Warning message
aaa authorization console command
Answered Question
Nov 4th, 2011
I don't really understand the need of the command "aaa authorization console".
We indeed often configure these lines, which according to me already ar eapplied by default to VTY, Console, etc ...:
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
Am I wrong? Or do these lines apply only to the VTY linse?
Thanks by advance
Correct Answer by Richard Burts about 5 years 9 months ago
In IOS by default Cisco does not perform authorization on the console. When you configure aaa authorization it is applied to vty but not to console. Basically this is to make it harder for you to lock yourself out of the router or switch. If you want authorization to be applied on the console then you must explicitly configure it (and be very carefull that it is configured correctly or you can wind up being locked out of the router - think especially of how it will work when you can not get to the external aaa server that is normally doing the authorization).
Rick
Overall Rating: 5 (1 ratings)
Correct Answer
Richard Burts Mon, 11/07/2011 - 10:55
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Rick
ts-stg Fri, 01/13/2012 - 06:47
I learned this locking out form console today in the hard-way
we use as standard
aaa authentication login default group tacacs+ enable
aaa authentication enable default group tacacs+ enable
aaa authorization exec default local group tacacs+ if-authenticated
aaa authorization commands 1 default group tacacs+ if-authenticated
and I missed the trailing "if-authenticated" in line "aaa authorization exec default local group tacacs+ if-authenticated", unfortuanatly also the tacacs serves wasn't reachable.
So no way to log in without the hard way rebooting and reconfiguring again
Richard Burts Fri, 01/13/2012 - 09:47
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Thanks for sharing your experience about authorization problems.I find that many people do not understand well the importance of configuring if-authenticated when configuring authorization. Your post is a good reminder about this important part of the configuration. Many of us have learned these lessons the hard way and we all can benefit from a reminder about the problem.
Rick
