Warning message
ASA 5520: Adding network objects via CLI
Answered Question
Hi (again),
I'm working with ASA 5520s. I am trying to figure out how to add network objects via CLI. I know I could easily do it using ASDM, but I like to learn the hardway first.
Question: How do I add the subnet mask for a network object when creating via CLI?
Here's how I'm creating the obejcts:
config t
object-group network telnet-users-group
description users allowed telnet access outbound
network-object host 172.16.25.50
network-object hosts 172.16.25.51
That sets up the hosts with IP addresses, but how do I add the subnet mask?
Dan
Correct Answer by varrao about 5 years 9 months ago
Hi Dan,
You do not need to it for a single host, the firewall takes it to be 255.255.255.255, but if you are adding a network or subnet then you can, for it you can add:
object network test
  subnet 20.0.0.0 255.0.0.0
object network test1
  subnet 10.0.0.0 255.0.0.0
object-group network test-group
network-object object test
network-object object test1
Hope that helps.
Varun
Overall Rating: 5 (1 ratings)
Correct Answer
varrao Fri, 11/04/2011 - 09:37
  • Red, 2250 points or more
Hi Dan,
object network test
Hope that helps.
Varun
