00:00:c9:65:69:31
member pwwn 22:00:00:18:62:06:7f:f6
zone name syedzone vsan 1
member fwwn 20:11:00:0d:ec:56:7b:40
member pwwn 50:06:01:60:44:60:23:4f
zone name bg_qa vsan 1
zoneset name TOM vsan 1
member bg-qa
zoneset name bg_dvt vsan 1
member sf_RAM
zoneset name lancer vsan 1
member anand
zoneset name bg-qa vsan 1
zoneset name syed vsan 1
member syedzone
zoneset activate name lancer vsan 1
!Full Zone Database Section for vsan 20
zone name amrita_zone1 vsan 20
member pwwn 10:00:00:00:c9:5b:a3:83
member pwwn 22:00:00:04:cf:89:19:67
member pwwn 22:00:00:0c:50:79:93:ae
zone name amr_zset vsan 20
zoneset name amr_zset vsan 20
member amrita_zone1
zoneset activate name amr_zset vsan 20
!Full Zone Database Section for vsan 52
zone name vinod vsan 52
member pwwn 50:06:01:69:44:60:23:4f
member pwwn ff:f3:00:00:c9:12:34:78
member pwwn 10:00:00:00:c9:12:34:5b
member pwwn 10:00:00:00:c9:12:34:57
zone name neha vsan 52
zone name siv1 vsan 52
member pwwn 10:00:00:00:c9:ad:ac:43
member pwwn 50:06:01:61:44:60:23:4f
member pwwn 10:00:00:00:c9:ad:ac:47
zone name neha1 vsan 52
member pwwn 10:00:00:00:c9:5b:ab:ad
zone name neha2 vsan 52
member pwwn 10:00:00:00:c9:5b:ab:a9
zone name neha3 vsan 52
member pwwn 10:00:00:00:c9:9d:1f:bf
zone name neha4 vsan 52
member pwwn 10:00:00:00:c9:9d:1f:c1
zone name chetan vsan 52
member pwwn 10:00:00:00:c9:f2:73:d3
zone name siv2 vsan 52
member pwwn 10:00:00:00:c9:d1:0a:6d
member pwwn ff:f2:00:00:c9:d1:0a:8c
member pwwn 22:00:00:0c:50:79:93:af
member pwwn 22:00:00:0c:50:79:92:90
member pwwn 22:00:00:0c:50:79:91:0f
member pwwn 20:01:00:11:0d:77:9d:00
zone name sroy vsan 52
member pwwn 10:00:00:00:c9:b1:ea:7f
member pwwn 10:00:00:00:c9:5b:ab:99
member pwwn 10:00:00:00:c9:bb:cb:8f
member pwwn 10:00:00:00:c9:5b:ab:c4
member pwwn 10:00:00:00:c9:d1:16:25
member pwwn 10:00:00:00:c9:a5:ac:f3
zone name manju vsan 52
member pwwn 10:00:00:00:c9:bb:c7:8f
zone name ram vsan 52
member pwwn 10:00:00:00:c9:a0:ce:2d
member pwwn 10:00:00:00:c9:bb:17:b7
member pwwn 10:00:00:00:c9:5b:a5:27
member pwwn 10:00:00:00:c9:91:f7:f1
member pwwn 10:00:00:00:c9:b1:e5:5f
zone name jana vsan 52
zone name priya vsan 52
member pwwn 10:00:00:00:c9:e3:06:89
zoneset name IBMraptor vsan 52
member vinod
member siv1
member neha1
member neha2
member neha3
member neha4
member chetan
member siv2
member sroy
member manju
member ram
member priya
zoneset name ananda vsan 52
zoneset name vinod vsan 52
zoneset activate name IBMraptor vsan 52
no system default switchport shutdown san
Cisco-5020# sh system internal dcbx info interface ethernet 1/38
Interface info for if_index: 0x1a025000(Eth1/38)
tx_enabled: TRUE
rx_enabled: TRUE
dcbx_enabled: TRUE
DCX Protocol: CIN
Port MAC address: 00:0d:ec:b2:15:6d
DCX Control FSM Variables: seq_no: 0x1, ack_no: 0x0,my_ack_no: 0x0, peer_seq_no:
0x0 oper_version: 0x0, max_version: 0x0 fast_retries 0x0
Lock Status: UNLOCKED
PORT STATE: UP
LLDP Neighbors
No DCX tlvs from the remote peer
6 Features on this intf for Protocol CIN(0)
3 Features on this intf for Protocol CEE(1)
Feature type LLS (6)sub_type FCoE Logical Link Status (0)
feature type 6(LLS)sub_type 0
Feature State Variables: oper_version 0 error 0 local error 0 oper_mode 0
feature_seq_no 0 remote_feature_tlv_present 0 remote_tlv_aged_out 0
remote_tlv_not_present_notification_sent 0
Feature Register Params: max_version 0, enable 1, willing 0 advertise 1
disruptive_error 0 mts_addr_node 0x101 mts_addr_sap 0x1d9
Desired config cfg length: 1 data bytes:00
Operating config cfg length: 0 data bytes:
Peer config cfg length: 0 data bytes:
Feature type PFC (3)
feature type 3(PFC)sub_type 0
feature_seq_no 0 remote_feature_tlv_present 0 remote_tlv_aged_out 1
disruptive_error 0 mts_addr_node 0x101 mts_addr_sap 0x179
Desired config cfg length: 1 data bytes:08
Feature type App(Fcoe) (5)sub_type FCoE (0)
feature type 5(App(Fcoe))sub_type 0
Feature type PriMtu (8)
feature type 8(PriMtu)sub_type 0
Desired config cfg length: 16 data bytes:24 00 24 00 24 00 08 6e 24 00 24 00 24 00 24 00
Feature type PriGrp (2)
feature type 2(PriGrp)sub_type 0
Desired config cfg length: 24 data bytes:32 32 00 00 00 00 00 00 00 0f 00 0f 00 0e 20 64 00 0e 00 0e
00 0e 00 0e
Feature type LLS (6)sub_type LAN Logical Link Status (1)
feature type 6(LLS)sub_type 1
disruptive_error 0 mts_addr_node 0x101 mts_addr_sap 0xaf
Desired config cfg length: 1 data bytes:80
Traffic Counters
DCBX pkt stats:
Total frames out: 20296
Total Entries aged: 27
Total frames in: 0
DCBX frames in: 0
Total frames received in error: 0
Total frames discarded: 0
Total TLVs unrecognized: 0
Cisco-5020#
Cisco-5020#
Cisco-5020#
I am new to this PFC, and first time trying to configure so you can see nothing being configured.
12-01-2011 11:38 PM
Hi there,
you have configured Flow Control on quite a lot ports and if I can remember correctly this leads, and from the logical standpoint definitely has to lead, to non working PFC. The standard FC pauses traffic on a whole link wehereas PFC does this for dedicated CoS priorities only. In your case you simply have "overconfigured" (P)FC.
Unconfigure standard Flow Control from your interface, overload an interface and check the output of "show interface priority-flow-control". You should the see the PPP counter not being zero anymore.
Let me know if I was right ;-)
